| Segala Persoalan V13 | |
+47mazakim fx110 shrinklefritz fiq abg_apis oddysee11 bdkbarunaik chez83 wgs4@9 su iqram dy rasau faaizil Arthur bender xopai ~*PeRaK MaLI*~ Kato_125 N.A.M.I jacob komi carlz pasquale aleen90 kamarulhaha absolute_ahben NCH_KU midi judge125 superjoemanito mutoudoh wormzx najmimecha Que Danealle chocolate babet yi_tupaijek01 paan1171 tupai comel jem_125zr nurkaye_akmal devilmeasha Ultra-Z MaGNum_1721 unknownh chaosworld mantadkb 51 posters |
bender Bintara Muda
Posts : 452 Join date : 16/11/2010 Location : cheras
| Subject: Re: Segala Persoalan V13 Sat Mar 19, 2011 7:55 pm | |
| btol2... tapi pas rebore tu kena lah jaga blok 2 btol2.. elakkan daripada peristiwa tedahulu berulang kembali.... ceewaahh.. hehe | |
aleen90 Laskar Muda
Posts : 81 Join date : 25/02/2011 Age : 34 Location : KL
| Subject: Re: Segala Persoalan V13 Sat Mar 19, 2011 8:10 pm | |
| - bender wrote:
- btol2... tapi pas rebore tu kena lah jaga blok 2 btol2.. elakkan daripada peristiwa tedahulu berulang kembali.... ceewaahh.. hehe
cm ner nk jge? | |
bender Bintara Muda
| Subject: Re: Segala Persoalan V13 Sat Mar 19, 2011 8:47 pm | |
| kene bepantang lah..jgn lbih 80km/j cam moto baru beli...tapi biasanya blok baru rebore ni pantang x yah lama sngat, lam 700km da ckop da...x pon wat hardbreakin engine cam lam thread hardbreak engine tuh.. otai2 tlg btol kan klu salah ye... | |
| Subject: Re: Segala Persoalan V13 Sat Mar 19, 2011 9:01 pm | |
| muto baru dah bunyi camtu..ada lenjan ka? | |
aleen90 Laskar Muda
| Subject: Re: Segala Persoalan V13 Sat Mar 19, 2011 9:04 pm | |
| - bender wrote:
- kene bepantang lah..jgn lbih 80km/j cam moto baru beli...tapi biasanya blok baru rebore ni pantang x yah lama sngat, lam 700km da ckop da...x pon wat hardbreakin engine cam lam thread hardbreak engine tuh.. otai2 tlg btol kan klu salah ye...
hmm asyik nk kena pntang jer ni.. sblum ni aku bwak xlbih pun 80kmj... | |
dy rasau Laskar Muda
Posts : 80 Join date : 23/03/2009 Location : dekat2 ni je...
| Subject: Re: Segala Persoalan V13 Sat Mar 19, 2011 9:09 pm | |
| salam....
nk tnye ni..ade efek x kalo kite pasangkn piston tu tbalik.. mksud ak, yg anok panoh tu pasang ke atas(valve)..kn biasenye anok panoh tu ke arah bawah kn...
sb ade mmber kabo, kalu pasang kat atas..minyak flow lg efektif..ntah..cmne tu..ade sesape leh bg pndapat..mane tau kot2 buleh + ilmu baru ke..best jg kn.. | |
aleen90 Laskar Muda
| Subject: Re: Segala Persoalan V13 Sat Mar 19, 2011 9:38 pm | |
- muto baru dah bunyi camtu..ada lenjan ka?
lnjan pe nyer... hari2 bwak xsmpai 80kmj pun.. jln pun 3 km jah.. | |
| Subject: Re: Segala Persoalan V13 Sat Mar 19, 2011 10:20 pm | |
| hoo camtu kalu kasi hantar kedai cepat2,takut ada sumthing wrong with your bike..assumption je,sbb x dgr depan2 bunyi camno
inche dy_rasau,apakata deme cuba try test dulu jd ke x he3 | |
| Subject: Re: Segala Persoalan V13 Sat Mar 19, 2011 10:26 pm | |
- hoo camtu kalu kasi hantar kedai cepat2,takut ada sumthing wrong with your bike..assumption je,sbb x dgr depan2 bunyi camno
inche dy_rasau,apakata deme cuba try test dulu jd ke x he3 t ade mase ambe try r...bules wak ilang puah..hehehe | |
~*PeRaK MaLI*~ Laskar Kelas I
Posts : 148 Join date : 17/07/2009 Age : 33 Location : Manjung,Ipoh
| Subject: Re: Segala Persoalan V13 Sun Mar 20, 2011 1:04 am | |
| tmpang bertanya..batang stud kt blok patah nk ganti batang stud baru wat ktne ek??kdai moto bley wat x?? | |
| Subject: Re: Segala Persoalan V13 Sun Mar 20, 2011 1:07 am | |
| - ~*PeRaK MaLI*~ wrote:
- tmpang bertanya..batang stud kt blok patah nk ganti batang stud baru wat ktne ek??kdai moto bley wat x??
kedai moto pon boleh wat...n bengkel2 welding@besi pon kadang2 ade jg.. tp hrga tu x brape pasti r..dulu pernah jg patah, g bengkel welding, dia pateri kasi cabut itu stud..then, g kedai moto beli stud baru..setel... | |
| Subject: Re: Segala Persoalan V13 Sun Mar 20, 2011 1:15 am | |
| inche perak mali,wat kat kedai muto/bengkel muto..
inche dy_rasau,nak buat bleh tp kemungkinan utk jahanam tu ada.. 1.ring piston patah..cuba tgk lock ring piston ada kat bahagian mana..kl pasang piston terbalik,cuba tgk lock tu ada kat mana-->utk blok stended mungkin selamat lg,kl port ekzos dah besar,mungkin serta merta k.o. 2.fuel lost,compression lost-->belah piston menghadap ke blkg ada satu lubang minyak..kl lubang ni menghadap ke port ekzos,senang2 jer minyak bleh kuar ke lubang ekzos
tp tu cuma teori je,bleh je kl nak cuba,mana tau dapat mende baru he3 | |
| Subject: Re: Segala Persoalan V13 Sun Mar 20, 2011 1:19 am | |
- inche perak mali,wat kat kedai muto/bengkel muto..
tp tu cuma teori je,bleh je kl nak cuba,mau tau dapat mende baru he3 oo..gitu..good info good info...tq abg incik choco... | |
| Subject: Re: Segala Persoalan V13 Sun Mar 20, 2011 1:36 am | |
xopai Laskar Kelas I
Posts : 133 Join date : 03/10/2010 Location : Seremban & Bangi
| Subject: Re: Segala Persoalan V13 Sun Mar 20, 2011 4:09 am | |
| xlme lg aku nk bukak enjin.sbb aku rse enjin aku ni da mengong.biler bwk sangkut pd rpm 6.klo tarik lg cm tersedak2/sekat.pastu bunyi bising sgt.cm ader bende yg tggl.bergoncang2.sbb ader satu time uh,aku try gak tarik, walaupn tersangkut, pastu rpm naik dgn kasarnyer,tapi moto xgerak.then,tros jadi cm skrg nih.bunyi bising giler.clutch,api and piston oke jeh.clutch da rivet balik,piston da tuka ori.sistem api da check.carb da tuka².tapi still sme gak.
ak blum pnh bukak enjin lg.egat nk wat sendiri jeh, tuka rod skali.SO ADER APE² TIPS OR MENDE YG PENTING YG PATUT TAHU X????aku rse alat aku cukup kot.cume crank and rod tu kne anta kedai lah kn. | |
| Subject: Re: Segala Persoalan V13 Sun Mar 20, 2011 4:17 am | |
| ko professional ke newbies? hntar kedai je lar..bhaya wor wat sendiri kalo xbpe tau..
*kalo bajet lebih, sumbat trus bearing F.A.G 1 set kat enjin ko..hehe | |
| Subject: Re: Segala Persoalan V13 Sun Mar 20, 2011 7:49 am | |
| - xopai wrote:
- xlme lg aku nk bukak enjin.sbb aku rse enjin aku ni da mengong.biler bwk sangkut pd rpm 6.klo tarik lg cm tersedak2/sekat.pastu bunyi bising sgt.cm ader bende yg tggl.bergoncang2.sbb ader satu time uh,aku try gak tarik, walaupn tersangkut, pastu rpm naik dgn kasarnyer,tapi moto xgerak.then,tros jadi cm skrg nih.bunyi bising giler.clutch,api and piston oke jeh.clutch da rivet balik,piston da tuka ori.sistem api da check.carb da tuka².tapi still sme gak.
ak blum pnh bukak enjin lg.egat nk wat sendiri jeh, tuka rod skali.SO ADER APE² TIPS OR MENDE YG PENTING YG PATUT TAHU X????aku rse alat aku cukup kot.cume crank and rod tu kne anta kedai lah kn. lg syok kalo ada compressor n air gun...tidak dilupakan jet magnet 125z n impact...selain dr tu alat2 asas je ...paling penting skill jela...jgn nt berterabur gear box.. | |
| Subject: Re: Segala Persoalan V13 Sun Mar 20, 2011 8:06 am | |
ak blum pnh bukak enjin lg.egat nk wat sendiri jeh, tuka rod skali.SO ADER APE² TIPS OR MENDE YG PENTING YG PATUT TAHU X????aku rse alat aku cukup kot.cume crank and rod tu kne anta kedai lah kn. bro da ada buku part katalog 125z ke? sekurang2nya boleh membantu dlm proses disamble/pemasangan..hehe. ni..download kt sini.. http://www.mediafire.com/?tymyl04tjmt -->kredit to inche vendetta | |
| Subject: Re: Segala Persoalan V13 Sun Mar 20, 2011 2:55 pm | |
| waa.. bleh dowload ek..ade dlm mudah.my org jual RM20.. BIG CREDIT TO MR.VENDETTA a.k.a SAUDAGAR ALLENKEY>>!!! | |
| Subject: Re: Segala Persoalan V13 Sun Mar 20, 2011 3:49 pm | |
| eh nape aku nk bk link tu xle ek? | |
| Subject: Re: Segala Persoalan V13 Sun Mar 20, 2011 4:35 pm | |
| - chaosworld wrote:
- ko professional ke newbies? hntar kedai je lar..bhaya wor wat sendiri kalo xbpe tau..
*kalo bajet lebih, sumbat trus bearing F.A.G 1 set kat enjin ko..hehe xdela newby sgt.bearing tu akan dipertimbangkn. sgt best ke bearing tuh?? - yi_tupaijek01 wrote:
ak blum pnh bukak enjin lg.egat nk wat sendiri jeh, tuka rod skali.SO ADER APE² TIPS OR MENDE YG PENTING YG PATUT TAHU X????aku rse alat aku cukup kot.cume crank and rod tu kne anta kedai lah kn. lg syok kalo ada compressor n air gun...tidak dilupakan jet magnet 125z n impact...selain dr tu alat2 asas je ...paling penting skill jela...jgn nt berterabur gear box.. sme alat tu ak ade dah.sbb tu ader confident nk bukak.ha,gearbox tu jgn dileraikn.keluarkn seketul. - devilmeasha wrote:
-->kredit to inche vendetta katalog tu pn aku da lme ader.da lme dok belek².rse boleh kot,klo aku jus berpandukn tuh. | |
| Subject: Re: Segala Persoalan V13 Sun Mar 20, 2011 6:10 pm | |
ak blum pnh bukak enjin lg.egat nk wat sendiri jeh, tuka rod skali.SO ADER APE² TIPS OR MENDE YG PENTING YG PATUT TAHU X????aku rse alat aku cukup kot.cume crank and rod tu kne anta kedai lah kn. bearing crankshaft dh kong kot.. tkpe bro, slow2 kayuh barai enjin. semua orang ade first time, even pomen cubprix pn bukannye kuar perut ibu ade label kt dahi tulis 'pandai oberhaul 125z'.. respek gile semangat mau mencuba ko. hehehe.. pendapat aku, pastikan kawasan nk jalankn kerja oberhaul tu ckup lapang, sumer brg2 terkumpul n tersusun..gud luck n all the best bro!! | |
| Subject: Re: Segala Persoalan V13 Sun Mar 20, 2011 6:16 pm | |
ak blum pnh bukak enjin lg.egat nk wat sendiri jeh, tuka rod skali.SO ADER APE² TIPS OR MENDE YG PENTING YG PATUT TAHU X????aku rse alat aku cukup kot.cume crank and rod tu kne anta kedai lah kn. bearing crankshaft dh kong kot.. tkpe bro, slow2 kayuh barai enjin. semua orang ade first time, even pomen cubprix pn bukannye kuar perut ibu ade label kt dahi tulis 'pandai oberhaul 125z'.. respek gile semangat mau mencuba ko. hehehe.. pendapat aku, pastikan kawasan nk jalankn kerja oberhaul tu ckup lapang, sumer brg2 terkumpul n tersusun.. gud luck n all the best bro!! wah.tq sgt bro.mmbakar smangat aku.hhee.. mmg dlm plan aku nk tuka bearing skali rod. bape bajet agak2 eh?? - bearing skf enduro c3, 1 set. 9 unit kn? - rod ori. | |
su Laskar Kelas I
| Subject: Re: Segala Persoalan V13 Mon Mar 21, 2011 2:43 am | |
| salam semua...
nk tnye skit...klu blok std cap ikk ok ke ye? agak2 tahan x..... | |
| Subject: Re: Segala Persoalan V13 Mon Mar 21, 2011 2:46 am | |
| blok racing kan? pape hal pun blok ori gak yg terbaik..! | |
| Subject: Re: Segala Persoalan V13 | |
