 Piston KTM 300 (Motocross)
Go to page : 1, 2  Next
apiz
PostSubject: Piston KTM 300 (Motocross)   Fri Apr 30, 2010 1:41 am
salam semua bro2 sekalian..
bro2 prnah dgr x sal piston moto ni msuk "bikin" msuk blok stendet 125z..
BOLEH KE?? N ade ke moto ni msuk mlaysia?
0 size=72mm
bro2 cuba kupas ckit..
sila bca komen ni https://www.youtube.com/watch?v=TCMVXpuMCnU
n spec moto ni http://motoprofi.com/motospecspictures/ktm/300_exc-2005.html
bujang
PostSubject: Re: Piston KTM 300 (Motocross)   Fri Apr 30, 2010 2:50 am
pergh!! giler arg pis. nk wat pojek bsar nmpk pasni.
nk smbat piston 72mm ke??
aku rasa tu dh bkn ori sleeve kot.gler lobos!!kaw2 pnya hilang dara.
http://www.facebook.com/mohdnoorhelmi
apiz
PostSubject: Re: Piston KTM 300 (Motocross)   Fri Apr 30, 2010 10:16 am
aku brcadang jer...klo bleh nk ade kdai nk wt baik aku try..huhu
tp nk suh dia wt knala tau skit2 sal piston ni..leh msuk ke x,entah2 tinggi/rendah beza jauh ssh gak nk kna potong or ltk gasket tebal2..tu yg nk tnye otai2 ni
bdkbarunaik
PostSubject: Re: Piston KTM 300 (Motocross)   Fri Apr 30, 2010 10:49 am
nk buat racing k bro?
http://www.facebook.com/?ref=home#!/profile.php?ref=profile&
anep4742
PostSubject: Re: Piston KTM 300 (Motocross)   Fri Apr 30, 2010 10:52 am
hohoho..ko sumbat je dl bro..aku nk tgk gk pe jd..
apiz
PostSubject: Re: Piston KTM 300 (Motocross)   Fri Apr 30, 2010 11:10 am
xdela..nk pnaskn line kt tasik p.gudang je ptg2..huhu
PostSubject: Re: Piston KTM 300 (Motocross)   Fri Apr 30, 2010 11:44 am
ko tgk dari spec tu pun dah tau konpom2 piston tu lagi panjang sebab stroke die hampir 20mm lagi panjang dari standard..
yang lagi konpom blok ori amat la mustahil,melainkan custom balik ruang silinder,intake port,ngan sleeve custom..
giler r,nak kene rebore sampai 18mm dari blok standard...
lagi pun pakai piston oversize,banyak nak kene alter balik,firing etc sebab takut x support dalam combustion chamber nanti..
pade aku la,banyak bende nak kene kaji balik,n yg penting tujuan die ape?nak masuk competition drag ke sprint konpom xleh sebab ade saiz piston maximum yg dibenarkan..melainkan haram nye nak open game leh la..hehe..silap2 kos nak modi = sebijik 4 stroke..
nak buat bleh,cam budak2 greece buat,tapi kepakaran cam diorang je blum jumpe lagi kat sini..
farul
PostSubject: Re: Piston KTM 300 (Motocross)   Fri Apr 30, 2010 5:37 pm
mahal 2 law nk tkar sleve...tp piston 67mm ke atas untk 125 bru srtus lbh kat JB...
apiz
PostSubject: Re: Piston KTM 300 (Motocross)   Fri Apr 30, 2010 9:45 pm
kdai mne tu?leh rekemenkn x?
gilgamesh88
PostSubject: Re: Piston KTM 300 (Motocross)   Sat May 01, 2010 3:56 am
PostSubject: Re: Piston KTM 300 (Motocross)   Sat May 01, 2010 9:00 pm
knape mesti piston besar?
jgn smpai piston 72mm tu kne tapau ngan piston 53.8mm..
piston besar saje tk ckup..
carb kne besar,
klac n spring kne baekkk punya,
api kne kuat..
isk..
leceh la..~
PostSubject: Re: Piston KTM 300 (Motocross)   Sat May 01, 2010 9:25 pm
bajet pun kena besar gak.. kalau takat bajet ciput... erk...
PostSubject: Re: Piston KTM 300 (Motocross)   Sat May 01, 2010 9:44 pm
haah,
aku tlupe nk taip.. 'bajet kne besar..'
try masuk blok tzm+radiator dlu..
kalo tu pn terkial2 bek lupekan piston gaban berkenaan..
ekekeke..
apiz
PostSubject: Re: Piston KTM 300 (Motocross)   Sun May 02, 2010 9:22 am
haah,
ekekeke..
klo nk msukkn radiator tu dah acvnce sgt tu..huhu
PostSubject: Re: Piston KTM 300 (Motocross)   Sun May 02, 2010 3:09 pm
try masukkan piston honda rider dl tgk bleh ke x muakakakaka
ada alternative lain,try cari piston gilera,tp pin piston rasanya kene buat lain kot..
kl dah 70++mm cc dah jadi 200++cc,tu blum jek rod lagi tu
selagi tinggi piston tu x lebih 30mm bleh jer nak sumbat(30mm kira dari tgh pin piston ke piston crown),kl lebih pun beli jer gasket blok byk2 kasi lapik ke3
apiz
PostSubject: Re: Piston KTM 300 (Motocross)   Wed May 05, 2010 1:25 am
carb kne besar,
api kne kuat..
isk..
leceh la..~
owh spring leh wt lju gak eh..bru aku tau..lps ni kna tukar clutch dgn spring la
farul
PostSubject: Re: Piston KTM 300 (Motocross)   Wed May 05, 2010 1:37 pm
law bsar 72mm pkai carb delorto je bley lyn hu3...bt sprint bley la...law stakt carb rxz mesti berlobang tgah...hm ari tu aku try bt tkar sleeve blok kat area jb dkat 500 die cas 2 bru 60mm je,blm lg 72mm,hu3...
apiz
PostSubject: Re: Piston KTM 300 (Motocross)   Mon May 10, 2010 1:03 pm
bro2 skalian..aku de blok rxz sbijik ni,tp cmne nk sumbat kt tupai eh sal klo blok rxz carb dia kt blok,tupai lak kt antara blok dgn enjin..
bg cadangan ckit bro2
PostSubject: Re: Piston KTM 300 (Motocross)   Mon May 10, 2010 1:08 pm
tk tuka pn tkpe ke?
oic..
apiz
PostSubject: Re: Piston KTM 300 (Motocross)   Mon May 10, 2010 2:33 pm
tk tuka pn tkpe ke?
oic..
xtau la bro..ambe ni xpndai sgt sal2 moto ni.. No
PostSubject: Re: Piston KTM 300 (Motocross)   Mon May 10, 2010 4:10 pm
xke rasa besor sgt piston 2..meh tuka blok ngan aku nk..piston aku lg besar dr 2.00..
apiz
PostSubject: Re: Piston KTM 300 (Motocross)   Mon May 10, 2010 5:28 pm
xjd la bro pkai pston ktm tu..xjmpe kdai n mhal sgt kot kos tu..
PostSubject: Re: Piston KTM 300 (Motocross)   Tue May 11, 2010 10:40 am
drpd piston besar + blok standard,
lbey bek pkai piston standard + blok porting..
blaja porting blok n point2 die..
masyuk woo~~
PostSubject: Re: Piston KTM 300 (Motocross)   Tue May 11, 2010 10:53 am
apiz wrote:
tk tuka pn tkpe ke?
oic..
kne la tuka kalo tol2 nk rase power enjin tu..
kalo enjin leh hasilkan 20hp tp power tu dtransfer ke clutch ade power loss,
kt gearbox ade friction(maybe minyak itam dh pekat atau bearing worn out dh),
pastu rantai karat(friction lg),
disc tk center(friction lg),
tyr oversize+soft compound(more rubber on the road,more grip, more friction, more power loss)..
tk smpai la 20hp output kn?
gilgamesh88
PostSubject: Re: Piston KTM 300 (Motocross)   Sat May 15, 2010 6:55 pm
apiz wrote:
tk tuka pn tkpe ke?
oic..
btol tu.....
sbb tu ade yg rate hp kt flywheel dan ade yg kt wheel...
Page 1 of 2Go to page : 1, 2  Next
