| Segala Persoalan V19 | |
+50EmpatBelasRatus comebackid amil7709 pedo88 jmg235 addin77 Ijat Stylo iqram iez WanttofightZack chocolate nazjb bdk_sesat96 redline mat lam ajizaimi jacob soNa Lok Lok kenzou Kato_125 sauf125z absolute_ahben adeqyana eddy8075 h@ziQ hyuhuu letak_pisang NCH_KU samporna ccn sherlock nurkaye_akmal EjanNiz MCB zouk188 aloy devilmeasha unknownh xopai JJR2395 payjalrazali babet jokker mrbean superjoemanito -sLip- Azrul mazakim 125z ganu Shark pfa ahmag 54 posters |
| Subject: Re: Segala Persoalan V19 Wed Jan 25, 2012 9:04 pm | |
| - aloy wrote:
- unknownh wrote:
- aloy wrote:
- ade sape2 yang boley tolong x...moto aku problem kalau handle pusing ke kanan enjin mati...kalau ke kiri ok je...
wiring kot.cuba cek.. wiring ape yang nak kene check...kalu nak wat pusingan ke kanan kene main throttle, kalau x mesti enjin semput2 pas tu mati.. kabel throttle aku dah abeh ejas xbley gak... cer ko tinggi kan timing dulu pastu pusing handle ke kanan, klu masih nak mati jugak ada wiring prob ler tuh, klu x mati ada masalah ngan kable throttle ko tuh, dabel check lagik kat mana dia sangkut.... | |
unknownh Bintara Kanan
| Subject: Re: Segala Persoalan V19 Wed Jan 25, 2012 9:23 pm | |
| - aloy wrote:
- unknownh wrote:
wiring kot.cuba cek.. wiring ape yang nak kene check...kalu nak wat pusingan ke kanan kene main throttle, kalau x mesti enjin semput2 pas tu mati.. kabel throttle aku dah abeh ejas xbley gak... mungkin jgk tu.kabel throttle | |
aloy Laskar Kanan
Posts : 250 Join date : 19/07/2010 Age : 34 Location : Kuantan~Shah Alam
| Subject: Re: Segala Persoalan V19 Wed Jan 25, 2012 9:43 pm | |
| - mazakim wrote:
- aloy wrote:
- unknownh wrote:
wiring kot.cuba cek.. wiring ape yang nak kene check...kalu nak wat pusingan ke kanan kene main throttle, kalau x mesti enjin semput2 pas tu mati.. kabel throttle aku dah abeh ejas xbley gak... cer ko tinggi kan timing dulu pastu pusing handle ke kanan, klu masih nak mati jugak ada wiring prob ler tuh, klu x mati ada masalah ngan kable throttle ko tuh, dabel check lagik kat mana dia sangkut.... dah tinggikan timing still nak mati gak...kene check wiring la ni...TQ kalo xbley gak anta soh pomen tengok la sok... | |
aloy Laskar Kanan
| Subject: Re: Segala Persoalan V19 Wed Jan 25, 2012 10:40 pm | |
| dah setel...rupenye kabel choke yang sangkut kat blah kiri...patut la enjin mati bile pusing handle ke kanan... | |
125z ganu Laskar Kelas I
Posts : 164 Join date : 31/10/2011 Location : Kelate-Terengganu
| Subject: Re: Segala Persoalan V19 Thu Jan 26, 2012 12:52 pm | |
| Persoalan aku,125z ni kalo tambah wayar earth ke body ok @ x? cthnyer dari terminal ( - ) negative ke body,dari coil ke bodi dan lain2 yg boleh di earthkn ke bodi atau x payah,yg asal biar mcm tu dah ok,x yah gatal2 jari jemari nk tambah2 kot2 ada efek yg buruk
kalo dah ada yg bt bg info sikit,sekian terima ksh
zouk188 Laskar Muda
Posts : 74 Join date : 17/06/2009 Age : 39 Location : USJ Subang Jaya
| Subject: Re: Segala Persoalan V19 Thu Jan 26, 2012 11:10 pm | |
| bro, nak tya kat area selangor ni kat mana kedai nak cari cat untuk spray moto pkai air gun?? bkn spay tin.. ak nak li cat sahaja untuk spay moto..
ada sesiapa tau?? | |
MCB Laskar Muda
Posts : 4 Join date : 19/01/2012
| Subject: Re: Segala Persoalan V19 Fri Jan 27, 2012 11:14 am | |
| assalamualaikum. aku baru pasang kt moto aku 2 ari lepas. perubahan yg dpt dirasai setakat ni:
1. pikap bertambah. moto aku sebelum ni kalo naek bukit je mesti kantoi (spoket 15-37), tapi semalam pakai gear 6 pon larat lagi. terasa la pegi die tu.
2. nak dapat top macam cepat. tapi aku belum try betul2 top sebab jalan tak panjang.
3. pagi2 start ada beza kot (ataupon perasaan aku jek). 2, 3 kali tendang enjin da stable xperlu maen2 minyak. sebab function die stabilkan arus kot.(tulis kat kotak)
4. jimat minyak. haa yang ni aku belum rasa lagi jimatnya. sebab baru sehari dua sarung.
tapi yang aku tak faham cmane benda ni buat keje. yelah, nak pasang die mcm simple gile. bentuk die mcm gegelung cincin. cabut kepala kabel plug tu then masukkan natang ni. pastu pasang balik kepala kabel plug tu then cucuk kt plug cam biasa. pelikkan?
p/s : moto aku jadi bahan eksperimen sebab adek aku ni dealer ntang ni. so die nak uji kat motor 2 stroke pulak. dgr kabar, bdk2 LC sangap natang ni. ada yg pasang sekali 2, 3 kat kabel plug tu. aku try motor lc adek aku terangkat2 gak gear 1 2 3 die sebab die sarung 2 bijik skali. (aku bukan nk promote sekadar berkongsi) wassalam. | |
EjanNiz Laskar Muda
Posts : 56 Join date : 10/05/2011 Age : 29 Location : Semenyih/Kajang/Cheras/Balakong
| Subject: Re: Segala Persoalan V19 Fri Jan 27, 2012 8:28 pm | |
| Coil api 125zr oringinal berape RM ? nk pasang kat ex5 | |
zouk188 Laskar Muda
| Subject: Re: Segala Persoalan V19 Sat Jan 28, 2012 1:09 am | |
| coil starter atau coil plug? | |
EjanNiz Laskar Muda
| Subject: Re: Segala Persoalan V19 Sat Jan 28, 2012 1:56 am | |
| entah la, tapi member aku cakap kalo ex5 pakai coil api 125 boleh cecah 140-160kmh | |
| Subject: Re: Segala Persoalan V19 Sat Jan 28, 2012 11:35 am | |
| - EjanNiz wrote:
- entah la, tapi member aku cakap kalo ex5 pakai coil api 125 boleh cecah 140-160kmh
mcm pyh gk la ex5 blh pegi sampai 1 nam bile pakai c.plug 125z je,mesti ade modi2x lain punye,bocor piston awal2x dulu pastu 125z tunde dlm 1 nam dpt la aku rase.. | |
| Subject: Re: Segala Persoalan V19 Tue Jan 31, 2012 2:19 am | |
| salam...mcm mana teknik betol utk polish coverset?
bukan polish set yg baru mmg dh kilat....tp polish set2 yg season...
anyone know? | |
Azrul Laskar Kelas I
Posts : 146 Join date : 24/01/2011
| Subject: Re: Segala Persoalan V19 Tue Jan 31, 2012 11:41 am | |
| sbelum ni aku pkai piston 0.50.. mse pkai piston ni mainjet aku saiz 190 carb Z..skunk aku baru rebore blok pkai saiz 1.00 .. mainjet nk kna set lain ke ?.. | |
nurkaye_akmal Pegawai Waran I
| Subject: Re: Segala Persoalan V19 Tue Jan 31, 2012 1:02 pm | |
| - babet wrote:
- salam...mcm mana teknik betol utk polish coverset?
anyone know? kalo nk polish coverset, seelok-eloknye hantar kt kedai polish kete je, kalo polish gune tangan tk berape nk cantik, kalo hantar kt kedai dye ade tool dye ngan bahan wax dye yg btol2 tuk polish nye, cume bayar mahal skit la kot | |
| Subject: Re: Segala Persoalan V19 Wed Feb 01, 2012 10:45 am | |
| - Azrul wrote:
- sbelum ni aku pkai piston 0.50.. mse pkai piston ni mainjet aku saiz 190 carb Z..skunk aku baru rebore blok pkai saiz 1.00 .. mainjet nk kna set lain ke ?..
bwk dulu tgk camne feeling dia, klu rasa ok cam bese xyah ler setting carb tuh tp klu rasa len mcm baru la setting... | |
| Subject: Re: Segala Persoalan V19 Thu Feb 02, 2012 6:49 pm | |
| - mazakim wrote:
bwk dulu tgk camne feeling dia, klu rasa ok cam bese xyah ler setting carb tuh tp klu rasa len mcm baru la setting... aku bwak moto rasa mcm biasa jew..tngk color reading plug pon oke.. tgh2 dye hitam , tepi2 pon hitam juga..rasa2 nye x pyh tukar mainjet da kot kn ? | |
| Subject: Re: Segala Persoalan V19 Thu Feb 02, 2012 7:00 pm | |
| - Azrul wrote:
kalau ko btol2 nak tau moto ko dah cun,ko xleh cube bawak moto tu slow,atau biase..xkan ada error...cube ko tarik,ko main long...ada pape x..itu baru btol nk check setting moto dah ngam ke blum.. | |
sherlock Laskar Kanan
Posts : 247 Join date : 07/01/2010 Age : 35 Location : jEnGkAx to BanGi...
| Subject: Re: Segala Persoalan V19 Thu Feb 02, 2012 10:06 pm | |
| salam,Adakah plug reading sbelah laen2 mnunjukkn pembakaran yg kurang sempurna...??? blok calar b'kemungkinan x...??? compress kurang...??? sori kalo da de post tntg nie.. | |
| Subject: Re: Segala Persoalan V19 Mon Feb 06, 2012 2:05 am | |
anyone know? kalo nk polish coverset, seelok-eloknye hantar kt kedai polish kete je, kalo polish gune tangan tk berape nk cantik, kalo hantar kt kedai dye ade tool dye ngan bahan wax dye yg btol2 tuk polish nye, cume bayar mahal skit la kot mmg ada bercadang nk bwt....tp brp harga upah polish tu....mmg keje dia puas hati ke?? anyone penah bwat.... | |
EjanNiz Laskar Muda
| Subject: Re: Segala Persoalan V19 Tue Feb 07, 2012 3:20 pm | |
| 125zr standard kuar kilang timing 2T dia bape benang ? | |
samporna ccn Laskar Kelas II
Posts : 876 Join date : 06/05/2010 Age : 32 Location : jengka <- gambang -> kuantan
| Subject: Re: Segala Persoalan V19 Tue Feb 07, 2012 8:15 pm | |
| - EjanNiz wrote:
- 125zr standard kuar kilang timing 2T dia bape benang ?
ak pnye ari tu kuar kdai xde lngsung benang nmpk ak ase.. hahahha..tp skrg ak da bka sket je..nmpk sket alur pertma... | |
| Subject: Re: Segala Persoalan V19 Tue Feb 07, 2012 8:21 pm | |
| ak nk tnye.. pe tnda2 beteri da xelok ey??? beteri asal mto lg.. mto thun 2010.. da tpop air bateri, try running... pastu matikan enjen n on suiz, lmpu N ngn merah idup cerah.. tp 1week lpas tu running sane sni, ak cek smula mse enjen xidup lmpu N ngn mearh malap.. spe tau pe msalah mto ak ni????? ak ase da pnh ad org tny tp nk survey 1 1 tenet brat.. lg pun klu tny smula ni msti lg bnyk kn pndpat yg ak dpt.. heheheh.. | |
NCH_KU Bintara Muda
Posts : 524 Join date : 19/06/2010 Location : gemencheh
| Subject: Re: Segala Persoalan V19 Tue Feb 07, 2012 8:32 pm | |
| Subject: Re: Segala Persoalan V19 Wed Feb 08, 2012 2:29 am | |
| pe kate try gie charge dlu bateri 2... | |
| Subject: Re: Segala Persoalan V19 | |
