| Overhaul Motor | |
+70tupaiberasap su -sLip- meerul samporna ccn qayyum_qz banchiksk8 throne_undead xopai pasquale chaosworld devilmeasha Conan Edogawa faaizil unknownh haizamlee N.A.M.I nurkaye_akmal ss110 unggu wormzx Ultra-Z wan_210407 poknik lanunlaut fishbike tupai_tempur h@ziQ acab fizerpool mzul787 airil hanturaya111 kekuravslelabi adiz aus_ipoh paan1171 ne0bolimi3rd amirfarhan yi_tupaijek01 acaapxx man JGN8917 ajizaimi sherlock oddysee11 apmsd HailToKing mousepink hafidz ijam125 mantadkb arjuna86 absolute_ahben undetected anep4742 azdli90 yoshi hidup_sihat ihsanxx vendetta cerah9 geeks chocolate superjoemanito zouk188 ak soNa assasin_lunxe WKQ4913 hasrul_90 archonixm 74 posters |
ajizaimi Bintara Muda
| Subject: Re: Overhaul Motor Sun Feb 28, 2010 11:57 pm | |
| 3000km atau 6bulan top ovehaul, transmission oil 12000km atau 2tahun manual ckp top overhaul biasanya brp RM??? | |
| Subject: Re: Overhaul Motor Mon Mar 22, 2010 1:58 am | |
| transmission oil tu kt mane ek? | |
| Subject: Re: Overhaul Motor Mon Mar 22, 2010 2:10 am | |
| transmission oil kt keta aku tau=myk gearbox...transmission tu sndiri maksudnya sistem gear..auto @ manual...tp kalu kat moto??? maybe yg dmaksudkan beliau ialah myk enjin=myk itam=minyak 4t...tp xkan smpi 12k km ru nk tkar...berkecaila clutch plat cam tu...hehe....kot la... | |
| Subject: Re: Overhaul Motor Mon Mar 22, 2010 2:16 am | |
| tu pelik tu.hua3. transmission oil ny setau sye la minyk gearbox @ minyk itam tupa.hu3. bkn berkecai2 da. da jdik cm serebuk teh da.keh3. | |
soNa Bintara Muda
| Subject: Re: Overhaul Motor Mon Mar 22, 2010 1:09 pm | |
| - absolute_ahben wrote:
- transmission oil tu kt mane ek?
transmission oil = minyak transmisi @ minyak gear 125z = 2 stroke = myk pelincir hanya bermain pada bahagian gear+clutch jadi, transmission oil bagi motosikal adalah untuk kegunaan 2 stroke engine..tapi tak sesuai untuk kegunaan 4 stroke yang memerlukan myk yang lagi likat untuk melincirkan piston dan kepanasan yang lagi tinggi.. sebab itu,minyak pelincir bagi 125z dipanggil minyak transmisi.. | |
acaapxx Bintara Kanan
Posts : 787 Join date : 29/03/2010 Location : seremban~besut
| Subject: Re: Overhaul Motor Wed Apr 07, 2010 12:52 pm | |
| aku penah kene dkt 200 gak overhll moto nih.. siap ngn barang n upah... | |
| Subject: Re: Overhaul Motor Wed Apr 07, 2010 1:37 pm | |
| ai murahnya..pe yg ko tukar..kos upah shj berapa | |
| Subject: Re: Overhaul Motor Thu Apr 08, 2010 3:15 pm | |
| - zouk188 wrote:
- Quote :
- aku nak kongsi gak..aku pun baru gak overhaul...
rod...... rm130 jet rod workmanship......25 piston.......rm60 piston ring.....rm60 bearing skf 6205 (2 biji)....rm60 oil seal.....rm35 overhaul gasket....rm35 bearing bust....rm100 minyak 4t.....rm28 piston pin..rm10 piston bearing...rm10 balancing bearing..rm20 reboring...rm20 upah..rm100 discount...rm20 total..dalm rm680...
mahal siot.. salam semua...newbies disini....nkblaja oberhaoul ngn bro zouk...bleh x?blaja uitm shah alm kos meki...tp skrg prktikal kt tganu...insyallh kalo xda pape bln 7 ni smbg blik kt shah alm...nt aku pm nofon kt bro zouk...motor aku ni ada bunyi pelik ckt...bunyi mcm ring piston gtu.tp bkn ring..aku da tukar pin n bearing piston,rebore blok,pastu bunyi tu xhlang2 jgk...ada kaitan ngn rod x? | |
| Subject: Re: Overhaul Motor Thu Apr 08, 2010 4:20 pm | |
| bunyik kat mangkuk klac kot..klau tarik klac bunyik gak ke? | |
| Subject: Re: Overhaul Motor Thu Apr 08, 2010 4:35 pm | |
| - WKQ4913 wrote:
- bunyik kat mangkuk klac kot..klau tarik klac bunyik gak ke?
bkn mgkuk clutch...masa tarik klac pon bunyi jgk...ms jalan bunyi jgk,tp paling ketara ms jalan,lpas trotel tanpa tarik klac...mknayer bia motor jalan dlm keadaan bergear n xtarik trotel | |
| Subject: Re: Overhaul Motor Sat Apr 10, 2010 8:12 pm | |
| - man JGN8917 wrote:
- ai murahnya..pe yg ko tukar..kos upah shj berapa
tah la bro.. tpi xbyk ngat tuka.. mura sbb wat kat kdai membe... | |
amirfarhan Laskar Kanan
Posts : 211 Join date : 07/04/2010 Age : 35 Location : sa-kb-sa
| Subject: Re: Overhaul Motor Wed Apr 28, 2010 1:28 pm | |
bkn mgkuk clutch...masa tarik klac pon bunyi jgk...ms jalan bunyi jgk,tp paling ketara ms jalan,lpas trotel tanpa tarik klac...mknayer bia motor jalan dlm keadaan bergear n xtarik trotel ni jd mcm ak la ni...bunri ring tu,or ko pnye rod longgr ke ak tkar piston,gasket, sje pn da rm250 upah bkak,korek blok mhl.... | |
ne0bolimi3rd Laskar Muda
Posts : 11 Join date : 08/05/2010
| Subject: Re: Overhaul Motor Mon May 17, 2010 1:15 am | |
| pagi tadi baru sambung projek da dekat sminggu terbengkalai.. housing bearing secondary kot.. da pecah 2 batang..spring oil seal masuk lak dlm bearing tu.. patut la bunyi macam haram.. misteri minyak hitam kurang tak dapat dikesan..adoi aii.. barang yg da beli.. rod rm125 bearing crank rm150 piston te 25 ring riken 29 upah pump rod rm10 petrol+diesel da dekat rm20 buat cuci je penangan 10 bulan tak basuh moto.. lain2 bearing/oil seal/full set gasket belum lagi.. tah bape lagi la nak kena ni.. tu pon aku tak hantar rebore blok.. miskin la camni...
nak tya sket..klu lampu 2t,top,free kat meter tak nyala pasal apa arrr... nak kena ada bateri gak ke..aku wiring moto ni memang fail.. | |
| Subject: Re: Overhaul Motor Mon May 17, 2010 11:27 am | |
| - ne0bolimi3rd wrote:
- pagi tadi baru sambung projek
nak tya sket..klu lampu 2t,top,free kat meter tak nyala pasal apa arrr... nak kena ada bateri gak ke..aku wiring moto ni memang fail.. umah bearing ok ke bro?.. bearing tuh pki bearing ape?.. | |
| Subject: Re: Overhaul Motor Mon May 17, 2010 11:32 am | |
| kalau berminat nk oilseal crankshaft original cop Acs, roger aku... seketul dlm rm20++ | |
ak Laskar Kanan
Posts : 279 Join date : 04/05/2009 Location : tengganu,dungun
| Subject: Re: Overhaul Motor Mon May 17, 2010 12:06 pm | |
bkn mgkuk clutch...masa tarik klac pon bunyi jgk...ms jalan bunyi jgk,tp paling ketara ms jalan,lpas trotel tanpa tarik klac...mknayer bia motor jalan dlm keadaan bergear n xtarik trotel hehe..tumpang skaki..mslh ko tu sme cam ak laa..ak aspect rod longgar..free play(gerak kiri kanan) tu terlalu banyak..sbb tu bunyi kot..ak pon da wat mcm ko potong ,tukat pinston n ring..tpi still bunyi..kne overhaul la kot klu nk hilang bunyi..ak punyer x effect kat performance pon..ko punyer?? | |
| Subject: Re: Overhaul Motor Mon May 17, 2010 3:25 pm | |
bkn mgkuk clutch...masa tarik klac pon bunyi jgk...ms jalan bunyi jgk,tp paling ketara ms jalan,lpas trotel tanpa tarik klac...mknayer bia motor jalan dlm keadaan bergear n xtarik trotel hehe..tumpang skaki..mslh ko tu sme cam ak laa..ak aspect rod longgar..free play(gerak kiri kanan) tu terlalu banyak..sbb tu bunyi kot..ak pon da wat mcm ko potong ,tukat pinston n ring..tpi still bunyi..kne overhaul la kot klu nk hilang bunyi..ak punyer x effect kat performance pon..ko punyer?? performance tu stended je....xda effect mane pon...cuma bunyi jela xsdap dngar...aku da overhaul enjin motor aku...aku rs bunyi tu sb bearing rod la....yg dkt crankshaft tu...bkn yg dkt piston | |
ak Laskar Kanan
| Subject: Re: Overhaul Motor Tue May 18, 2010 8:24 am | |
performance tu stended je....xda effect mane pon...cuma bunyi jela xsdap dngar...aku da overhaul enjin motor aku...aku rs bunyi tu sb bearing rod la....yg dkt crankshaft tu...bkn yg dkt piston sme jela cam ak..wat2 xdgar jela bunyi..moto kuat lenjan lgi kuat bunyi..ko wat overhaul stu engine ker??mksud ko crank pin bearing??mingkin gak kot..tapi mase overhaul tu ko x tukar ker? | |
| Subject: Re: Overhaul Motor Wed May 19, 2010 10:31 pm | |
| silap la..cek balik smalam umah bearing crank yg patah tu..memang terbaik la.. seb baik benda tu utk cover oil seal je.. patut minyak itam kurang.. dulu bearing stock je..koyo japan ni 1st time turun enjin..da terpaksa sgt.. skang ni nak try skf lak.. sek layan fag je..da 3hari tak sambung lagi.. tgu ujung minggu lak.. kang rajin aku upload gambar menatang yg patah tu... nak kata bearing housing yg pecah pon tak gak.. macam stopper utk oil seal je kat crank shaft tu gambar oil seal tu koyak takde arr.. tangan ada dua je..takkan tgn hitam2 nak pegang henpon.. | |
| Subject: Re: Overhaul Motor Fri May 28, 2010 5:29 pm | |
| moto da siap 2minggu lepas.. crank bearing skf enduro c4.. perfomance memang tip top.. tak seringan FAG la tapi tak jauh beza.. nak pegi 11 senang2 je.. lain2 aku guna NTN je.. balancing sebijik aku guna skf explorer c3.. oil seal NOK tak tau tahan ke tak.. nak beli ACS tak berduit la haku..huhuhu piston maintain 1.00 lagi wlupon da longgar sket.. spocket memang spoil..16,36 (dulu main long) skang wat pegi kedai je.. nak kena tukar jugak la.. so sesapa nak tya skf or fag better dua2 cam sama je.. tapi skf ada sebijik ceramic ball | |
| Subject: Re: Overhaul Motor Fri May 28, 2010 5:42 pm | |
| perh..tukar full bearing baru,byk bajet tue nok tue kire oilseal baik la,ha3x.. | |
| Subject: Re: Overhaul Motor Fri May 28, 2010 11:14 pm | |
| tukar semua la..motor da nak 10tahun.. alang2 da bukak.. nak bukak lagi tah bila.. tu pon sebab bearing crank rosak masuk spring oil seal.. tepakse la merajinkan diri.. walaupon da betahun tak pegang minyak..huhuhu total damage 600 lebih.. klu anta kedai tak tau la.. | |
| Subject: gear 6 bunyik... Sun Jul 04, 2010 7:29 am | |
| msok gear 6 je kuar bunyik berdengung per prob ek..? | |
aus_ipoh Laksamana Armada
Posts : 2936 Join date : 19/05/2009 Age : 37 Location : ipoh dan kawasan yg sewaktu dengannya
| Subject: Re: Overhaul Motor Sun Jul 04, 2010 12:23 pm | |
| bro sila kenalkn diri dulu..klik link kat bwh nie http://125z.forumms.net/pengenalan-diri-f3/my-email-ym-friendster-handphone-location-t42.htm http://125z.forumms.net/pengenalan-diri-f3/attention-to-all-new-members-t2.htm tq M125ZC MODERATORS | |
| Subject: Re: Overhaul Motor | |
| Overhaul Motor | |
