| Segala Persoalan V8 | |
+45ariffm0hd doktahu_TAQ7196 unknownh ak WKQ4913 fizerpool anep4742 buntat Ultra-Z kyrasbc 23sh0pah0lic man JGN8917 chrome Kaer geeks eddy8075 tupai comel hanturaya111 haizamlee KbQ4468 WTY 4666 tupai_tempur xapex fishbike vendetta Ezad yi_tupaijek01 superjoemanito Hanomichi89 mantadkb sherlock alpazz ramdzi absolute_ahben kemeja kotak mousepink chocolate imanhalimi pais924 paan1171 kenzou ajizaimi azdli90 fareez91 mazakim 49 posters |
| Subject: Segala Persoalan V8 Tue Aug 03, 2010 4:25 pm | |
| Rumah lama :~>> http://125z.forumms.net/diskusi-bengkel-diy-f5/segala-persoalan-v7-t1029.htm LC135 is 4-speed and 125Z have 6-speed: Why?
Have you ever wonder about this? Why is it the marvelous and lovable Yamaha LC135 only have 4-speed gear and Yamaha 125Z having additional 2 speed gear? Is Yamaha neglected the important aspect of speeds and thrills? Well, I have been thinking about this for a while and tried to find out why. Here is what I’ve found out…The reason why Yamaha 125Z needed to have 6-speed gear is due to narrow powerband that is natural for 2-stroke engine. 2-stroke engine needs RPM more than 5000 (depends to the cc) to deliver its optimum torque, whereby 4-stroke engine can deliver the optimum torque from as low as 1500 RPM. So, because of this, 2-stroke engine needs to have a lot more gear than 4-stroke engine to make sure the torque can be spreads out all along the speed (km/h) starting from low speed to very high speed. For example, LC135 can run on 4th gear as low as 20km/h and from there you can also speeds up to 160km/h without hesitation from the engine. Try this on your 125Z, and tell me how does it feels. As you can see, having only 4-speed gear on LC135 is not a disadvantage, it is the nature of 4-stroke engine that have wide powerband. But, I think it is also not a wrong decision if Yamaha engineers decides to make LC135 being 6-speeder! More power, more fun!
Drive safely! | |
| Subject: Re: Segala Persoalan V8 Tue Aug 03, 2010 4:41 pm | |
| The Compression StrokeNow the momentum in the crankshaft starts driving the piston back toward the spark plug for the compression stroke. As the air/fuel mixture in the piston is compressed, a vacuum is created in the crankcase. This vacuum opens the reed valve and sucks air/fuel/oil in from the carburetor. Once the piston makes it to the end of the compression stroke, the spark plug fires again to repeat the cycle. It's called a two-stoke engine because there is a compression stroke and then a combustion stroke. In a four-stroke engine, there are separate intake, compression, combustion and exhaust strokes. You can see that the piston is really doing three different things in a two-stroke engine:
- On one side of the piston is the combustion chamber, where the piston is compressing the air/fuel mixture and capturing the energy released by the ignition of the fuel.
- On the other side of the piston is the crankcase, where the piston is creating a vacuum to suck in air/fuel from the carburetor through the reed valve and then pressurizing the crankcase so that air/fuel is forced into the combustion chamber.
- Meanwhile, the sides of the piston are acting like valves, covering and uncovering the intake and exhaust ports drilled into the side of the cylinder wall.
It's really pretty neat to see the piston doing so many different things! That's what makes two-stroke engines so simple and lightweight. If you have ever used a two-stroke engine, you know that you have to mix special two-stroke oil in with the gasoline. Now that you understand the two-stroke cycle you can see why. In a four-stroke engine, the crankcase is completely separate from the combustion chamber, so you can fill the crankcase with heavy oil to lubricate the crankshaft bearings, the bearings on either end of the piston's connecting rod and the cylinder wall. In a two-stroke engine, on the other hand, the crankcase is serving as a pressurization chamber to force air/fuel into the cylinder, so it can't hold a thick oil. Instead, you mix oil in with the gas to lubricate the crankshaft, connecting rod and cylinder walls. If you forget to mix in the oil, the engine isn't going to last very long! | |
fareez91 Pegawai Waran II
Posts : 1192 Join date : 22/06/2009 Location : Jinjang ↔ penang
| Subject: Re: Segala Persoalan V8 Tue Aug 03, 2010 9:14 pm | |
| huhu.. asal bi? sape2 ley tlg translate kn x? hhehe.. jap phm jap idak ler.. =) | |
azdli90 Kadet
| Subject: Re: Segala Persoalan V8 Tue Aug 03, 2010 9:15 pm | |
| Compression Stroke
Sekarang momentum di crankshaft piston mula memandu kembali ke busi untuk langkah mampatan. Seperti udara / bahan api campuran di piston dikompresi, vakum dibuat dalam crankcase itu. vakum ini membuka injap buluh dan menghisap hawa / bahan bakar / minyak dari karburator.
Setelah piston membuat sampai akhir langkah kompresi, percikan api plug lagi untuk mengulangi kitaran. Ini disebut mesin dua-stoke kerana ada stroke mampatan dan kemudian stroke pembakaran. Dalam mesin empat-stroke, ada asupan berasingan, mampatan, pembakaran dan exhaust stroke.
Anda dapat melihat bahawa piston benar-benar melakukan tiga perkara yang berbeza di mesin dua-stroke:
* Pada satu sisi piston adalah ruang bakar, di mana piston adalah mampatan hawa / bahan bakar campuran dan menangkap energi yang dilepaskan oleh pembakaran bahan api.
* Di sisi lain piston adalah crankcase, di mana piston mencipta vakum untuk menghisap hawa / bahan bakar dari karburator melalui injap buluh dan kemudian pressurizing crankcase sehingga hawa / bahan bakar terpaksa ke ruang pembakaran.
* Sementara itu, sisi piston bertindak seperti injap, yang merangkumi dan mengungkap intake dan exhaust port dibor ke sisi dinding silinder.
Ini benar-benar cantik rapi untuk melihat piston melakukan banyak hal yang berbeza! Itulah yang membuat dua-stroke engine begitu mudah dan ringan.
Jika anda pernah menggunakan mesin dua-stroke, anda tahu bahawa anda perlu campuran minyak dua-stroke khusus dengan petrol. Sekarang bahawa anda memahami kitaran dua-stroke anda boleh melihat mengapa. Dalam mesin empat-stroke, crankcase sudah benar-benar terpisah dari ruang pembakaran, sehingga Anda boleh mengisi tab mesin dengan minyak berat untuk melumasi bantalan poros engkol, bantalan pada kedua-dua hujung batang yang menghubungkan piston dan dinding silinder. Dalam sebuah enjin dua-stroke, di sisi lain, crankcase adalah melayani sebagai ruangan tekanan untuk memaksa hawa / bahan bakar ke dalam silinder, sehingga tidak dapat memegang minyak tebal. Sebaliknya, anda mencampur minyak dengan gas untuk melumasi crankshaft, menyambung batang dan dinding silinder. Jika anda lupa untuk campuran dalam minyak, mesin tidak akan bertahan lama! | |
azdli90 Kadet
| Subject: Re: Segala Persoalan V8 Tue Aug 03, 2010 9:21 pm | |
| paham bagus2...laa ore pasir mas dio nie..baru aku tahu | |
| Subject: Re: Segala Persoalan V8 Tue Aug 03, 2010 10:28 pm | |
| - azdli90 wrote:
- paham bagus2...laa ore pasir mas dio nie..baru aku tahu
jo lo doh...gegar botol2 budu bawoh glegar buluh dapur hahaha |
ajizaimi Bintara Muda
| Subject: Re: Segala Persoalan V8 Wed Aug 04, 2010 12:31 am | |
| salam. aku rasa translate pki google | |
| Subject: Re: Segala Persoalan V8 Wed Aug 04, 2010 12:33 am | |
| LC135 adalah 4-kelajuan dan 125Z mempunyai 6-speed: Mengapa?
Adakah anda pernah bertanya-tanya tentang hal ini? Mengapa di LC135 Yamaha mengagumkan dan dicintai hanya memiliki gigi 4-kelajuan dan Yamaha 125Z mempunyai tambahan 2 gigi kelajuan? Apakah Yamaha mengabaikan aspek penting dari kelajuan dan thrills? Well, saya telah memikirkan hal ini untuk sementara dan cuba mencari tahu mengapa. Berikut adalah apa yang aku tahu ... Alasan mengapa Yamaha 125Z diperlukan untuk memiliki gigi 6-speed adalah kerana powerband sempit yang alami untuk mesin 2-stroke. 2-stroke engine memerlukan RPM lebih dari 5000 (bergantung kepada cc) untuk memberikan torsi optimum, di mana mesin 4-stroke dapat memberikan torsi yang optimum dari terendah 1500 RPM. Jadi, kerana ini, mesin 2-stroke perlu memiliki gigi lebih banyak dari mesin 4-stroke untuk memastikan torsi boleh tersebar sepanjang kelajuan (km / jam) bermula daripada kelajuan rendah ke kelajuan yang sangat tinggi. Contohnya, LC135 boleh berjalan di gigi 4 serendah 20km / h dan dari sana anda juga boleh kelajuan hingga 160 km / h tanpa ragu-ragu dari mesin. Cubalah ini dalam 125Z anda, dan katakan bagaimana rasanya. [color:359e=#000]Seperti yang anda lihat, yang hanya memiliki 4-speed gear pada LC135 tidak merugikan, itu adalah sifat mesin 4-stroke yang memiliki powerband lebar. Tapi, saya pikir ini juga bukan keputusan yang salah jika jurutera Yamaha memutuskan untuk membuat LC135 menjadi 6-speeder! Kekuatan lebih menyenangkan, lebih! | |
| Subject: Re: Segala Persoalan V8 Wed Aug 04, 2010 12:37 am | |
| tah.. lenmcm je bm ko.hehehe.. tp xpe.. phm la gak.. thnkz.. | |
kenzou Laskar Kelas I
Posts : 139 Join date : 22/03/2010 Age : 31 Location : k.l
| Subject: Re: Segala Persoalan V8 Wed Aug 04, 2010 12:42 am | |
| canne carb leh tersumbat ea?? kwan aku die nye carb tersumbat...*tersumbat ape pon aku xtaw.die kata tersumbat je.. =_= die xnek moto tuh da lama da... mngkin ke sbb tuh?? | |
| Subject: Re: Segala Persoalan V8 Wed Aug 04, 2010 12:48 am | |
| ko servis carb sdh la kn.. setel mslh... mybe mnyk da kering lngsung kot..
die PKAI KOTAK ANGIN x?? tkut ade bnde msuk kn.. | |
| Subject: Re: Segala Persoalan V8 Wed Aug 04, 2010 1:47 am | |
| dia pkai kotak angin.. moto stended... juz dia jrang pkai sbb die kene blajar kat perlis.. amek matrik..taw2 je la matrik xleh pkai moto... berhabuk moto die blek ari tuh.. enn... ouh..servis je? xperlu tukar carb ea??
hehehe... | |
| Subject: Re: Segala Persoalan V8 Wed Aug 04, 2010 3:54 am | |
| ape nk buat ek.. rpm x lpas 8k.. pling kuat pon dpat 8.5.. cadangan ape yg prlu di modi... | |
pais924 Laskar Muda
Posts : 64 Join date : 25/07/2010
| Subject: Re: Segala Persoalan V8 Wed Aug 04, 2010 11:06 am | |
imanhalimi Bintara Kanan
Posts : 637 Join date : 16/06/2010 Age : 36 Location : Perlis->kL->???
| Subject: Re: Segala Persoalan V8 Wed Aug 04, 2010 11:11 am | |
| kalu masa yg singkat xnk ganti baru, bancuh la 2t.. sumbat je dlm tank mengikut skala... | |
pais924 Laskar Muda
| Subject: Re: Segala Persoalan V8 Wed Aug 04, 2010 11:24 am | |
| oooo bg2 kaa....maksudnye kne tuka jugak la ek | |
| Subject: Re: Segala Persoalan V8 Wed Aug 04, 2010 11:29 am | |
| - pais924 wrote:
- kalo pam 2t rosak or dh x bleh dipercayai cmne ek.....
abh da cakap rosak @ xdipercayai kn... ganti baru kot dapat meyakinkan balik kepercayaan tuan badan terhadap pam 2t 2... pendapat seposen aku je.. tgu la apa kata otai2 len... manatau ada cara lem lg.. | |
| Subject: Re: Segala Persoalan V8 Wed Aug 04, 2010 1:03 pm | |
| Subject: Re: Segala Persoalan V8 Wed Aug 04, 2010 4:10 pm | |
| yela 2 choco... haha..da dya cakap x yakin n xboleh dipercayai...beli baru jela bagi yakin lek.. wakaka | |
pais924 Laskar Muda
| Subject: Re: Segala Persoalan V8 Wed Aug 04, 2010 5:51 pm | |
| - imanhalimi wrote:
- yela 2 choco...
haha..da dya cakap x yakin n xboleh dipercayai...beli baru jela bagi yakin lek.. wakaka btul gak 2....hehe....tp msalahnye br jek tuka 3 mggu lps dh jahanam... .dhla mhl nk mati...2 yg x percaya sgt 2...tp kalo x cbut pam 2t itu ketika 2t bancuh digunekan adakah ia akan mendatangkan ape2 kesan ke ats motot saye ....hehehe...begitu panjang lebar skali persoalan hambe..... | |
| Subject: Re: Segala Persoalan V8 Wed Aug 04, 2010 7:28 pm | |
| - pais924 wrote:
- imanhalimi wrote:
- yela 2 choco...
btul gak 2....hehe....tp msalahnye br jek tuka 3 mggu lps dh jahanam... .dhla mhl nk mati...2 yg x percaya sgt 2...tp kalo x cbut pam 2t itu ketika 2t bancuh digunekan adakah ia akan mendatangkan ape2 kesan ke ats motot saye ....hehehe...begitu panjang lebar skali persoalan hambe..... aish camner bleh jadi camtu,xde warranty ke..kl x cabut: 1.kl pump elok lg nnt 2t supply jadi lebih kat engine blok crank,seterusnyer bleh wat plug kong tiap2 hari 2.kl pump elok lg tp 2t dah bleeding kuar habis dr tank 2t,nnt xde lubrication kat pump 2t lantas membuat pump 2t trus jahanam 3.kl pump dah tersedia xleh pki,nnt angin masuk kat bahagian pump 2t tu lantas buat timing engine jadi giler,tetiba jer tinggi masa tgh idle..masa off throttle pun nnt jadi giler,timing ssh nak turun | |
| Subject: Re: Segala Persoalan V8 Wed Aug 04, 2010 8:18 pm | |
| Subject: Re: Segala Persoalan V8 Wed Aug 04, 2010 8:22 pm | |
| smpai jarum ptah 12... hahahha ... modal bnyak x... sen xde sgt ni... brape nk stnby...? | |
| Subject: Re: Segala Persoalan V8 Thu Aug 05, 2010 12:35 am | |
| - kenzou wrote:
- dia pkai kotak angin..
hehehe... ko try servis ja dlu.. tah ade ulat ke bnatang ape msuk kn.heee... klo x ley gak,mybe laen prob ke.. aku nyer mto dkt sbln x start pon ok je... skali 2 je start da idup.hee | |
| Subject: Re: Segala Persoalan V8 | |
