 Piston Enduro
gilgamesh88
PostSubject: Re: Piston Enduro   Thu Sep 16, 2010 4:45 am
da msuk piston enduro... Very Happy
mangketey
PostSubject: Re: Piston Enduro   Thu Sep 16, 2010 7:56 pm
piston enduro tuh bsr sgt dh..klu bleh nk yg saiz 125 lgi lar
http://man_rempitkerteh@yahoo.com
redline
PostSubject: Re: Piston Enduro   Tue Nov 02, 2010 10:22 am
kenal x piston stended 125z rupa camner?
[/quote]
ni ke piston 0.0 125z? wah... comelnya...
bujang
PostSubject: Re: Piston Enduro   Tue Nov 02, 2010 11:38 am
mar, ko pakai mainjet ngn pilot size bape?? carb pe?
http://www.facebook.com/mohdnoorhelmi
PostSubject: Re: Piston Enduro   Wed Nov 03, 2010 1:41 am
comey?wakakakaka
tu piston 125z inche redline,saiz dr 0.00 sampai ler 2.00 gitu le rupanya
assasins
PostSubject: Re: Piston Enduro   Wed Nov 03, 2010 8:50 am
pergh..... masing2 da layan piston enduro nie.......
pasti aku hanya akan bau 2t jer..... bayang asap pun x nampak.....
PostSubject: Re: Piston Enduro   Wed Nov 03, 2010 9:25 am
camner nak nampak byg asap,muto dah jem lepak tepi jalan minyak x saport sbb piston besor sgt kuikuikui
assasins
PostSubject: Re: Piston Enduro   Wed Nov 03, 2010 9:47 am
adeh..... mcm tu plak........
gilgamesh88
PostSubject: Re: Piston Enduro   Wed Nov 03, 2010 10:26 pm
carb 125 je jang...
menjet size 160,pilot ak x igt..huhu...
assasins
PostSubject: Re: Piston Enduro   Thu Nov 04, 2010 8:52 am
gilgamesh88 wrote:
carb 125 je jang...
salam bro.. nak tanya nie.. size piston enduro berapa pakai mainjet ngan pilot mcm tu? ader member pakai enduro size 1.00 mainjet 230 pilot 27.5.. tue pun cun2 jer utk long distance dia kata..
gilgamesh88
PostSubject: Re: Piston Enduro   Thu Nov 04, 2010 5:28 pm
yg ak gune size 0.0 enduro..
menjet 230 tu karb z ke???
dtk3a
PostSubject: Re: Piston Enduro   Sun Nov 07, 2010 8:41 pm
salam kawan2..nak tnya...nie.... baru2 nie ak bw jer pakai piston enduro saiz std..
tapi nak tnya saiz minjet n pilot jet yg sesuai dgn saiz piston nie...??
erm be4 nie saiz minjet ak 95 n pilot jet 20....ok ar dgn saiz tue....tp bila tukar minjet saiz 215
n pilot jet 225 , rasa mcm semput...kenapa erk..??
kalo minjet 95 adew apa2 kesan x..?? sbb bw pun 100 120 jer...belum abis pantang...lagi
PostSubject: Re: Piston Enduro   Sun Nov 07, 2010 8:47 pm
menjet 95?stended gaban pki piston 53.8mm pun dah saiz 100...
PostSubject: Re: Piston Enduro   Sun Nov 07, 2010 9:17 pm
erk sdikit confius ngn saiz mj n pj yg dgunakn tuh..knp dr saiz 95 tukar kpd 215?
dtk3a
PostSubject: Re: Piston Enduro   Sun Nov 07, 2010 9:19 pm
aah bro...be4 pakai piston enduro std. pakai minjet 95 jer std piston 125.....erm kenapa bro?? adew papew efect ker??
dtk3a
PostSubject: Re: Piston Enduro   Sun Nov 07, 2010 9:21 pm
sbb nya bro...erm ak br pakai piston enduro....erm td run 90KM ar pas tukar mj 215....semput2 ar juga...be4 nie mj 95...tapi takut myk x support to yg tukar...
adew pandangan ke bro..?? apa yg harus d buat??
PostSubject: Re: Piston Enduro   Sun Nov 07, 2010 9:27 pm
karb apa bro?95 tu terlalu kecik..tp xtau le camner cara pomen bro set
PostSubject: Re: Piston Enduro   Sun Nov 07, 2010 9:30 pm
pomen set ke bro set sendiri?try mj 130 pj 30 atau 27.5
kalo pomen yg set,abaikn saiz ni.dia lebih tau.ni utk karb stended 125z shj
dtk3a
PostSubject: Re: Piston Enduro   Sun Nov 07, 2010 9:32 pm
erm carb std 125 mikuni.......erm erm pomen ak kata ar... dia wat pun sbb nak bg save minyak....tp ak pun x tahu lah..pakai ok jer ar....ipoh KL ley ar 20 pergi blk....
tp nie ak dah pakai piston enduro..tue yg takut kalau2 pakai mj 95...takut myk x sapot. duk laju2...blow...
dtk3a
PostSubject: Re: Piston Enduro   Sun Nov 07, 2010 9:36 pm
be4 ni pomen set kan 95.....tp dia kata suh pakai 215...takut2 myk x ckp bila mj 95...sbb pakai piston enduro std...tue yg ak tukar mj 215....tp bawa rasa cam semput2....minyak cam x smpi....
PostSubject: Re: Piston Enduro   Sun Nov 07, 2010 9:41 pm
bro slh dgr x?mgkin dia ckp 115..hehehe..mgkin je..motor rs berat x?
PostSubject: Re: Piston Enduro   Sun Nov 07, 2010 9:45 pm
blok dah port blom bro?kl dah port mmg patut la ada semput2 skit..papepun kene tny pomen bro le camner sbb dia yg set
dtk3a
PostSubject: Re: Piston Enduro   Sun Nov 07, 2010 9:51 pm
tak salah ar....hehe 215 bro....tp lar nie pakai 215....erm tapi rasa berat tak juga...cuma bila full throttle rasa cam minyak x sspot jer....semput2...bila dah top...
dtk3a
PostSubject: Re: Piston Enduro   Sun Nov 07, 2010 9:53 pm
dah bro....port std piston enduro...........erm mmg camtue erk kalo dah port...sbb pertama kali bw port nie...masuk piston enduro...
ok bro..thanx atas pandangan bro...
assasins
PostSubject: Re: Piston Enduro   Mon Nov 08, 2010 8:41 am
salam bro choco.. nak tanya nie.. apsal erk, bila masuk gear 6, rpm 9 meter den baru 160 kmph.. bila rpm 9.5k meter 170kmph.. meter tu still lagi nek.. tapi kena tgu & menten full throtle.. x tau setakat nie end meter tu boleh sampai mana.. meter kuy ader probs ker ader apa2 masalah pada enjin ku Sad
Piston Enduro
Page 4 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
