Share | .
 2T & 4T Pilihan Anda V4
Go to page : Previous  1 ... 7 ... 11, 12, 13 ... 16 ... 20  Next
PostSubject: Re: 2T & 4T Pilihan Anda V4   Tue Feb 23, 2010 5:55 pm
ha3x,aku pun pening..nnt aku nk ushar kt kedai,sbb xpnh lak jumpe castrol 2t yg fully sintetik
4T=PETRONAS SYNTIUM MOTO 4SX - SAE 15W-50..
2T=PETRONAS SYNTIUM MOTO 2SX/PENNZOIL MARINE® PREMIUM PLUS OUTBOARD TWO-CYCLE OIL..
the strokes - you only live once..
final top speed_ttc..
stupid monkey..
silent is easy..
soul_reaper..
PostSubject: Re: 2T & 4T Pilihan Anda V4   Tue Feb 23, 2010 6:36 pm
owh..castrol power1 racing 2t ek,ade jumpe ke 2t castrol racing bro?..
baru tgk..die tulis castrol power1 je..xde racing..hehe..ade castrol power1 racing punye ke?
xsilap ak ade castrol power1 racing...tp kalo jaso FD tu fully sintetic xmngkin hrga bleh murah cmtu...sume org tau kn fully sintetic msti mhal punye RM40++..
bro joe...4T maxoil superbike yg ko gne tu bape inggit???
PostSubject: Re: 2T & 4T Pilihan Anda V4   Tue Feb 23, 2010 6:46 pm
lupe dah bro,yg pastinye bwh rm20..
stupid monkey..
silent is easy..
soul_reaper..
PostSubject: Re: 2T & 4T Pilihan Anda V4   Tue Feb 23, 2010 8:00 pm
Benefits
Maximum power operation
Maximum engine power without compromising on protection
  • Excellent resistance to exhaust system blocking which may lead to
    power loss over time
  • Exceptional engine cleanliness
    Low levels of visible smoke
    Applications
    Suitable for use in all Modern Japanese and European Bikes.
    Specification : Exceeds JASO FD, ISO EGD and API TC
    Performance Level
    Exceed the following specifications:
    JASO FC
    ISO EG-C
    TISI
    dipetik dr http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=82914632&contentId=6006021
    ade lg..
    Specifications for Two
    Stroke Oil
    NMMA TC-W3 ? two cycle
    water-cooled, third generation. TC-W3 obsoletes TC-W & TC-WII. Oils
    with this spec do not use metal based additives, and are ashless. This
    is an outboard specific spec.
    API TC ? only API spec
    established for two cycle engines. It regulates lubricity, detergency,
    ash content & pre-ignition. Oils with this spec are typically using
    metal based, ash producing additives.
    JASO FA ? original
    spec established regulating lubricity, detergency, initial torque,
    exhaust smoke and exhaust system blocking.
    JASO FB ?
    increased lubricity, detergency, exhaust smoke and exhaust system
    blocking requirements over FA.
    JASO FC ? lubricity and
    initial torque requirements same as FB, however far higher detergency,
    exhaust smoke and exhaust system blocking requirements over FB.
    JASO
    FD
    - same as FC with far higher detergency requirement.
    ISO-L-EGB ?
    same tests and requirements as JASO FB.
    ISO-L-EGC ? same
    tests and slightly higher detergency requirements (piston varnish) as
    JASO FC.
    ISO-L-EGD ? same tests and requirements as JASO FD.
    Good
    = JASO-FB, ISO-EGB
    Better = API-TC, JASO-FC, ISO-EGC
    Best =
    JASO-FD, ISO-EGD
    taken from MBC
    erm..ape kene mengena gred jaso ni dgn sintetik? hihi..xtau..
    confirmation: jaso FD = semisintetik
    PostSubject: Re: 2T & 4T Pilihan Anda V4   Tue Feb 23, 2010 8:07 pm
    2T castrol yang ade dalam pasaran malaysia,yg botol gold tu semi sintetik je wahai kawan2 ku sekalian,kelebihan die gred die tertinggi = Jaso FD,tu je,taraf sintetik sama je ngan VSX,Sprinta 4000..
    *yang kalau castrol fullsintetik,namanye Castrol Power1 TTS racing Fully Sintetik--member aku pernah beli tapi kat indon n thai
    *2T full sintetik yang murah takat ni aku rase Sprinta 5000 je,RM38++..
    *yang aku pakai dulu,Sprinta GP,RM78 seliter / sebotol..hehe
    JASO tu senang citer gred untuk tgk brape bersih 2t ni..(kadar pembebasan asap,n kebersihan enjin)..
    -sintetik plak kandungan dalam minyak tu... kalo fully sintetik minyak tu lebih nipis dan ringan berbanding minyak mineral..
    PostSubject: Re: 2T & 4T Pilihan Anda V4   Tue Feb 23, 2010 11:18 pm
    ha3x,baru aku tau ade gk castrol power 1 tts fully sintetik,yg aku tau malaysia xbwk masuk pun 2t fully sintetik a.k.a castrol power 1 racing fully sintetik nie,klu nk merasa 2t fully sintetik buat mase skrg petronas sprinta 5000 je ar,tue pun pyh nk mencarinye,he3x..
    stupid monkey..
    silent is easy..
    soul_reaper..
    PostSubject: Re: 2T & 4T Pilihan Anda V4   Wed Feb 24, 2010 4:20 am
    kt petronas kt hiway federal aku perasan ade jual..
    yg seblah2 dgn shell..
    rm+38 argenye..
    tp aku pkai sprinta 1000 je..
    hehe..
    PostSubject: Re: 2T & 4T Pilihan Anda V4   Wed Feb 24, 2010 11:35 pm
    aku pun xpnh pakai petronas sprinta 5000 bro,mahal giler,ha3x..
    stupid monkey..
    silent is easy..
    soul_reaper..
    enzoanz
    PostSubject: Re: 2T & 4T Pilihan Anda V4   Fri Feb 26, 2010 11:58 am
    banyak sgt brand 4t n 2t ni..
    ak dh xtau nk pkai yg mane..
    skrg ak pkai 4t castrol semi sintetik, 2t vsx je..
    tp smlm mmbe ak bli 2t hi-rev, ak xpasan model pe, tp bau die soft sket dr vsx tp wangi gk la..
    mmbe ak 2 pkai tupai gk.. ajak die join kte die xnk..
    huhu..
    PostSubject: Re: 2T & 4T Pilihan Anda V4   Fri Feb 26, 2010 1:02 pm
    lorh..
    2t neh bagus tk bagus jgn ikut wangi tk wangi bro..
    kalo manusia tk wangi mmg tk bagus..
    hahaha..
    tcw3 2t plg hangat dlm forum neh tk wangi pn..
    tp performance mmg tiptop.
    PostSubject: Re: 2T & 4T Pilihan Anda V4   Fri Feb 26, 2010 2:26 pm
    da try TCW3..maxxoil..baru start..da rase laju.. Razz
    enzoanz
    PostSubject: Re: 2T & 4T Pilihan Anda V4   Fri Feb 26, 2010 3:04 pm
    lorh..
    hahaha..
    hehe.. ak pun xnk busuk2 ni..
    okes.. nnt ak try tcw3 2t 2...
    PostSubject: Re: 2T & 4T Pilihan Anda V4   Fri Feb 26, 2010 3:22 pm
    maxxoil tcw3 bau mcm tengik..
    tp performance best..
    pg2 start moto je..x nmpk asap pon..rase mcm NGV la plak..
    PostSubject: Re: 2T & 4T Pilihan Anda V4   Fri Feb 26, 2010 3:26 pm
    asap mmg xde lgsg klu pakai ekjos catalyzer nie,he3x..bau die xla tengik sbnrnye,klu bau sekali tengik,bau 2 kali wangi lak,klu bau 3 kali busuk lak,klu bau 4 kali trs masuk spital
    stupid monkey..
    silent is easy..
    soul_reaper..
    ijat666
    PostSubject: Re: 2T & 4T Pilihan Anda V4   Fri Feb 26, 2010 3:45 pm
    hahaha....aku sekali bau da terbang da bro...
    hehehe....tp mmg best la maxoil nye 2t ni...
    clean....
    durjana kau yang punya angkara
    mengalih setiap pandangan manusia
    yang benar kau palsukan
    tugasmu seumpama syaitannnn!!!
    http://www.facebook.com/?ref=home#!/ijat666?ref=profile
    PostSubject: Re: 2T & 4T Pilihan Anda V4   Fri Feb 26, 2010 3:59 pm
    aku masih confuse..walaupon TCW3..ia tetap jaso FC..
    less protection compare to jaso FD ke?
    enzoanz
    PostSubject: Re: 2T & 4T Pilihan Anda V4   Fri Feb 26, 2010 5:39 pm
    betul jgk soalan ko 2 tupai comel..
    ak pn mcm tfikir gk nk tny..
    Question
    enzoanz
    PostSubject: Re: 2T & 4T Pilihan Anda V4   Fri Feb 26, 2010 5:54 pm
    • 2T-TCW3 merupakan minyak motorsikal 2-lejang yang rendah (kurang pengeluaran) asap dan berbau harum. Dihasilkan untuk enjin 2 lejang kelas tertinggi, enjin perlumbaan serta sesuai untuk enjin sangkut
    • 2T-TCW3 menepati keperluan tertinggi JASO FC, Global GC dan NMMA Service TC-W3
    • Memaksimakan hayat enjin dan pengeluaran asap ekzos yang luar biasa rendah
    • Mencegah kehilangan kuasa
    • Pelinciran terbaik untuki mencegah perampasan omboh dan lekatan gelang
    • Mencegah palam pencucuh daripada tersumbat
    • Dihasilkan untuk sistem suntikan bahanapi atau sebaliknya. Bahan api/minyak tidak perlu dicampurkan terlebih dahulu
    • Nisbah gasolin dengan minyak yang disyorkan ialah 50:1
    Sesuai digunakan dengan gasolin plumbum atau tanpa plumbum
    ak dpt info ni.. sje nk share dgn korang.. huhu
    PostSubject: Re: 2T & 4T Pilihan Anda V4   Fri Feb 26, 2010 6:21 pm
    sy syg 2t tcw3 maxoil..
    PostSubject: Re: 2T & 4T Pilihan Anda V4   Fri Feb 26, 2010 6:37 pm
    bkn la mksdnye jaso fc tue xbgs,sbnrnye jaso fc same je ngan fd,bezanye skit kt bahan detergent je
    stupid monkey..
    silent is easy..
    soul_reaper..
    Last edited by superjoemanito on Fri Feb 26, 2010 6:49 pm; edited 4 times in total
    Page 12 of 20Go to page : Previous  1 ... 7 ... 11, 12, 13 ... 16 ... 20  Next
    » BAHAGIAN 2- Minyak 2t & 4t 125z Anda
    » Helmet Openface Apakah pilihan Rider~rider kita?
    » Tayar Pilihan Anda V3
    » kisah-kisah seram anda bersama motorsikal.
    » apa pandangan kenalan anda sebaik sahaja pertama kali melihat motor anda...
