| Segala Persoalan V10 | |
+65MadAxel nazrifumi chrome cerry87 archonixm nurkaye_akmal ariffm0hd B4cKTr4X midi wan2pai Apislegend Kato_125 AEJ3525 zul fazli MegatBLA3089 venom jem_125zr MaGNum_1721 CerealKiller kenzou tupaiku N.A.M.I zariq1 redline nazjb mzul787 xapex wst2360 man JGN8917 iqram ayl alemm unknownh ajizaimi h@ziQ koie06 k.a chaosyu94 buntat mR.nobita assasins kudaunismall chocolate laporpo_laporno tupai comel roda karat wormzx eddy8075 fizerpool hanturaya111 yi_tupaijek01 vendetta Kaer Jokey Cabuk mazakim geeks paan1171 babet Ezad superjoemanito mantadkb kUnAk Ultra-Z hamzi999 BKR3**4 chaosworld 69 posters |
mzul787 Laskar Muda
Posts : 41 Join date : 27/11/2009 Age : 33 Location : utp
| Subject: Re: Segala Persoalan V10 Sat Nov 20, 2010 4:38 pm | |
| bro. cam ngan spring function dye tok pe ae? klu tuka plug n play je ke? | |
| Subject: Re: Segala Persoalan V10 Sat Nov 20, 2010 6:35 pm | |
| - mzul787 wrote:
- bro. cam ngan spring function dye tok pe ae? klu tuka plug n play je ke?
cam? spring valve? sistem enjin 2stroke tk pkai cam n spring valve bro.. porting blok utk up performance.. kalo spring clutch ade la, pickup lg mantop, jari tgn kiri semakin berotot.. | |
mzul787 Laskar Muda
| Subject: Re: Segala Persoalan V10 Sat Nov 20, 2010 6:45 pm | |
cam? spring valve? sistem enjin 2stroke tk pkai cam n spring valve bro.. porting blok utk up performance.. kalo spring clutch ade la, pickup lg mantop, jari tgn kiri semakin berotot.. ooo. tu aku plek asl x pna dbncng kn pasl bnde2 ue kat sini. aku bese lepak ngan bdk LC. so dga2 dorg ckp2 sal bnde alah tu. haha p/s: sape2 ade nk jual carb z mili pm aku.. hehe | |
| Subject: Re: Segala Persoalan V10 Sat Nov 20, 2010 8:06 pm | |
| haha.. tk syok la 4stroke.. enjin manje, kalo modi sng je nk rosak.. 2stroke enjin lasak, maintenance mudah, murah.. tp kalo ko ckp ngan dak2 LC ayat kt atas, msti diorg ckp, 'msti la nk menangkn mesin ape yg sndr pkai..' ko reply, 'jom oberhaul moto, kte tgk sape lg murah..' wakakaka.. | |
nazjb Bintara Muda
| Subject: Re: Segala Persoalan V10 Sat Nov 20, 2010 9:13 pm | |
| bro2 sekalian,block aku ader mengeluarkan bunyi yg agak kurang enak la.aku x pasti samaada itu bunyi ring piston atau pin bearing..aritu dh bunyi,so aku bukak n tukar ring piston(baek punye tokey 2 kedai ckp la) ngan pin bearing racing bee.tp mase aku test running,bunyi yg same tetap ader.dah penat turun naek head block 2..bunyi 2 berpunce dr ape?aduyay.. | |
| Subject: Re: Segala Persoalan V10 Sat Nov 20, 2010 11:50 pm | |
- babet wrote:
- hmmm....thnx kawan2....hantr kedai jela nmpknye,,,
bleh record video skali..hehe bleh je blaja tgk pomen wat byk kali.. then try wat sndr.. contohnye org pkai rim lidi biasenye pkai tiub.. tuka tyr viva 2.50, leh kategori tyr sotong gak la, bleh lyn corner ckit, modal tk smpai rm30.. tyr rm25 + tiub rm5.. jnji tools ckup(set spana, cungkil tyr, pam kaki ke pijak ke henjut ke namenye tu).. huhuhu.. tgk org lame la, zaman 80-90an, rmai pkai rim lidi.. teknologi sportrim neh kt moto2 mhl, n kurang mampu milik kot.. siap tmpal tiub boco pkai gum dunlop lg.. mmg jiwe DIY sbnr!!(ke save bajet ke mmg suke brtukang ke tk sure.. hehe ) babet.. cakap pasal DIY.. ni dia DIY pum tayar tubeless.. Tengok kat sini try jangan tak try.. ahakss | |
| Subject: Re: Segala Persoalan V10 Sun Nov 21, 2010 1:30 am | |
| ffehhh terbaaik la.. hahah... die gune gas ape 2 ek..? | |
| Subject: Re: Segala Persoalan V10 Sun Nov 21, 2010 4:07 am | |
| - paan1171 wrote:
- ffehhh terbaaik la.. hahah... die gune gas ape 2 ek..?
tak pasti la bro.. macam tin cat samurai je.. ahakssss | |
| Subject: Re: Segala Persoalan V10 Sun Nov 21, 2010 9:11 pm | |
| sape tau ade x kedai mne2 leh repair meter 125z?? aku nk repair meter 2nd model.. ade msalah dgn dia punye rpm.. cm sial..mne leh repair ek?? | |
Ezad Laskar Kelas I
Posts : 113 Join date : 07/08/2010 Age : 30 Location : Shah Alam , Selangor
| Subject: Re: Segala Persoalan V10 Sun Nov 21, 2010 10:22 pm | |
| assalamualaikum, nk bertanya ye, kenapa carb kite semput walaupun da servis byk kali? bile rem rpm nek smpai 6, pastu trus sangkut2, kenapa ea? da byk kedai pegi servis tp tetap same. | |
unknownh Bintara Kanan
| Subject: Re: Segala Persoalan V10 Sun Nov 21, 2010 10:34 pm | |
| Subject: Re: Segala Persoalan V10 Mon Nov 22, 2010 1:53 am | |
| - Ezad wrote:
- assalamualaikum,
nk bertanya ye, kenapa carb kite semput walaupun da servis byk kali? bile rem rpm nek smpai 6, pastu trus sangkut2, kenapa ea? da byk kedai pegi servis tp tetap same. bnyak kemungkinan.. xleh ckap carb je... mybe cdi nk kong,coil api@coil magnet,plug dll.. try check 1 per 1 dlu.. pling snang cdi.. pnjam cdi mmber tset jp... slamat berusaha... | |
| Subject: Re: Segala Persoalan V10 Mon Nov 22, 2010 9:44 am | |
| hah bunyi cam jetting tak betul jer ...... | |
Ezad Laskar Kelas I
| Subject: Re: Segala Persoalan V10 Mon Nov 22, 2010 3:15 pm | |
| xkn angin xbtol kot, da hmpir 5 kedai aku try anta servis, xkn smua xreti setting angin kot? cdi xcheck ag, pluh ngan coil api bru ag, tp cdi bru ag kot, tp cap ayam kuda laut coil magnet xpnah check lak | |
| Subject: Re: Segala Persoalan V10 Mon Nov 22, 2010 3:42 pm | |
| try pkai cdi ori kwn ko ke..tgk cne | |
Ezad Laskar Kelas I
| Subject: Re: Segala Persoalan V10 Tue Nov 23, 2010 11:49 am | |
| Subject: Re: Segala Persoalan V10 Tue Nov 23, 2010 12:30 pm | |
| check api..check jarum karb..check hose getah dr air box,ada bocor x | |
| Subject: Re: Segala Persoalan V10 Tue Nov 23, 2010 5:28 pm | |
| nie mesti problem ngan sistem api,klu satu part je dah lokel,akan berkait2x ngan part lain,seeloknnye pakai coil magnet,coil api n cdi yg original,klu x mmg selalu akan ade problem,mende yg berkait rapat cdi @ coil api,1st cek yg tue dulu.. | |
mR.nobita Bintara Kanan
Posts : 611 Join date : 14/09/2009 Location : tganu - shah alam
| Subject: Re: Segala Persoalan V10 Wed Nov 24, 2010 2:05 pm | |
| lau letak myk fork byk ape jd ek? makin absorb ke fork tu? | |
| Subject: Re: Segala Persoalan V10 Wed Nov 24, 2010 2:10 pm | |
- nie mesti problem ngan sistem api,klu satu part je dah lokel,akan berkait2x ngan part lain,seeloknnye pakai coil magnet,coil api n cdi yg original,klu x mmg selalu akan ade problem,mende yg berkait rapat cdi @ coil api,1st cek yg tue dulu..
seeloknye tuka coil magnet, coil api yg local sbb pkai cdi local.. semua local br la serasi.. wakakaka.. hmm, tp rasenye mmg cdi.. aku pnh try saje2 cdi local mmg jd semput ke tk ngam gtu.. tp tk sure plak cdi racing leh settle prob ke tk? aku nk try racing bee la plak tgk ape jd..<---tkde mslh cari mslh.. wakakaka.. | |
| Subject: Re: Segala Persoalan V10 Wed Nov 24, 2010 2:24 pm | |
| - mR.nobita wrote:
- lau letak myk fork byk ape jd ek?
makin absorb ke fork tu? nk absorb ape kalau dh minyak fork tu byk sgt? silap2 minyak tu tendang blk, oilseal yg rosak... rasanya stndard pn dlm 60ml jer...kalau letak 70-80ml tu ok lg lar..dh dkt 100mL atau lbh tu dh mcm mampat sgt.. letak byk2 pn nk buatpe? kalau nk bg keras fork, nk kurangkn goyang bila laju, sumbat minyak yg pekat skit mcm minyak enjin kereta... nk lg pekat, letak minyak gearbox kereta..MTF... langgar2 lubang mmg mantul2 skit..biasala...tp kalau main highway/korner, rilek je lg... | |
| Subject: Re: Segala Persoalan V10 Wed Nov 24, 2010 2:32 pm | |
| - vendetta wrote:
nk absorb ape kalau dh minyak fork tu byk sgt? silap2 minyak tu tendang blk, oilseal yg rosak... rasanya stndard pn dlm 60ml jer...kalau letak 70-80ml tu ok lg lar..dh dkt 100mL atau lbh tu dh mcm mampat sgt.. letak byk2 pn nk buatpe? kalau nk bg keras fork, nk kurangkn goyang bila laju, sumbat minyak yg pekat skit mcm minyak enjin kereta... nk lg pekat, letak minyak gearbox kereta..MTF... langgar2 lubang mmg mantul2 skit..biasala...tp kalau main highway/korner, rilek je lg... ok bro..tq bg info.. sje nk tnye pendapat dlu.. sbb aku rse fork aku tu cam melantun.. x brape nk absorb.. lalu kt line kuning belang2 tu gegar/melenting semacam je... ke normal cmtu.. hehe. # pau myk gearbox keta ayah aku la nmpk nye.. hahaha | |
redline Laskar Kanan
| Subject: Re: Segala Persoalan V10 Wed Nov 24, 2010 4:30 pm | |
seeloknye tuka coil magnet, coil api yg local sbb pkai cdi local.. semua local br la serasi.. wakakaka.. hmm, tp rasenye mmg cdi.. aku pnh try saje2 cdi local mmg jd semput ke tk ngam gtu.. tp tk sure plak cdi racing leh settle prob ke tk? aku nk try racing bee la plak tgk ape jd..<---tkde mslh cari mslh.. wakakaka.. alang2 cari masalah, try la cdi ikk...dgr citer lagi mantap dari cdi racing bee... aku pakai standard je...dah mesin pn standard... | |
| Subject: Re: Segala Persoalan V10 Sun Nov 28, 2010 10:40 am | |
| cne nk check carb ori rxz(catalyzer)? klu carb ori boss ade tulis made in japan kn? | |
| Subject: Re: Segala Persoalan V10 Sun Nov 28, 2010 11:01 am | |
| - unknownh wrote:
- cne nk check carb ori rxz(catalyzer)?
klu carb ori boss ade tulis made in japan kn? sendiri tanya, sendiri jawap? bgs betul.. bkn ker dh ada org tlg jwp pertanyaan bro kt sini.. http://125z.forumms.net/diskusi-motosikal-f4/hong-leong-yamaha-genuine-part-t89-300.htm tak cukup lg ker gmbr kt sini? http://125z.forumms.net/diskusi-motosikal-f4/125z-carb-rxz-v3-t1536.htm ni aku bg lg satu gmbr... slot jarum carb catalyzer warna hitam..yg carb rxz selain dr catalyzer kaler kuning emas.. jarum carb catalyzer pjg skit sbb slot jarum tu lain skit..tak mcm slot jarum carb rxz lama.. | |
| Subject: Re: Segala Persoalan V10 | |
