| 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 | |
+79NiTRO697 kamal96 ajmal92 budak kt same iqbal92 Snake125z Sya125z mzul787 areyz95 nurkaye_akmal BCDSyaz Azeri_conquistador serez sakaihutan muhd_amir kasimselamat matjang99 d1grandprix Liquey wan_210407 su thibhan stormtrooper WVG 9651 tongdrum92 am_pitam adeqyana comebackid MadAxel payjalrazali Ijat Stylo mangketey Paktam redline cabai low profile Conan Edogawa thee_abu sherlock mat lam L5M4 125z ganu bergerKedah qayyum_qz NIKZELMY paan1171 G.i.joule jmg235 pasquale Mal-PuChOng3300 aleen90 Shark pfa absolute_ahben samporna ccn mudienLC152 -sLip- HaIkAl 125z Kaer Apislegend wanhaniff devilmeasha k.a monster block Azrul amer_horatio throne_undead bender babet kenzou fizerpool der z0uwl fiq nazjb naem 2345 chocolate meerul KapcaiKuDie superjoemanito 83 posters |
budak kt Laskar Muda
Posts : 47 Join date : 16/10/2012 Location : Kuala Terengganu
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Mon Oct 07, 2013 3:16 pm | |
| setting angin standard mcmtu la yg aku tahu.. kalau motor ak pusing bnyk tu mmg dh | |
Snake125z Laskar Muda
Posts : 20 Join date : 24/07/2012 Age : 39 Location : Kuala Krai Kelantan
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Fri Oct 11, 2013 10:14 am | |
| Budak Kt, biar saya jawab soalan kamu tu, pengalaman saya pemasangan karburater rxz millenium kepada 125z block standard, disesuaikan pilot jet 27.5....untuk senang permulaan penyalaan api, satu kali kick start terus hidup, dan main jet tukar kepada saiz 190 memang best result bagi motor saya, warna plug pun coklat, tapi syaratnya takat jarum jangan usik biar tengah dan karburater mesti asal Jepun. Kalau rasa engin masih ada kurang pickup atau lancar Kotak agin pula pemilihan diantara tebuk lubang letak span, ataupun buang span je. Setting agin.....lebih kurang daripada dua pusingan. | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Fri Oct 11, 2013 2:47 pm | |
| Antara cara cara yang dicadangkan untuk motor standard ialah :
Setting sporcket 15-37 Tukar kepada rim alloy lidi tayar 70-80, Check tengok breake pad ketat sebab piring disk belok Tukar 4 bearing racing pada rim anda, satu pada sproket hub. Extream lagi boleh tebuk lubang pada chasis dan swing arm anda supaya lebih ringan.
Untuk engine pula, tapi syaratnya engine masih berkeadaan baik....
Tukarkan coil api motor original seperti nsr, yz 125, atau pro sikit kereta "kancil" ,pakai plug ngk power, Cdi cut off tapi original . Pakai boyesen reed valve dual stage, atau yang mahal v Force4, Tukar cluth spring yang tegangan tinggi, Pakai minnyak hitam and 2t yang berkualiti, dan satu lagi teknik pakai booster botol seperti RXZ "Yamaha Induction Energy Sistem"
Sekian mencuba.
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Sat Oct 12, 2013 11:55 am | |
| - Snake125z wrote:
- Antara cara cara yang dicadangkan untuk motor standard ialah :
Sekian mencuba.
Kena usik banyak tu..haha..sproket aku 15-38...CDI pakai MJE aje... | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Sat Oct 12, 2013 9:53 pm | |
| Satu soalan lagi..skrg dah pakai carb 125z..tapi kenapa kadang-kandang pagi boleh kick satu dah start..tapi lepas bawa..(macam beli barang kat kedai)lepas tu nak start balik..kena pulas throttle?pagi pagi start tu tak pulas dan boleh start gitu je..kenapa erk?macam ada yang tak kena aje...pomen dah guna tape tu tapekan kotak angin yang dah tebuk tu.. | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Sun Oct 13, 2013 10:53 am | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Sun Oct 13, 2013 4:58 pm | |
| - Azeri_conquistador wrote:
- naikkan mata pilot jet
Kalo bawa biasa.. (80- 100) rpm 6 dan 7 gitu..lepas tutup engine..start satu kick dan tak payah pulas throttle..tapi kalo aku full throttle...lepas off dan mau start balik engine..kena pulas throttle dan kena kick macam 3 dan 4 kali.. | |
BCDSyaz Laskar Kelas I
Posts : 169 Join date : 14/12/2012 Location : Tanjong Malim
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Mon Oct 14, 2013 8:51 am | |
| biase kalu masalah ideal timing @ throttle tutup..yg main peranan adalah pilotjet.. | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Tue Oct 15, 2013 7:25 pm | |
| Pilot jet 15..mainjet 125..kotak angin tu dah tebuk tapi sudah tape tinggal sikit lubang je..blok standard 050.. start pagi memang payah..plug hitam je..yang tgh tu dgn luar sama kolour..apa saya kena buat?naik pilot?skru angin tu separuh pusingan saje.. | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Tue Oct 22, 2013 12:00 am | |
| Ada satu kemungkinan besar iaitu carb 125z kamu sudah cukup masa untuk ditukar. Saya pernah mengalami carb rxz saya tidak dapat setting angin yang baik dan bobok walaupun saya tebok lubang buang getah kotak air cleaner, tukar jarum asah, testing setting macam macam.... hampir setting nak gila....Selepas ganti yang baru. Masalah pun selesai lagi mudah setting. Tapi belilah original buatan Jepun. | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Fri Oct 25, 2013 10:40 pm | |
| - Snake125z wrote:
- Ada satu kemungkinan besar iaitu carb 125z kamu sudah cukup masa untuk ditukar. Saya pernah mengalami carb rxz saya tidak dapat setting angin yang baik dan bobok walaupun saya tebok lubang buang getah kotak air cleaner, tukar jarum asah, testing setting macam macam.... hampir setting nak gila....Selepas ganti yang baru. Masalah pun selesai lagi mudah setting. Tapi belilah original buatan Jepun.
Carb 125z ori jepun tu berapa harganya? | |
NiTRO697 Laskar Muda
Posts : 35 Join date : 23/11/2012 Location : Taiping,Perak
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Wed Dec 04, 2013 3:05 am | |
| blok 0.0 dh korek,head ptong,kotak angin dh buang span n tebuk,ekzos tebok stopper nk msuk carb z mili pilot n menjet ap yg sesuai? | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Thu Dec 05, 2013 12:10 pm | |
| - NiTRO697 wrote:
- blok 0.0 dh korek,head ptong,kotak angin dh buang span n tebuk,ekzos tebok stopper
nk msuk carb z mili pilot n menjet ap yg sesuai? kalau nk yg cun betul2 kena try semua saiz kalau boleh.. sbb lain motor lain setting dia.. tapi kalau mau yg tahap setting yg okay2 je ko tnggu abam2 yg gna carb z memberi jawapan.. | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Fri Dec 06, 2013 4:13 pm | |
nk msuk carb z mili pilot n menjet ap yg sesuai? kalau nk yg cun betul2 kena try semua saiz kalau boleh.. sbb lain motor lain setting dia.. tapi kalau mau yg tahap setting yg okay2 je ko tnggu abam2 yg gna carb z memberi jawapan.. orite bro , kalu ak test moto pulas throttle rpm naik mencanak tp meter kmh pegi lembab knpa ye? mj ke pj yg x ok? | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Fri Dec 06, 2013 9:29 pm | |
nk msuk carb z mili pilot n menjet ap yg sesuai? kalau nk yg cun betul2 kena try semua saiz kalau boleh.. sbb lain motor lain setting dia.. tapi kalau mau yg tahap setting yg okay2 je ko tnggu abam2 yg gna carb z memberi jawapan.. orite bro , kalu ak test moto pulas throttle rpm naik mencanak tp meter kmh pegi lembab knpa ye? mj ke pj yg x ok? sprocket saiz berapa? masa rpm laju je dia naik ,speed berapa masa tu? | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Sat Dec 07, 2013 1:27 am | |
nk msuk carb z mili pilot n menjet ap yg sesuai? kalau nk yg cun betul2 kena try semua saiz kalau boleh.. sbb lain motor lain setting dia.. tapi kalau mau yg tahap setting yg okay2 je ko tnggu abam2 yg gna carb z memberi jawapan.. orite bro , kalu ak test moto pulas throttle rpm naik mencanak tp meter kmh pegi lembab knpa ye? mj ke pj yg x ok? sprocket saiz berapa? masa rpm laju je dia naik ,speed berapa masa tu? sprocket 15/36 428 , contoh rpm dh 4 tp kmh baru 30 nk ke 40 , rsanya ak slah settng carb leh ades letih dh duk bukak psg tp xkena jugak set:( | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Sat Dec 07, 2013 10:05 pm | |
| - NiTRO697 wrote:
sprocket 15/36 428 , contoh rpm dh 4 tp kmh baru 30 nk ke 40 , rsanya ak slah settng carb leh ades letih dh duk bukak psg tp xkena jugak set:( adoiyaii klau susah2 sgt antr pomen je senang..dh try tgk colour plug? confirm ke salah setting carb.. clutch cable semua ok.. klau boleh ambil gmbr plug then post kt sini..baru abam2 yg terer boleh bgi jawapan. | |
arai Laskar Muda
Posts : 2 Join date : 05/05/2014
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Mon May 05, 2014 4:01 pm | |
| salam sume bro2 otai2 . saya na tumpang tanya . carburator rxz mili dgn katok apa perbezaan die dr segi kelajuan ... tgh pening na beli yg mane . sbb stgh ckp mili stgah ckp katok . mintak pendapat dan tunjuk ajar yehh .. trima kasih | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Wed May 07, 2014 9:04 pm | |
| kalau ak carb mili dah ok.. carb apapn mcm mili ka bosch ka kalau setting cun baru leh rasa power + penjimatan mnyk dia .. kalau setting tk cun, siap la duit bnyk2 nk isi petrol | |
madan77 Laskar Muda
Posts : 2 Join date : 30/05/2014 Age : 32 Location : Penang
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Fri May 30, 2014 4:13 am | |
| salam buat semua, saya nak tanya sikit tentang set carb rxz catalyzer ni, ekzos potong, sarang buang silencer tukar pakai rxz. blok stendet. spoket 15-37. nak set jimat minyak ja. brapa size minjet dah pilot yg diperlukan? mohon penjelasan. saya baru ja belajar set2 carb ni, jadi tolong kasi info yg mudah utk faham ya kawan2 semua. | |
kadi7161 Laskar Muda
Posts : 2 Join date : 25/08/2014
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Mon Aug 25, 2014 3:53 am | |
| Salam bro2 tupai .nak tnye cket nie .gua bru sarung carb mili .mj 190 pj 225 .sume standart .kotak angin da tacap boh washer .ok x mj n pj tu ?so far so good tpi ad pomen ckp jgn rembat .npe ae ?ape kesan nye ? | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Mon Aug 25, 2014 3:59 am | |
| Lgi satu nk tnye ,ad x cdangan laen nk set pj n mj slaen dari mj '190 pj 225 tuk spec tupai gua nie ?harap blas cpat . | |
khairool Laskar Muda
Posts : 2 Join date : 21/07/2015
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Tue Jul 21, 2015 11:07 am | |
| To kadi7161: jetting carb z kw tu dh ok if kotak angin just buboh washer tnpa tebok2... pomen tu xnk tggugjwb la kiranya if kw jamkan piston kw... setting ni selamat utk dilenjan dn safe minyak... | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 | |
