| Overhaul Motor | |
+70tupaiberasap su -sLip- meerul samporna ccn qayyum_qz banchiksk8 throne_undead xopai pasquale chaosworld devilmeasha Conan Edogawa faaizil unknownh haizamlee N.A.M.I nurkaye_akmal ss110 unggu wormzx Ultra-Z wan_210407 poknik lanunlaut fishbike tupai_tempur h@ziQ acab fizerpool mzul787 airil hanturaya111 kekuravslelabi adiz aus_ipoh paan1171 ne0bolimi3rd amirfarhan yi_tupaijek01 acaapxx man JGN8917 ajizaimi sherlock oddysee11 apmsd HailToKing mousepink hafidz ijam125 mantadkb arjuna86 absolute_ahben undetected anep4742 azdli90 yoshi hidup_sihat ihsanxx vendetta cerah9 geeks chocolate superjoemanito zouk188 ak soNa assasin_lunxe WKQ4913 hasrul_90 archonixm 74 posters |
su Laskar Kelas I
| Subject: Re: Overhaul Motor Thu Sep 08, 2011 12:08 am | |
| owh...gitu...kirenye bearing tu mungkin ori tapi wat kt korea..camtu la lbih kurang kot eh?... thanks bnyk2 abam2 otai...tqvm.... jauh kot klu nak jmpe pn..huhuhu...upgrade bg laju? x brani kot laju2 sgt...gayat...hehehe... | |
tupaiberasap Laskar Muda
Posts : 95 Join date : 10/08/2011 Age : 28 Location : Johor/Skudai/Tmn U
| Subject: Re: Overhaul Motor Thu Sep 08, 2011 12:56 am | |
| ada eh korea? mati-mati aku ingat lokal dulu . bukan apa takot rod menari cam Korea POP pulak . hehehehe . last sarung bearing SKF jerr . | |
soNa Bintara Muda
| Subject: Re: Overhaul Motor Thu Sep 08, 2011 9:04 am | |
| byk sebab kenapa mto gegar ni bro..satu aku nak tanye ko,pomen ko tu ade modi crank ke?..potong ape2 ke?.. | |
Man4822 Bintara Muda
| Subject: Re: Overhaul Motor Thu Sep 08, 2011 4:16 pm | |
| - tupaiberasap wrote:
- ada eh korea? mati-mati aku ingat lokal dulu . bukan apa takot rod menari cam Korea POP pulak . hehehehe . last sarung bearing SKF jerr .
Ada je yang korea fag ni Dulu memang portugal.. Skrang portugal punya tak byk dah sebab nak cut cost. So buat kat korea Mcm SKF jgk, ada indonesia, malaysia,italy | |
su Laskar Kelas I
| Subject: Re: Overhaul Motor Thu Sep 08, 2011 8:31 pm | |
| - soNa wrote:
- byk sebab kenapa mto gegar ni bro..satu aku nak tanye ko,pomen ko tu ade modi crank ke?..potong ape2 ke?..
xde rsenye bro...aritu just tukar connecting rod, crank bearing, mgkuk clutch, clutch plate, shift shaft..tu jele..potong2 tu pn rse nye xde... npe bro? | |
| Subject: Re: Overhaul Motor Fri Sep 09, 2011 12:15 am | |
Ada je yang korea fag ni Dulu memang portugal.. Skrang portugal punya tak byk dah sebab nak cut cost. So buat kat korea Mcm SKF jgk, ada indonesia, malaysia,italy oouh thanks bgi info . lau lokal nye ade ke? | |
| Subject: Re: Overhaul Motor Fri Sep 09, 2011 6:53 pm | |
Ada je yang korea fag ni Dulu memang portugal.. Skrang portugal punya tak byk dah sebab nak cut cost. So buat kat korea Mcm SKF jgk, ada indonesia, malaysia,italy oouh thanks bgi info . lau lokal nye ade ke? FAG lokel ada je.. dia duk dalam 1 plastik mcm kita beli gasket .. Yang ori 1 kotak 1 bearing | |
su Laskar Kelas I
| Subject: Re: Overhaul Motor Fri Sep 09, 2011 7:12 pm | |
| owh gitu rupenyer....jd better klu beli cari yg jual satu2... | |
| Subject: Re: Overhaul Motor Fri Sep 09, 2011 7:18 pm | |
| - su wrote:
- owh gitu rupenyer....jd better klu beli cari yg jual satu2...
berhati-hati kalau boleh, beli kat dealer bearing.. senang sikit | |
Apislegend Laskar Kanan
Posts : 377 Join date : 01/08/2010 Age : 35 Location : kuantown-ganu-kelate
| Subject: Re: Overhaul Motor Sat Sep 10, 2011 5:12 pm | |
| bkn made in german ke apis?,he3x..nie fag 1st model,fiber case warne hitam..kod 1k.. | |
| Subject: Re: Overhaul Motor Sat Sep 10, 2011 7:02 pm | |
| [quote="superjoemanito"]bkn made in german ke apis?,he3x..nie fag 1st model,fiber case warne hitam..kod 1k..[/quote/] loo..germany kew, aku tgk ada cop portugal dan ada kod F63 V,F, nie bearing yg aku pki ari tu sebelum aku overhoul motor aku baru nie..huhu.... | |
| Subject: Re: Overhaul Motor Sat Sep 10, 2011 7:47 pm | |
| bearing pon ade lokal gak eh? lau dah pakai lokal nye , ad kelemahan tak? atau setakat boley pakai jee . | |
| Subject: Re: Overhaul Motor Sat Sep 10, 2011 8:16 pm | |
- bearing pon ade lokal gak eh? lau dah pakai lokal nye , ad kelemahan tak? atau setakat boley pakai jee .
dlm enjin kene la pakai ori,x kan nk barai enjin je setiap mase cm moto trek,setakat bearing rim blh pakai yg rm4,tpi kualiti mmg out la..lggr lbg sane sini dah gyg.. | |
| Subject: Re: Overhaul Motor Sat Sep 10, 2011 8:17 pm | |
| - Apislegend wrote:
- loo..germany kew, aku tgk ada cop portugal dan ada kod F63 V,F, nie bearing yg aku pki ari tu sebelum aku overhoul motor aku baru nie..huhu....
perhh overhaul,c3 kan?,brape rm?..yg pnh aku jumpe cop portugal n germany,fiber warne hitam,tpi skrg yg nie byk jumpe yg jns baru,case warne merah, | |
su Laskar Kelas I
| Subject: Re: Overhaul Motor Sat Sep 10, 2011 9:17 pm | |
| fuyooo...ni msti best klu pkai bearing nie...hehe
| Subject: Re: Overhaul Motor Sat Sep 10, 2011 10:14 pm | |
| hoho , camtuh , setakat nih mampu pakai bearing skf 2 bijik kat shaft , len len ntn je . huhu | |
| Subject: Re: Overhaul Motor Sun Sep 11, 2011 12:25 am | |
perhh overhaul,c3 kan?,brape rm?..yg pnh aku jumpe cop portugal n germany,fiber warne hitam,tpi skrg yg nie byk jumpe yg jns baru,case warne merah, joe pandai teka..huhu, aku bli C3 enduro baru nie kt dealer SKF kuantan rm30 sebiji...alang2 joe dah cite psal bearing FAG bleh a cite lebih lanjut, sebab bearing FAG aku berapa tak tahu lebih detail asal usulnya.... | |
abg_apis Laskar Kanan
Posts : 328 Join date : 19/10/2010 Location : johor~
| Subject: Re: Overhaul Motor Thu Sep 15, 2011 7:49 am | |
| ary nie aku nk overhaul moto tp brg2 aku nk beli sndiri .. rase lgik murah kot klu beli sndiri dri kne ketuk ngn kdai .. nk taw ape code2 bearing yg ptut dbeli .. koyo atau skf hi-speed ?
kod bearing;
crankshaft : 6205(kiri,knn) primary gear :6303(knn),6205(kiri) secondry gear:6304(kiri),6205(knn) balancer :6004,6202(lupa mana satu kiri ngan kanan)
kt atas nie btul ke ? | |
| Subject: Re: Overhaul Motor Thu Sep 15, 2011 8:30 am | |
| - abg_apis wrote:
- ary nie aku nk overhaul moto tp brg2 aku nk beli sndiri ..
kod bearing;
kt atas nie btul ke ? kalau nak best SKF, kalau nak standart KOYO... | |
| Subject: Re: Overhaul Motor Thu Sep 15, 2011 8:52 am | |
| kire2 blik ..
6205 - 4 bjik 6303 - 1 bjik 6304 - 1 bjik 6044 - 1 bjik 6202 - 1 bjik
8 bjik ke nk beli ? | |
| Subject: Re: Overhaul Motor Thu Sep 15, 2011 9:06 am | |
| - abg_apis wrote:
- kire2 blik ..
8 bjik ke nk beli ? nak tukar full set bearing ke??? biasa org tukar bearing 2 biji kt crankshaft(6205) jew sbb nak jimat | |
soNa Bintara Muda
| Subject: Re: Overhaul Motor Thu Sep 15, 2011 12:45 pm | |
| - abg_apis wrote:
- kire2 blik ..
8 bjik ke nk beli ? ade 9 biji dalam enjin tu..tapi 1 susah nak buka,welding lekat kat gear selector..8 biji boleh tukar.. dari list ko tu aku rase mcm ade yang tak betul..6205 tak salah aku ade 2 biji je..nak kene check kat rekod aku tukar dulu..kalau jumpe aku bgtau balik nanti k.. | |
| Subject: Re: Overhaul Motor Thu Sep 15, 2011 12:47 pm | |
| - abg_apis wrote:
- kire2 blik ..
8 bjik ke nk beli ? moto tahun bila? kalau moto dah lama nak tukar full bearing pun ok kalau moto masih baru, tukar yang crankshaft pun dah ringan SKF=ringan KOYO=std | |
| Subject: Re: Overhaul Motor | |
| Overhaul Motor | |
