aus_ipoh Laksamana Armada
Posts : 2936 Join date : 19/05/2009 Age : 31 Location : ipoh dan kawasan yg sewaktu dengannya
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Wed Oct 21, 2009 7:28 pm | |
| nk g tuka wiring meter la..da xda lampu apa pon kat meter..heh _________________ M125ZC  terus pecut sampai perut kecut |
kelvin45 Support Crew
Posts : 745 Join date : 19/04/2009 Age : 29 Location : Putrajaya,Dengkil,Semenyih,Kajang.....
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Wed Oct 21, 2009 7:36 pm | |
| - aus_ipoh wrote:
- nk g tuka wiring meter la..da xda lampu apa pon kat meter..heh
Bulb semua dah blow wei.........hahaa........... Tukar semua.......1bijik RM1.............^^ |
Posts : 1556 Join date : 12/09/2009 Location : shah alam/puchong/saujana putra/kuala pilah
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Wed Oct 21, 2009 7:41 pm | |
| aku ade gak prblm bateri nih dlu.. motor lame da xidup..
kadang ade wire dalam putus xtau... aku ingatkan bateri... da tukar bateri tengok problem lagi... nih kes aku la.. die bypass jer cable yang ptus dalam tuh.. cane die detect aku xtau... tapi pomen kg. aku tuh pndai gak..
da rugi .. ade 2 bateri lak.. huhuhu... skang nih ujung cable yang ad besi skru tuh da patah.. aku sumbat jer ujung kabel yang ade besi tuh kat lubang skru bateri tuh... ok jer.. kalau ad spark, mask .. seblah tank jer.. huhu.. _________________ blind and could not see, deaf and could not hear, stupid and could not understandBayerische Motoren Werke |
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Wed Oct 21, 2009 8:03 pm | |
| khe3x,spark tue maby xlarat nk hidupkan sumber dari petrol,harap2 la  |
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Thu Oct 22, 2009 9:04 am | |
| hehe.. harap2 gitu la.. malang xleh dicium.. =D _________________ blind and could not see, deaf and could not hear, stupid and could not understandBayerische Motoren Werke |
ihsanxx Laskar Muda
Posts : 70 Join date : 09/07/2009 Age : 31 Location : Pantai Melawi
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Fri Oct 23, 2009 1:12 pm | |
| okay2...
skg nie adakah masalah wiring nih ada kaitan dengan meter untuk minyak nyer??
sbb ak nyer meter sentiasa full (jem la..) kire nyer cam shock la kut...
pastu ak try cabut connection dengan pelampung dalam tangki tu mse on ignition..
pastu meter tu drop sampai empty...cucuk balik meter tu top balik.... nape eh??
ada kemungkinan litar dalam meter tu je rosak (tuk meter miyak jela) ataup0n wiring aku nyer dah bengong...??
tp kan klu wiring aku xrosak..maknanya meter aku la rosak?? aduh la..syg btol la meter jenis lama nih..xleh ke repair letronik tu??
hehe...tp klu btol rosak kn bli br ar...susah tol nak bajet minyak |
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Fri Oct 23, 2009 2:52 pm | |
| - ihsanxx wrote:
- okay2...
ade.. sbab aku penah kene... regulator xjalan... charge xmasuk bateri... skang nih, kabel yang smbung ke bateri tuh da putus, so, charge xmasuk... mmng meter minyak xjalan... ade kes aku kene, mase tengh jalan, charge xmsuk, meter minyak tunjuk minyak ade suku jer, padahal aku da isi minyak penuh... bile on, lampu N xnyale... bile smbung kabel tuh kat bateri, die ok.. check dlu bateri, pnjam mane2 bateri, tukar dlu tengok... t kang abis duit tukar wiring... _________________ blind and could not see, deaf and could not hear, stupid and could not understandBayerische Motoren Werke |
ihsanxx Laskar Muda
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Fri Oct 23, 2009 3:28 pm | |
| skg btry da baru..wayar kat bateri (+ dan -) sumer ok..lampu lain sme nyaler...ok
hon bun kuat gaban...br tukar btery la katakan..
cuma yang saspek meter@pelampung rosak...tp pelampung tgki pon aku dah tukar..
jadi kemungkinan besar meter tu la rosak kot...xpon wire yg hubungkan batery ng indicator minyak yang jem@trputus... |
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Fri Oct 23, 2009 3:42 pm | |
| so ade 2 possibility:
1 - kabel ke meter putus 2 - cable ke indicator putus
cube solve yang 1st dlu.. pnjam meter 125 member ko tengok... try on jer... meter nek tak... _________________ blind and could not see, deaf and could not hear, stupid and could not understandBayerische Motoren Werke |
venom Laskar Kanan
Posts : 343 Join date : 03/04/2009 Age : 43 Location : Semenyih - KL - Semenyih
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Fri Oct 30, 2009 11:38 am | |
| aku punya bateri pun baru kong ni... siot, tgh² kering dia buat hal... abis la budget utk makan... huhuhu...
susah la kalau naik motor bateri kong...signal, bateri mcm malu² nak nyala, mcm tak sempurna hidup...bahaya...
tapikan..kalau dah tukar bateri baru, kenapa ye bila tekan brek, pastu on signal...dia mcm berkongsi power. lampu indicator kat meter terang tapi bila signal on kureng terang...sikit jer la.. |
Posts : 2181 Join date : 26/04/2009 Age : 32 Location : cheras
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Fri Oct 30, 2009 11:57 am | |
| - venom wrote:
- aku punya bateri pun baru kong ni... siot, tgh² kering dia buat hal... abis la budget utk makan... huhuhu...
tapikan..kalau dah tukar bateri baru, kenapa ye bila tekan brek, pastu on signal...dia mcm berkongsi power. lampu indicator kat meter terang tapi bila signal on kureng terang...sikit jer la.. ngaaa...bateri punya hal spi x dpt mkn en.venom bateri x cas penuh ler tue...pki bateri maintainance free jer cam ak nie...dr bulan 5 2008 spi skang ok jer bateri tue... xpayah usha2 air or masalah serbuk putih kt connecter tue... _________________  |
Posts : 1565 Join date : 04/04/2009 Age : 31 Location : Sentul KL
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Fri Oct 30, 2009 2:53 pm | |
- update..
kt tempat aku ade jual wiring jns lame,first model,yg xde wiring untuk lampu ke 3.. rm=30..
ori ke joe? |
venom Laskar Kanan
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Fri Oct 30, 2009 4:26 pm | |
ihsanxx Laskar Muda
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Fri Oct 30, 2009 6:03 pm | |
| btol duh...aku nyer kabel cam tu gak..yang connector antara batery ngn wiring tuh...rupa2 nyer wayar dia cam dah reput dah... tapi aku buang penebat tu cket pastu sambung kat klip (tmbaga) tu dgn player jer...pasal reput tu wat dono jer..da mende2 berumur besa la.. last2 ok la...kelip2 cket2 tu jap je... dah lama2 lenjan ok la...  batery yang kuar putih2 tu upe2 nyer dah hampir expired..ble tukar yg baru xde dah serbuk2 putih tu.. |
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Fri Oct 30, 2009 6:07 pm | |
| - WKQ4913 wrote:
- ori ke joe?
xori,tapi blh pakai la.. |
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Fri Oct 30, 2009 6:10 pm | |
| aku selalu tgk kt mende tue,klu ade serbuk2 putih buangkan die n sembur dgn ngan wd40 or seangkatannya,klu x mmg sng reput  ,klu nk wiring tahan lama,belah perut kt bawah die,so bile basuh moto or moto kene hujan,air xbertakung duk dlm penebat wiring.. |
ihsanxx Laskar Muda
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Fri Oct 30, 2009 6:13 pm | |
| joe..klu yg model baru skg brape ek?? |
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Fri Oct 30, 2009 6:29 pm | |
| aiseh,xsure la bro,spare part kt tmpt aku xde jual yg jns baru,nnt ade aku update.. |
ckua Support Crew
Posts : 421 Join date : 27/10/2009 Age : 25 Location : Kuantan,Pahang
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Sat Oct 31, 2009 10:01 am | |
| bro klu aku nyer signal x berkelip.. coz aritu aku bru tukar bateri baru n wayar bateri baru... aku xtahu wayar mana salah pasang.? |
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Sat Oct 31, 2009 4:57 pm | |
| tue relay nyer problem,mungkin loose connection or xpsg kt relay tue,relay yg ade tulisan mitsuba,bentuk petak warna hitam,mende nie jgk digelar flasher,mende nie duk kt handle moto ko,bile cabut cover hitam meter,mende nie akan muncul.. |
S-T-P Laskar Kelas I
Posts : 185 Join date : 07/07/2009 Age : 30 Location : Jasin melaka
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Sat Oct 31, 2009 10:20 pm | |
| kalu ig semua x nyala bile start lampu belakng,depan,meter and highbem indctr jer yang nyala. lain semua x da. ader saper2 tau??? |
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Sun Nov 01, 2009 8:28 am | |
| - S-T-P wrote:
- kalu ig semua x nyala
tue bateri dah kong la bro,kasi tkr bateri baru la  |
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Sun Nov 01, 2009 9:11 am | |
| bateri ok.check guna multimeter |
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Sun Nov 01, 2009 9:29 am | |
| emm..dpt 12volt ek?,dah try swap ngan bateri lain?,klu bkn sbb bateri punyer prob mungkin fius yg warna merah@biru kt sebelah die dah burn,try cek pakai meter..
Last edited by superjoemanito on Mon Nov 02, 2009 12:38 am; edited 1 time in total |
ihsanxx Laskar Muda
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Sun Nov 01, 2009 8:18 pm | |
| aku nyer pon camtu gak aritu...tapi wayar nyer je yang problems...
btol kt joe..try check fius dia...yang dalam kotak hotam signal tu ker..
fius tu klu xsilap yang wane biru antara wiring ngn terminal bateri...
klu slh tlg betol kan... |
 | Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x  | |
