| Spesifikasi & Modifikasi Tupai Masing2 V2 | |
+69MadAxel wan_210407 Kazamasaga-san putra1691 Kato_125 poknik koie06 chrome MegatBLA3089 nurkaye_akmal xopai majidali softoperator hashimirosicky 125zRskala along paan1171 redline Hanomichi89 airil man JGN8917 yi_tupaijek01 kenzou hanturaya111 fiq seng_87 acaapxx h@ziQ azdli90 imanhalimi xapex kekuravslelabi Cat Faris musesaddiq fareez91 ak wormzx hidup_sihat Ajib geeks arjuna86 monyet BKR3**4 absolute_ahben komi kirkhamster sANi bUAs hasrul_90 zr90 ajmon_85 oddysee11 aus_ipoh farul oliey2u amex neomerc Ultra-Z fizerpool vendetta nizam1407 mantadkb gilgamesh88 superjoemanito hakemrahim chocolate tupai comel WKQ4913 soNa mazakim 73 posters |
airil Laskar Muda
Posts : 76 Join date : 30/07/2010 Age : 35 Location : BPP
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Mon Aug 02, 2010 7:01 pm | |
| salam..ada x sapa2 penah try msuk gearbox panther kat tupai?aku igt nk msuk gearbox panther tapi xtau ok ka x..tolg sket otai2..tq.. | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Mon Aug 02, 2010 7:45 pm | |
| ngaaa,mana dengar nih masuk gearbox panther kat tupai..bleh ker?gearing dia baper?diameter setiap gigi gear tu ko dah kira blom?tapak gigi camner?shaft muat x?aisehmen macam2 hal la aku tanya.. | |
fiq Laskar Kanan
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Mon Aug 02, 2010 8:15 pm | |
| pergh..dasat tol warga2 kat sini..mcm2 jenis modified ak jmpe..
sape tw maximum rebore ngan saiz piston bleh utk 125?? | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Tue Aug 03, 2010 9:38 am | |
| - airil wrote:
- salam..ada x sapa2 penah try msuk gearbox panther kat tupai?aku igt nk msuk gearbox panther tapi xtau ok ka x..tolg sket otai2..tq..
blh masuk..tp kene kacuk gear2 tertentu lar...mcm kacuk gearbox rxz jugak.. jgnla sumbat 1 set gearbox panther tu plak.... | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Tue Aug 03, 2010 1:13 pm | |
| - fiq wrote:
- pergh..dasat tol warga2 kat sini..mcm2 jenis modified ak jmpe..
sape tw maximum rebore ngan saiz piston bleh utk 125?? maximum size piston 125z 2.00..nk rebore lebih pon boleh tp kene pakai piston laen la.. plg besa aku jumpe blok 125z pakai piston rxz 0.75..itu pun sleeve da nipis gile2..cepat jem..setting kene betul2 baek punya | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Tue Aug 03, 2010 8:55 pm | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Tue Aug 03, 2010 8:59 pm | |
| laen org laen taste.. piston besar pikap ke top speed tu lg cepat.. blok yg same porting.. tp berbeza size..kompem la piston besa lg cpt smpai top speed.. | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Tue Aug 03, 2010 9:23 pm | |
| kilang dah balance berat magnet,berat ngan bentuk crank nak suh seswai ngan saiz & berat piston stended tupai..dah obersize lebih2 lg dah pki piston luar tabii yg lg berat dr piston stended,lg la out of balance..bl dah out of balancer,engine jadi gegar,dah gegar power dah drop,x dapat spt sepatutnyer,% utk komponen failure pun jadi tinggi..
pendek kata,ko pun dah pernah pki piston besor ngan kecik,mana lg smooth nak menten top?kompem piston saiz kecik..kecuali la kl dah buat blue print kat engine tupai tu nak suh masuk piston besor gedabak punya | |
Hanomichi89 Laskar Kelas I
Posts : 159 Join date : 21/05/2010 Age : 32 Location : nibong tebal - Kubang Krian/ Kota Baru
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Mon Aug 23, 2010 1:46 am | |
| hee..ini spesifikasi tupai cyg ak carb z, mainjet 210, pilot x ingt. blok 0.50,piston enduro, spoket 15-36, tu je kot.. | |
redline Laskar Kanan
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Mon Aug 30, 2010 10:33 am | |
| moto aku baru dapat jalan balik so blok,piston,carb setting standard.. spoket je y x standard.. x pe la, moto wat g keje cari duit kan.. kayuh pelan2 sudah.. | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Tue Sep 28, 2010 10:00 pm | |
| blok porting lame lg, head same, skimmed 3mm.. carb pn setting lame lg, carb z lay(28mm) mainjet 265 pilot 32.5.. bearing crankshaft 2bijik, spoket sbijik, skf enduro c3... yang len standard koyo.. rim tkde besor2 dh, rim besi 1.4 dpn blkg, depan 70/90 vee rubber, belakang 70/100 dunlop tt900.. rantai 415 KMC silver, spoket 14-32.. disc depan 320mm, set brake disc blkg tadak; pam rosak.. sekian setting terkini cik jijah saye.. | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Tue Sep 28, 2010 10:22 pm | |
- blok porting lame lg,
head same, skimmed 3mm.. carb pn setting lame lg, carb z lay(28mm) mainjet 265 pilot 32.5.. bearing crankshaft 2bijik, spoket sbijik, skf enduro c3... yang len standard koyo.. rim tkde besor2 dh, rim besi 1.4 dpn blkg, depan 70/90 vee rubber, belakang 70/100 dunlop tt900.. rantai 415 KMC silver, spoket 14-32.. disc depan 320mm, set brake disc blkg tadak; pam rosak.. sekian setting terkini cik jijah saye.. nk tau ls,rpm maximum,topspeed max,myk kuat ke x? | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Tue Sep 28, 2010 11:00 pm | |
head same, skimmed 3mm.. carb pn setting lame lg, carb z lay(28mm) mainjet 265 pilot 32.5.. bearing crankshaft 2bijik, spoket sbijik, skf enduro c3... yang len standard koyo.. rim tkde besor2 dh, rim besi 1.4 dpn blkg, depan 70/90 vee rubber, belakang 70/100 dunlop tt900.. rantai 415 KMC silver, spoket 14-32.. disc depan 320mm, set brake disc blkg tadak; pam rosak.. sekian setting terkini cik jijah saye.. nk tau ls,rpm maximum,topspeed max,myk kuat ke x? yi_tupaijek...nk tau suma tu kne join tt setiap mlm jumaat kt bangsar.... rpm maximum,topspeed max suma tu ko akan tau lepas blik dri tt bermula dri tol federal hiway bt 3 menuju ke shah alam... sbb meter dia ikot kelajuan "sebenar"..bkn kelajuan meter 125z lg... xdpt nk imagine pn even kalu dia bgtau pun di alam maya ni... | |
gilgamesh88 Laskar Kanan
Posts : 330 Join date : 25/05/2009 Age : 35 Location : wang ulu yg best....
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Tue Sep 28, 2010 11:13 pm | |
| spec baru muto sy... piston 0.0 enduro... carb 125z asah jarum menjet 150... head skim 3mm... blok da modi (port minyak ngan ekzos)... ekzos cutting mcm rxz boss... spoket 14-34... tayar viva 60/90 dpn blkg... CDI cop yamaha...
len2 cam asal... | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Wed Sep 29, 2010 3:20 am | |
| - gilgamesh88 wrote:
- spec baru muto sy...
len2 cam asal... nngee.... .. msti roket kaw2 ni... top meter kmh kt mner..? rpm max brape..? .. heheh.. | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Thu Sep 30, 2010 2:35 am | |
| Meter kmh kt 0..hehe..sbb meter x idup..max rpm 9.5k-10k dlm gear 6.. | |
along Laskar Muda
Posts : 3 Join date : 02/05/2010 Age : 38 Location : rawang
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Thu Sep 30, 2010 3:24 am | |
| Spec muto sy Head block stended Carb stended Ekzos stended Tayar depan blakang 80/90 Moto dah 7taun. block dara lagi.. Jaga baik punya.. Coverset local.. Ori punya dah hancur.. Moto semalam masuk bengkel. Esok mau pecah dara.. Mau kasi btoi2 ho liaow.. Hohoho.. Aku dak baru kat sini.. So yang otai2 tu. Tunjuk ajar ku sifu. | |
farul Laskar Muda
Posts : 81 Join date : 16/10/2009 Age : 34 Location : pasir gudang
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Thu Sep 30, 2010 11:24 am | |
| spec motr aku: carb rxz mainjet 250,pilot 27.5 jarum asal tayar viva 60/90 dpn blakang blok = piston 0.25 rxk sporket 14 - 36 head dan yg lain standard mcm asal.. | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Thu Sep 30, 2010 12:19 pm | |
| piston saiz 0.25 rxk?maksudnyer? atas lg dr rxz ke? | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Thu Sep 30, 2010 5:54 pm | |
| - farul wrote:
- spec motr aku:
carb rxz mainjet 250,pilot 27.5 jarum asal tayar viva 60/90 dpn blakang blok = piston 0.25 rxk sporket 14 - 36 head dan yg lain standard mcm asal.. berat ko brape farul?.. | |
farul Laskar Muda
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Fri Oct 01, 2010 11:04 am | |
| - geeks wrote:
- farul wrote:
- spec motr aku:
carb rxz mainjet 250,pilot 27.5 jarum asal tayar viva 60/90 dpn blakang blok = piston 0.25 rxk sporket 14 - 36 head dan yg lain standard mcm asal.. berat ko brape farul?.. 48kg je | |
farul Laskar Muda
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Fri Oct 01, 2010 11:10 am | |
- piston saiz 0.25 rxk?maksudnyer?
atas lg dr rxz ke? piston aku skg bsr ckit dr 2.00 125z..bkn ape bearing kcg aku pecah sampai mkn blok..t,pkse aku lay smpai bsar mcm 2 ...2.00 rxk = 58mm x silap aku le.. | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Fri Oct 01, 2010 12:59 pm | |
atas lg dr rxz ke? piston aku skg bsr ckit dr 2.00 125z..bkn ape bearing kcg aku pecah sampai mkn blok..t,pkse aku lay smpai bsar mcm 2 ...2.00 rxk = 58mm x silap aku le.. bkn rxk tu bro...rxk lg besar dr rxz...mayb piston enduro kot?bleh ke blok stended 125z lay smp 58mm? | |
125zRskala Bintara Muda
Posts : 484 Join date : 22/06/2010 Age : 37 Location : liang lahad dan masih hidup....
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Fri Oct 01, 2010 3:49 pm | |
| spec moto aku..
=standard stok kilang,tayar vee rubber pon x tuko lg.. | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 | |
