| Piston Enduro | |
+34ajizaimi Pure_Soul tupaiberasap nazjb Fendi Faito man JGN8917 fiq paan1171 yi_tupaijek01 dtk3a assasins redline mangketey gilgamesh88 sANi bUAs Ultra-Z apiz -angah- supcendawan absolute_ahben ipin_8403 tupai comel superjoemanito farul dy rasau Are_riff zouk188 hasrul_90 chocolate soNa fizerpool WKQ4913 monyet bujang 38 posters |
bujang Laskar Kanan
Posts : 223 Join date : 03/04/2009 Age : 37 Location : koTa TinGGi
| Subject: Piston Enduro Fri Jan 08, 2010 12:03 am | |
| Sape2 penah pakai piston yamaha DT125 a.k.a enduro kt blok tupai. citer skit best ke x? pe rasa. klu leh cter details skit ler...pkai carb ape,saiz mnjet,pilotjet. PERBEZAAN | | Y-125Z | DT-125E | DT-125A/ DT-125FB | OEM No. | 5BU- | OEM No. | 2A6- | 444- | CODE No. | AY0720X | CODE No. | AY0570X | AY0560X | BORE(mm) :A | 53.8 | BORE(mm) :A | 56 | 56 | LENGTH(mm) :B | 66.70 | LENGTH(mm) :B | 66.00 | 66.00 | PIN DIA (mm) :C | 16 | PIN DIA (mm) :C | 16 | 16 | COMPRESSION HEIGHT① (mm):D | 32.70 | COMPRESSION HEIGHT① (mm):D | 33.00 | 33.00 | COMPRESSION HEIGHT② (mm):E | 29.50 | COMPRESSION HEIGHT② (mm):E | 29.80 | 30.00 | PIN LENGTH (mm):F | 16X44.5 | PIN LENGTH (mm):F | 16x47 | 16x47 | PLATING |
| PLATING |
| | STROKE | 2 | STROKE | 2 | 2 | PISTON CODE No. | PY0960X | PISTON CODE No. | PY0820X | PY0810X |
monyet Laskar Kanan
Posts : 212 Join date : 26/11/2009 Age : 34 Location : sunway-k.trg
| Subject: Re: Piston Enduro Fri Jan 08, 2010 12:26 am | |
| dlu pernah dgr sorang pomen kat area ak pki...die pki carb tzm...best x best ak x sure...tp outmeter tu normal muto die... | |
| Subject: Re: Piston Enduro Fri Jan 08, 2010 1:04 am | |
| piston enduro ni sama cam ko pakai piston saiz oversize 125z la..kelebihan pickup la sebab cc dah besar,kene ngan setting awal ade,ujung rpm pun ade,klau salah setting ujung rpm lemau..yang penting pakai piston besar2 ni,head pun kene oter gak..klau x x allout la.. | |
fizerpool Bintara Kanan
| Subject: Re: Piston Enduro Fri Jan 08, 2010 1:07 am | |
| size 0.0 enduro= size 2.0 125z tul ker....kalo salah tolong betulkan | |
soNa Bintara Muda
| Subject: Re: Piston Enduro Fri Jan 08, 2010 1:22 am | |
| - fizerpool wrote:
- size 0.0 enduro= size 2.0 125z
tul ker....kalo salah tolong betulkan silap skit tu.. enduro 0.00 = 56mm 125z 0.00 = 53mm jadi, enduro 0.00 = 125z 3.00 OS | |
| Subject: Re: Piston Enduro Fri Jan 08, 2010 1:24 am | |
| owh yeke... mau bertahun gak la nk smpai size 3.0 tuh....hahahaha cita xkesampaian la ni...hahahaha | |
| Subject: Re: Piston Enduro Fri Jan 08, 2010 1:38 am | |
jadi,enduro 0.00 = 125z 3.00 OS 125Z 53.8mm /54mm la sona..hehe *ooo jadi encik Sona pakai piston enduro la ni ye..hehe kantoiii.. | |
bujang Laskar Kanan
| Subject: Re: Piston Enduro Fri Jan 08, 2010 1:57 am | |
| yup! tol la tu piston 125z std 53.8mm. dt125 std 56m. ptg td, aku dh cuba psg blok aku yg bru pas lay saiz enduro 0-0. tp xleh hidup la plak aku start. apsal ek? last2, mlm td aku pasang balik blok lain. leh hdup plak. poning2! bru nk mrasa..hajat trbantut la plak. | |
| Subject: Re: Piston Enduro Fri Jan 08, 2010 2:34 am | |
| piston pasang terbalik?piston jejak head? | |
| Subject: Re: Piston Enduro Fri Jan 08, 2010 6:30 am | |
*ooo jadi encik Sona pakai piston enduro la ni ye..hehe kantoiii.. owh....jadi 0.00 enduro=2.20 125z la yer... | |
soNa Bintara Muda
| Subject: Re: Piston Enduro Fri Jan 08, 2010 8:20 am | |
*ooo jadi encik Sona pakai piston enduro la ni ye..hehe kantoiii.. yup..aku tersilap skit lak..stended 125z = 53.8mm.. eh,mane ade pakai enduro wan..dulu ye la..best gak..lagi2 buat long distance dari penang ke N9..syok je meluncur..hehe..CC dah jadi 133cc mase tu.. - bujang wrote:
- yup! tol la tu piston 125z std 53.8mm. dt125 std 56m.
ptg td, aku dh cuba psg blok aku yg bru pas lay saiz enduro 0-0. tp xleh hidup la plak aku start. apsal ek? last2, mlm td aku pasang balik blok lain. leh hdup plak. poning2! bru nk mrasa..hajat trbantut la plak. mm..piston enduro ada byk jenis.. DT125A/DT125FB DT125E DT125K DT125K1 DT125LC *setiap model ni berbeza dari segi ketinggian,kedudukan piston pin,ketinggian dome,rupa tapi sama diameter iaitu 56mm.. yang aku pakai dulu DT125A/DT125FB..mungkin piston yang ko pasang tu terbalik macam kata en choc td..blok dah porting ke?..gasket berapa keping ko guna?.. | |
| Subject: Re: Piston Enduro Fri Jan 08, 2010 12:02 pm | |
| kire ko bore blok ko sampai saiz brape?ko pakai piston enduro saiz 0.0 ke?ke ko tukau sleeve blok baru?
-oooo patot la geng utare report moto ko laju..hehehe | |
soNa Bintara Muda
| Subject: Re: Piston Enduro Fri Jan 08, 2010 5:16 pm | |
| - WKQ4913 wrote:
- kire ko bore blok ko sampai saiz brape?ko pakai piston enduro saiz 0.0 ke?ke ko tukau sleeve blok baru?
-oooo patot la geng utare report moto ko laju..hehehe ahaha..mane ade laju wan..slow je..laju pon kelajuan stended tupai je.. aku pakai piston DT 0.25 OS..rebore blok ori stended sampai sais 56.25mm+0.8mm (clearance)..sebelum tu aku dah pakai 125z sais 1.00,1.25,1.50,1.75 n 2.00 OS..aku tak rebore sekaligus untuk dapat sais DT tu..bila dah masuk piston DT ni,sleeve mmg nipis dah..setting kena cun untuk elak risiko jem panas..so far aku guna blok ni ride penang ke n9 dgn kelajuan 8k-9k menten takde masalah.. | |
bujang Laskar Kanan
| Subject: Re: Piston Enduro Fri Jan 08, 2010 6:10 pm | |
- piston pasang terbalik?piston jejak head?
piston aku psg btul. anak panah ke lubang ekzos. jejak head pn x kot. klu jejak head mmg xleh hdup lgsg ke moto?aku bru tau.. ni bru pas siap psg. aku g kdai moto sblm solat jumaat td:p bli ring rxz 0-0. skrg dh leh hdup. binawe tol! bengkel yg aku htr lay blok tu kasi ring ape ntah. laen mcm..gap ngn longkang ring tu bsar giler. | |
| Subject: Re: Piston Enduro Fri Jan 08, 2010 6:23 pm | |
| err kl dah jejak kaw2 camner nak hidup? err ambe x reti sgt lor,hipotesis semata2... x reti lor nak pki piston besor2 ni............ | |
soNa Bintara Muda
| Subject: Re: Piston Enduro Fri Jan 08, 2010 7:48 pm | |
bujang Laskar Kanan
| Subject: Re: Piston Enduro Sat Jan 09, 2010 2:52 pm | |
hasrul_90 Support Crew
Posts : 339 Join date : 12/06/2009 Age : 33 Location : K.Terengganu
| Subject: Re: Piston Enduro Sat Jan 09, 2010 4:02 pm | |
| ape barang main piston besar2 nih..kan x pasal2 tmbus lak piston nanti...x cukup minyak punye pasal...klu nk main piston nih kene set minyak lebih... klu x..tanggung la sndiri akibatnye.. pastu bunyi kt blok tu akan kuat sket..biase la piston besar... | |
zouk188 Laskar Muda
Posts : 74 Join date : 17/06/2009 Age : 39 Location : USJ Subang Jaya
| Subject: Re: Piston Enduro Sat Jan 09, 2010 5:22 pm | |
| x kira bro piston besar/kecik.. myk mesti mau jg.. | |
Are_riff Laskar Muda
Posts : 67 Join date : 28/12/2009 Age : 38 Location : penang/arau
| Subject: Re: Piston Enduro Sat Jan 09, 2010 5:42 pm | |
| laju mcm mn sklipun kat trafik light brnti gak... cita rasa masing2 la jnji puas hati.... bwk laju2 bnyak negetif dari yg positif... amalkan cara hidup yg chat....pe yg aku merapu nie.. | |
zouk188 Laskar Muda
| Subject: Re: Piston Enduro Sat Jan 09, 2010 10:18 pm | |
| tp mmg x d nafikan pkai piston dt125 nih mmg superb.. performance mmg ho liow.. tp biasa la bila slevee da nipis x tahan panas.. bunyi pun bising sket.. kena jg 2t leklok.. overal recommended for hardcore jokey.. for beginner no need lah... piston std pun da cun.. cuma shoot dia kureng sket la dr dt1255 nih.. | |
| Subject: Re: Piston Enduro Wed Feb 03, 2010 12:46 am | |
| camner nak kasi kurang gegaran bl pki piston bosar2 ni?
sbb gegaran ni ada byk makna,satunya sbb mass balance out of order,muto sepatutnya bleh pi lagi laju,tp sbb x belen maka performence jadi soo2 sj
soo kl sesapa ada ilmu blue print enjin,camner nak kasi belen balik berat ngan komponen2 lain,supaya keseimbangan seperti pki piston stended tu bleh dapat balik,kongsi2 la yer | |
dy rasau Laskar Muda
Posts : 80 Join date : 23/03/2009 Location : dekat2 ni je...
| Subject: Re: Piston Enduro Mon Feb 08, 2010 11:43 pm | |
| sory mencelah.. so mknenye nk pakai piston enduro kat tupai ni,saiz blok kite tu kene 2.0 ek? n ape lg yg nk kene tukar bile kite nk guna piston ni cntohnye roller dia ke ape ke..tq | |
farul Laskar Muda
Posts : 81 Join date : 16/10/2009 Age : 34 Location : pasir gudang
| Subject: Re: Piston Enduro Wed Mar 03, 2010 9:00 pm | |
| tmpang tnyer ..piston enduro pling besar smpai bpe mm.. | |
| Subject: Re: Piston Enduro Sun Mar 07, 2010 12:19 am | |
| enduro ni muto aper sebenarnya?starting saiz mmg 56mm ke?atau ada starting saiz yg lain? | |
| Subject: Re: Piston Enduro | |
| Piston Enduro | |
