 Overhaul Motor
tupaiberasap
su
meerul
samporna ccn
qayyum_qz
banchiksk8
throne_undead
xopai
Conan Edogawa
faaizil
haizamlee
N.A.M.I
ss110 unggu
wan_210407
poknik
lanunlaut
fishbike
h@ziQ
acab
mzul787
airil
kekuravslelabi
adiz
ne0bolimi3rd
sherlock
oddysee11
apmsd
hafidz
ijam125
undetected
anep4742
yoshi
ihsanxx
cerah9
zouk188
ak
archonixm
74 posters
Go to page : Previous  1 ... 6, 7, 8 ... 12 ... 17  Next
Overhaul Motor - Page 7 Empty
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptyMon Sep 06, 2010 8:30 pm
tupai_tempur wrote:
piston aku baru je bobos ahad lepas. hantar g bengkel,serpihan dah masuk cranshaft.
pomen turun enjin,ganti bearing kiri kanan ( brand ntn ke tnt. tak ingat pulak),jek balik rod,lay blok,piston (0.50),ring baru,upah,minyak hitam (elf yang harga dekat rm45. huhu),tukar mj,pilot,set balik carb. gedabak gedebuk semua rm400. ok ke harga tu? berapa km pulak nak pantang?
bobos?....erk...menakutkan....
berapa saiz pj & mj yg ko gne time piston bobos tu bro
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptyTue Sep 07, 2010 7:29 pm
salam..nak bagi info sikit..
aritu aku oberhol rxz aku..
upah oberhol kat DAL motor kampung pandan RM90 je,siap bukak pasang cuci,balancing rod sume..
pastu bearing SKF enduro C3 untuk crank beli kat kedai bearing SKF,Rm26 sebijik.. oilseal NOk Rm18 kat NKS..
nak beli bearing enjin baik beli kat kedai2 yang spesial jual bearing..memang murah giler,janji tau kod..
contoh bearing tayar SKF klau kat kedai motor RM18,kat kedai bearing RM9 je..
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptyTue Sep 07, 2010 8:35 pm
haha...
memang la kat kedai bearing lagi murah..
half price dari kedai moto..
janji tau kod.. atau bawak sample..
kalau tau spek bering lagi bagus..
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptyTue Sep 07, 2010 9:32 pm
pilot 5.5. besar kedabak. dengan kotak angin tebuk. main open pun tak beso cam tu. mj 195. jarum rxz. aku rasa silap kat jarum. top speed minyak tak sapot. minyak memang safe gile. perjalanan sejam bantai top speed 140-150 cuma topup minyak rm7.00 je. last2 melayang rm400. huhuu
sekarang setting pomen lain. pilot 22.5. mj 145. jarum halus. sekarang layan 80-90 je. ada bunyi sekat2 cam tak lepas. masyuk woo. hehee
fishbike
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptySun Sep 12, 2010 12:33 am
lubang eksos di bore cocok ngan lambang bingkai superman, tapi condong ikut ori. 23mm dari atas. 22.5 + letter U selebar 5mm kat tajam, condong kecil tuh nembak lurus ke intake hole yang curvy.
lanunlaut
lanunlaut
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptySun Oct 03, 2010 12:21 pm
salam otai2 sekalian, sy ada hajat nk oberhol moto ni, boleh tak tlg bg sy SENARAI BARANG2 DALAM ENJIN (contoh: bearing berserta no siri, oil seal, crank shaft, gear dll) untuk sy beli sendiri bahan2 tu semua...bawak sumer barang2 tu p kedai then just upah pomen je...rasa2 lagi jimat kan cara mcm ni.... mintak tolong sangat2..
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptySun Oct 03, 2010 1:08 pm
buat cara tu... maybe lagi jimat or lagi mahal..
ko buat moto katner? sabah ke semenanjung ke atas kapal Navy?
kalau kat sabah.. lagi murah la.. kalau kat semenanjung ni..
betel pegi kedai setel semua sekali..
kecuali kalau ko nak hantar kat pomen yang ko kenal@buat sendiri
lanunlaut
lanunlaut
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptySun Oct 03, 2010 11:12 pm
oberhol sumer kat sabah...sini barang2 mahal aku tgk kat kedai...lg 1 takut kalau takde barang yg nk di order...
acab
acab
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptyWed Nov 03, 2010 8:36 pm
agak 2 kalo blok 175 mj ngan pj pew yg sesuai????komen please
poknik
poknik
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptyTue Nov 30, 2010 10:17 pm
aritu g servis, pomen aku tengok minyak itam pastu die kate oilseal da bocor. so aku nak taw dari abg otai skalian oilseal yg mane bocor tu ek? oilseal ade banyak kan? satu lg die kate rod goyang sket..so kalau obehaul kene tuka 1 crankshaft assy skali ngan bearing ke or just tuka conecting rod je?
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptyWed Dec 01, 2010 9:13 pm
klu tgk kt mnyk hitam tue biase klac plate dah out,x tau la die tgk ade serpihan2x oilseal,pelik tue..biase dlm enjin kt crank la bocor,x kat primary kt magnet,tue je la,biase rod gyg tkr 1 set connecting rod spptnye dah ok,klu crank dah out,baru tkr lain,jrg la crank trs jhnm..
wan_210407
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptyTue Dec 21, 2010 12:21 am
salam..to otai2..
td da bukak mangkuk enjin sebelah clutch...nk tuka final gear(betul ke istilah ni?) ori..skrg pakai mata 22..nak tuka 21 balik,. saya ada kemusykilan...setelah tgk pada spring clutch,, problem pertama ada 4bolt...3 je yg ade kepala 1 lagi kepala da xde tp mata die ade dlm housing nut tu.. ade sape2 tau cmne nk settlekn masalah nih??
yg kedua...bg orang mcm saya yg nk DIY...ckup ke bukak nut clutch plate n final gear tu dgn guna impact yg ketuk2 tu...bukn guna impact gun?? sbb impact gun xde...kalo bleh guna impact biasa bole bagi tips sket tuk senang kan proses melonggarkan nut tu... thanks
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptyTue Dec 21, 2010 12:37 am
patutnye sukat blk minyak itam yg ditukar tu..
kalo sbelum ni masuk 850ml, 850ml jugak la kluar..
tp kalo kluar 600-700ml je, haa, jage2 cik salmah~~ silent
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptyTue Dec 21, 2010 4:37 pm
kbyakan nyer oberhol..khatam gak ak bace thread ni..hahaha, top overhaul usik head n blok jer kn? bese rm brape kalu wat? clucth ak cam bunyi laa...dari bulan jan 2010 x sebis2...huhu, tuka myak itam jep...
ss110 unggu
ss110 unggu
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptyWed Dec 22, 2010 11:03 pm
hrge nk rivet mngkuk clutch ni slalu bpe??
sape pena wat? Overhaul Motor - Page 7 452355
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptyFri Dec 24, 2010 3:29 pm
hehe nk ribet ni murah jer, tmpat aku 20, kt area selangor bleh dapatlah 15, aku baru lpas ribet ni Overhaul Motor - Page 7 655303
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptySat Dec 25, 2010 2:38 am
top overhaul servis headblok je..
diy la murah,top gasket baru rm2-3 je,janji ade tools..
clutch bunyi sbb mg sll narik ar tue,selagi x bunyi kruk2x blh je pakai lg,nk confirm bkk cover clutch n pusingkan rumah clutch n gear,agk2x skit je free-play die bt x reti je,aku pakai smp hncr getah rivet,klu nk bg jln moto siap kene tolak Razz
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptySat Dec 25, 2010 12:06 pm
hm "free play" sikit jer tp cam xsedap nk bawak muto...blok pn dah ader bunyi, nk g buat top everhaul ptg ni umah nobita..huhuhu
ss110 unggu
ss110 unggu
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptyMon Dec 27, 2010 12:51 am
bru tkar piston ring mggu lpas, tpi byi mkin bsing...:-(
pomen ni syak byi mngkok clucth, tp bile trik clucth ad gax byi....
hish tkar bnde bru mesty la mkin elok,tp bsing Overhaul Motor - Page 7 844808
panaszzzz!!! Overhaul Motor - Page 7 844808
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptyMon Dec 27, 2010 12:53 pm
hehe ni marah btol ni, rilek la der, bunyi skit2 tu memang ader la, tk kira la time idle ke tak hehe Overhaul Motor - Page 7 321135
ss110 unggu
ss110 unggu
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptyTue Dec 28, 2010 2:36 am
herm bnde da jd, xkn nk bkak ag....
da laa duet xda skang Overhaul Motor - Page 7 763622
Overhaul Motor - Page 7 844808 Overhaul Motor - Page 7 839860 Overhaul Motor - Page 7 763622 Overhaul Motor - Page 7 279868 Overhaul Motor - Page 7 313242 Overhaul Motor - Page 7 655303 Overhaul Motor - Page 7 473957
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptyTue Dec 28, 2010 8:33 pm
klu problem kt bahagian clutch lain bunyinye,mmg lain ngan bunyi ring n x semestinye tkr ring saje bunyi ring hlg,silap2x makin kuat lagi,penyelesaian terbaik rebore je trs..
ss110 unggu
ss110 unggu
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptyThu Dec 30, 2010 1:20 am
ad 1 blok bru rebore saiz sme syg nk pakai Overhaul Motor - Page 7 264185
tp pomen aq ckp blok 2 da wat Overhaul Motor - Page 7 655303
syg o blok bru Overhaul Motor - Page 7 565771
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptySat Jan 08, 2011 5:53 pm
try revert clucth dulu..kot2 ok...
poknik
poknik
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 7 EmptyMon Jan 24, 2011 10:32 pm
aku overhaul kt zam motor seksyen 23.
mahal nak mati.
harap korang nilai..
plug-rm5
4t oil-rm12
gasket-rm18
service charge-rm60
potong block-rm15
piston-rm58
piston pin-rm12
piston ring-rm35
piston bearing-rm15
bearing koyo 6205 2 biji-rm56
balancing bearing 2 biji-rm36
cluch buch-rm28
mainjetr-rm3
pilot jet-rm7
rod-rm130
rod pin-rm68
pump rod-rm15
rod bearing-rm68
oil seal 25x40x8 ARS-rm28
oil seal 32x44x8 ARS-rm28
lay head-rm28
poting-rm100
total=rm883
Overhaul Motor
Page 7 of 17Go to page : Previous  1 ... 6, 7, 8 ... 12 ... 17  Next
» Overhaul Motor v2
» Laporan Kehilangan Motosikal..
» Segala Persoalan V15
