| | Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 | |
+74budak kt areyz95 onetwofive alifmz19 mantadkb iqbal92 sigung su Azeri_conquistador NiTRO697 Ijat Stylo daoz_black bender SAA1729H irfanrazeiq WVG 9651 apik sure azrey hyuhuu adeqyana sherlock Shark pfa qayyum_qz thee_abu -sLip- Mal-PuChOng3300 siput sedut 125z ganu tengku mohd bakhtia bdkbarunaik shrinklefritz syaz nurkaye_akmal tupaijet_junior fizerpool mangketey samporna ccn anep4742 syamz5429 Kaer MaGNum_1721 meerul boy fei cai megnamon man JGN8917 nazjb Pure_Soul Mafiaflix azdli90 komi chaklek Kasut Terbang Fendi Faito Man4822 chez83 Faiz absolute_ahben askrun faristrx Arthur KapcaiKuDie babet musesaddiq paan1171 Azrul chocolate Que Danealle Ultra-Z devilmeasha wormzx tupai comel pasquale yi_tupaijek01 superjoemanito 78 posters | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Thu Mar 17, 2011 11:10 am | |
| erk mcm payah je nk polish selekoh tu bro...try la guna alat2 yg kck utk jolokn ke dlm lubg2 tu...balut ngn kain + outosol...polish ngn port same ke? | |
| | | Ultra-Z Support Crew
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Thu Mar 17, 2011 11:39 am | |
- erk mcm payah je nk polish selekoh tu bro...try la guna alat2 yg kck utk jolokn ke dlm lubg2 tu...balut ngn kain + outosol...polish ngn port same ke?
port mksudnye pelabuhan melibatkan perubahan dimension/ukuran asal spec standard.. polish cme michelinmelichinkan segala lubang n permukaan yg kasar.. *aku tk pk pn cmne nk polish lubang2 kt blok, sbb mmg tnk buat. hahaha.. brg 'standard' maa.. ade kelebihannye.. | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Thu Mar 17, 2011 11:42 am | |
| uk aloh.. yi koya doktahu. ambo timbuk demo skali br tau.. | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Thu Mar 17, 2011 12:17 pm | |
| erk..ambe ni cuma manusia bese...ilmu kne cr n tye kalo xtau..uhuk2 | |
| | | faristrx Laskar Muda
Posts : 58 Join date : 02/02/2011 Age : 29 Location : kota bharu
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Sun Mar 20, 2011 8:07 pm | |
| tnya..nape muto aku..gear 5 btol2 feel.......haha..change gear 6....rpm trun..motor lembik smacam je...... | |
| | | askrun Laskar Kelas I
Posts : 145 Join date : 31/05/2009
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Sun Mar 20, 2011 8:34 pm | |
| - faristrx wrote:
- tnya..nape muto aku..gear 5 btol2 feel.......haha..change gear 6....rpm trun..motor lembik smacam je......
haha cuba check spocket ko dgn setting carburetor aku rasa cm minyak kurang je sme problem cm moto aku... | |
| | | absolute_ahben Laskar Kelas II
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Sun Mar 20, 2011 10:49 pm | |
| minyak kureng knocking bro. x de kaitan ngn rpm turun. rpm naek abes ade la klu minyk kurang.
pendapat 1sen sye | |
| | | tupai comel Pegawai Kadet Kanan
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Mon Mar 21, 2011 1:47 pm | |
| - absolute_ahben wrote:
- minyak kureng
pendapat 1sen sye knocking tu bile mnyk lebih la ahben.. knocking = premature ignition..pembakaran berlaku sblm piston berada pada kedudukan top dead centre (TDC).. biase org setting..tak ngam sgt..mesti ade knocking sikit supaya boleh berbahagia meroket di highway tanpa rasa risau | |
| | | pasquale Kadet
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Mon Mar 21, 2011 3:20 pm | |
- minyak kureng
biase org setting..tak ngam sgt..mesti ade knocking sikit supaya boleh berbahagia meroket di highway tanpa rasa risau owh mcm tu ka...aku baru taw...patut la ganas je bunyi... | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Mon Mar 21, 2011 8:59 pm | |
| owhh...carb aku..nmpak kotor je..dgn minyak mleleh kt tpi..cm kuning nmpak...kna servis ke ek??? | |
| | | superjoemanito Laksamana Armada
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Mon Mar 21, 2011 9:49 pm | |
| - faristrx wrote:
- owhh...carb aku..nmpak kotor je..dgn minyak mleleh kt tpi..cm kuning nmpak...kna servis ke ek???
biase kuar kt sambungan hos carb ke kotak angin,mmg ptt servis dah tue,buat sekali top overhaul,mesti ringan mesin lps tue..
Last edited by superjoemanito on Tue Mar 22, 2011 10:21 pm; edited 1 time in total | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Mon Mar 21, 2011 11:25 pm | |
| yg aku perasan.. kalau pakai carb 125z..boleh dpt top speed at top rpm..tp susah nk maintain.. pakai carb rxz..top speed same je..tp boleh maintain walaupun highway tu naek bukit sikit.. peh..mantop.. | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Tue Mar 22, 2011 10:08 pm | |
| owh yeke? maaf atas pendapat nubis sye. knocking bunyi minyak lebih la ye? ingtkn minyak kurang. hu3
info dari wikipedia. kalu slah marah wikipedia,jgn marah ak yek.hu3
Causes of pre-ignition include the following:
* Carbon deposits form a heat barrier and can be a contributing factor to preignition. Other causes include: An overheated spark plug (too hot a heat range for the application). Glowing carbon deposits on a hot exhaust valve (which may mean the valve is running too hot because of poor seating, a weak valve spring or insufficient valve lash).
* A sharp edge in the combustion chamber or on top of a piston (rounding sharp edges with a grinder can eliminate this cause).
* Sharp edges on valves that were reground improperly (not enough margin left on the edges).
* A lean fuel mixture.
* Low coolant level, slipping fan clutch, inoperative electric cooling fan or other cooling system problem that causes the engine to run hotter than normal.
* Auto-ignition of engine oil droplets | |
| | | Faiz Laskar Muda
Posts : 39 Join date : 30/05/2010 Age : 33 Location : Cheras.bndar sri permaisuri
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Mon Mar 28, 2011 9:15 pm | |
| salam bro . Kalo moto size piston size dah 2.0 tp pikup dye kuat . Tp top langsung xbole . Head da potong 1.2 . Pj 23 mj 196 xsilap . Crb rxz . Cm ne erk nk kasI top tu naik siket . | |
| | | paan1171 Support Crew
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Mon Mar 28, 2011 9:58 pm | |
| - Faiz wrote:
- salam bro . Kalo moto size piston size dah 2.0 tp pikup dye kuat . Tp top langsung xbole . Head da potong 1.2 . Pj 23 mj 196 xsilap . Crb rxz . Cm ne erk nk kasI top tu naik siket .
nk kena porting skit blok tu.. korek ape2 yg ptot.. ntar kt pomen je... | |
| | | Faiz Laskar Muda
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Mon Mar 28, 2011 10:11 pm | |
| sbb mmg trase mcm mnyk tak ckup pn ade . Rmai yg ckap bile piston da besa top speed xbleh blarh . 2kilo cm tu jew moto da tak leh g . | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Mon Mar 28, 2011 11:13 pm | |
| Faiz: blok tk port rpm mmg tkleh nek tinggi bro.. jd lemau lepas 2kilo carik top speed pn psl dh overrev kot. piston 2.00 kalo porting ngam, setting ngam, nk wat long distance menten outmeter pn boley.. tp ajak skilo lg sy takot~ tup, tup, tup pegi dier.. | |
| | | Faiz Laskar Muda
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Tue Mar 29, 2011 4:14 am | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Wed Mar 30, 2011 8:50 pm | |
| hua. bump2! mane nieh pic gambar blok piston oversize,port n polish blok tahap gaban? xkn sume moto standrd je kowt?
*kasi perhangat skit topic nieh~ | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Thu Mar 31, 2011 1:11 am | |
- owh yeke?
* Auto-ignition of engine oil droplets sorry le ahben.. dari ape yg aku blajar heat and fluid.. knocking tu premature ignition = pembakaran pra matang.. mase compression process..pembakaran berlaku sblm piston tu smpai ke atas..oleh sebab tu..ade rase berat sikit.. kt jepun..kete2 racing kt sane..yg da modi sana sini..masuk piston besa gedabak..compression bertambah kaw2 punye..knocking gerenti berlaku..terpaksa pakai minyak ron tggi..ade yg smpai ron105 utk elakkan knocking tu.. itu kereta..pakai system valve..function die still same..tggi RON number..lg lmbt pembakaran..just utk elakkan pembakaran pra matang.. kene tau..knocking ni..rase berat sikit..menurut yg dihighlight merah tu..engine panas..bile engine panas..jem panas bakal berlaku.. sblm jem panas berlaku akan ade rase berat2 sbb piston or ring tu da nk lekat dgn sleeve... takdenye knocking sbb mnyk kurang..kalau kurang bobos terus.. kite ni pakai moto..utk performance mantop..tak payah knocking pon takpe.. nk slmt bg knocking sikit.. knocking byk sgt jd bobok.. tahle..tggu jela otai2 tlg jwb.. p/s: fuel mixture tu kan campuran minyak dan udara.. lean fuel mixture tu bukan ratio campuran mnyk dan udara tak balance ke?? kenapa pakai ron97 boleh tambah performance compare dgn ron95? sbb die..ron 97 pembakaran lmbt sikit..knocking kurang sikit..so moto rase ringan sikit.. eh..cite ron plak aku ni.. | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Thu Mar 31, 2011 10:07 pm | |
| owh ye ke. hu3. x tawu lak nk ckp. yup betul cm anda ckp. klu tande2 piston nk bobos, mmg rase berat skit.
tp pengalaman ak
2 piston bobos,mmg x de bunyi knocking. rpm naek tetibe dari yg biase sedar2 da bunyi tus je.
1 piston jem panas. sme gk rpm naek tetibe sedar2 trus lekat. ak tarik clutch n tgu smpai pelan skit n trus drop gear n jalan. cz da tawu cnfirm blok calar nye.
elok2 ak pakai enduro 0.0 skrnk da jadik enduro 0.50. hu3.. ape la naseb~
| | | chez83 Laskar Muda
Posts : 32 Join date : 21/03/2011 Age : 40 Location : ipoh load
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Fri Apr 01, 2011 11:44 am | |
| bro nak tnya sket r ... 2 minggu lpas aq baru rebore moto aq pas 2 skunk nyh da mcm lmbab smcam jer pick up pown kurang nak nek top pown lambat pas 2 paling laju 160 jer skunk nie singgle rider sbelom 2 nek 2 orang pown boleh g 180 lg ... apakah masalah beliau agaknya ?? | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Fri Apr 01, 2011 1:14 pm | |
| bobos mmg takde knocking bro.. mnyk lebih baru ade knocking..aiyaa | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Fri Apr 01, 2011 9:02 pm | |
| owh betape bengap nye ak. maaf ye ats kebengapan sye~ | |
| | | Man4822 Bintara Muda
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Thu Apr 07, 2011 8:30 pm | |
| nak tanye otai2 semua, piston ape yang ok untuk 125zr ni??
satu lagi, skim head kalo Rm 15 tu mahal ke x?? | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 | |
