| Spesifikasi & Modifikasi Tupai Masing2 V2 | |
+69MadAxel wan_210407 Kazamasaga-san putra1691 Kato_125 poknik koie06 chrome MegatBLA3089 nurkaye_akmal xopai majidali softoperator hashimirosicky 125zRskala along paan1171 redline Hanomichi89 airil man JGN8917 yi_tupaijek01 kenzou hanturaya111 fiq seng_87 acaapxx h@ziQ azdli90 imanhalimi xapex kekuravslelabi Cat Faris musesaddiq fareez91 ak wormzx hidup_sihat Ajib geeks arjuna86 monyet BKR3**4 absolute_ahben komi kirkhamster sANi bUAs hasrul_90 zr90 ajmon_85 oddysee11 aus_ipoh farul oliey2u amex neomerc Ultra-Z fizerpool vendetta nizam1407 mantadkb gilgamesh88 superjoemanito hakemrahim chocolate tupai comel WKQ4913 soNa mazakim 73 posters |
s-rank Laskar Muda
Posts : 60 Join date : 03/05/2010 Age : 38 Location : subang-kajang-bangi-nilai-seremban
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Sun Jan 02, 2011 8:29 pm | |
| tak de la teruk..normal rsnya. gune karb rxz.sblm ni gune karb 125 lay & tzm mmg cam air..pokoknya kalu udah gilak kuasa ngak apain ah ding dong | |
Kazamasaga-san Laskar Kanan
Posts : 201 Join date : 15/12/2010
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Sun Jan 02, 2011 10:36 pm | |
| - Mafiaflix wrote:
- Salam bro.
aku 125Z rider from Indonesia. mau share spec motor aku...
head skimmed 1 mm, cylinder blok standart, exhaust YYPang SPR silencer AHM, coil Yamaha YZ125, carburator PWK 28 mm SUDCO pilot jet 40 main jet 110, reed valve Boyesen dual stage, sproket standart, tire IRC Razzo 166 90/80. footrest Racing Boy.
ini foto motor aku bro...
- My Yamaha 125Z:
cantik ejos bro..hahaha.. kalo disini pak polisi mmg suka ejos mcm itu... | |
Mafiaflix Laskar Muda
Posts : 77 Join date : 08/12/2010 Age : 35 Location : Yogyakarta - Indonesia.
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Mon Jan 03, 2011 2:59 am | |
| - Kazamasaga-san wrote:
- Mafiaflix wrote:
- Salam bro.
- My Yamaha 125Z:
cantik ejos bro..hahaha.. kalo disini pak polisi mmg suka ejos mcm itu... Hahaha iya bro, kalo di sini 2 stroke aman lah pakai ejos macam apapun... pak polisi lebih suka menangkap bikers yg memakai exhaust racing pada motor 4 stroke, macam YYPang atau AHM tu bising kali bro... hahaha | |
koie06 Laskar Kelas I
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Mon Jan 03, 2011 12:17 pm | |
- kasi sumbat clutch TRiNiTi la bro.. xpon OS Giken loceng..(igt nih kete ke ape)hehehehe
Triniti xde spring...time nak jalan nnt bergegar...mounting cpt pecah...hahaha... OS Giken & Ogura harge x tahan...bley beli moto lg 1 tu...huhu... skang nak carik bajet tuka clutch plate ori pastu nak revert balik mangkuk clutch... | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Mon Jan 03, 2011 12:21 pm | |
| - Mafiaflix wrote:
- Salam bro.
- My Yamaha 125Z:
best nye kalo aku pun ade carb PWK SUDCO nie...respond cepat n throttle lembut je...berapa harga kat sane bro?... | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Mon Jan 03, 2011 3:48 pm | |
skang nak carik bajet tuka clutch plate ori pastu nak revert balik mangkuk clutch... trniti mule2 pkai bnyik mcm klac bearing kong, pastuh refer pomen mmg mcm tuh bnyik dia.. pomen suh pkai solid mounting kalo xmounting stendet mmg jhnam...keras? memula pkai kaki tempang kjap...hahaha | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Mon Jan 03, 2011 4:20 pm | |
| - koie06 wrote:
- Mafiaflix wrote:
- Salam bro.
- My Yamaha 125Z:
best nye kalo aku pun ade carb PWK SUDCO nie...respond cepat n throttle lembut je...berapa harga kat sane bro?... iya bro memang seedap lah pickup motor kalau kita pakai carb PWK 28. Namun manifold mesti di modif sikit, di buatkan semacam spacer almunium kotak sebagai joint antara manifold dg reed valve. Kalau x di modif nanti tersangkut lah tu carb dg crackcase. Harga disini Rp 1.900.000 bro atau 210 US$ | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Tue Jan 04, 2011 11:39 pm | |
| ffehh.. 210 usd.. duit malaysia dkat rm600++ wwoo.... | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Wed Jan 05, 2011 1:30 am | |
| - paan1171 wrote:
- ffehh.. 210 usd.. duit malaysia dkat rm600++ wwoo....
iya bro, mangtop lah pakai carb ini... akselerasi sangat cepat topspeed pun bertambah RPM mau tinggi, tidak rugi lah kita keluar uang segitu. alternatif lain bisa cari yg 2nd kisaran rm 450 bro. | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Wed Jan 05, 2011 1:51 am | |
| ishh..besh besh!! mahu duduk indonesia la pasni.. hahaha | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Wed Jan 05, 2011 2:01 pm | |
| - Mafiaflix wrote:
iya bro, mangtop lah pakai carb ini... akselerasi sangat cepat topspeed pun bertambah RPM mau tinggi, tidak rugi lah kita keluar uang segitu. alternatif lain bisa cari yg 2nd kisaran rm 450 bro. mantop juga mau cari uang nya... huhuhu... tpi majoriti dari kami menggunakan carburator asal @ carburator rx-z... keranan agk susah ingin mencari dan harga yg agk keras... hahaha... | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Thu Jan 06, 2011 3:20 am | |
| stendet la m'sia brg ape jek yg x mahal... sume mahal.... | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Thu Jan 06, 2011 10:45 am | |
| - Mafiaflix wrote:
- koie06 wrote:
- Mafiaflix wrote:
- Salam bro.
- My Yamaha 125Z:
best nye kalo aku pun ade carb PWK SUDCO nie...respond cepat n throttle lembut je...berapa harga kat sane bro?... iya bro memang seedap lah pickup motor kalau kita pakai carb PWK 28. Namun manifold mesti di modif sikit, di buatkan semacam spacer almunium kotak sebagai joint antara manifold dg reed valve. Kalau x di modif nanti tersangkut lah tu carb dg crackcase. Harga disini Rp 1.900.000 bro atau 210 US$ macam mane la cara nak modified ek?...xdpt nak imagine la...aku ade carb TM30...nak masuk kat moto x lepas... harge PWK Sudco kat sini RM590-595...mainjet n pilotjet die lain dr RXZ...harge pun mahal dr mj n pj RXZ...da mcm UMA punye.. | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Fri Jan 07, 2011 12:21 am | |
| - koie06 wrote:
- macam mane la cara nak modified ek?...xdpt nak imagine la...aku ade carb TM30...nak masuk kat moto x lepas...
harge PWK Sudco kat sini RM590-595...mainjet n pilotjet die lain dr RXZ...harge pun mahal dr mj n pj RXZ...da mcm UMA punye.. carb tm30 tu labuh bwh die jejak crankcase ek? kalo psg jd senget sket carb nye kot.. hehehe.. pwk sudco tu kalo tk silap versi upgrade dr keihin pwk.. so, jetting die same dgn carb keihin.. bleh dpt kot kt kdai sparepart.. at least bleh bli satu2 tk mcm UMA kne beli satu set.. | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Fri Jan 07, 2011 5:46 pm | |
| - paan1171 wrote:
- Mafiaflix wrote:
iya bro, mangtop lah pakai carb ini... akselerasi sangat cepat topspeed pun bertambah RPM mau tinggi, tidak rugi lah kita keluar uang segitu. alternatif lain bisa cari yg 2nd kisaran rm 450 bro. mantop juga mau cari uang nya... huhuhu... tpi majoriti dari kami menggunakan carburator asal @ carburator rx-z... keranan agk susah ingin mencari dan harga yg agk keras... hahaha... Salam bro... carb RXZ bagus juga itu bro, namun kalau di Indonesia, bisa di modified lagi itu carb jd ukurn 28 mm. bagian venturi carb kena skim lagi... lalu throttle valve pun di tukar pakai ukuran 30 mm. coba try cari carb Yamaha TZR 125 bro, macam ini. Mikuni VM 26 mm, with powerjet. | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Fri Jan 07, 2011 5:47 pm | |
- stendet la m'sia brg ape jek yg x mahal... sume mahal....
Sama la bro... di Indonesia pun mahal. namun karena hobby maka yg harganya mahal pun jadi dapat kita beli bro... hahahahaha | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Fri Jan 07, 2011 5:54 pm | |
harge PWK Sudco kat sini RM590-595...mainjet n pilotjet die lain dr RXZ...harge pun mahal dr mj n pj RXZ...da mcm UMA punye.. ooo lebih murah lah disana, sini mahal betul bro. besok kalau pas aku tukar size pilot jet coba aku ambilkan picts bro... nanti aku upload kesini. tujuannya di buatkan "almunium spacer" agar posisi intake bisa lebih naik miring sikit sehingga carb tidak kena dg crankcase. betul bro, pilot jet & main jet memang lain la... tapi sama macam carb UMA. | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Mon Jan 10, 2011 10:21 am | |
harge PWK Sudco kat sini RM590-595...mainjet n pilotjet die lain dr RXZ...harge pun mahal dr mj n pj RXZ...da mcm UMA punye.. carb tm30 tu labuh bwh die jejak crankcase ek? kalo psg jd senget sket carb nye kot.. hehehe.. pwk sudco tu kalo tk silap versi upgrade dr keihin pwk.. so, jetting die same dgn carb keihin.. bleh dpt kot kt kdai sparepart.. at least bleh bli satu2 tk mcm UMA kne beli satu set.. TM30 try nak masuk dr atas mmg x lepas langsung..trus cancel nak pakai...time rajin nnt nak try masuk ikut bahagian airbox pulak... kalo bawah carb sangkut crankcase maknenye kne wat spacer kat reedcage utk jauhkan getah ikat carb tu ke blkg ckit la kan?... kalo x silap jetting PWK ade jual satu2... | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Mon Jan 10, 2011 10:27 am | |
tq bro...nanti kasi upload satu gamba spacer yg dah pasang ek...kalo boleh bgtau skali bpe mm spacer tu... | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Mon Jan 10, 2011 9:54 pm | |
tq bro...nanti kasi upload satu gamba spacer yg dah pasang ek...kalo boleh bgtau skali bpe mm spacer tu... ok bro, besok aku ada pergi ke workshop, nanti aku kabari ukurannya dan aku ambil picts nya. | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Tue Jan 11, 2011 11:09 am | |
| ok bos...ape bende yg bro lekat kat fairing depan tu?... | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Tue Jan 11, 2011 4:08 pm | |
| this is the one that i use with mikuni tm 28.. cant use the oem part since the carb being larger at the base,stuck with engine casing.. | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Wed Jan 12, 2011 1:23 am | |
| - koie06 wrote:
- ok bos...ape bende yg bro lekat kat fairing depan tu?...
Hahahahaha itu kami sebut "registration plat number/ plat nomer" bro. x lekat kan bende itu di depan & belakang motor maka akan kena kejar oleh pak polisi... hahahaha | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Wed Jan 12, 2011 1:27 am | |
- this is the one that i use with mikuni tm 28..
- Spoiler:
cant use the oem part since the carb being larger at the base,stuck with engine casing.. Cool bro... could you please give us more picts from another angle? why you didn't make some hole to add Bost Bottle hole(YEIS) this is aluminium spacer with Boyesen dual stage reed in my Tupai Jet... - almunium spacer:
harap dapat membantu kawan kawan yg ingin mengupgrade size carb Tupai Jet nya masing masing... | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 Wed Jan 12, 2011 2:15 am | |
| i can see there's a dual stage boyesan reed valve ho3
sorry but that's the only clear picture that i have
i dont really like using yeis since it add more heat to my engine..or is it because the configuration of the yeis itself making it hotter? once i try to fit a DIY yeis to my bike,try running it for the first time,and not bad,it fix the sluggish problem at mid rpm..but my engine easily become hotter compare with before i install the yeis
i use a 200ml plastic bottle(fork oil bottle),a tubeless tire valve(with the inside part removed) to connet the tube from the bottle itself to the intake manifold..is it because the tube is too small?the diameter of the tube is only quater of inch.. | |
| Subject: Re: Spesifikasi & Modifikasi Tupai Masing2 V2 | |
