| Segala Persoalan V9 | |
+44softoperator mzul787 venom nazjb Shiro naem 2345 kingkong501 archonixm soNa mantadkb Or-kEi Ultra-Z eddy8075 ariffm0hd hamzi999 lencai absolute_ahben izzat_125zr babet imanhalimi lanunlaut Jokey Cabuk xapex Kaer yan_zr amirfarhan paan1171 fareez91 ramdzi unknownh tupai comel iqram man JGN8917 yi_tupaijek01 tupaiku chrome mazakim vendetta geeks ajizaimi Ezad mousepink chocolate superjoemanito 48 posters |
| Subject: Segala Persoalan V9 Sun Sep 26, 2010 12:18 am | |
| Segala Persoalan V8 http://125z.forumms.net/diskusi-bengkel-diy-f5/segala-persoalan-v8-t1270.htm | |
| Subject: Re: Segala Persoalan V9 Sun Sep 26, 2010 12:20 am | |
| coco kite smbg kt sini ek,aku ade spare gk satu,yela..x kn nk pakai coil magnet lokel kot | |
| Subject: Re: Segala Persoalan V9 Sun Sep 26, 2010 12:26 am | |
| xpe aku try dl yg aku beli ngan sona,kl simptom2 tersebut hilang maka sah la original muto aku dah kong..bese kl dah kong baper ek orang beli?ori tu..... | |
| Subject: Re: Segala Persoalan V9 Sun Sep 26, 2010 1:11 am | |
| mane aku tau harge ori,harge lokel tau la,wa lyn brg lokel je,try jgn x try,nk best tkr trs coil api,cdi,wiring,confirm ar setel prob ko tue | |
mousepink Bintara Muda
Posts : 400 Join date : 19/04/2009 Age : 36 Location : Kuala Perlis
| Subject: Re: Segala Persoalan V9 Sun Sep 26, 2010 1:49 am | |
| moto aku rsnya mengalami simptom yg sama...bobok pada mid rpm..lagi2 bila nk amek selekoh..turun gear n pulas minyak balik terasa enjin loss power pada mid rpm..da try set carb balik prblm sama jugak..bila mid rpm enjin mcm nk mati..mslh nie didatangkan serentak dgn prblm wiring..signal,lmpu brek dan komponen yg guna bateri sume tidak berfungsi..mybe kene try tukar satu2 br tau kut prblm | |
| Subject: Re: Segala Persoalan V9 Sun Sep 26, 2010 2:44 am | |
- mane aku tau harge ori,harge lokel tau la,wa lyn brg lokel je,try jgn x try,nk best tkr trs coil api,cdi,wiring,confirm ar setel prob ko tue
ah tipu ah layan lokel,segala enkai ngan kaberset ori tu ko nak sumbat mana..meh bak kat aku kiranya kl nak tukar cuma tukar coil tu jer la?dia punya contact point tu camner? | |
| Subject: Re: Segala Persoalan V9 Sun Sep 26, 2010 9:56 am | |
kiranya kl nak tukar cuma tukar coil tu jer la?dia punya contact point tu camner? tkr coil je la,papan die blh pakai yg asal blk,contact point mane?,bkn ke fix da mende tue.. | |
Ezad Laskar Kelas I
Posts : 113 Join date : 07/08/2010 Age : 30 Location : Shah Alam , Selangor
| Subject: Re: Segala Persoalan V9 Sun Sep 26, 2010 9:43 pm | |
| bro, saya punye masalah len, ble rem pada high RPM dye akn meletup kat ekzos, pastu dye mati ar, tp bukan mati trus, leh start blek. atau kdg tgh bwak jalan2, mati tibe2, aduh, knape ea? | |
| Subject: Re: Segala Persoalan V9 Sun Sep 26, 2010 10:38 pm | |
| try swap cdi,kl x jadi try swap coil megnet,x jadi gak try coil plug,x jadi jgk kalu wallahua'lam | |
Ezad Laskar Kelas I
| Subject: Re: Segala Persoalan V9 Sun Sep 26, 2010 10:59 pm | |
| thank | |
Ezad Laskar Kelas I
| ad brape coil ea dlm 125z ny? | |
| Subject: Re: Segala Persoalan V9 Sun Sep 26, 2010 11:18 pm | |
| 2,satu kat megnet@coil megnet..satu lg kat sebelum kepala plug,coil plug | |
Ezad Laskar Kelas I
| Subject: Re: Segala Persoalan V9 Sun Sep 26, 2010 11:29 pm | |
| ooke, thank | |
ajizaimi Bintara Muda
| Subject: Re: Segala Persoalan V9 Mon Sep 27, 2010 12:31 am | |
| salam
"rajin hang buka n ccuci block ye...waduh2..sebulan sekali kew...hehehe... aku cm nak kongsi tip...pki je shell puya...xde pun smpi pki kertas pasir nak hilangkan karbon dia...tp seblm tu korg polish block pakai kertas sampi btui2 dah xnmpk garis2...cmfirm bila bka kilat bagaikan emas...hehehe..slmt mencuba..."
petikan ni amik dr mbc. Polish blok pakai kertas tu memudaratkan blok atau enjin ke?? | |
| Subject: Re: Segala Persoalan V9 Mon Sep 27, 2010 12:37 am | |
| maknanya polish permukaan piston ngan permukaan kawah head sampai jadi licin,so karbon senang nak tanggal kl nak bersihkan di kemudian hari,ataupun karbon mmg ssh nak lekat sbb dah licin...
nak best lg amik autosol@metal polisher kasi licin mcm cermin hehehehe | |
| Subject: Re: Segala Persoalan V9 Mon Sep 27, 2010 1:24 am | |
| xde kesan negatif ke polish permukaan piston ngan permukaan kawah head sampai jadi licin | |
| Subject: Re: Segala Persoalan V9 Mon Sep 27, 2010 1:32 am | |
| err xtau le plak ambe,nnt le ambe try tgk jadi camner... | |
| Subject: Re: Segala Persoalan V9 Mon Sep 27, 2010 9:44 am | |
kiranya kl nak tukar cuma tukar coil tu jer la?dia punya contact point tu camner? tkr coil je la,papan die blh pakai yg asal blk,contact point mane?,bkn ke fix da mende tue.. coil magnet tuh jual berasingan, brape regenyer yer?.. | |
| Subject: Re: Segala Persoalan V9 Mon Sep 27, 2010 10:30 am | |
| salam. Bukan apa tkt sengaja dibuat permukaan piston tu berkerutu ckt agar karbon melekat | |
| Subject: Re: Segala Persoalan V9 Mon Sep 27, 2010 10:44 am | |
| - ajizaimi wrote:
- salam. Bukan apa tkt sengaja dibuat permukaan piston tu berkerutu ckt agar karbon melekat
tapi pasan tak kalau kite bersihakn kawah tuh, performance die lagi smooth.. tapi tang permbersihan tuh mungkin kene pikir balik samade ade effect ke tak kalau pakai kertas pasir.. mungkin ade tapi tak banyak, sebab calar-calar halus.. | |
| Subject: Re: Segala Persoalan V9 Mon Sep 27, 2010 10:55 am | |
| salam. Tapi klu kerak karbon byk sgt org pki krts pasir jgk kan? | |
| Subject: Re: Segala Persoalan V9 Mon Sep 27, 2010 11:15 am | |
| haah, biase macam tuh lah, care ape lagi nak gune kalau nak buang karbon tuh, campur dengan petrol sket, so senang lah nak tanggal hitam-hitam tuh..
| Subject: Re: Segala Persoalan V9 Mon Sep 27, 2010 11:27 am | |
| pakai berus periuk jerla...nk guna kertas pasir jugak buatpe? lg sng kalau guna berus periuk...cari yg jenis kilat2 tu...bkn yg halus tu... guna berus periuk tu tinggal gosok je smpai bersih...nk cuci kt lubang ekzos pn sng... | |
| Subject: Re: Segala Persoalan V9 Mon Sep 27, 2010 12:37 pm | |
| rajin benar nak tonyoh karbon degil ketegaq tuh ngan kertas pasir tp ak pun tonyoh ngan kertas pasir jugak wakakaka | |
| Subject: Re: Segala Persoalan V9 | |
