| Spec. 125Z Standard | |
+86terra_ryzer pedo88 hisham kechik naw zul187 serez BCDSyaz Azeri_conquistador Snake125z archonixm wan_210407 noobies redline adolJB KapcaiKuDie MCB Paktam cabai fizerpool naem 2345 samporna ccn Apislegend xopai NCH_KU wan_125z emi melaka herel_rocks mR.nobita firdausazman Mafiaflix nova fx110 pasquale hazwan achie G.i.joule paan1171 budackgempak azizi5587 tupaiku mzul787 23sh0pah0lic yi_tupaijek01 Kaer azdli90 pais924 fareez91 xapex 125zul_r assasin_lunxe absolute_ahben babet rizal_p2 osiris devilmeasha ~*PeRaK MaLI*~ s-rank Ultra-Z mantadkb gilgamesh88 hidup_sihat Bob Sensei jem_125zr wormzx MAT4311 madie man JGN8917 hydar bujang ne0bolimi3rd zr90 enzoanz geeks ashhard125z acaapxx rufaz tupai comel oddysee11 kimi |ashefast| ariffm0hd vendetta mazakim superjoemanito HailToKing WKQ4913 amex chocolate 90 posters |
adolJB Laskar Muda
Posts : 1 Join date : 24/03/2012
| Subject: Re: Spec. 125Z Standard Sat Mar 24, 2012 3:06 pm | |
| NAT TNY ARI TU MOTO SAYER PROBLEN,, PISTON BOBOS,, BERLUBANG SEBELAH ATAS NYER... TP DAH REPAIR TP KNP STILL XLEY EDUP??? AGAG2 APE MASALAHNYER ERK??? | |
redline Laskar Kanan
| Subject: Re: Spec. 125Z Standard Tue Mar 27, 2012 7:07 am | |
| ni kena tanya otai ni...tanya sikit....cdi,coil magnet n coil plug ok x? | |
noobies Laskar Muda
Posts : 4 Join date : 02/08/2012 Age : 32 Location : kay L
| Subject: Re: Spec. 125Z Standard Thu Aug 02, 2012 1:48 am | |
| cite pasal stndard nie... aku pn nk tau gk resepi die.. cz motor aku pn stndrd gaban,fulltrtle blh g 160 jew... span dh bkk,kotak lapik nat.. spoket plak 36/15 m.j n p.j pn msh lg stndrd... ape aku prlu wat ekkk.. nk kne main m.j n p.j kew... klu kne,bpe saiz yg sesuai... dpt naik 180 pn jd lh... sadis cz kne tinggal ngn motor stndrd yg lg bru dr aku..(stndrd sme cm aku,spojet pn same saiz) klu blh nk maintain jew blok 0.0.. | |
wan_210407 Laskar Muda
Posts : 19 Join date : 19/12/2010 Age : 32 Location : kuala terengganu/klang
| Subject: Re: Spec. 125Z Standard Fri Aug 03, 2012 1:05 pm | |
| bro choco.. kompem ke crankshaft kiri kanan bearing die 6205?? fobia btol nk tuka bearing ni, bearing nk beli sndiri.. tp anta kedai tunggu dorg pasang sambil2 curi2 ilmu...
archonixm Laskar Muda
Posts : 47 Join date : 15/09/2009 Age : 37 Location : Puchong
| Subject: Re: Spec. 125Z Standard Fri Nov 09, 2012 1:11 pm | |
Snake125z Laskar Muda
Posts : 20 Join date : 24/07/2012 Age : 39 Location : Kuala Krai Kelantan
| Subject: Re: Spec. 125Z Standard Fri Oct 11, 2013 1:19 pm | |
| - noobies wrote:
- cite pasal stndard nie...
aku pn nk tau gk resepi die.. cz motor aku pn stndrd gaban,fulltrtle blh g 160 jew... span dh bkk,kotak lapik nat.. spoket plak 36/15 m.j n p.j pn msh lg stndrd... ape aku prlu wat ekkk.. nk kne main m.j n p.j kew... klu kne,bpe saiz yg sesuai... dpt naik 180 pn jd lh... sadis cz kne tinggal ngn motor stndrd yg lg bru dr aku..(stndrd sme cm aku,spojet pn same saiz) klu blh nk maintain jew blok 0.0.. Sebab ini kes standard gaban ni, kadang kadang performance motor berlainan ikut nasib pemilik. Kemungkinan dia pakai petrol ron 97, kamu pakai ron 95? Saya rasa kena tunduk kepala atau pun superman poss untuk potong aliran udara, supaya motor baru tu rasa bau asap. Nak dapat 180, paling senang tukar exhaust racing Ahm atau YY pang dengan setting carb juga sproket sekali. Selesai kes.... | |
| Subject: Re: Spec. 125Z Standard Fri Oct 11, 2013 5:25 pm | |
| motor std kelajuan dia mmg berbeza.. masa ak baru beli motor dulu leh dpt 170, sprocket 40.. kwn ak sprocket 38 tapi boleh dpt dlm 160 je.. | |
| Subject: Re: Spec. 125Z Standard Fri Oct 11, 2013 5:29 pm | |
aku pn nk tau gk resepi die.. cz motor aku pn stndrd gaban,fulltrtle blh g 160 jew... span dh bkk,kotak lapik nat.. spoket plak 36/15 m.j n p.j pn msh lg stndrd... ape aku prlu wat ekkk.. nk kne main m.j n p.j kew... klu kne,bpe saiz yg sesuai... dpt naik 180 pn jd lh... sadis cz kne tinggal ngn motor stndrd yg lg bru dr aku..(stndrd sme cm aku,spojet pn same saiz) klu blh nk maintain jew blok 0.0.. nk dpt 180 senang je, tukar rim aloi, guna tayar saiz 60/90 depan blakang.. sprocket ko dh cun dh tu.. | |
BCDSyaz Laskar Kelas I
Posts : 169 Join date : 14/12/2012 Location : Tanjong Malim
| Subject: Re: Spec. 125Z Standard Sat Oct 12, 2013 5:55 am | |
| set mainjet ngan pilotjet pd carb pun perlu gak..sekali ngan airfilter box.. | |
serez Laskar Kelas I
Posts : 146 Join date : 07/06/2012 Age : 41 Location : USJ
| Subject: Re: Spec. 125Z Standard Sat Oct 12, 2013 6:03 am | |
| fuu berapa la berat korang ni bwk 15/36 motor xberat ke.. | |
zul187 Laskar Muda
Posts : 5 Join date : 19/03/2013
| Subject: Re: Spec. 125Z Standard Mon Oct 14, 2013 5:07 am | |
| spocket sy set 15-39 moto baru leh dpt 160...tp tunduk la...tu pun tak full trottle..risau takut melingkup/jem ja motor.. mbr sy full trottle set spocket 15-37 bole dpt 180..tunduk..tapi dua dua motor meter skala la.. Â | |
| Subject: Re: Spec. 125Z Standard Mon Oct 14, 2013 5:58 am | |
| aku pun standard sikit je tp sebabkan rider berat so ratio spoket cuma 2.64 je (14/37). itu pun ada sebiji legend cucuk belakang aku siot tul. tp mamat tu tunduk abis la aku duduk mcm ride balik keja je heh. dpt potong aku pn time keta blok aku | |
| Subject: Re: Spec. 125Z Standard Mon Oct 14, 2013 11:42 am | |
| berat ak 5+kg ja.. sprocket 15-35 pn tkde hal.. jnji motor kna power | |
| Subject: Re: Spec. 125Z Standard Mon Oct 14, 2013 12:15 pm | |
| alamak...moto korang power la walaupun standard..tupai aku ful throttle pun baru dpt 160km/j lbh sikit je..makan asap la.. | |
| Subject: Re: Spec. 125Z Standard Mon Oct 14, 2013 6:12 pm | |
| - BCDSyaz wrote:
- alamak...moto korang power la walaupun standard..tupai aku ful throttle pun baru dpt 160km/j lbh sikit je..makan asap la..
laju2 pn nk kemana bro??? igtlah orang yg tersayang | |
| Subject: Re: Spec. 125Z Standard Sat Oct 19, 2013 3:04 am | |
| nak tau laju xlaju try ikut konvoi rxz la heheh.. aku kena bertiang kot | |
hisham kechik naw Laskar Muda
Posts : 2 Join date : 29/03/2015
| Subject: Re: Spec. 125Z Standard Sun Mar 29, 2015 7:12 am | |
| Assalamualaikum kepada semua otai² sye ni baru dalam tupai ni. Sye nak tanye lah kenapa bunyi y125z sye kering eh? Ape patut sye buat. Kawan sye ade cakap kalau high rem bunyi kering boleh jem. Jadi ape yang saye perlu lakukan. Mintak tunjuk ajar otai² sekalian. Terime kasih | |
| Subject: mengapa bunyi y125z sye kering. Sun Mar 29, 2015 7:13 am | |
pedo88 Laskar Muda
Posts : 30 Join date : 20/08/2010 Age : 35 Location : Gombak
| Subject: Re: Spec. 125Z Standard Sat May 09, 2015 5:42 pm | |
| Salam Otai2 tupai sume.. sy ade 1 persoalan untuk di tujukan pada para otai. baru angkat tupai 2bln lpas. test speed kt highway, ble long distance bwa dlm 120km/j, rse gegar bile remp2.. Agak2 ape mslahnye ye??? | |
terra_ryzer Laskar Muda
Posts : 2 Join date : 04/08/2015 Age : 29 Location : Kuala Lumpur
| Subject: Re: Spec. 125Z Standard Tue Aug 04, 2015 4:49 pm | |
| kalau pakai tayar besar (80/90/17) .. top speed akan effect ke ??? spoket 15/36 nak cecah 130 pun susah .. tips utk tinggikan top ?? | |
| Subject: Re: Spec. 125Z Standard Tue Aug 04, 2015 4:50 pm | |
rulcool Laskar Muda
Posts : 27 Join date : 04/11/2012
| Subject: Re: Spec. 125Z Standard Mon Aug 08, 2016 7:24 am | |
| kalau tayar besar memang la effect ckit...tapi kalau dah motor tu standard gaban lagila...haha... | |
airil Laskar Muda
Posts : 76 Join date : 30/07/2010 Age : 35 Location : BPP
| Subject: Re: Spec. 125Z Standard Sat Aug 20, 2016 10:10 pm | |
NazrienHashim Laskar Muda
Posts : 1 Join date : 20/01/2020
| Subject: Re: Spec. 125Z Standard Mon Jan 20, 2020 9:06 pm | |
| assalammualaikum otai ii sekalian . mintak petunjuk sikit . moto 125z sy pinston size 0.25 enduro . sarang b**i da tebuk . carb z . spocket 33 15 . nak tanya , MJ n PJ ap yg ssuai n size spocket ap yg ssuai ?? sebab 1 2 3 4 sedap , msuk 5 6 lemau ket . top lmbt smpai . | |
softoperator Laksamana Armada
Posts : 702 Join date : 12/01/2010 Age : 35 Location : kl
| Subject: Re: Spec. 125Z Standard Wed Mar 11, 2020 10:36 am | |
| - NazrienHashim wrote:
- assalammualaikum otai ii sekalian . mintak petunjuk sikit . moto 125z sy pinston size 0.25 enduro . sarang b**i da tebuk . carb z . spocket 33 15 . nak tanya , MJ n PJ ap yg ssuai n size spocket ap yg ssuai ?? sebab 1 2 3 4 sedap , msuk 5 6 lemau ket . top lmbt smpai .
spoket kicik sgt tu bossku | |
| Subject: Re: Spec. 125Z Standard | |
