| Plag Kegunaan Masing2x.. | |
+53fareez91 enzoanz geeks carlz softoperator imanhalimi ajizaimi Ultra-Z ckua 125zR gilgamesh88 absolute_ahben Ajib madie jem_125zr silentpiper -angah- kudaunismall 125zM_Epin AspideSensei azdli90 ayip125 oliey2u matwe87 feederxv kelvin45 fizerpool 23sh0pah0lic assasin_lunxe hasrul_90 hafidz ekzosboorukipoh ak vendetta dy rasau mousepink kick_ingoal mazakim hydar superjoemanito zouk188 aus_ipoh soNa arjuna86 chocolate andy-wkv WKQ4913 Admin lanunlaut mantadkb bujang venom HailToKing 57 posters |
enzoanz Laskar Kanan
Posts : 363 Join date : 29/06/2009 Age : 36 Location : Ipoh mali/ Taiping
| Subject: Re: Plag Kegunaan Masing2x.. Tue Jul 13, 2010 3:29 pm | |
| br je bro.. sblum konvoi mlaka aritu.. maybe aritu 2t ak bkak besa sbb jln jauh, tp skrg ni ak pkai utk g n blk kje je yg xsmpi pn 2km.. nnt ak cuci plug blk n kecikkan 2t.. hehe.. thx membantu.. | |
imanhalimi Bintara Kanan
Posts : 637 Join date : 16/06/2010 Age : 36 Location : Perlis->kL->???
| Subject: Re: Plag Kegunaan Masing2x.. Tue Jul 13, 2010 3:34 pm | |
| yela 2... mto aku pom penah jd gak sje gatal nk try set 2t lebih nk tegk pe jd... mmg lembab jugak la... aku pom xbpe taw sagt... nek je taw.. huhuhu | |
| Subject: Re: Plag Kegunaan Masing2x.. Tue Jul 13, 2010 5:22 pm | |
| hehe.. ak mto stendet je.. tp nk set 2t mcm moto aus.. mmgla xngam.. so kne la bg kecik blk.. skrg da ok da.. jgn mare ye aus.. | |
aus_ipoh Laksamana Armada
Posts : 2936 Join date : 19/05/2009 Age : 37 Location : ipoh dan kawasan yg sewaktu dengannya
| Subject: Re: Plag Kegunaan Masing2x.. Wed Jul 14, 2010 12:41 am | |
| ceh nama aku disebut2..apasal la gatai bukak 2t besar cm aku..aku xpela bukak 2t smpi hbs..hehe | |
fareez91 Pegawai Waran II
Posts : 1192 Join date : 22/06/2009 Location : Jinjang ↔ penang
| Subject: Re: Plag Kegunaan Masing2x.. Wed Jul 14, 2010 6:05 pm | |
| aus mto laju,korg jgn ikut kn.hahahaha... | |
ss110 unggu Laskar Muda
Posts : 33 Join date : 23/11/2010 Age : 33 Location : PJ
| Subject: Re: Plag Kegunaan Masing2x.. Thu Dec 16, 2010 5:11 pm | |
| sape pena gne palam pencucuh jnme VPR?? | |
ajizaimi Bintara Muda
| Subject: Re: Plag Kegunaan Masing2x.. Tue May 17, 2011 7:48 pm | |
| W24ES-Us
ni kod plug denso rm7 utk kegunaan tupai n rxz | |
Kato_125 Bintara Kanan
Posts : 682 Join date : 28/09/2010 Age : 33 Location : kUaNtaN mEnJeRiT
| Subject: Re: Plag Kegunaan Masing2x.. Tue May 17, 2011 11:38 pm | |
| - ajizaimi wrote:
- W24ES-Us
ni kod plug denso rm7 utk kegunaan tupai n rxz abam, blanjer gmbo bulih? sy x bape knl la jnis2 plug nih.... | |
| Subject: Re: Plag Kegunaan Masing2x.. Wed May 18, 2011 10:14 am | |
| - Kato_125 wrote:
- ajizaimi wrote:
- W24ES-Us
abam, blanjer gmbo bulih? sy x bape knl la jnis2 plug nih.... nak blh, jom g jusco ipoh,dlm tu ada jual. Aku tgk je xbli pn. kod dia kat website denso. ok | |
tupaijet_junior Laskar Kelas I
Posts : 161 Join date : 24/04/2010 Location : Petaling Jaya
| Subject: 03 SPARK PLUG DENSO IRIDIUM 0.4mm (Let Discuss About Advantage & Disadvatage) Sat Jul 09, 2011 11:51 pm | |
| Apa kebaikan dan keburukan Spark Plug ni...? kalau moto baru @ stendert, all in standard condition, apa efek guna nihh...? (riso tembus je lau tak setting carb) Iridium Alloy In a never-ending effort to improve upon success, DENSO developed an Iridium alloy that is superior to platinum based on hardness, strength and melting point. The new Iridium alloy is composed primarily of Iridium with rhodium mixed in for oxidation wear. Iridium Alloy Pure Iridium has a melting point of almost 700?C higher than platinum, and had the greatest potential for resistances against wear. Iridium by itself is susceptible to oxidation wear at temperatures over 900?C, however, ordinary driving around town an engine would never reach these temperatures. Further testing proved that Iridium alone would not meet DENSO's demanding standards. After testing other pure metals combined with Iridium, rhodium proved to be the best choice to meet the needs of DENSO's spark plug engineers
Laser Welding Process DENSO's Iridium Alloy had all of the qualities to produce the world's best spark plug, but conventional tooling prevented DENSO from mass manufacturing. Due to the high melting point there wasn't a welding process hot enough to join the Iridium tip to the nickel base. Necessity to melt the Iridium to the nickel base forced DENSO to pioneer its third patent, the 360? Laser Welding Process, to provide a seal so reliable; the electrode resists wear even in the worst combustion conditions.
Fewer Volts Means More Amps DENSO Iridium spark plugs require on average 5,000 fewer volts to fire than conventional spark plugs. Less power is required to fire DENSO Iridium Power Plugs, and coupled with our patented U-Groove technology, the use of Iridium alloy, the tapered cut, and the ultra fine 0.4mm diameter electrode translates to increased horsepower throughout the dyno range.
%20%20Uploaded%20with%20ImageShack.us] %20%20Uploaded%20with%20ImageShack.us] %20%20Uploaded%20with%20ImageShack.us] %20%20Uploaded%20with%20ImageShack.us] | |
| Subject: Re: Plag Kegunaan Masing2x.. Tue Jul 12, 2011 8:17 am | |
| bincg kt sini.. http://125z.forumms.net/t104-plag-kegunaan-masing2x#173 nnt aku mergekan.. | |
cikun Laskar Muda
Posts : 4 Join date : 13/07/2011
| Subject: Re: Plag Kegunaan Masing2x.. Wed Jul 13, 2011 3:19 pm | |
| salam . .tanye ckit neh . .apsal moto sy xda api kat plug ek ? | |
| Subject: Re: Plag Kegunaan Masing2x.. Wed Jul 13, 2011 7:53 pm | |
| - cikun wrote:
- salam . .tanye ckit neh . .apsal moto sy xda api kat plug ek ?
dah cek coil plug,coil magnet,cdi?.. | |
| Subject: Re: Plag Kegunaan Masing2x.. Wed Jul 13, 2011 7:59 pm | |
| - tupaijet_junior wrote:
- Apa kebaikan dan keburukan Spark Plug ni...?
kalau moto baru @ stendert, all in standard condition, apa efek guna nihh...? (riso tembus je lau tak setting carb) nk pakai better set mnyk lbh skit,mmg berisiko tembus piston untuk jangke mase pnjg untuk moto yg btl2x standard,klu ngk n denso,yg pakai name platinum n iridium yg jns gune centre rod kecik.. | |
| Subject: Re: Plag Kegunaan Masing2x.. Thu Jul 14, 2011 9:35 pm | |
olrite joe.. thanxx... | |
| Subject: Re: Plag Kegunaan Masing2x.. | |
