 Spec. 125Z Standard
terra_ryzer
pedo88
hisham kechik naw
zul187
serez
BCDSyaz
Azeri_conquistador
Snake125z
archonixm
wan_210407
noobies
redline
adolJB
KapcaiKuDie
MCB
Paktam
cabai
naem 2345
samporna ccn
Apislegend
xopai
NCH_KU
wan_125z
emi melaka
herel_rocks
firdausazman
Mafiaflix
nova
fx110
hazwan achie
G.i.joule
budackgempak
azizi5587
tupaiku
mzul787
23sh0pah0lic
pais924
fareez91
125zul_r
rizal_p2
osiris
~*PeRaK MaLI*~
s-rank
gilgamesh88
jem_125zr
MAT4311
madie
bujang
ne0bolimi3rd
enzoanz
ashhard125z
rufaz
oddysee11
kimi
|ashefast|
90 posters
Go to page : 1, 2, 3 ... 9, 10, 11  Next
Spec. 125Z Standard Empty
PostSubject: Spec. 125Z Standard   Spec. 125Z Standard EmptySun Jul 19, 2009 12:13 am
salam dan selamat sejahtera..ambe duk cari2 xde nmpk spec 125z kat forum 125z nih..soo kut2 lah mate ambe rabun,mod jgn segan2 nak delete yer Spec. 125Z Standard Icon_eek
spec 125z stended gaban
jenis : 2 lejang sejukan udara
bil silinder : single maa
lubang x lejang : 53.8mm x 54.7mm
nisbah mampatan : 6.5:1
max hp : 17.5ps/8000rpm
max torque : 1.65 kgf-m/7500rpm
karburetor : vm 22 ss
pilot jet : 15
main jet : 100
plug : bp8es,b8es,b8ecs (NGK)
sistem penyalaan : digital advanced
magneto tube C.D.I
primary reduction ratio : 3.227 (71/22)
secondery reduction ratio : 3.071
nisbah gear 1 : 2.833
nisbah gear 2 : 1.813
nisbah gear 3 : 1.368
nisbah gear 4 : 1.143
nisbah gear 5 : 1.000
nisbah gear 6 : 0.875 <-- gigi 21/24
final reduction ratio(ratio spoket) : 43/15 -->2.8667
berat kering : 101kg
bateri : YB3L-B
kapasiti petrol : 5.5 liter
lampu dpn : 12V,25W/25W
tayor blkg stended kilang : 80/90 17inch
tayor depan stended kilang : 70/90 17inch
kod bearing;
crankshaft : 6205(kiri,knn)
primary gear :6303(knn),6205(kiri)
secondry gear:6304(kiri),6205(knn)
balancer :6004,6202(lupa mana satu kiri ngan kanan)
hub depan : 6300
hub blkg : 6301
hub spoket: 6004
kod oilseal;(quote dr mbc oleh bro vandetta )
oil seal plak...
shaft spoket pakai 20-38-5
shaft lever gear 12-21-4
balancer 25-42-6
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptySat Jul 25, 2009 11:18 pm
kat piston 125 ori ade tulis saiz x???? bape saiz ori? Question
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptySat Jul 25, 2009 11:57 pm
kalo saiz ori kilang die tulis 0.0.. means 53.8mm
kalo rebore sekali pakai piston 0.25..saiz piston yg sebenarnye = 53.8 + 0.25 =54.05
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptyTue Aug 25, 2009 7:53 am
standard saiz 0-0
kalo korek skali 0.25
x nmpk beza pn bsar dier
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptyTue Aug 25, 2009 9:02 am
x de rs sgt pbezaan tu, yg pasti cc bertambah je tp kalo nak nek topspeed kena set carb blik, asal ubah saiz piston kena set pilot ngn menjet blik bru ngam
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptyTue Aug 25, 2009 12:00 pm
rebore sekali = 0.25mm,kan kecik tu,mane nak nampak beze,even kalo rebore 2.00mm pun belum tentu dapat nampak beze dgn mate kasar..
klau rebore sampai saiz 1.00mm,xyah ubah setting carb pun xpe,sebab still x lari jauh,klau rebore jauh dari tu barula set balik carb.. pendek kate takat rebore 1 / 2 saiz xde rase sgt peningkatan die.. bile saiz piston besar = CC naik = pickup naik.. x bermakne topspeed pun naik..
moto standed mmg berat klau pakai 15/36.. try pakai 37 blakang.. biasela tu moto standed mmg berat cket nak sampai top..
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptyTue Aug 25, 2009 8:07 pm
butut2,stakat ribo 1 or 2 mate xpyh nk set ape2 dah,melainkn btl2 rajin la,biasenye pickup je bertambah bile saiz block dh besar,lain xde ape2 pn..
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptyFri Oct 09, 2009 11:26 am
azdli90 wrote:
kalau mot da bikin camne nak kire primary reduction ratio dye???ajar plsss
primary reduction ratio takkan berubah klau ko x kacau gearbox..
gear ratio tu ratio kat gear,xde kene ngena ngan spoket..
final drive ratio tu baru la kene ngene nagn spoket,amek nilai blakang bahagi depan la,dah berbuih kot bitau dalam forum,bace2 la cket bang.. scratch
final reduction ratio(ratio spoket) : 43/15 -->2.8667 (ni klau spoket standed)
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptyWed Feb 10, 2010 6:29 pm
no oilseal fork 125z
brand Nok, tc4 27 39 10.5 47
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptyWed Feb 10, 2010 11:29 pm
spec stended ialah segala2 nyer mengenai 125z stended gaban yg baru kuar kilang mcm yg ada kat 1st page..xpun spec2 cam oilseal,no bearing,watt mentol,segala gearing stended dll
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptyThu Feb 11, 2010 11:20 am
ak dah bersihkan topic nih dari spam yg takde kaitan ngan tajuk topic...Spec. 125Z Standard Monkey11
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptyThu Feb 11, 2010 12:13 pm
nah spam dari aku.... Spec. 125Z Standard Icon_twisted
saiz2 spanar yg biasa guna utk mtr standard original......
skru ekzos&head&blok = 12
shaft rim dpn =14
nat shaft rim dpn = 17
skru bracket caliper dpn = 14
skru fork-T = 14
shaft rim blkg = 17
nat shaft rim blkg = 19
skru spoket blkg-hub = 17
skru spoket dpn = 10
skru bracket caliper blkg = 12
skru bracket-swing arm caliper blkg = 14
nat 'anting2' rantai = 12
nat magnet = 17
nat mangkuk clutch = 19
skru cover clutch = 10
nat primary gear = 19
nat balancer gear = 19
skru enjin-body belah atas = 12
skru enjin-body belah tgh = 12
skru enjin-body belah bwh = 14
aku tak pasti betul ker tak saiz2 ni..main hentam jer.... Spec. 125Z Standard Icon_razz
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptyTue Feb 16, 2010 1:49 pm
sape2..ingat lg x camne rupa paras meter 125z yf first model.
ada gmbr die x.help me
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptyTue Feb 16, 2010 2:04 pm
ha nie la parasnye..
Spec. 125Z Standard 17022010425
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptyTue Feb 16, 2010 3:10 pm
sgt mmbantu.tima kasih bro superjoemanito. Spec. 125Z Standard Icon_cheers
|ashefast|
|ashefast|
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptySun Feb 21, 2010 10:30 pm
meter ori ke tu suparjoe? yang asal 1st model bukan ada tulisan YAMAHA ke kt tgh2?
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptySun Feb 21, 2010 10:39 pm
he3x,xori tue,sample nk tunjuk kt mmb kite je tue Spec. 125Z Standard Icon_biggrin
kimi
kimi
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptySun Feb 21, 2010 10:43 pm
patut pelik bebenar aku nmpak Spec. 125Z Standard Icon_mad
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptySun Feb 21, 2010 10:57 pm
nie rupe sbnrnye..copyright from mudah.my Spec. 125Z Standard Icon_biggrin
Spec. 125Z Standard 6098119247
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptySun Feb 21, 2010 11:54 pm
walaupun meter 1st model dah outdated,tapi background carbon fiber tu yang menarik..disamping meter ni "berat" berbanding meter2 yang baru..
oddysee11
oddysee11
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptySun Feb 21, 2010 11:56 pm
old skol gle meter lama.....rare 2...pakai sti tangkap meleleh...hehehe
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptyMon Feb 22, 2010 12:03 am
hah.smalam punya ads kalo x silap.aku dah tepon tanya.budak tu nak tolak rm210 siap pos.fuh...
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptyMon Feb 22, 2010 12:12 am
ha3x,pos2x nie risiko skit bro,hati2x skit,tapi mmg xdpt dah nk cari meter 1st model nie,klu ade pun ssh nk cari yg cun n like new Spec. 125Z Standard Icon_biggrin ala meter skalar skrg pun rm250 blh dpt Spec. 125Z Standard Icon_smile
|ashefast|
|ashefast|
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptyMon Feb 22, 2010 12:18 am
biar benar smpi 2rat. kalu camtu sape2 mau, meter 1st model.. dari model full silver punya. Bulb lampu TOP indicator saja tak ori. amik la RM199. Hehehe..
buat pengetahuan rakan2, motor2 125 model awal, dekat cover horn@dada tu pki stiker tulisan YAMAHA. printed atas stiker clear. Bukan lambang garfu Yamaha mcm skrg. tak silap dekat kaver kecil bwh carrier dkt ekor pun sama.. model skrg xtau ada stiker apa kt situ. hehe..
PostSubject: Re: Spec. 125Z Standard   Spec. 125Z Standard EmptyMon Feb 22, 2010 12:19 am
meter 1st model ni x brape best..
bwk menten speed..jarum speed n rpm gegar2..huu..
Spec. 125Z Standard
Page 1 of 11Go to page : 1, 2, 3 ... 9, 10, 11  Next
» Motor 125z buat masalah setelah tukar standard blok n piston.
» Spec Desktop Untuk Bajet Ciput???
» "Standard tipu"
