 Piston Enduro
PostSubject: Re: Piston Enduro   Tue Jan 11, 2011 2:56 pm
xtau la...ambe xda pomen2 besar..stakat pomen member2 je...mgkin ada pomen2 yg bolh bt..tp xtau tmpt...paan ckp dia penah bt,tp mcm jauh lok...xkn nk bwk blok tu ke pj..hehehe
PostSubject: Re: Piston Enduro   Tue Jan 11, 2011 7:48 pm
bwk jela blok tu yi kalu adepun kt pj tu..xjauh manala pj-shah alam...
isap sebtg rokok nusantara pun xabis...erkkk tp ko xisap rokok kn....
xnk ssh leh bwk blok time tt & bg kt paan...next tt dtg balik colect balik blok tu
PostSubject: Re: Piston Enduro   Tue Jan 11, 2011 9:15 pm
heheheh..problemnyer man blok tu ada kt nanana TERENGGANU kiter....hahaha...lame dh xpakai blok tu
fiq
PostSubject: Re: Piston Enduro   Wed Jan 12, 2011 12:38 pm
Ak terblur jap psal sleeve ni..125 mmg pkai sleeve ke? Hrap ade yg mnrgkn sprt bro sona..huhu..bdk br bljr
PostSubject: Re: Piston Enduro   Thu Jan 13, 2011 1:41 am
ad sleeve bro... meh aq bljne pic block sblum dan slepas tukar sleeve....
sblum resleeve... saiz DT (enduro) 0.25
selepas resleeve... standet 0.25.. aq rebore 1 kali...
kiri selepas.. knan sblum.. mgkin x nmpak sgt beza... sbb gmbar pon x clear sgt... ..
fiq
PostSubject: Re: Piston Enduro   Thu Jan 13, 2011 11:30 am
Apa beza resleeve ngan rebore?resleeve usik part mne?
PostSubject: Re: Piston Enduro   Thu Jan 13, 2011 3:06 pm
tgok kt gmbar tu nmpak xmcm x ring bulatan... tu la sleeve... klau rebore besar kn saiz piston...
Fendi Faito
PostSubject: Re: Piston Enduro   Thu Jan 13, 2011 6:52 pm
broo maw tanya lee...saya dah rebore blok saya kan...larian mmg dah sedap dan starting mmg bagus..tapi saya rasa ada yang kurang la...kalo blok dah rebore api mesti set balik kan?
http://125z.darkbb.com
PostSubject: Re: Piston Enduro   Fri Jan 14, 2011 1:36 am
paan,ko buat kat mana?brape kene?blok yg pki skrg ka?ada beza performence?
PostSubject: Re: Piston Enduro   Fri Jan 14, 2011 1:42 am
den buat kt klang lama... sigboard mos.. kdai kecik je.. kedai tu leh rebore,reslvee,polish pape jelah... aq buat rm 120.00... siap outer ikut porting lame blok aq...
soo far aq pkai ok la... sblum g Melaka n smpai ary ni... x tau la long term ad effect.. cume beza la dlu pkai stok piston oversive pick up mmg toing2 la.. ni dh saiz stendet lek berat skit la nk dpat top... boleh je dpat outmeter... hehehe...
PostSubject: Re: Piston Enduro   Fri Jan 14, 2011 2:02 am
nak masuk sleeve oversize diorang bleh buat x?ada option utk material x?hoho banyaknye soklan
PostSubject: Re: Piston Enduro   Fri Jan 14, 2011 2:29 am
oohh.. x tau la plak.. try la tnye lau ad...
fiq
PostSubject: Re: Piston Enduro   Fri Jan 14, 2011 10:20 am
ooh,lubang kat dalam yg besar 2 eh? kalo resleeve, apa benefit kita dapat eh?
lg 1, ak tanya pomen ak 2, kalo x silap aku, dia kate die msk piston 0.5dt..kalo saiz 125 0.75..ak masih blur..tlg ak..
PostSubject: Re: Piston Enduro   Fri Jan 14, 2011 4:12 pm
resleeve ni biasa org buat utk kembalikan sais asal piston stended (lepas dah rebore berkali2 n sleeve asal dah nipis..) atau pon nak pakai piston besar yang sleeve ori tak mampu tampung..
benefit die ade byk bergantung kepada niat..
niat pertama:nak kembalikan sais asal piston
-dapat pakai sais stended balik
-dapat balancekan balik berat engine (dah tak balance sbb piston teramat besar sebelum resleeve)
-dah sebagainye..
niat kedua:nak guna piston besar
-ni kene tanye kepada yang pakai piston besar.. Mad
tentang piston DT tu..
mungkin pomen tu silap kot fiq..tgk fakta ni..
piston 125z 0.00 = 53.8mm
piston DT 0.00 = 56mm
standed 125z = 53.8mm..untuk 0.75 oversize(OS) akan jadi 53.8+0.75 = 54.55mm..
DT stended = 56mm..untuk 0.5 OS akan jadi 56+0.5 = 56.5mm..
jadi sais tu tak same..sais max 2.00 OS bagi piston 125z pon takkan boleh sama sais dgn piston 0.00 DT..
harap membantu..
soNa - 0194485713
PostSubject: Re: Piston Enduro   Wed Oct 26, 2011 5:36 pm
aku ader sebiji blok saiz 2.00
ring dh bunyi gilekentang.ingat nk rebore.
kalau rebore sekali dh boleh masuk piston dt0.0 la ye.
mainjet ngan pilotjet ape yg sesuai utk saiz dt0.0 tu.
carb z mili,head dh scheme 2mm.
nk taaaaaaaaau sgt2
PostSubject: Re: Piston Enduro   Wed Oct 26, 2011 7:18 pm
da boleh da.
pakai carb z mj start 190 keatas
pilot 25 keatas
kalau ak la.
PostSubject: Re: Piston Enduro   Wed Oct 26, 2011 7:25 pm
da boleh da.
pilot 25 keatas
kalau ak la.
PostSubject: Re: Piston Enduro   Wed Oct 26, 2011 7:34 pm
tp blok dh port..bole ke mj190 tu?
tupaiberasap
PostSubject: Re: Piston Enduro   Wed Oct 26, 2011 8:09 pm
tgok gak ah len moto len ragam . hehe
cam aku dt125e piston 0.75 . port angin + minyak . ekzos kacau .
230 mjet , pjet 30 . start pagi sekali . cuma timing lambat turun . hmmmm . .
try lu ah
http://facebook.com/tupaiberbeza
PostSubject: Re: Piston Enduro   Wed Oct 26, 2011 8:10 pm
alarhai.
kan ckp starting mj 190.
aduyai.
xkn nk sumbat mj 300 trus.
PostSubject: Re: Piston Enduro   Wed Oct 26, 2011 8:31 pm
ahben,jgn marah2 nt cepat tua..hehehe
ok2..nt ader mase kwn wt.
skrg gune saiz 0.50 je dulu..huhu
PostSubject: Re: Piston Enduro   Wed Oct 26, 2011 8:53 pm
th la.
ade pomen ckp x ley pakai enduro jalan jauh.
ak pakai oke je.
da setahun da piston TRIM enduro tuh kt moto ak.
elok jek Smile
th la.
ak pakai oke je.
elok jek Smile
tupaiberasap
PostSubject: Re: Piston Enduro   Wed Oct 26, 2011 8:55 pm
setau aku la , kalau motor 2t ni jaga 2t nye . susah gak nak calar kan blok?
kalau tak mati la . rebore jerk . . huhu
PostSubject: Re: Piston Enduro   Wed Oct 26, 2011 8:57 pm
bile pakai enduro ni nt blok bising sket la ye?ke bising banyak?
Piston Enduro
Page 6 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
