| Semua Tentang Clutch | |
+99are_mair letak_pisang SAA1729H Azeri_conquistador comebackid wan_210407 Shark pfa -sLip- mfareez esabadi84 megnamon naem 2345 MrAchit iqram fareast fx110 zai KapcaiKuDie jacob tupai comel pasquale aleb lemonish abg_apis jem_125zr satria_zr crankster Apislegend fiq Kato_125 su midi Ultra-Z nurkaye_akmal devilmeasha eqbal ss110 unggu azli syah sParK_koRn Ezad chaosworld hery kery capik_9981 tupaiku unknownh tupai_tempur alpazz Fendi Faito haizamlee redline absolute_ahben yi_tupaijek01 ajizaimi hudrey_z madie wan2pai fizerpool mR.nobita alip_jkx6331 araifish soNa oliey2u ijat666 cerah9 kelvin45 alibattay bdk_125zR ihsanxx ayip125 S-T-P vendetta azdli90 aus_ipoh amex matwe87 mantadkb feederxv encik hariz assasin_lunxe osiris hafidz kick_ingoal ~*PeRaK MaLI*~ superjoemanito dy rasau mazakim Thund3r budak p.d zouk188 abdullah_yantie ak chocolate arjuna86 andy-wkv ridsect lanunlaut udin_014 WKQ4913 Admin HailToKing 103 posters |
haizamlee Laskar Kelas I
| Subject: Re: Semua Tentang Clutch Wed Sep 01, 2010 8:50 pm | |
| mmg la sama,sbb mende tu sama jer..no tu bukan no siri production brg tu,tp no barangan dlm katalog..soo kl ko nak order just bgtau jer no tu..rm7 terlalu murah le bro..bese dlm rm18++ sekeping | |
| Subject: Re: Semua Tentang Clutch Wed Sep 01, 2010 11:32 pm | |
| clutch plate ex5 4keping rm5? murah betol...kalo skeping rm10 mgkin btol la kot...tp gne plate ex5 ni lbh kurang ngn gne plate 125 HLY? |
| Subject: Re: Semua Tentang Clutch Wed Sep 01, 2010 11:47 pm | |
| tu la pasai...tp yg pelik nye,,dlm 5 keping tu,,,satu je no dia lain...aiyoo..ragu2 nk pakai..ke aku jual kat budak2 je...huuhh | |
Fendi Faito Support Crew
Posts : 412 Join date : 17/08/2010 Age : 32 Location : KOTA KINABALU SABAH
| Subject: Re: Semua Tentang Clutch Thu Sep 02, 2010 12:28 am | |
| bro nak tanya ni....napa arr....moto aku bila aku kaci hampir tu clutch kan...susah maw masuk gear sama bagi free gear...pa masalahnya tu arr..masalah mangkuk clutch ka tu?taw sebaliknya..ada cakap cabel aku..tapi moto aku lum gak lama beli.. | |
alpazz Laskar Kelas I
Posts : 143 Join date : 06/04/2010 Location : ipoh
| Subject: Re: Semua Tentang Clutch Thu Sep 02, 2010 12:56 am | |
| - Fendi Faito wrote:
- bro nak tanya ni....napa arr....moto aku bila aku kaci hampir tu clutch kan...susah maw masuk gear sama bagi free gear...pa masalahnya tu arr..masalah mangkuk clutch ka tu?taw sebaliknya..ada cakap cabel aku..tapi moto aku lum gak lama beli..
adjust freeplay clutch dlu bro.. baru beli moto kan? klau ade buku manual cube cari kt dlm tu.. situ ade cara2 nak pnjangkan freeplay clutch.. klau x boleh gak try tnye otai len.. | |
| Subject: Re: Semua Tentang Clutch Thu Sep 02, 2010 4:55 am | |
ok bro nanti aku try adjust...thanks inform ni. moto ni nak 2 tahun uda lum gak lama.. | |
| Subject: Re: Semua Tentang Clutch Fri Sep 03, 2010 9:20 pm | |
| - haizamlee wrote:
- tu la pasai...tp yg pelik nye,,dlm 5 keping tu,,,satu je no dia lain...aiyoo..ragu2 nk pakai..ke aku jual kat budak2 je...huuhh
yg no. lain tu yg plg kecik ke? | |
tupai_tempur Laksamana Armada
Posts : 411 Join date : 21/07/2009 Location : Taman molek,jb
| Subject: Re: Semua Tentang Clutch Fri Sep 03, 2010 10:18 pm | |
| time aku tinggalkan moto untuk rivet balik clutch aku,aku dapati ada kesan retak pada mangkuk clutch aku. so terpaksa tukar baru. memang retak atau angkara kecuaian pomen semasa buka mangkuk clutch? | |
| Subject: Re: Semua Tentang Clutch Fri Sep 03, 2010 10:45 pm | |
| biasenye retak time nk pushkan mate rivet kuar untuk asingkan gigi gear n umah klac tue atau pun time nk matikan mate rivet untuk ikat blk gigi gear ngan umah klac,klu process rivet pakai tangan xde la risiko retak@pecah,klu pakai mesin mmg sng2x je pecah,so mende nie normal je.. | |
| Subject: Re: Semua Tentang Clutch Sat Sep 04, 2010 2:49 am | |
yg no. lain tu yg plg kecik ke? a.aa... Uploaded with ImageShack.us yg ni no lain dri yg len... yg ni 4-4 keping sumer sama no...adui.. | |
unknownh Bintara Kanan
| Subject: Re: Semua Tentang Clutch Thu Sep 16, 2010 10:07 pm | |
| bleh x ajar cne nk tukar spring klac nga plate die? die cmne ek?bukak cover belah klac kn..rivet2 tu aku x tau tu..tukar spring aku tau..buang nat 4 ketul,,pastu tukar je spring.then msuk balik..pastu pasang balik je la?gasket baru then pasang cover belah klac tu.?? | |
| Subject: Re: Semua Tentang Clutch Thu Sep 16, 2010 10:12 pm | |
| pasal retak tu sebab pomen mls la tu..so die cuai.. kate pomen aku la pomen aku sbelum jadi pomen sruh pomen lain jgk buat..(ayt ngarot) die ckp sbb pomen x sabar buat keje..sbb tu jadi retak tu..(pomen aku punye hancur trus) bende ni normal ke?klu cmtu nk tukar spring clutch,plate kene tukar skali mangkuk la.. aduh la. | |
| Subject: Re: Semua Tentang Clutch Sun Sep 19, 2010 11:25 pm | |
| unknownh,maksud joe retak tu jadi time nak bkk rivet/rivet balik mangkuk clutch..kl time nak ganti spring pomen tu dah awal2 kasi retak mangkuk tu,mmg salah pomen tu ler wat kerje cuai.. | |
| Subject: Re: Semua Tentang Clutch Mon Sep 20, 2010 12:37 am | |
| a'ah.time bkk nga rivet blik la.. pomen aku bukak nga cre die canai dlu hujung tu,,pastu tolak dgn ketuk paku guna tukul ats tu.. pastu kluar la.. ayt ats slh ket(pkai mesin mmg sng retak) | |
tupaiku Laskar Muda
Posts : 30 Join date : 29/07/2010 Age : 32 Location : melaka-area bkit beruang-ayer molek
| Subject: Re: Semua Tentang Clutch Fri Oct 01, 2010 3:12 pm | |
| tpi nk ribet klac kena pki mngkuk yg ori aje klo pki mngkok yang lokel mmng tetap ad juga bnyi bertukang tu... klo korang pki yg lokel baik simpan duit ,,,, biar je bnyi betukang tu... | |
tupaiku Laskar Muda
| Subject: Re: Semua Tentang Clutch Fri Oct 01, 2010 3:16 pm | |
| tmpng tanye skit... otai2 suma thu tak cmne nk pendekkan clutch... aq takde ah bku manual tu... | |
| Subject: Re: Semua Tentang Clutch Fri Oct 01, 2010 3:25 pm | |
| - tupaiku wrote:
- tmpng tanye skit... otai2 suma thu tak cmne nk pendekkan clutch... aq takde ah bku manual tu...
bukak coverset kepala tu.. tengok kt cluth lever punye cable.. longgarkan nut tu saiz 12 kot.. pastu pusing kedalam to pendekkan.. rsenye ssh nk faham.. tapi kalau dah tengok rsenye ley faham dgn sendirinye.. gdluck.. | |
capik_9981 Laskar Muda
Posts : 99 Join date : 03/10/2010 Age : 32 Location : Bkt Payong,marang,teganu
| Subject: Re: Semua Tentang Clutch Tue Oct 26, 2010 10:53 pm | |
| kalau pkai clutch racing effect dia byk x??? | |
| Subject: Re: Semua Tentang Clutch Tue Oct 26, 2010 11:10 pm | |
| - capik_9981 wrote:
- kalau pkai clutch racing effect dia byk x???
clutch plate ke spring clutch bro?,klu clutch plate racing lebey kurg same je ngan standard,ade la skit beza,bab ketahanan x tau la,klu spring clutch lak ade beza time shifting gear ke gear,lbh kpd pickup je,klu bwk biase2x same je,kene tarik kaw2x baru rase beza.. | |
hery kery Laskar Kanan
Posts : 246 Join date : 16/09/2010 Age : 35 Location : butterworth
| Subject: Re: Semua Tentang Clutch Thu Nov 11, 2010 12:23 pm | |
- mmg la sama,sbb mende tu sama jer..no tu bukan no siri production brg tu,tp no barangan dlm katalog..soo kl ko nak order just bgtau jer no tu..rm7 terlalu murah le bro..bese dlm rm18++ sekeping
kt tmpt aku skping rm15...klu yg skping rm7 tu kre cmne lak, local?? | |
| Subject: Re: Semua Tentang Clutch Sat Nov 13, 2010 12:11 am | |
| kalo pkai spring clucth racing (faito/uma) ape jd? Pikap brtmbah? Brtmbah cm ne? Mto pegi melantun-lantun ke? Top plak mcm mne? Adakah same atau brtmbah atau brkurang? | |
| Subject: Re: Semua Tentang Clutch Sat Nov 13, 2010 7:12 am | |
| melantun la sket dr spring ori. top sme je. | |
| Subject: Re: Semua Tentang Clutch Sat Nov 13, 2010 7:54 am | |
| kalo spring clucth cam faito ngn uma,bpe rm ek? | |
| Subject: Re: Semua Tentang Clutch Sat Nov 13, 2010 11:32 am | |
| - hery kery wrote:
kt tmpt aku skping rm15...klu yg skping rm7 tu kre cmne lak, local?? mungkin lokel kot harga cam murah sgt jer.. clutch plate resing utk lebih grip masa change gear..means muto xde menengung masa change gear,trus jer sambung..tp jangka hayat plate tu kurang kl banding ngan stended punya | |
| Subject: Re: Semua Tentang Clutch | |
