| Segala Persoalan V15 | |
+56Kaer am125zr mukhaz90 syamaleeto roda karat anep4742 SAYANG SAHABAT Shark pfa najmimecha vendetta faristrx mutoudoh musesaddiq meerul kenzou -sLip- black_125zx fizerpool nazjb h@ziQ MadAxel wgs4@9 Azrul softoperator geeks hanturaya111 bender monster block Shiro superjoemanito EjanNiz chaosworld ajizaimi komi tupaijet_junior man JGN8917 mangketey MaGNum_1721 chocolate AdHwA tupaiku nurkaye_akmal muhd.haniff Man4822 Kato_125 aboi Ultra-Z jacob yi_tupaijek01 devilmeasha tupai comel babet unknownh NCH_KU Conan Edogawa mantadkb 60 posters |
| Subject: Re: Segala Persoalan V15 Tue Jun 14, 2011 11:30 am | |
| - babet wrote:
- cmne nk kira hp moto???
ape formulanya ye?
saiz piston paling besar yg bleh masuk kt blok 125z saiz ape ye? memerlukan jwpn.... | |
| Subject: Re: Segala Persoalan V15 Tue Jun 14, 2011 12:24 pm | |
| - babet wrote:
ape formulanya ye?
saiz piston paling besar yg bleh masuk kt blok 125z saiz ape ye? memerlukan jwpn.... kalau nak kira hp tu..tnya uncle google..aku x tau..math.fail..haha...piston 125z paling besar saiz 2.00 (utk blok std la)..hehehe..lebih dari tu da oversize..kena masuk piston moto lain.. | |
mukhaz90 Laskar Muda
Posts : 28 Join date : 03/02/2011 Age : 34 Location : nilai,marang.
| Subject: Re: Segala Persoalan V15 Tue Jun 14, 2011 9:27 pm | |
- cek dulu tgk pum 2t jln cun ke x,time moto hdp,bkk hos kecik kt pum 2t tue,yg bersmbg ke carb,pastu pusingkan roda hitam tu,2t tue akan kuar ikut byk mane ko pusingkan roda hitam tue,klu pusing byk dah,tapi 2t kuar same je,mmg ade problem la pump kit 2t tue,klu ok mean problem lain la..
thanks bro..terfikir jgak nk buat mcm ni tp risau kat carb tu kn xde 2t 6t...tkut calar je... 6t ak try buat.... roda itam tu ak taw...yg sgkut kabel 2t tu kn? thanks bro... | |
| Subject: Re: Segala Persoalan V15 Tue Jun 14, 2011 9:34 pm | |
| - devilmeasha wrote:
- babet wrote:
ape formulanya ye?
kalau nak kira hp tu..tnya uncle google..aku x tau..math.fail..haha...piston 125z paling besar saiz 2.00 (utk blok std la)..hehehe..lebih dari tu da oversize..kena masuk piston moto lain.. piston oversize tu plak brp max saiz nya bro? | |
roda karat Laskar Kelas II
Posts : 879 Join date : 07/11/2009 Age : 35 Location : parit moen, bagan, batu pahat...orang kampong jer...
| Subject: Re: Segala Persoalan V15 Wed Jun 15, 2011 8:16 am | |
| 3.0 125z ok lg...ko try up lg babet.. | |
| Subject: Re: Segala Persoalan V15 Wed Jun 15, 2011 8:29 am | |
| rasanya hampir xde max..kalau pandai costum masuk piston kancil dlm tupai..xde masalah rasanya.. .., 125z saiz 2.00=56mm, da habis piston tupai (sleeve da nipis) leh sambung kat yamaha enduro 0.25>2.00=56.25mm>58mm, da habis yamaha enduro..leh masuk piston honda raider-ni aku x tau..tanya abam choco..hehehe.. p/s: tapi aku ada nampak kat mudah jual piston racing..starting saiz 59mm-60mm.. http://www.mudah.my/Yamaha+125z+piston+racing+japan-9952958.htm | |
Azrul Laskar Kelas I
Posts : 146 Join date : 24/01/2011
| Subject: Re: Segala Persoalan V15 Wed Jun 15, 2011 5:19 pm | |
| klau Blok da porting lubang angin,minyak n ekzos..piston 0.75..klau pkai head standart boley x ?.. | |
| Subject: Re: Segala Persoalan V15 Wed Jun 15, 2011 5:45 pm | |
- rasanya hampir xde max..kalau pandai costum masuk piston kancil dlm tupai..xde masalah rasanya.. ..,
http://www.mudah.my/Yamaha+125z+piston+racing+japan-9952958.htm orite...terbaik la penjelasan ko bro..thnx byk2.. | |
| Subject: Re: Segala Persoalan V15 Wed Jun 15, 2011 5:46 pm | |
| - roda karat wrote:
- 3.0 125z ok lg...ko try up lg babet..
blok ak kecik lg,,,juz tnye...sbb ingt nk cari blok stndard saiz 1.00 dan ke atas...kekeke,,,nk layan bigbore... | |
kaz Laskar Muda
Posts : 2 Join date : 15/06/2011 Age : 36 Location : johor
| Subject: problem nk idup kan motor Wed Jun 15, 2011 10:44 pm | |
| assalamualaikum, baru kt sini..nk tanya otai2 125z, klu moto baru beli tp susah nk idup pagi2, kne tarik choke bru idup, problem apa ye..angin dah bnyk kali setting, tp same gak, timing pun if rem lambt turun. pas 2 enjin cam ada bunyi bising. moto baru beli 3 minggu. mintak pendapat ye..risau nie... | |
su Laskar Kelas I
| Subject: Re: Segala Persoalan V15 Thu Jun 16, 2011 12:32 am | |
| salam..keme nk tanye ni...macam mane nk pasang piston ring dengan btul? asl keme tukor pasang yg bru je msti bunyi..kuat plak tu...runsing teman.. | |
| Subject: Re: Segala Persoalan V15 Thu Jun 16, 2011 7:21 am | |
| selagi x kuar besi aloi kat sleeve blok,maknanya still bleh pki,tp sleeve stended xleh lebih dr 58mm..57.++ pun dah kuar aloi..kl berani pki je walaupun aloi dah kuar,mudah jem kalu jgn ditanya~
blok resing yg aku pki pun 58.5mm dah kluar aloi
inche su,tukar piston ring sj ka?xde gambor le nak jelaskan... | |
| Subject: Re: Segala Persoalan V15 Thu Jun 16, 2011 7:26 am | |
| xperlu bukak thread bru lar bro... usha thread ni sudah..dah ade problem cam ko sblum ni kat sini http://125z.forumms.net/t2156-segala-persoalan-v15..mto bru standard lar susah skit..xnk susah up kat pilot...skang pilot standard kilang 15 kan? up kn jd 17.5 sudah..pastu set sikit angin..mainjet jgn usik... slmat mncuba | |
| Subject: Re: Segala Persoalan V15 Thu Jun 16, 2011 8:56 am | |
| telebih suda...terlebih set kot..standed la moto standed slalu kena tarik choke pagi2..x payah la set dulu..tggu habis pantang baru set..timing if lambat turun sebb minyak lebih, angin kurang..mmandangkan moto bro std..so maknanya..angin kena buka lagi.
p/s: minyak lebih(banjir-overflow) pun boleh sbb kan moto susah nak hidup...mgkin sebb masa bro start, throttle pulas lebih sgt..
bro..sila perkenalkan diri dulu.. | |
su Laskar Kelas I
| Subject: Re: Segala Persoalan V15 Thu Jun 16, 2011 10:22 am | |
inche su,tukar piston ring sj ka?xde gambor le nak jelaskan...[/quote]
ye inche chocolate...sbb hari tu msuk blok baru,jadi piston,ring dan lain2 smua bru...da siap pasang ok tp ring still bunyi.. ke cara keme pasang ring tu x betul?
| Subject: Re: Segala Persoalan V15 Thu Jun 16, 2011 10:54 am | |
| - su wrote:
inche su,tukar piston ring sj ka?xde gambor le nak jelaskan... ye inche chocolate...sbb hari tu msuk blok baru,jadi piston,ring dan lain2 smua bru...da siap pasang ok tp ring still bunyi.. ke cara keme pasang ring tu x betul? [/quote] oberhol | |
| Subject: Re: Segala Persoalan V15 Thu Jun 16, 2011 1:35 pm | |
| ntah le,rasanya kl pasang x btul xleh masuk trus piston dlm blok..dah porting ka blok tu?..saiz piston?kompem ka bunyi ring? | |
Man4822 Bintara Muda
| Subject: Re: Segala Persoalan V15 Thu Jun 16, 2011 5:58 pm | |
| nak tanye sikit, tabung ekzos kalau dah bengkok, boleh betulkan balik x?? | |
su Laskar Kelas I
| Subject: Re: Segala Persoalan V15 Thu Jun 16, 2011 7:17 pm | |
- ntah le,rasanya kl pasang x btul xleh masuk trus piston dlm blok..dah porting ka blok tu?..saiz piston?kompem ka bunyi ring?
bro mazakim : kne oberhol ke?..sori le keme idak le tau sangat psal motor..hehehe bro chocolate : piston cap RK..ring cap NPR..xde port ape2 pun..blok cap ikk taiwan mari.. saiz std 0.0.. rse nye kompem bnyi ring..sebab time idle je bunyi..ble jln ok je.. yang runsing nye bkn psal ape..kuat jugak le bnyi nye..hehehe | |
| Subject: Re: Segala Persoalan V15 Thu Jun 16, 2011 8:11 pm | |
bro chocolate : piston cap RK..ring cap NPR..xde port ape2 pun..blok cap ikk taiwan mari.. saiz std 0.0.. rse nye kompem bnyi ring..sebab time idle je bunyi..ble jln ok je.. yang runsing nye bkn psal ape..kuat jugak le bnyi nye..hehehe mcm bunyi mangkuk clutch je...time jalan xdgr..bile idle je dgr... | |
| Subject: Re: Segala Persoalan V15 Thu Jun 16, 2011 9:17 pm | |
| mungkin la..try kacip clutch masa idle,kl bunyi tu hilang maknanya mangkuk clutch yg problem..kasi panaskan enjin dl,baru buat | |
su Laskar Kelas I
| Subject: Re: Segala Persoalan V15 Thu Jun 16, 2011 11:34 pm | |
- mungkin la..try kacip clutch masa idle,kl bunyi tu hilang maknanya mangkuk clutch yg problem..kasi panaskan enjin dl,baru buat
thanks bro2 sekalian...sbb sudi dengor luahan perasaan teman...hehehe mangkuk clutch memang da bunyi...(klak klak klak)...tp ni bnyi kt blok...lbih kurang mcm ni...(ktik ktik ktik) | |
| Subject: Re: Segala Persoalan V15 Fri Jun 17, 2011 2:49 pm | |
| eh cam bunyi timing bom je keh3..piston longgar kot,xpun roller bearing piston dah haus | |
| Subject: Re: Segala Persoalan V15 Fri Jun 17, 2011 4:25 pm | |
| pada ak bunyi klik klik klik klik klik klik lelaju kat blok tuh normal jer.... cer masuk 2t shell vsx or seumpama... | |
| Subject: Re: Segala Persoalan V15 | |
