| Overhaul Motor | |
+70tupaiberasap su -sLip- meerul samporna ccn qayyum_qz banchiksk8 throne_undead xopai pasquale chaosworld devilmeasha Conan Edogawa faaizil unknownh haizamlee N.A.M.I nurkaye_akmal ss110 unggu wormzx Ultra-Z wan_210407 poknik lanunlaut fishbike tupai_tempur h@ziQ acab fizerpool mzul787 airil hanturaya111 kekuravslelabi adiz aus_ipoh paan1171 ne0bolimi3rd amirfarhan yi_tupaijek01 acaapxx man JGN8917 ajizaimi sherlock oddysee11 apmsd HailToKing mousepink hafidz ijam125 mantadkb arjuna86 absolute_ahben undetected anep4742 azdli90 yoshi hidup_sihat ihsanxx vendetta cerah9 geeks chocolate superjoemanito zouk188 ak soNa assasin_lunxe WKQ4913 hasrul_90 archonixm 74 posters |
N.A.M.I Pegawai Waran II
Posts : 1131 Join date : 25/07/2010 Age : 35 Location : MELAKA BANDARRAYA BERSEJARAH
| Subject: Re: Overhaul Motor Mon Jan 24, 2011 10:41 pm | |
| gile r zam motor ni... mlm dah bleh open table ngan family dier kot..haha | |
| Subject: Re: Overhaul Motor Mon Jan 24, 2011 10:42 pm | |
| - poknik wrote:
- aku overhaul kt zam motor seksyen 23.
mahal nak mati.
harap korang nilai..
plug-rm5 4t oil-rm12 gasket-rm18 service charge-rm60 potong block-rm15 piston-rm58 piston pin-rm12 piston ring-rm35 piston bearing-rm15 bearing koyo 6205 2 biji-rm56 balancing bearing 2 biji-rm36 cluch buch-rm28 mainjetr-rm3 pilot jet-rm7 rod-rm130 rod pin-rm68 pump rod-rm15 rod bearing-rm68 oil seal 25x40x8 ARS-rm28 oil seal 32x44x8 ARS-rm28 lay head-rm28 poting-rm100
total=rm883 porting..hehehe..nape xupload je gbr resit tu?lg real | |
poknik Laskar Kelas I
Posts : 158 Join date : 05/11/2010 Age : 33 Location : shah alam, pauh limo, klate
| Subject: Re: Overhaul Motor Mon Jan 24, 2011 10:46 pm | |
| kemere hp murah sangat la.. xnampak ape.. | |
| Subject: Re: Overhaul Motor Mon Jan 24, 2011 10:55 pm | |
| owh...tgu otai2 explain la gtu... | |
| Subject: Re: Overhaul Motor Mon Jan 24, 2011 10:58 pm | |
| barang2x mahal sgt dari biase n ade trick harge kt parts2x.. | |
| Subject: Re: Overhaul Motor Mon Jan 24, 2011 11:01 pm | |
| tu la..aq tgok upah ok je... cume brg mhal.. nape x ko je yg g runner crik brg..? | |
| Subject: Re: Overhaul Motor Mon Jan 24, 2011 11:03 pm | |
| sebab aku xtaw ape brg yg nak patot tuka.. aku xpenah overhaul lor.. | |
| Subject: Re: Overhaul Motor Mon Jan 24, 2011 11:07 pm | |
- barang2x mahal sgt dari biase n ade trick harge kt parts2x..
aku pn rase macam barang2 yg biase orang beli die letak murah.. pastu barang cam jarang beli n kurang taw harge die letak mahal.. rod tu memang mahal camtu ke?setiap barang ade cas.. aku ingat 1 set rm130 xtermasuk upah pump.. | |
| Subject: Re: Overhaul Motor Mon Jan 24, 2011 11:15 pm | |
| salah satu la,die asing2xkan part2s rod assembly kit untuk nmpk harge lbh mahal..andai kate pakai rod tkrj brape la sgt harge die,he3x.. | |
| Subject: Re: Overhaul Motor Tue Jan 25, 2011 1:33 pm | |
mahal nak mati.
total=rm883 ape rosak sbnrnya sblm g oberhaul ni..pttnya mana part yg leh pki tu pki je dulu...balancing bearing pun tukar eh.. oil seal tu pki yg 1 set pye tu dh ok..siap sekali dgn gasket enjin(overhaul)+oilseal=rm 30.. rod tu pki tkrj pun dh ok..siap sekali 1 pakage dgn pin rod+bearing rod..baru rm 80 ni dia asing2 kn brg tu nk nampak mcm byk..pdhal kebanyakkan brg2 tu dlm 1 pakaging je | |
| Subject: Re: Overhaul Motor Tue Jan 25, 2011 1:52 pm | |
| sb motor dia jem tgkap rod kot tu... | |
| Subject: Re: Overhaul Motor Tue Jan 25, 2011 2:10 pm | |
mahal nak mati.
plug-rm5 4t oil-rm12 gasket-rm18 service charge-rm60 potong block-rm15 piston-rm58 piston pin-rm12 piston ring-rm35 piston bearing-rm15 <-------------------------------Total sume2 ni kalo wat sndr dlm rm80-90 bearing koyo 6205 2 biji-rm56 balancing bearing 2 biji-rm36 cluch buch-rm28 mainjetr-rm3 pilot jet-rm7 rod-rm130 rod pin-rm68 pump rod-rm15 rod bearing-rm68 oil seal 25x40x8 ARS-rm28 oil seal 32x44x8 ARS-rm28 lay head-rm28 poting-rm100<------ dua2 ni 'harga' skil n thp modifikasi
total=rm883 jumlah ni bleh kurang sikit kalo ko bwk blk blok n hntr blk blok ke kedai keesokan hari bersama blok dh siap rebore beserta parts2 nye skali. tu kalo settle sendiri dkt blok je contohnye.. kalo ko beli sendiri semua parts yg perlu diganti, ko cme byr upah kt pomen je. total kos modal beli sparepart +rm400, n upah pomen maybe dlm rm100-150 kot.. tp pomen pn ade bengkel yg perlu dbyr sewa, gaji pekerja, bil air letrik, so, nk tnk, tkkn meniaga talak mau untun maa..? kte sbg pengguna cme leh menilai berbaloi atau tidak. n pd saye, ok la arge overhaul kt zam motor sek23 tu.. / 5 sbb oberhaul tk rebore just tuka brg dlm, plg murah aku pnh jumpe, rm4xx-5xx..
| Subject: Re: Overhaul Motor Tue Jan 25, 2011 2:18 pm | |
| sng cte mlm ni dtg tt shah alam bwk resit, same2 kite rungkaikan segala persoalan..~~ | |
| Subject: Re: Overhaul Motor Tue Jan 25, 2011 4:37 pm | |
| overhaul aq yg lepas... nk jimat punye psal...
aq turun enjin sndri kt umah... bwak g bengkel... brg aq crik sndri.. abg bengkel tu amek upah rm 75.00 je.. hahaha... | |
| Subject: Re: Overhaul Motor Tue Jan 25, 2011 8:20 pm | |
| yg rm909 tu aku tuka.. kabel cluch n kabel minyak-rm30 mentol lampu-rm3 soket lampu-rm6 | |
| Subject: Re: Overhaul Motor Tue Jan 25, 2011 8:23 pm | |
| man: yg rosaknye piston aku tembus, sisa2 masuk lam enjin..
yap: service 60 tu setting, carb sampai cun giler...die kasi aku nek ulang2 smpai betol2 sedap smpai ke gear 6.. | |
| Subject: Re: Overhaul Motor Wed Jan 26, 2011 3:10 am | |
| oops, tsilap. mlm besok, arini br selasa.. alamak, cable clutch n cable minyak pn tuka ke..? isk2.. mende bukan sng2 putus, putus skali dua2 plak tu..? sisa masuk enjin tk wajib overhaul pn, tp smemangnye bukak/turun enjin care terbaik kompom bersih dlm tu sumer. cme ' alang2 bukak, tuka sumer' yg wat arge melebihi bajet kot. setting carb tu mmg patut ade dlm jaminan aftersales services.. tk patut la tune carb tk cun sedangkan customer dh abeskan beribanberatus RM.. ataupn benda yg baru tuka tp dh rosak blk kurang dr tempoh ia sepatutnye rosak.. | |
| Subject: Re: Overhaul Motor Wed Jan 26, 2011 6:05 pm | |
| - poknik wrote:
- man: yg rosaknye piston aku tembus, sisa2 masuk lam enjin..
piston tembus? tolak harga upah porting tu& cable minyak & clutch tu...aku rasa bnda alah ni je yg ptt tukar... piston ring bearing rod rod pin rod upah pump bearing+upah balancing crankshaft gasket oberhaul upah rebore blok.. bearing kt crank minyak itam p/s:aku oberhaul kt mbr kg..just tukar bearing kt crank..rm50..bkk skru suma guna tgn..xpki compressor ..kena tlg dia sekali la turunkan enjin...kotor sikitla tgn kena minyak..xpe..ilmu pye pasal.. | |
haizamlee Laskar Kelas I
| Subject: Re: Overhaul Motor Wed Jan 26, 2011 8:03 pm | |
| kalo masuk blok 2.00...rod kena tukar skali ke...ke pakai rod ori tu,,, | |
| Subject: Re: Overhaul Motor Wed Jan 26, 2011 8:10 pm | |
| - haizamlee wrote:
- kalo masuk blok 2.00...rod kena tukar skali ke...ke pakai rod ori tu,,,
x pyah tukar rod... pkai je... ade yg smpai dt 1.00 pon x tukar rod... | |
| Subject: Re: Overhaul Motor Wed Jan 26, 2011 8:21 pm | |
| - paan1171 wrote:
x pyah tukar rod... pkai je... ade yg smpai dt 1.00 pon x tukar rod... dt 1.00....xphm la..huhuh...n...piston brand apa plak yg kualiti terbaik....hehe.. | |
| Subject: Re: Overhaul Motor Wed Jan 26, 2011 8:58 pm | |
| man jgn-aku pon da lame nak blaja bukak enjin sendiri..tp xde plak org membe2 pomen.. oil seal aku mmg bocor sbb tu tukar.. mentor terbakar.. tayar pn tembus..xtekan klac.. | |
| Subject: Re: Overhaul Motor | |
| Overhaul Motor | |
