 Resleeve Blok
payjalrazali
PostSubject: Resleeve Blok   Tue Sep 27, 2011 10:55 am
ada yg cakap.. resleeve blok ni akan mengakibatkan blok mudah jem panas.. apa pendapat otai2??
blok aku ni da oversaiz da...nk campak dlm sungai syg..
PostSubject: Re: Resleeve Blok   Tue Sep 27, 2011 11:07 pm
oversize msk la enduro bro..thread nie dah ade dulu kot,tpi dah kene delete agknye,ok je pun blok yg dah tanam sleeve baru,cume material untuk sleeve yg nk tanam baru tue kene baik la..
PostSubject: Re: Resleeve Blok   Tue Sep 27, 2011 11:31 pm
alang2 nak masuk sleeve try la tgk2 piston ni kalau berminat..secara kasar cuma adjust tinggi blok n head guna gasket je.. Very Happy
yang ni..59mm..
MODEL TZR-150
OEM No. 3RR-
CODE No. AY0800X
BORE(mm) :A 59
LENGTH(mm) :B 66.50
PIN DIA (mm) :C 16
COMPRESSION HIGHT① (mm):D 33.60
COMPRESSION HIGHT② (mm):E 30.00
PIN LENGTH (mm) :F 16x50.5
PLATING O
STROKE 2
PISTON CODE No. PY1060X
atau yang ni..59mm gak.. Basketball
MODEL VR-150
OEM No. 2JK-
CODE No. AY0810X
BORE(mm) :A 59
LENGTH(mm) :B 66.40
PIN DIA (mm) :C 16
COMPRESSION HIGHT① (mm):D 33.40
PLATING O
STROKE 2
PISTON CODE No. PY1070X
yang ni spec piston stended..
MODEL Y-125Z
OEM No. 5BU-
CODE No. AY0720X
BORE(mm) :A 53.8
LENGTH(mm) :B 66.70
PIN DIA (mm) :C 16
COMPRESSION HIGHT① (mm):D 32.70
COMPRESSION HIGHT② (mm):E 29.50
PIN LENGTH (mm) :F 16X44.5
PLATING O
STROKE 2
PISTON CODE No. PY0960X
soNa - 0194485713
samporna ccn
PostSubject: Re: Resleeve Blok   Thu Sep 29, 2011 10:14 pm
heheheh resleve ni pe mksudnye??
kcikkn smula blok ke??? Very Happy Laughing
ok ke???
PostSubject: Re: Resleeve Blok   Mon Oct 03, 2011 12:27 am
bykkn lah lagi para2 otai info tentang Resleeve blok ni,aku pn berminat gak nk tau,memandangkn blok aku ni pn dah makin membesau..
kdg2 ada yg berminat nk pkai piston kecik2
cth:
1-Resleeve blok bahan@jenis yg paling bagus(kot2 ada nama sainstifiknyer)
2-biasa harganyer brapa?(kalo dah nk sama harga mcm nk beli blok lain,bole difikir2kn Resleeve blok)
3-ketahananyer bgaimana pula(ok ke x,betul ke mudah jem panas,kalo ok,itu sdah bagus)
4-ada yg dah pernah bt
sekian terima ksh..
PostSubject: Re: Resleeve Blok   Mon Oct 03, 2011 12:55 am
aq pnah buat. soo far okkk la.. xpenah kena jem pnas lg.. maintain jg 2t ok je... dari 0.25 enduro - stendet 0.25..( aq rebore lg skali dari 0.0).. tpi dri pngalaman mne2 blok yg dh modi 2 elok teruskn je la pkai smpai abis sleeve... bergantung pd porting...
cth: blok aq dh port ikut saiz piston oversize.. bila di resleeve porting masih yg asal ikut piston oversize.. tkut xlarat piston baru 2 nk bwak... sbb dh overport... jdik gear 6 ko mmg lemau... tpi still boleh je pkai.. counter balik spoket...
renung2kn lah... klau blok stendet rse xde mslah... upah x smpai rm 150...
ipin_8403
PostSubject: Re: Resleeve Blok   Wed Oct 05, 2011 5:28 pm
ikut besi yg ko nak tanam buat sleeve tu la...jgn pakai besi murah.memang jem pans aja..
Resleeve Blok
