 Piston Enduro
Go to page : 1, 2, 3, 4, 5, 6, 7, 8  Next
bujang
PostSubject: Piston Enduro   Fri Jan 08, 2010 12:03 am
Sape2 penah pakai piston yamaha DT125 a.k.a enduro kt blok tupai.
citer skit best ke x? pe rasa. klu leh cter details skit ler...pkai carb ape,saiz mnjet,pilotjet.
PERBEZAAN
Y-125Z
DT-125E
DT-125A/
DT-125FB
OEM No.
5BU-
OEM No.
2A6-
444-
CODE No.
AY0720X
CODE No.
AY0570X
AY0560X
BORE(mm) :A
53.8
BORE(mm) :A
56
56
LENGTH(mm) :B
66.70
LENGTH(mm) :B
66.00
66.00
PIN DIA (mm) :C
16
PIN DIA (mm) :C
16
16
COMPRESSION HEIGHT① (mm):D
32.70
33.00
33.00
COMPRESSION HEIGHT② (mm):E
29.50
29.80 30.00
PIN LENGTH (mm):F
16X44.5
PIN LENGTH (mm):F
16x47
16x47
PLATING
PLATING
STROKE
2
STROKE
2
2
PISTON CODE No.
PY0960X
PISTON CODE No.
PY0820X
PY0810X
http://www.facebook.com/mohdnoorhelmi
PostSubject: Re: Piston Enduro   Fri Jan 08, 2010 12:26 am
dlu pernah dgr sorang pomen kat area ak pki...die pki carb tzm...best x best ak x sure...tp outmeter tu normal muto die...
PostSubject: Re: Piston Enduro   Fri Jan 08, 2010 1:04 am
piston enduro ni sama cam ko pakai piston saiz oversize 125z la..kelebihan pickup la sebab cc dah besar,kene ngan setting awal ade,ujung rpm pun ade,klau salah setting ujung rpm lemau..yang penting pakai piston besar2 ni,head pun kene oter gak..klau x x allout la..
PostSubject: Re: Piston Enduro   Fri Jan 08, 2010 1:07 am
size 0.0 enduro= size 2.0 125z
tul ker....kalo salah tolong betulkan
PostSubject: Re: Piston Enduro   Fri Jan 08, 2010 1:22 am
silap skit tu..
enduro 0.00 = 56mm
125z 0.00 = 53mm
jadi,enduro 0.00 = 125z 3.00 OS
soNa - 0194485713
PostSubject: Re: Piston Enduro   Fri Jan 08, 2010 1:24 am
owh yeke...
mau bertahun gak la nk smpai size 3.0 tuh....hahahaha
cita xkesampaian la ni...hahahaha
PostSubject: Re: Piston Enduro   Fri Jan 08, 2010 1:38 am
silap skit tu..
enduro 0.00 = 56mm
125z 0.00 = 53mm
125Z 53.8mm /54mm la sona..hehe
*ooo jadi encik Sona pakai piston enduro la ni ye..hehe kantoiii..
bujang
PostSubject: Re: Piston Enduro   Fri Jan 08, 2010 1:57 am
yup! tol la tu piston 125z std 53.8mm. dt125 std 56m.
ptg td, aku dh cuba psg blok aku yg bru pas lay saiz enduro 0-0.
tp xleh hidup la plak aku start. apsal ek?
last2, mlm td aku pasang balik blok lain. leh hdup plak. poning2!
bru nk mrasa..hajat trbantut la plak.
PostSubject: Re: Piston Enduro   Fri Jan 08, 2010 2:34 am
piston pasang terbalik?piston jejak head?
PostSubject: Re: Piston Enduro   Fri Jan 08, 2010 6:30 am
WKQ4913 wrote:
silap skit tu..
enduro 0.00 = 56mm
125z 0.00 = 53mm
owh....jadi 0.00 enduro=2.20 125z la yer...
PostSubject: Re: Piston Enduro   Fri Jan 08, 2010 8:20 am
yup..aku tersilap skit lak..stended 125z = 53.8mm..
eh,mane ade pakai enduro wan..dulu ye la..best gak..lagi2 buat long distance dari penang ke N9..syok je meluncur..hehe..CC dah jadi 133cc mase tu..
mm..piston enduro ada byk jenis..
DT125A/DT125FB
DT125E
DT125K
DT125K1
DT125LC
*setiap model ni berbeza dari segi ketinggian,kedudukan piston pin,ketinggian dome,rupa tapi sama diameter iaitu 56mm..
yang aku pakai dulu DT125A/DT125FB..mungkin piston yang ko pasang tu terbalik macam kata en choc td..blok dah porting ke?..gasket berapa keping ko guna?..
soNa - 0194485713
PostSubject: Re: Piston Enduro   Fri Jan 08, 2010 12:02 pm
kire ko bore blok ko sampai saiz brape?ko pakai piston enduro saiz 0.0 ke?ke ko tukau sleeve blok baru?
-oooo patot la geng utare report moto ko laju..hehehe
PostSubject: Re: Piston Enduro   Fri Jan 08, 2010 5:16 pm
ahaha..mane ade laju wan..slow je..laju pon kelajuan stended tupai je..
aku pakai piston DT 0.25 OS..rebore blok ori stended sampai sais 56.25mm+0.8mm (clearance)..sebelum tu aku dah pakai 125z sais 1.00,1.25,1.50,1.75 n 2.00 OS..aku tak rebore sekaligus untuk dapat sais DT tu..bila dah masuk piston DT ni,sleeve mmg nipis dah..setting kena cun untuk elak risiko jem panas..so far aku guna blok ni ride penang ke n9 dgn kelajuan 8k-9k menten takde masalah..
soNa - 0194485713
bujang
PostSubject: Re: Piston Enduro   Fri Jan 08, 2010 6:10 pm
piston aku psg btul. anak panah ke lubang ekzos.
jejak head pn x kot. klu jejak head mmg xleh hdup lgsg ke moto?aku bru tau..
ni bru pas siap psg. aku g kdai moto sblm solat jumaat td:p
bli ring rxz 0-0. skrg dh leh hdup. binawe tol! bengkel yg aku htr lay blok tu kasi ring ape ntah. laen mcm..gap ngn longkang ring tu bsar giler.
PostSubject: Re: Piston Enduro   Fri Jan 08, 2010 6:23 pm
err kl dah jejak kaw2 camner nak hidup?
err ambe x reti sgt lor,hipotesis semata2...
x reti lor nak pki piston besor2 ni............
PostSubject: Re: Piston Enduro   Fri Jan 08, 2010 7:48 pm
Laughing Laughing Laughing Laughing
soNa - 0194485713
bujang
PostSubject: Re: Piston Enduro   Sat Jan 09, 2010 2:52 pm
agakny moto dia xprlu pkai piston bsor2 ni.
klu jam..sleeve calar xyah rebore.
campak kt sungai je kot. hehe
PostSubject: Re: Piston Enduro   Sat Jan 09, 2010 4:02 pm
ape barang main piston besar2 nih..kan x pasal2 tmbus lak piston nanti...x cukup minyak punye pasal...klu nk main piston nih kene set minyak lebih...
klu x..tanggung la sndiri akibatnye..
pastu bunyi kt blok tu akan kuat sket..biase la piston besar...
IngatLah OranG yg TersaYang
Ride SloW2 SuDaH....
zouk188
PostSubject: Re: Piston Enduro   Sat Jan 09, 2010 5:22 pm
x kira bro piston besar/kecik.. myk mesti mau jg..
Are_riff
PostSubject: Re: Piston Enduro   Sat Jan 09, 2010 5:42 pm
laju mcm mn sklipun kat trafik light brnti gak...
cita rasa masing2 la jnji puas hati....
bwk laju2 bnyak negetif dari yg positif...
amalkan cara hidup yg chat....pe yg aku merapu nie.. scratch
zouk188
PostSubject: Re: Piston Enduro   Sat Jan 09, 2010 10:18 pm
tp mmg x d nafikan pkai piston dt125 nih mmg superb..
performance mmg ho liow.. tp biasa la bila slevee da nipis x tahan panas..
bunyi pun bising sket.. kena jg 2t leklok..
overal recommended for hardcore jokey..
for beginner no need lah... piston std pun da cun.. cuma shoot dia kureng sket la dr dt1255 nih..
PostSubject: Re: Piston Enduro   Wed Feb 03, 2010 12:46 am
camner nak kasi kurang gegaran bl pki piston bosar2 ni?
sbb gegaran ni ada byk makna,satunya sbb mass balance out of order,muto sepatutnya bleh pi lagi laju,tp sbb x belen maka performence jadi soo2 sj
soo kl sesapa ada ilmu blue print enjin,camner nak kasi belen balik berat ngan komponen2 lain,supaya keseimbangan seperti pki piston stended tu bleh dapat balik,kongsi2 la yer
dy rasau
PostSubject: Re: Piston Enduro   Mon Feb 08, 2010 11:43 pm
sory mencelah..
so mknenye nk pakai piston enduro kat tupai ni,saiz blok kite tu kene 2.0 ek?
n ape lg yg nk kene tukar bile kite nk guna piston ni cntohnye roller dia ke ape ke..tq
farul
PostSubject: Re: Piston Enduro   Wed Mar 03, 2010 9:00 pm
tmpang tnyer ..piston enduro pling besar smpai bpe mm..
PostSubject: Re: Piston Enduro   Sun Mar 07, 2010 12:19 am
enduro ni muto aper sebenarnya?starting saiz mmg 56mm ke?atau ada starting saiz yg lain?
Piston Enduro
Page 1 of 8Go to page : 1, 2, 3, 4, 5, 6, 7, 8  Next
