 Piston Enduro
PostSubject: Re: Piston Enduro   Tue Apr 20, 2010 10:13 pm
gambar aku tu piston rd125lc,sama saiz ngan rxz tp lebih rendah dr rxz,lebih kurang sama tinggi ngan tupai punya
apiz
PostSubject: Re: Piston Enduro   Thu Apr 29, 2010 9:14 pm
piston rd125lc dgn enduro mane ag besar eh klo saiz stendet?
apiz
PostSubject: Re: Piston Enduro   Thu Apr 29, 2010 9:42 pm
dah jmpe dah info sal piston 125lc ni
n nk kongsi brsama..
DIAMETER
0 rxz = 0 enduro = 0 RD 125Lc =1.25 125z = 56mm
LENGTH
enduro=50.7mm
RD125lc=66.2mm
PostSubject: Re: Piston Enduro   Fri Apr 30, 2010 8:08 pm
maaf mencelah bro..dari maklumat tu ada sikit silap..
DIAMETER
LENGTH
enduro=50.7mm
RD125lc=66.2mm
*yang merah2 tu boleh refer kat bawah ni..
ni serba sedikit tentang spek piston yang aku ada..
harap dapat mambantu..
MODEL DT-125LC
OEM No. 10V-
BORE(mm) :A 56
LENGTH(mm) :B 65.60
PIN DIA (mm) :C 16
COMPRESSION HIGHT① (mm):D 32.60
COMPRESSION HIGHT② (mm):E 30.40
PIN LENGTH (mm) :F 16x47
PLATING O
STROKE 2
MODEL RXZ-135/RX-135Z/RX-Z
OEM No. 55G-
BORE(mm) :A 56
LENGTH(mm) :B 66.90
PIN DIA (mm) :C 16
COMPRESSION HIGHT① (mm):D 36.90
COMPRESSION HIGHT② (mm):E 35.00
PLATING O
STROKE 2
MODEL Y-125Z
OEM No. 5BU-
BORE(mm) :A 53.8
LENGTH(mm) :B 66.70
PIN DIA (mm) :C 16
COMPRESSION HIGHT① (mm):D 32.70
COMPRESSION HIGHT② (mm):E 29.50
PIN LENGTH (mm) :F 16X44.5
PLATING O
STROKE 2
soNa - 0194485713
PostSubject: Re: Piston Enduro   Sun May 02, 2010 8:36 pm
kiri tue piston rxz..
joe,belah knn tu piston aper?dah 3-4 biji piston camtu aku pki tapi xtau name..
PostSubject: Re: Piston Enduro   Sun May 02, 2010 8:46 pm
piston enduro dt125 la bro,over size kt block 125z dgn port super saiya,size 1.50,tapi akhirnye tumpas jua kt LPT time hari raya haji thn brape tah,sbbnye lupe bkk 2t besar skit,campur pun x,trs full throttle melayan katak2x lizer sekalian,mmg aku jela duk dpn,pstu kene tunda
PostSubject: Re: Piston Enduro   Sun May 02, 2010 8:50 pm
lorr,kok gitu aku dah pernah pki ler piston enduro ceitt
aku ada saiz 1.00 punya,nak?
PostSubject: Re: Piston Enduro   Sun May 02, 2010 8:52 pm
xnak ar aku,nk buat ape?,klu ko nk piston tue amik la,blh pakai lagi,kene gosok ngan sine paper ok la die..
PostSubject: Re: Piston Enduro   Sun May 02, 2010 8:55 pm
ko kene pikir masa depan joe,ko dah pki saiz 2.00 dah skrg,lambat bangat kompem ko kene pki gak size tu,beli la ngan aku..
PostSubject: Re: Piston Enduro   Sun May 02, 2010 9:01 pm
xnak ar,aku beli kt kedai baru lagi baik klu dah kondem nnt sumbat piston 0.0 enduro dt125..
piston TE japan = rm32
ring TP or RK japan = rm25
labour lay block = rm8
mmg tip top condition la,har3x..tapi skrg layan block standard je,ha3x..
PostSubject: Re: Piston Enduro   Sun May 02, 2010 9:30 pm
ko dah x pki ker blok 2.00 tu?tolak kat aku la murah2
PostSubject: Re: Piston Enduro   Sun May 02, 2010 9:35 pm
aku pakai le de..saje je nk melayan block standard,kesian tgk block tue byk karbon,so nk cuci block tue pakai maxoil,he3x..
PostSubject: Re: Piston Enduro   Sun May 02, 2010 9:47 pm
jap nak yane,so aku klau nak pakai enduro ni kene rebore sampai 2.00 ke atau 2.25 baru dapat masuk saiz 0.0 enduro?ade ke jual 0.0 enduro?
PostSubject: Re: Piston Enduro   Sun May 02, 2010 9:53 pm
0.00 enduro tu sama ngan piston saiz stended gaban enduro ler wan
saiz stended gaban enduro sama ngan stended gaban menyelam rxz = 56mm
2.00 tupai = 55.75 lebih kurang..so bl blok dah calar rebore skali lg baru bleh sumbat saiz enduro 0.00
PostSubject: Re: Piston Enduro   Sun May 02, 2010 10:01 pm
btl2x,saiz 0.0 enduro besar skit je dari 2.0 125z
PostSubject: Re: Piston Enduro   Sun May 02, 2010 11:42 pm
erm.. pomen aku penah ckp..pakai blok racing 56mm..mmg siap2 dpt piston enduro..tp tahla..aku pon tak pasti..
PostSubject: Re: Piston Enduro   Mon May 03, 2010 1:31 pm
block racing mmg kne pkai piston enduro sbb stroke pendek sket dr blok standard 125z..
kalo blok racing masuk piston standard kne pkai gasket blok/head 5-6 keping gasket.
nguahaha..
PostSubject: Re: Piston Enduro   Mon May 03, 2010 2:25 pm
nguahaha..
eh?tinggi blok resing ngan blok stended sama je..kecuali kl tuan blok tu dah skim blok kaw2
lg satu yg pernah aku beli 2 kali la,blok resing x pernah dtg ngan piston enduro,sumer datang ngan piston 125z,tp saiz gaban besar(57mm)
yg plg x bestnyer piston yg dtg ngan blok tu x tahan..aku ngan kawan aku pki jadi jahanam,aku punya tembus tgh,kawan aku punya sumbing tepi
sANi bUAs
PostSubject: Re: Piston Enduro   Mon May 03, 2010 4:06 pm
pendek sket dr blok
standard 125z..
nguahaha..
ala bro..skunk nie zaman da maju..xpyh nk pki byk2 keping gasket..
bleh tempah,bp tebal yg kte nak..
gilgamesh88
PostSubject: Re: Piston Enduro   Sun Sep 12, 2010 7:20 pm
saye nk tnye sket...
skg ni ak tgh plan nak msuk piston enduro kerane calar dlm gile b**i...
menjet nak kne pakai size brpe klo pakai piston nih???
pilot nak kne up jugak ke?
(carb 125z cume asah jarum je..)
PostSubject: Re: Piston Enduro   Sun Sep 12, 2010 7:35 pm
gilgamesh: cte la sket mainjet n pilot brape saiz time calar aritu.. then blok dh port ke blom? set kotak angin bukak ke standard ke tebuk ke.. head standard ke dh skim ke.. hehe..
*raye dtg rumah weh.. tmn sri wangsa, pt besor..
gilgamesh88
PostSubject: Re: Piston Enduro   Sun Sep 12, 2010 11:45 pm
ultra: yes en.ultra ade...cheers cheers
skg ni blok saiz 1.00, da porting ekzos ngan minyak, head skim 3mm, kotak angin xde,
menjet 130 pilot 20...
*moto siap ak trus g umah ko...hehehe...
PostSubject: Re: Piston Enduro   Mon Sep 13, 2010 3:37 am
gilgamesh: uih.. keciknye mainjet ko.. aku dlu pkai blok piston 0.50 pn pkai mainjet 145 carb 125z.. hehehe.. porting lain2, tu yg lain setting.. apepn aku rase masuk piston enduro try dari 150.. pastu cek kaler plug.. pilot maintain je..
gilgamesh88
PostSubject: Re: Piston Enduro   Mon Sep 13, 2010 4:06 am
ok bro TY...
siang nnt ak try...
mangketey
PostSubject: Re: Piston Enduro   Thu Sep 16, 2010 2:46 am
korang xde ker blok 125 yg lebih2..klu ader roger2 lar kt aku..aku tgh mncri nih
http://man_rempitkerteh@yahoo.com
Piston Enduro
Page 3 of 8Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
