| Segala Persoalan V18 | |
+53Ultra-Z MadAxel bergerKedah adeqyana soNa 125z ganu ~*PeRaK MaLI*~ adiena emy musee paan1171 pedo88 najmimecha JJR2395 bhs2490 -sLip- mukhaz90 Kaer Man4822 Azrul tupai comel qayyum_qz rais6603 hamzi999 NCH_KU aleen90 wormzx mousepink man JGN8917 absolute_ahben abg_apis fizerpool nazjb pasquale Paktam syaz ajizaimi jacob boy fei cai fiq tupaiberasap chocolate babet monster block nurkaye_akmal superjoemanito Shark pfa Apislegend su chaosworld samporna ccn mazakim devilmeasha EjanNiz 57 posters |
| Subject: Re: Segala Persoalan V18 Tue Nov 08, 2011 7:04 pm | |
| kuar kilang sproket 15/43 kan..try la tuka 15/36 or 37..lagi2 meter skala ni..rpm 8 tah2 dapat 170
nazjb Bintara Muda
| Subject: Re: Segala Persoalan V18 Wed Nov 09, 2011 8:33 pm | |
| semua dah sedia maklum meter skala yg baru ni ringaaannnnnn sgt... so,nk tanye lah..boleh x pemuka papan meter tu ditukar? contohnye pemuka meter yg baru masuk pd meter yg lama. dgrnye meter lame agak berat n kelajuan yg ditunjukkan lebih konsisten.. ade yg penah wt x?ingat nk masuk papn pemuka yg baru pada meter lame..sbb yg baru cantik maaaa...hehehe | |
| Subject: Re: Segala Persoalan V18 Thu Nov 10, 2011 8:13 am | |
Azrul Laskar Kelas I
Posts : 146 Join date : 24/01/2011
| Subject: Re: Segala Persoalan V18 Fri Nov 11, 2011 10:00 pm | |
| apa ,kelebihan pkai paip standart tapi da potong ?..klau potong pe yg akn dibuang dlm ekzos? | |
nurkaye_akmal Pegawai Waran I
| Subject: Re: Segala Persoalan V18 Sat Nov 12, 2011 12:00 am | |
| alamak mane otai2 ni, ramai dah bertanye soklan ni hihik, aku nk jawab tpi tk reti kiki | |
Paktam Laskar Kelas I
Posts : 131 Join date : 04/10/2011 Age : 33 Location : Miri,Sarawak/Kuala Lumpur
| Subject: Re: Segala Persoalan V18 Sat Nov 12, 2011 12:47 am | |
| aduzz... moto aku wat hal lak arini... susah nk start... ble da start dia rasa nk mati je bila time idle... rpm stop kat rpm 6~7 time neutral... bwk pun max rpm 6... aku suspect carb kotor... ape pendapat otai2 sekalian? | |
| Subject: Re: Segala Persoalan V18 Sat Nov 12, 2011 12:57 am | |
| ntah otai2..sumer dah berkubur kot..
connecting rod ori?ntah..cap yamaha punya kot..dtg dlm kotak,contoh cam bwh ni: http://www.mudah.my/New+Yamaha+125Z+Original+Connecting+Rod+Kit-12322483.htm
yg bergegar tu tarik sampai rpm brape..stended kalu layan dlm 7-8k jer..kl bergegar tgk skru mana2 kot longgar
nak cabut papan tu kene cabut jarum..bl dah cabut jarum,kedudukan asal dah berubah-->spring dah berubah-->asal berat mungkin bl dah cabut jadi ringan giler2 plak..kecuali kalu fotostat je papan baru,kerat kecik2 kendian tampal skit2 kat meter lama..setel~
paip stended tp dah potong?...persoalannya potong camner?x semestinya bl dah potong tu kompem jadi power..kene tgk plak potong tu tujuan utk apa,nak set ngan blok porting camner,etc2..jgn letak mentaliti dah potong kompem akan pawer,rugi masa depan nnt~
sekian,kl salah tulun sound elok2 yer~
| Subject: Re: Segala Persoalan V18 Sat Nov 12, 2011 1:01 am | |
| - Paktam wrote:
- aduzz... moto aku wat hal lak arini... susah nk start... ble da start dia rasa nk mati je bila time idle... rpm stop kat rpm 6~7 time neutral... bwk pun max rpm 6... aku suspect carb kotor... ape pendapat otai2 sekalian?
aku rase in case kalo carb kotor tk jejas timing time idle rasenye bro, kalo dah kotor tahap gaban nye pun paling tinggi susah start je, ermm ade suspect bocor ke kt carb tu, tkpun setting angin dah lari ker, lagi satu kalo lebih rpm 6 jadik ape | |
| Subject: Re: Segala Persoalan V18 Sat Nov 12, 2011 1:05 am | |
| aku,baru ja anta moto kt kdai..aku nk potong paip untuk buat long..blok semua da port..head skim..klau potong paip mmg bunyi akn jd lain kew ?.. | |
| Subject: Re: Segala Persoalan V18 Sat Nov 12, 2011 1:11 am | |
| - Azrul wrote:
- aku,baru ja anta moto kt kdai..aku nk potong paip untuk buat long..blok semua da port..head skim..klau potong paip mmg bunyi akn jd lain kew ?..
besenya akan ada beza la walaupun sikit..potong camno tu?kl pomen bertauliah yg buat xpe ler,dia lebih tau | |
| Subject: Re: Segala Persoalan V18 Sat Nov 12, 2011 1:22 am | |
besenya akan ada beza la walaupun sikit..potong camno tu?kl pomen bertauliah yg buat xpe ler,dia lebih tau aku pon x tao dye nk operate cm na..ase nye belah prot exzos je kot..buang sarang..dari segi pengunaan minyak lak cm ne ?..kuat skit kew.. | |
| Subject: Re: Segala Persoalan V18 Sat Nov 12, 2011 1:28 am | |
| bab minyak tu agak subjektif,mungkin akan lebih dr bese..kene tgk porting jgk..kl port dah tahap membobok je mmg makan minyak | |
| Subject: Re: Segala Persoalan V18 Sat Nov 12, 2011 1:32 am | |
- bab minyak tu agak subjektif,mungkin akan lebih dr bese..kene tgk porting jgk..kl port dah tahap membobok je mmg makan minyak
oww..lg satu soalan nk tanye..klau blok x port lubang angin,hanya port lubang ekzos n minyak jew..piston enduro..head skim..spec cm ni ley outmeter x ? | |
| Subject: Re: Segala Persoalan V18 Sat Nov 12, 2011 1:36 am | |
| err. slalu nye orang port lubang angin. lubang minyak orang x. maap laen orang laen gaya nye. n kelajuan yang akan dikecapi itu perkara subjektif. tak ley nak cakap. | |
| Subject: Re: Segala Persoalan V18 Sat Nov 12, 2011 1:38 am | |
| Subject: Re: Segala Persoalan V18 Sat Nov 12, 2011 1:39 am | |
| transfer port?lubang minyak masuk kat silinder tu ka..
lubang minyak? | |
| Subject: Re: Segala Persoalan V18 Sat Nov 12, 2011 1:42 am | |
| Subject: Re: Segala Persoalan V18 Sat Nov 12, 2011 1:45 am | |
| thankzz yg sudi menjawab soalan smua..hehe..bkn pew,moto baru anta kdai td..nk msuk piston enduro..risao juga da msuk piston enduro ,top speed still sama jew..rugi la plak kn..masuk piston besar2 ni boley wt jln jaoh kew ?... | |
| Subject: Re: Segala Persoalan V18 Sat Nov 12, 2011 1:48 am | |
| boleh je. tp rugi. baik layan piston kecik. piston beso, maintainance pun beso. | |
| Subject: Re: Segala Persoalan V18 Sat Nov 12, 2011 1:51 am | |
| - nurkaye_akmal wrote:
aku rase in case kalo carb kotor tk jejas timing time idle rasenye bro, kalo dah kotor tahap gaban nye pun paling tinggi susah start je, ermm ade suspect bocor ke kt carb tu, tkpun setting angin dah lari ker, lagi satu kalo lebih rpm 6 jadik ape aku pun rs cmtu... kalo bocor ada cmne lak? brapa kos? yg time idle tu bila remp max dpt 6~7 time neutral... biasa dpt lebih... n bila nk bwk moto xkn dpt lebih rpm 6... tu yg aku kata max rpm 6 je... aku igt nk cuci carb sok(arini)... tgk cmna... | |
| Subject: Re: Segala Persoalan V18 Sat Nov 12, 2011 1:54 am | |
| carb x de kaitan. try cek sambungan carb ke getah hitam tuh. try cek area situ. then try cek head takut longgar. kalau tade jugak, g beli reedvalve bru and tuka reedvalve. hambe pernah terkena dlu. tp itu time pakai reedvalve carbon cap sugaya | |
| Subject: Re: Segala Persoalan V18 Sat Nov 12, 2011 1:56 am | |
| - absolute_ahben wrote:
- boleh je.
tp rugi. baik layan piston kecik. piston beso, maintainance pun beso. maintainance tinggi ?..maksud bro mcm mana 2.. | |
| Subject: Re: Segala Persoalan V18 Sat Nov 12, 2011 1:58 am | |
| 2t da kne pakai yang sadap2 punye. poket makin bocor bler kerap kali kene isi minyak. 2t da kene bukak besa. so 2t pun secare lansung cepat la abes. hui3. | |
| Subject: Re: Segala Persoalan V18 Sat Nov 12, 2011 2:02 am | |
- 2t da kne pakai yang sadap2 punye.
poket makin bocor bler kerap kali kene isi minyak. 2t da kene bukak besa. so 2t pun secare lansung cepat la abes. hui3. perkara biasa la 2..moto nk power kna la berkorban wang ringgit..hehe..pkai piston enduro ni bunyi kt blok kuat ke ?.. | |
| Subject: Re: Segala Persoalan V18 | |
