 Segala Persoalan V15
Go to page : Previous  1 ... 8 ... 13, 14, 15, 16  Next
PostSubject: Re: Segala Persoalan V15   Fri Jun 10, 2011 4:38 pm
babet wrote:
speedometer aku dah tak berfungsi....nak start inspection dr mana ye?
kabel kat meter still terpasang kemas,speedo kt rim takda rosak pape...
kabel masih elok terpasang lum tntu kabel tu ok....
kot2 kabel tu rosak....jarum lain kat meter elok kan?
PostSubject: Re: Segala Persoalan V15   Fri Jun 10, 2011 5:03 pm
yup...jarum rpm,minyak n lampu2 semua hidup je lg kt meter tu...
speedometer je yg tak jalan..
so nak bwat ape ye?tukar kabel kt dlm tu?
PostSubject: Re: Segala Persoalan V15   Fri Jun 10, 2011 5:13 pm
try bkk kabel tgk dalam putus ke x
skim head nak kasi kompression tinggi,kompression tinggi-->letupan/tujahan makin kuat-->makin larat nak tolak muto-->kene set balik karb
tp kl kompression tinggi sgt nnt berlaku detonation,campuran bahan api meletup seblom spark plug nyala-->tambah haba kat head/blok,letupan x seragam-->power loss-->silap2 bleh buat piston tembus/sumbing sbb panas x sekata
PostSubject: Re: Segala Persoalan V15   Fri Jun 10, 2011 5:30 pm
p0tong head ni cume nk tmbhkn pickup kn..top tetap same atau lbh sket je kn,btl x?nk tmbh topspeed kena la p0rt blok.
jacob
PostSubject: Re: Segala Persoalan V15   Fri Jun 10, 2011 6:09 pm
moto ak lak bile pagi,meter semua tu jalan..
tp bile tgh hari/ptg,park tmpt pns skit,
semua meter tak naek..kene kasi lama skit
then ketuk2 kat meter tu,bru semua naek..
sbb ap ye?
anep4742
PostSubject: Re: Segala Persoalan V15   Fri Jun 10, 2011 7:50 pm
salam..nape moto aku time enjin sjuk (idle) lmpu N ngan 2T nyala
tp time enjin dh pnas (idle gk) dua2 lmpu tu x nyala?
PostSubject: Re: Segala Persoalan V15   Fri Jun 10, 2011 7:58 pm
ade wirering pr0bz kt meter k0t.chek r,mane tw ade yg l0nggar
mangketey
PostSubject: Re: Segala Persoalan V15   Fri Jun 10, 2011 9:26 pm
so lbh baik xyh skim head klu cmtuh..port blok je lar..phtu set carb..bleh pegi outmeter x?
http://man_rempitkerteh@yahoo.com
meerul
PostSubject: Re: Segala Persoalan V15   Fri Jun 10, 2011 10:32 pm
nk tnye la pd spe2 pn..motor sye carb z catalyzer slide z milenium,port blok dan lay head.. bkak kotak angin pinston 0.0.. outmeter tp x sdap bwak bese2.. vtec dy cm ssah sgt nk bkak.. rse cm x smooth.. knpe ea?
PostSubject: Re: Segala Persoalan V15   Sat Jun 11, 2011 9:08 am
bkn kata xyah...cuma.buat dgn betul la..jgn over..port blok pun klau x betul..campak longkang terus..tp apa2 pun try la dulu..belajar dari kesilapan..hehehe
PostSubject: Re: Segala Persoalan V15   Sat Jun 11, 2011 12:36 pm
aaaa lebih kurang camtu la..mungkin bleh main tang spoket skit
x gak,baik skim head skali..yg pernah aku pki blok dah korek tp head stended x best mcm pki ngan head skim...lain pomen lain setting kot
Shark pfa
PostSubject: Re: Segala Persoalan V15   Sat Jun 11, 2011 3:21 pm
salam....
ni pasal clutch motor aq....
apasal motor masih bergerak walaupun aq dah kacip clutch tu???
PostSubject: Re: Segala Persoalan V15   Sat Jun 11, 2011 3:48 pm
Shark pfa wrote:
salam....
pernah kacau kabel clutch tu ker?..
1.mungkin timing clutch terlalu rendah..
2.susunan clutch pad x betul..(pengalaman sendiri).
PostSubject: Re: Segala Persoalan V15   Sat Jun 11, 2011 3:50 pm
betul3..aku sokong abam choko..aku pakai blok std..head skim..performance
Shark pfa
PostSubject: Re: Segala Persoalan V15   Sat Jun 11, 2011 4:37 pm
devilmeasha wrote:
Shark pfa wrote:
salam....
tank bro sbab replay...
ermmm....timing clutch ngan clutch pas tu ape ehhh...huhu sory lar...sy bdak baru blajar....
ari tu aq ade usik kabel clutch....aq kemaskan nut kabel tu...nut tu ade dkat pengacip....
PostSubject: Re: Segala Persoalan V15   Sat Jun 11, 2011 5:59 pm
oo..die ada 1 bolt ngan 1 nut kan..hidupkan moto.longgarkan nut..then longgarkan bolt tu..tarik clutch pastu test masuk gear..kalau moto still gerak..longgarkan lg bolt tu..buat sampai moto x gerak..pastu ketatkan nut..spya setting x gerak2 lagi..
sorry kalau x fhm..aku xberapa pandai nak explain..hehehe.
Shark pfa
PostSubject: Re: Segala Persoalan V15   Sat Jun 11, 2011 9:51 pm
cantik.....jwapan yg lengkap dan padat.....tenk youuu....
PostSubject: Re: Segala Persoalan V15   Mon Jun 13, 2011 11:15 am
err..
sy ade sedikit persoalan..
apekah yG menyebabkan coil magnet kong a.k.a. rosak...
harap otai2 dpt mmberi pnjelasan..
skian persoalan sy..
PostSubject: Re: Segala Persoalan V15   Mon Jun 13, 2011 11:41 am
ni pendapat jer..mungkin short circuit kot..xpun da uzur/kotor,wayar(dawai coil) da putus2..
PostSubject: Re: Segala Persoalan V15   Mon Jun 13, 2011 12:16 pm
oilseal yg kt casing magnet 2 mmg xde jual ea?kalau x pakai,ade efek x kt moto?
PostSubject: Re: Segala Persoalan V15   Mon Jun 13, 2011 12:25 pm
oil seal?ker getah?...kalau oilseal, rasanya tu oilseal utk crankshaft..yg bersambung kat mangkuk mgnet..(flywhell)
PostSubject: Re: Segala Persoalan V15   Mon Jun 13, 2011 4:31 pm
cmne nk kira hp moto???
ape formulanya ye?
saiz piston paling besar yg bleh masuk kt blok 125z saiz ape ye?
PostSubject: Re: Segala Persoalan V15   Mon Jun 13, 2011 8:08 pm
haa yg getah 2 la..ade jual ke?klw x pkai gth 2 xde ape2 ke?
mangketey
PostSubject: Re: Segala Persoalan V15   Mon Jun 13, 2011 8:24 pm
owh..klu head skim nih compression dia lgi tnggi lar..ptt pun rpm lancar je naik..
PostSubject: Re: Segala Persoalan V15   Tue Jun 14, 2011 8:34 am
x tau la..rajin2 la tanya2 bengkel moto..ada jual rasanya..tggu member lain bagi pendapat.. Basketball
Page 14 of 16Go to page : Previous  1 ... 8 ... 13, 14, 15, 16  Next
