| | Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 | |
+34nazjb puex mazakim pais924 haizamlee fishbike YashaKami koie06 yi_tupaijek01 epol_langgar alry_89 paan1171 vendetta fizerpool chiekamaruz osiris xapex azdli90 roda karat gilgamesh88 absolute_ahben wormzx madie apiz superjoemanito Ultra-Z man JGN8917 -angah- geeks komi WKQ4913 chocolate tupai comel mantadkb 38 posters | |
laporpo_laporno Laskar Muda
Posts : 90 Join date : 28/05/2010 Age : 33 Location : Penang
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Mon Oct 18, 2010 7:20 pm | |
| ouh.. aku nye block 1st model,dh 2 kali korek,n ade kesan calar kat sleeve..syg gile.. aku lak dok penang n stdy kat alor setar,tiap2 mnggu blk umh.. biasenye kalo ats highway 2 aku dok rembat 120,140 n 160km/h.. so kalo aku nk sumbat piston rxz,block x yah usik pape ke..? just modi kawah head je..?carb plak mcm mne..? | |
| | | tupai comel Pegawai Kadet Kanan
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Mon Oct 18, 2010 7:41 pm | |
| maksud korek tu..rebore blok ke? baru 2 kali = 0.50..kecik lg tu.. setakat nk tutup calar kt sleeve blok tu..rebore skali je dah cukup..tak perlu la smpai masuk piston rxz.. pd aku..piston 125z bwh 1.00 masih dikira kecik..atas tu semua da besa..da tak sedap melayan topspeed.. kalau nk masuk piston rxz jgk..terpulang la.. modi head..kene modi betul2..salah modi mcm2 akibat..kt head tula pusat compression tenaga before pergi ke exhaust..bace post yg lepas2 berkaitan head..aku tak tau... carb..sudah semestinye kene setting balek.. laen blok..laen piston..laen comrpession..laen setting.. sekali ceburkan diri dlm modifikasi.. takde bende yg boleh plug n play je..awas... !! ekekeke | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Mon Oct 18, 2010 7:57 pm | |
| em..porting bro.. piston n head still stended.. kalo mcm 2 baek pkai piston 125z je kn.. n rebore utk ilangkan kesan calar kat sleeve tuh.. act moto dah 9thn,dlu ayh pkai ulang alik keje subang-kinrara.. start pndh penang je moto 2 dpt kat aku..keh3 tp moto x pnh overhaul skali pn even kerap merembat n long distance..x pe ke ek..? | |
| | | geeks Laksamana Armada
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Tue Oct 19, 2010 9:57 am | |
| - laporpo_laporno wrote:
- em..porting bro..
piston n head still stended.. kalo mcm 2 baek pkai piston 125z je kn.. n rebore utk ilangkan kesan calar kat sleeve tuh.. act moto dah 9thn,dlu ayh pkai ulang alik keje subang-kinrara.. start pndh penang je moto 2 dpt kat aku..keh3 tp moto x pnh overhaul skali pn even kerap merembat n long distance..x pe ke ek..? motor kalau enjin still running smooth, pade aku ok je.. pakai minyak hitam baik sket, pakai la motul 5100, transoil ke, eo diesel pun leh gak, tapi kene campur lah.. bace thread yang lepas.. tapi kalau nak overhaul balik bagus gak.. tukar bearing kat crankshaft tuh, amik bearing ceramic.. bearing2 lain pun tukar sekali, mungkin dah makan, check balik umah bearing, tukar rod piston & crankshaft original baru, walaupun rod tuh mungkin ok lagi, kut aku, aku tukar jer.. tukar gear 4 & 6 @ 6 rxz je.. baik punyer.. .. yang lain-lain... ikut kesesuaian lah.. | |
| | | softoperator Laksamana Armada
Posts : 702 Join date : 12/01/2010 Age : 35 Location : kl
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Tue Oct 19, 2010 10:11 am | |
| aku nye yamaha sukan da 14 taon pki xpnh oberhaul..ok jerk...hahahaha... | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Tue Oct 19, 2010 10:23 am | |
| pakai nih pun ok.. rod & crankshaft tak yah tukar.. pakai yang asal, tukar bearing jer.. | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Tue Oct 19, 2010 10:50 am | |
| owh mcm 2.. bearing 2 brape hrge bro..? slalunye org tukar brpe ketul..? kalo pkai bearing nih bg effect pd performance mto x..? n gear 6 rxz tuh tukar gigi sje ke..? kalo tukar pkai gear box rxz bole x..? huhu.. | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Tue Oct 19, 2010 1:52 pm | |
| pakai gear 6 rxz.. respon shift gear dr 5 ke 6 sgt mantap.. bahasa mudah..gear 5 tuka gear 6 terus pecut..ala2 powervalve gitu.. tp ratio gear 6 ni tggi.. menten topspeed?? rpm mungkin da 9 10..tp speed tak pegi mane pon sbb ratio yg tggi... (umpama pakai sproket besa) | |
| | | Guest Guest
| | | | paan1171 Support Crew
| | | | yi_tupaijek01 Leftenan Madya
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Tue Oct 19, 2010 9:48 pm | |
| owh.. bunyi mcm best gile.. ni yg gatai tgn nk sumbat gear 6 rxz nih.. tp brand ape yg elok ea..? kalo nk buat brape kos..? | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Tue Oct 19, 2010 10:49 pm | |
| masuk gear 6 rxz..moto meraung mntk gear je kang.. kalau nk maen sekilo..berbaloi kot pakai gear 6 rxz..sbb dlm sekilo tu..every second is crucial.. shifting gear kene betol..respons pada permulaan setiap gear sgt penting.. tp kalau nk wat daily?? terpulang la..
gear 6 rxz tp kecikkan sproket?? pada top gear mungkin dpt topspeed yg sama.. tp dr gear 1-5..pikap lemau la..sproket kecik kan.. | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Tue Oct 19, 2010 11:27 pm | |
| alamak.. ni yg x sdp dgr ni.. bru je nk sumbat gear 6 rxz utk long distance ride.. bri TC kalo gear 6 rxz utk long distance sdp x..? | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Tue Oct 19, 2010 11:51 pm | |
- alamak..
ni yg x sdp dgr ni.. bru je nk sumbat gear 6 rxz utk long distance ride.. bri TC kalo gear 6 rxz utk long distance sdp x..? pada hemat aku,xda hal nk pakai gear 6 rxz pon...cuma kne pndai set spoket,lg mantop adalah...kalo pakai gear stended 125z,dr gear 5 nk masuk gear 6,rpm jatuh byk,kdg2 xdpt cover balik rpm yg jatuh tu,clap aribulan topspedd terduduk,lebih2 la pd mereka yg pakai spoket kecik2..bg long distance mgkin ok,sb dpt cover rpm jatuh tu dlm ms yg lame...tp akibat lg truk bila lalu jln berbukit (memg jln malaysia ni berbukit) lg truk bg yg spoket kck2 tu... 1 lg aku xphm,mostly pomen pakai ratio spoket besar utk motor dorg,ada smp 14-39(daily ride)...mgkin ada sb tertentu yg kite xtahu | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Wed Oct 20, 2010 12:00 am | |
| owh.. bro nk tnye kalo gune gear 6 rxz n spoket 15-38 428 utk long distance cun x..? moto berat ke lembab ke..? | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Wed Oct 20, 2010 12:03 am | |
| xle nk jwb r soalan tu...sb tgk pd blok n setting jgk..kne try n error la pasal spoket ni... setting spoket ni paling last org bt,slepas setting enjin.. | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Wed Oct 20, 2010 12:05 am | |
| owh.. mcm 2 plak.. nk tnye block nye max port brpe kali ek..? sbb block aku pomen port manje2 je.. | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Wed Oct 20, 2010 8:28 am | |
| ko keliru istilah ni antara port ngn rebore...tp kalo port,kene ekt stage,stage 1 smp last stage(xtau brape) 4 kot..hehhe...tgk pd kepakaran pomen tu jgk... | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Wed Oct 20, 2010 9:26 am | |
| 1. porting & polishing.. 2. porting sahaje.. 3. polishing sahaje..
ketige-tige point nih memang effect kan performance, cume aku masing ragu-ragu tentang effect point-point nih... boleh eksplenkan?..
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Wed Oct 20, 2010 11:30 am | |
- ko keliru istilah ni antara port ngn rebore...tp kalo port,kene ekt stage,stage 1 smp last stage(xtau brape) 4 kot..hehhe...tgk pd kepakaran pomen tu jgk...
erk,act mmg aku keliru pn..huhu! tp kan,mse aku 1st bikin moto pomen ade tnye block nk korek ke x..?aku pn ckp korek je (pdhl x tau amende pn) then test naik mmg syok gile la.. 3 bln pas 2 nk g servis pomen 2 tnye lg nk korek lg skali ke..?aku pn ckp la 2 3 4 kali pn xpe..huhu tp pomen 2 ckp x leh la korek bnyk2 kali sbb yg lain sume stended..aku follow je pomen 2 ckp.. almaklumlah bdk baru..huhu! | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Wed Oct 20, 2010 11:50 am | |
| pomen tu dh ckp btol...korek = port...hehehe..xpela..blaja slow2..same2 blaja...brape modal kne nk korek tu bro? | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Wed Oct 20, 2010 12:07 pm | |
| mse 2 aku g servis skali..then die korek.. tukar gasket n plug.. die cuci block,head dgn piston gune machine.. x pkai sandpaper pn..clean gle.. total sume rm75.. ok x..? | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Wed Oct 20, 2010 12:16 pm | |
| ok la tu kalo dia korek skali...siap setting kn? | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 Wed Oct 20, 2010 1:32 pm | |
| eh,xde.. setting lebey kurang 6bln pas aku korek utk kali kedue.. time 2 kne rm170.. setting carb (sumbat rxz catl),buang karbon ekzos,servis block,head,piston,mnyk itam ape smue.. huh! rm170 tuh..huhu! | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V2 | |
