| 125Z + Carb RXZ V2 | |
+62laporpo_laporno nizam1407 man JGN8917 lanunlaut zul fazli nazjb haizamlee softoperator fiq monyet muaz fareez91 xapex roda karat absolute_ahben farul YashaKami imanhalimi Cat Faris bdkbarunaik alpazz tupai_tempur mR.nobita wormzx yi_tupaijek01 bujang tupai comel Ultra-Z acaapxx -angah- ipin_8403 ridsect mantadkb ijat666 apiz zouk188 assasin_lunxe fizerpool zek87 rufaz Arthur ak 125zM_Epin aus_ipoh archonixm alemborneo_125z sk8jaybees amex kelvin45 encik hariz matwe87 hasrul_90 kudaunismall mazakim azdli90 geeks superjoemanito vendetta soNa chocolate arjuna86 WKQ4913 66 posters |
| Subject: 125Z + Carb RXZ V2 Wed Nov 04, 2009 11:01 am | |
| ni umah baru..jangan menyepam la ye.. bincang yg berilmiah..
umah lama :
http://125z.forumms.net/diskusi-motosikal-f4/pakai-carb-rxz-kat-125z-t52.htm?sid=f3d7fc24f5ff137014110db907272c5a
spec standard carb RXZ :
Bosch : mainjet 210 pilot 22.5 Millenium : mainjet 210 pilot 22.5 Catalyte : mainjet 195 pilot 22.5
jarum biar duk kat takuk tengah.. resepi jarum:
pakai jarum panther txr atau jarum ori rxz tapi asah cket ujungnye..
*untuk motor standed gaban pakai kombinasi pilot standard rxz mainjet 180-200
*untuk motor dah standard modified plak pakai pilot >22.5,pilot>210,mengikut setting yg ngam..
*macam biase,setting ni try n error..
-susah nak jumpe yg ori jepun baru.. biasenye yg orikat sparepart tu dari yamaha thai..nak btol2 ori,dari HLY lah.. tapi x silap yg ade carb catalyt n milie kot..
ape2 try tanye tokan barang rxz ori HLY ni : shaiful 0126847164 | |
arjuna86 Laskar Kanan
Posts : 344 Join date : 15/05/2009 Age : 38 Location : tlk intan - sah alam - tlk intan.....
| Subject: Re: 125Z + Carb RXZ V2 Wed Nov 04, 2009 2:04 pm | |
| sona.. epoxy tu ape...? | |
| Subject: Re: 125Z + Carb RXZ V2 Wed Nov 04, 2009 2:14 pm | |
| aku beli kat kedai masa tahun 2003 dl,rm180 boss punya..kompem bukan ori yamaha..dan aku still pki sampai hari ni,dah siap kasi rebore
problem? masa aku set sendiri2 dl mmg problem byk giler sbb aku x reti miyahahaha
skrg dah ada org tulun set kan utk aku,soo goyang kaki jer la ngeeee | |
soNa Bintara Muda
| Subject: Re: 125Z + Carb RXZ V2 Wed Nov 04, 2009 2:27 pm | |
| - arjuna86 wrote:
- sona.. epoxy tu ape...?
epoxy tu gam yang ada campuran..boleh guna untuk tutup benda2 pacah ni..tapi ada byk epoxy..plastik epoxy,steel epoxy.. - chocolate wrote:
- aku beli kat kedai masa tahun 2003 dl,rm180 boss punya..kompem bukan ori yamaha..dan aku still pki sampai hari ni,dah siap kasi rebore
skrg dah ada org tulun set kan utk aku,soo goyang kaki jer la ngeeee wahh..goyang kaki je eh choc..sedapnya tgk pomen buat..kite dok rilek tgn bersih je kan..hehe...siap boleh gentel2 macam ni lagi.. | |
| Subject: Re: 125Z + Carb RXZ V2 Wed Nov 04, 2009 3:08 pm | |
| tangan x bersih gak sona,sbb aku yg kene bkk kaberset,kuarkan karb,tukar pilot menjet,then pasang balik huhu
keje dia cuma pulas minyak ngan pulas skru angin jer haha
kl dia rasa x cun,aku kene bkk lg karb,menjet,pilot..skali tu sampai 3 kali bkk psg karb nak suh setting cun letih wooo | |
soNa Bintara Muda
| Subject: Re: 125Z + Carb RXZ V2 Wed Nov 04, 2009 3:28 pm | |
| ooo..cikgu aku ada mahaguru lagi..hehe..biasa la tu choc..tu pomen berpengalaman tu..kena pulak buat sendiri..ohoho..mau 4 5 kali n giveup wo (hampir2 dlu,haha).. | |
| Subject: Re: 125Z + Carb RXZ V2 Wed Nov 04, 2009 3:43 pm | |
| cuma skrg ni xyah penin pale la nape set karb asyik x jadi haha,tang tu yg peritnya bl xtau punca,kl dah tau senang nak proceed walaupun cerewet
okeh aritu aku ada tny pomen aku,beza karb boss/mili ngan katak,dia kata ada skru ke punat ke hapa ntah kat mangkuk bwh karb tu | |
| Subject: Re: 125Z + Carb RXZ V2 Wed Nov 04, 2009 5:09 pm | |
| ni ada sedikit gambaran carb rxz catalyzer & bosch yg tak seberape ni utk tatapan semua... **cover atas tu sama jer patutnyer...yg dh dipotong tu utk lebih mudah p&p ke y125z.. choke carb bosch tu dh dicabut... | |
| Subject: Re: 125Z + Carb RXZ V2 Wed Nov 04, 2009 7:06 pm | |
| klu aku syg lak nk potong,mskkan aje tali throttle rxz,kene beli la,kene beli one set,tapi nk pakai satu je,khe3x | |
| Subject: Re: 125Z + Carb RXZ V2 Wed Nov 04, 2009 7:56 pm | |
| kalau pakai carb rxz.. choke standard leh gune x?... | |
azdli90 Kadet
| Subject: Re: 125Z + Carb RXZ V2 Wed Nov 04, 2009 7:57 pm | |
| Subject: Re: 125Z + Carb RXZ V2 Thu Nov 05, 2009 3:38 pm | |
| tp ad pomen kt tmpt aku.. dia bt mcm mna x tau.. pkai cab z pun bley gna choke tangan.. |
| Subject: Re: 125Z + Carb RXZ V2 Thu Nov 05, 2009 8:45 pm | |
| die custom la tue,DIY ,tapi klu pakai choke asal pun cam cun beb,bile nk tarik choke kene seluk | |
| Subject: Re: 125Z + Carb RXZ V2 Thu Nov 05, 2009 9:51 pm | |
| huhu cun2 gak,nnt gelabah mcm aku aritu kunci x bkk ingat muto wat hal,gelabah jer nak tarik choke terselit harharhar
choke karb asal dia punya skru lg besar dr choke rxz,kl korang wat balik thread skru kat choke rxz tu bleh je kasi masuk stended asal muto | |
| Subject: Re: 125Z + Carb RXZ V2 Thu Nov 05, 2009 10:22 pm | |
- huhu cun2 gak,nnt gelabah mcm aku aritu kunci x bkk ingat muto wat hal,gelabah jer nak tarik choke terselit harharhar
choke karb asal dia punya skru lg besar dr choke rxz,kl korang wat balik thread skru kat choke rxz tu bleh je kasi masuk stended asal muto choco... bengkel kat puchong tuh leh wat choke gitu?... | |
| Subject: Re: 125Z + Carb RXZ V2 Thu Nov 05, 2009 10:31 pm | |
| xpayah bro....lg pun xsusah mau tarik choke rxz tue juz seluk kt bwh jer... masa duk ats motot pun leh bongkok tarik.... | |
| Subject: Re: 125Z + Carb RXZ V2 Fri Nov 06, 2009 10:49 am | |
| wahahaha carb engko ke?aku pun ade terpikir idea nak sumbat tin coke..hehe | |
kudaunismall Laskar Kelas II
Posts : 937 Join date : 02/06/2009 Age : 35 Location : Bandar Baru Bangi
| Subject: Re: 125Z + Carb RXZ V2 Fri Nov 06, 2009 10:51 am | |
| tin coke? camna? ini pun tudung botol deodoran adidas aku. masuk ngam2 lak tu. | |
| Subject: Re: 125Z + Carb RXZ V2 Fri Nov 06, 2009 11:05 am | |
| - kudaunismall wrote:
- tin coke? camna? ini pun tudung botol deodoran adidas aku. masuk ngam2 lak tu.
ade tudung botol lebih x???hehehe.. | |
| Subject: Re: 125Z + Carb RXZ V2 Fri Nov 06, 2009 11:07 am | |
| hihi.. tu la aku dok mencari ni. puas menggeledah tong sampah dalam bilik ni. dulu ade je 2-3botol aku buang. adessss.. | |
| Subject: Re: 125Z + Carb RXZ V2 Fri Nov 06, 2009 11:09 am | |
- hihi.. tu la aku dok mencari ni. puas menggeledah tong sampah dalam bilik ni. dulu ade je 2-3botol aku buang. adessss..
hehe klau ade bak satu!nak diy..hehe | |
| Subject: Re: 125Z + Carb RXZ V2 Fri Nov 06, 2009 11:12 am | |
| suatu masa dulu masa zaman spm dulu2,,,member ak ader buat gak camni tp keliling botol tue dier sapu minyak skit kasi habuk2 n pasir2 melekat kt minyak tue....tp kne rajin cuci la botol tue ngeee | |
| Subject: Re: 125Z + Carb RXZ V2 Fri Nov 06, 2009 11:16 am | |
hehe klau ade bak satu!nak diy..hehe hehe.. tak jumpa malangnya.. alang2 deodoran aku dah abes.. beli lagik la nampaknya. nanti aku bli one set = 2 botol. ko amek la tutup je. deodoran aku nak pakei. hahahaha.. | |
hasrul_90 Support Crew
Posts : 339 Join date : 12/06/2009 Age : 33 Location : K.Terengganu
| Subject: Re: 125Z + Carb RXZ V2 Sun Nov 08, 2009 2:24 am | |
| skrang nih aku dah pakai cabr rxz..so far... rase2 minyak same je ngan cabr standard.. cume accelerate ngan top je la dapat sket.. bergantung lak camner korang setting... skrang ni blok aku saiz 50..standard gaban.. main jet=185,pilot=27.5..
| Subject: Re: 125Z + Carb RXZ V2 Sun Nov 08, 2009 10:24 am | |
| - hasrul_90 wrote:
- skrang nih aku dah pakai cabr rxz..so far...
rase2 minyak same je ngan cabr standard.. cume accelerate ngan top je la dapat sket.. bergantung lak camner korang setting... skrang ni blok aku saiz 50..standard gaban.. main jet=185,pilot=27.5.. Top ko dpt bp? |
| Subject: Re: 125Z + Carb RXZ V2 | |
