| Spec. 125Z Standard | |
Posts : 3215 Join date : 22/03/2009 Age : 31 Location : terengganu,bangi,kuala lumpur
 | Subject: Spec. 125Z Standard Sun Jul 19, 2009 12:13 am | |
| salam dan selamat sejahtera..ambe duk cari2 xde nmpk spec 125z kat forum 125z nih..soo kut2 lah mate ambe rabun,mod jgn segan2 nak delete yer spec 125z stended gabanjenis : 2 lejang sejukan udara bil silinder : single maa lubang x lejang : 53.8mm x 54.7mm nisbah mampatan : 6.5:1 max hp : 17.5ps/8000rpm max torque : 1.65 kgf-m/7500rpm karburetor : vm 22 ss pilot jet : 15 main jet : 100 plug : bp8es,b8es,b8ecs (NGK) sistem penyalaan : digital advanced magneto tube C.D.I primary reduction ratio : 3.227 (71/22) secondery reduction ratio : 3.071 nisbah gear 1 : 2.833 nisbah gear 2 : 1.813 nisbah gear 3 : 1.368 nisbah gear 4 : 1.143 nisbah gear 5 : 1.000 nisbah gear 6 : 0.875 <-- gigi 21/24 final reduction ratio(ratio spoket) : 43/15 -->2.8667 berat kering : 101kg bateri : YB3L-B kapasiti petrol : 5.5 liter lampu dpn : 12V,25W/25W tayor blkg stended kilang : 80/90 17inch tayor depan stended kilang : 70/90 17inch kod bearing; crankshaft : 6205(kiri,knn) primary gear :6303(knn),6205(kiri) secondry gear:6304(kiri),6205(knn) balancer :6004,6202(lupa mana satu kiri ngan kanan) hub depan : 6300 hub blkg : 6301 hub spoket: 6004 kod oilseal;(quote dr mbc oleh bro vandetta ) oil seal plak... shaft spoket pakai 20-38-5 shaft lever gear 12-21-4 balancer 25-42-6
amex Laskar Kelas II
Posts : 806 Join date : 10/07/2009 Location : kepala batas n seberang jaya
 | Subject: Re: Spec. 125Z Standard Sat Jul 25, 2009 11:18 pm | |
| kat piston 125 ori ade tulis saiz x???? bape saiz ori?  |
Posts : 1565 Join date : 04/04/2009 Age : 31 Location : Sentul KL
 | Subject: Re: Spec. 125Z Standard Sat Jul 25, 2009 11:57 pm | |
| - amex wrote:
- kat piston 125 ori ade tulis saiz x???? bape saiz ori?
kalo saiz ori kilang die tulis 0.0.. means 53.8mm kalo rebore sekali pakai piston 0.25..saiz piston yg sebenarnye = 53.8 + 0.25 =54.05 |
HailToKing Laskar Kanan
Posts : 321 Join date : 24/03/2009 Age : 37 Location : KK-Likas-Penampang-Keningau-Labuan
 | Subject: Re: Spec. 125Z Standard Tue Aug 25, 2009 7:53 am | |
| standard saiz 0-0 kalo korek skali 0.25 x nmpk beza pn bsar dier |
 | Subject: Re: Spec. 125Z Standard Tue Aug 25, 2009 9:02 am | |
| x de rs sgt pbezaan tu, yg pasti cc bertambah je tp kalo nak nek topspeed kena set carb blik, asal ubah saiz piston kena set pilot ngn menjet blik bru ngam |
 | Subject: Re: Spec. 125Z Standard Tue Aug 25, 2009 12:00 pm | |
| rebore sekali = 0.25mm,kan kecik tu,mane nak nampak beze,even kalo rebore 2.00mm pun belum tentu dapat nampak beze dgn mate kasar..
klau rebore sampai saiz 1.00mm,xyah ubah setting carb pun xpe,sebab still x lari jauh,klau rebore jauh dari tu barula set balik carb.. pendek kate takat rebore 1 / 2 saiz xde rase sgt peningkatan die.. bile saiz piston besar = CC naik = pickup naik.. x bermakne topspeed pun naik..
moto standed mmg berat klau pakai 15/36.. try pakai 37 blakang.. biasela tu moto standed mmg berat cket nak sampai top.. |
 | Subject: Re: Spec. 125Z Standard Tue Aug 25, 2009 8:07 pm | |
| butut2,stakat ribo 1 or 2 mate xpyh nk set ape2 dah,melainkn btl2 rajin la,biasenye pickup je bertambah bile saiz block dh besar,lain xde ape2 pn.. |
 | Subject: Re: Spec. 125Z Standard Fri Oct 09, 2009 11:26 am | |
| - azdli90 wrote:
- kalau mot da bikin camne nak kire primary reduction ratio dye???ajar plsss
primary reduction ratio takkan berubah klau ko x kacau gearbox.. gear ratio tu ratio kat gear,xde kene ngena ngan spoket.. final drive ratio tu baru la kene ngene nagn spoket,amek nilai blakang bahagi depan la,dah berbuih kot bitau dalam forum,bace2 la cket bang.. primary reduction ratio : 3.227 (71/22) secondery reduction ratio : 3.071 nisbah gear 1 : 2.833 nisbah gear 2 : 1.813 nisbah gear 3 : 1.368 nisbah gear 4 : 1.143 nisbah gear 5 : 1.000 nisbah gear 6 : 0.875 final reduction ratio(ratio spoket) : 43/15 -->2.8667 (ni klau spoket standed) |
 | Subject: Re: Spec. 125Z Standard Wed Feb 10, 2010 6:29 pm | |
| no oilseal fork 125z
brand Nok, tc4 27 39 10.5 47 _________________ i'am wearing a poker face,until when can i hold it?... |
 | Subject: Re: Spec. 125Z Standard Wed Feb 10, 2010 11:29 pm | |
| spec stended ialah segala2 nyer mengenai 125z stended gaban yg baru kuar kilang mcm yg ada kat 1st page..xpun spec2 cam oilseal,no bearing,watt mentol,segala gearing stended dll _________________ i'am wearing a poker face,until when can i hold it?... |
Posts : 2181 Join date : 26/04/2009 Age : 32 Location : cheras
 | Subject: Re: Spec. 125Z Standard Thu Feb 11, 2010 11:20 am | |
| ak dah bersihkan topic nih dari spam yg takde kaitan ngan tajuk topic...  _________________  |
 | Subject: Re: Spec. 125Z Standard Thu Feb 11, 2010 12:13 pm | |
| nah spam dari aku.... saiz2 spanar yg biasa guna utk mtr standard original...... skru ekzos&head&blok = 12shaft rim dpn = 14nat shaft rim dpn = 17skru bracket caliper dpn = 14skru fork-T = 14shaft rim blkg = 17nat shaft rim blkg = 19skru spoket blkg-hub = 17skru spoket dpn = 10skru bracket caliper blkg = 12skru bracket-swing arm caliper blkg = 14nat 'anting2' rantai = 12nat magnet = 17nat mangkuk clutch = 19skru cover clutch = 10nat primary gear = 19nat balancer gear = 19skru enjin-body belah atas = 12skru enjin-body belah tgh = 12skru enjin-body belah bwh = 14aku tak pasti betul ker tak saiz2 ni..main hentam jer....  |
ariffm0hd Laksamana Armada
Posts : 1058 Join date : 16/02/2010 Age : 31 Location : baru nak merangkak~
 | Subject: Re: Spec. 125Z Standard Tue Feb 16, 2010 1:49 pm | |
| sape2..ingat lg x camne rupa paras meter 125z yf first model. ada gmbr die x.help me |
 | Subject: Re: Spec. 125Z Standard Tue Feb 16, 2010 2:04 pm | |
| ha nie la parasnye..  |
 | Subject: Re: Spec. 125Z Standard Tue Feb 16, 2010 3:10 pm | |
| sgt mmbantu.tima kasih bro superjoemanito.  |
|ashefast| Laskar Muda
Posts : 80 Join date : 30/04/2009 Age : 34 Location : UnderTheAppleTree
 | Subject: Re: Spec. 125Z Standard Sun Feb 21, 2010 10:30 pm | |
| meter ori ke tu suparjoe? yang asal 1st model bukan ada tulisan YAMAHA ke kt tgh2? |
 | Subject: Re: Spec. 125Z Standard Sun Feb 21, 2010 10:39 pm | |
| - |ashefast| wrote:
- meter ori ke tu suparjoe? yang asal 1st model bukan ada tulisan YAMAHA ke kt tgh2?
he3x,xori tue,sample nk tunjuk kt mmb kite je tue  |
kimi Laskar Kanan
Posts : 272 Join date : 07/09/2009 Location : malacca,k terengganu
 | Subject: Re: Spec. 125Z Standard Sun Feb 21, 2010 11:54 pm | |
| walaupun meter 1st model dah outdated,tapi background carbon fiber tu yang menarik..disamping meter ni "berat" berbanding meter2 yang baru.. |
oddysee11 Laskar Kelas I
Posts : 113 Join date : 08/02/2010 Age : 31 Location : Ipoh
 | Subject: Re: Spec. 125Z Standard Sun Feb 21, 2010 11:56 pm | |
| old skol gle meter lama.....rare 2...pakai sti tangkap meleleh...hehehe |
 | Subject: Re: Spec. 125Z Standard Mon Feb 22, 2010 12:12 am | |
| ha3x,pos2x nie risiko skit bro,hati2x skit,tapi mmg xdpt dah nk cari meter 1st model nie,klu ade pun ssh nk cari yg cun n like new  ala meter skalar skrg pun rm250 blh dpt  |
 | Subject: Re: Spec. 125Z Standard Mon Feb 22, 2010 12:18 am | |
| biar benar smpi 2rat. kalu camtu sape2 mau, meter 1st model.. dari model full silver punya. Bulb lampu TOP indicator saja tak ori. amik la RM199. Hehehe..
buat pengetahuan rakan2, motor2 125 model awal, dekat cover horn@dada tu pki stiker tulisan YAMAHA. printed atas stiker clear. Bukan lambang garfu Yamaha mcm skrg. tak silap dekat kaver kecil bwh carrier dkt ekor pun sama.. model skrg xtau ada stiker apa kt situ. hehe.. |
Posts : 1677 Join date : 22/12/2009 Age : 28 Location : Segamat ShahAlam
 | Subject: Re: Spec. 125Z Standard Mon Feb 22, 2010 12:19 am | |
| meter 1st model ni x brape best.. bwk menten speed..jarum speed n rpm gegar2..huu.. |
 | Subject: Re: Spec. 125Z Standard  | |
