| | Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 | |
+74budak kt areyz95 onetwofive alifmz19 mantadkb iqbal92 sigung su Azeri_conquistador NiTRO697 Ijat Stylo daoz_black bender SAA1729H irfanrazeiq WVG 9651 apik sure azrey hyuhuu adeqyana sherlock Shark pfa qayyum_qz thee_abu -sLip- Mal-PuChOng3300 siput sedut 125z ganu tengku mohd bakhtia bdkbarunaik shrinklefritz syaz nurkaye_akmal tupaijet_junior fizerpool mangketey samporna ccn anep4742 syamz5429 Kaer MaGNum_1721 meerul boy fei cai megnamon man JGN8917 nazjb Pure_Soul Mafiaflix azdli90 komi chaklek Kasut Terbang Fendi Faito Man4822 chez83 Faiz absolute_ahben askrun faristrx Arthur KapcaiKuDie babet musesaddiq paan1171 Azrul chocolate Que Danealle Ultra-Z devilmeasha wormzx tupai comel pasquale yi_tupaijek01 superjoemanito 78 posters | |
megnamon Laskar Muda
Posts : 71 Join date : 16/05/2011 Location : BM,Muar( Sekarang ) /Shah Alam
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Fri Dec 30, 2011 12:37 am | |
| Mungkinlah kot . Aku berat pun dlm 75kg | |
| | | 125z ganu Laskar Kelas I
Posts : 164 Join date : 31/10/2011 Location : Kelate-Terengganu
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Fri Dec 30, 2011 6:13 pm | |
| ok la tu...75 xberat sgt...kalo >85kg dikira berat... | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Fri Dec 30, 2011 8:02 pm | |
| Gile ptg tadi , satu skru panjang kt blok longgar , amik bising je aku bwk . last taknak hidup . g repair ketatkan ,ak rs terkeluar compression sket agaknya sbb aku tgk gasket lebur . melayang duitttttt ~~~ | |
| | | -sLip- Bintara Muda
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Fri Dec 30, 2011 8:10 pm | |
| [img] [/img] errr blok ni bole dikira msh ok lagi kn,tang 4 lubang tu,kalo cuma polish2 gitu dgn buang bonggol lubang ekjos,kiri-kanan ats lubang ekjos msh standet.piston 1:00 kalo bt mcm tu cuma mampu bt sedap2 jln kn @ atau ada info yg lain @ kesan buruk dan baiknye | |
| | | devilmeasha Pegawai Waran II
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Wed Jan 04, 2012 10:22 am | |
| ade effect ka buat gini?..macam x jau beza ja.. | |
| | | -sLip- Bintara Muda
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Thu Jan 05, 2012 6:08 pm | |
| - devilmeasha wrote:
- ade effect ka buat gini?..macam x jau beza ja..
betul kata ko,x brapa jauh sgt bezanyer dgn standert,efeknyer biase2 je pakai blok tu keh3... respon pickup ada best sikit,top biase shj,betul la nk x nk kalo nk pergi rpm lebih jauh kena port lubang yg mana patut sperti mana yg dibincangkn dlm ruangan ni tapi aku belum berani nk port2... biar je la blok aku standet,lagipn x de blok spare hehe | |
| | | -sLip- Bintara Muda
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Mon Jan 09, 2012 8:44 pm | |
| yg ini jahat ke x??mcm blok jahat & nakal keh3.... [img] [/img]
| | | thee_abu Laskar Muda
Posts : 68 Join date : 09/12/2011 Age : 32 Location : taman maluri
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Tue Jan 10, 2012 12:24 am | |
| lg 2bln sy mahu korek blok laa.. agak2 bp MM yg best.. bengkel mane yg best korang wat.. ade setengah bengkel ikot bajet.. ade RM300 - RM1000.. ade ta bengkel korang wat dia ckp mcm tuh..??
| | | qayyum_qz Laskar Kelas I
Posts : 112 Join date : 17/01/2011
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Tue Jan 17, 2012 10:45 am | |
| salam...sape tau bengkel,or mne2 mamat yg pndai korek blok? blok stndard size 75....igt nk anta korek sesedap rse....xmo giler2 nyer korek... | |
| | | nazjb Bintara Muda
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Fri Jan 20, 2012 6:41 am | |
| kene bgtau p0men bro nk spec mcm mne.kalau ckp sesedap rase,t die wt sesedap tgn die menge"p0rting"..last2 blok 2 leh wt tukun..penah trjadi kt aku.haru sudahh | |
| | | -sLip- Bintara Muda
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Fri Jan 20, 2012 8:06 pm | |
| otai2 semua.. minta pandangan sikit tentang blok ni [img] [/img] [img] [/img] [img] [/img] [img] [/img] [img] [/img] piston 1:25,head skim 1mm... pretasi entah la,x psg lagi,agak2 spec blok mcm gini ok @ k.o,semcm pula rsanye nk sarung | |
| | | Azrul Laskar Kelas I
Posts : 146 Join date : 24/01/2011
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Tue Jan 24, 2012 3:15 am | |
| sapa tao rahsia nk port lubang exzos bape MM yg boley dpt 180KM/H ? tanpa port lubang angin n minyk.. | |
| | | Shark pfa Bintara Kanan
| | | | superjoemanito Laksamana Armada
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Sat Mar 03, 2012 7:28 pm | |
| dah modi n pnh jem blok nie,hntr kedai rebore smpi hlg clr,ha3x.. | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Sat Mar 03, 2012 7:48 pm | |
- dah modi n pnh jem blok nie,hntr kedai rebore smpi hlg clr,ha3x..
klau agak2 rebore berape pulus ehh...sbab aq x prnah lagi rebore2 block ni.... | |
| | | sherlock Laskar Kanan
Posts : 247 Join date : 07/01/2010 Age : 35 Location : jEnGkAx to BanGi...
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Sun Mar 04, 2012 9:27 pm | |
| biase bwh sratus ley ciap kot... smlm aku rebore + piston kotak Yamaha Genuine + Ring RIK = RM88... trus senyap tupai aku... kalo ats sratus aku iktiraf mahal trus jer... | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Sun Mar 04, 2012 10:12 pm | |
| xzoz tupai 1st model pkai catylyzer gak ke???.... | |
| | | adeqyana Laskar Kelas I
Posts : 133 Join date : 05/12/2011
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Sun Mar 11, 2012 7:55 pm | |
| salam..aku bdk br kat sni & baru pakai tupai ni..blok & piston aku dah calar,so aku nak rebore dari 0.25 ke 0.50..so aku kna rebore blok je la kn ngan tukar piston?? head nak kena skim lg tak?? atau klu xskim pun xapa head tu??? carb nak kena set blk tak?? Mj & Pj pun nak kena up juga ke?? sori la byk tanya sbb aku budak br belajar ttg motor ni..
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Mon Mar 12, 2012 4:53 am | |
| - Shark pfa wrote:
- ohh....klau kau tgk ukuran block aq tu...tu saiz standart lagi ka??...yang org ckp saiz 1.0,0.0 tu nk thu mcm mane ehh??
tgk saiz kt piston je.. kalo xnmpk,kasi cuci cket karbon 2... | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Mon Mar 12, 2012 5:16 am | |
| - adeqyana wrote:
- salam..aku bdk br kat sni & baru pakai tupai ni..blok & piston aku dah calar,so aku nak rebore dari 0.25 ke 0.50..so aku kna rebore blok je la kn ngan tukar piston?? head nak kena skim lg tak?? atau klu xskim pun xapa head tu??? carb nak kena set blk tak?? Mj & Pj pun nak kena up juga ke?? sori la byk tanya sbb aku budak br belajar ttg motor ni..
rebore skali n tukar piston kasi ngam2 shoi je... len xyh usik... rebore skali lebey kurg je besonyer..xnmpk beza sgt pon... pastu set ar carb blk... xpelh,tgk pendapat len lak... | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Mon Mar 12, 2012 8:37 am | |
| owh mcm tu ya bro sherlock..ok2..tq.. | |
| | | absolute_ahben Laskar Kelas II
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Mon Mar 12, 2012 11:32 pm | |
| rebore fit + runinng je dulu dengan mj dengan pilot yang sedia ada. pendapat nubis. | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Tue Mar 13, 2012 8:28 am | |
| ok..tq bro absolute_ahben.. | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 Tue Mar 13, 2012 3:39 pm | |
| dh dekat 6tahun aq x bukak head motor ni...sejah abg aq bagi kt aq....tadi ade angin rasa nk bkak...hhehe boleh bkak head je....block xleh bukak...xthu sbab ape...nut block dh bukak tp aq tarik xnk gerak pn....carbon kt head aq dh lap sampai licin....tp carbon kt piston xleh.... nk wat mcm mcm mane ehh...nk buang carbon tu??? | |
| Subject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4 | |
