 Overhaul Motor
tupaiberasap
su
meerul
samporna ccn
qayyum_qz
banchiksk8
throne_undead
xopai
Conan Edogawa
faaizil
haizamlee
N.A.M.I
ss110 unggu
wan_210407
poknik
lanunlaut
fishbike
h@ziQ
acab
mzul787
airil
kekuravslelabi
adiz
ne0bolimi3rd
sherlock
oddysee11
apmsd
hafidz
ijam125
undetected
anep4742
yoshi
ihsanxx
cerah9
zouk188
ak
archonixm
74 posters
Go to page : Previous  1 ... 6 ... 9, 10, 11 ... 13 ... 17  Next
Overhaul Motor - Page 10 Empty
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptySat Mar 26, 2011 10:15 am
mmg susah nak kluarkan bearing tu..tp kat bengkel kreta/motor(repair enjin) ada alat tu..ko try hantar la..mnta tlg cabutkn..
xopai
xopai
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptySun Mar 27, 2011 6:04 am
oh oke2.style2.
ha,lg satu.klo jus tuka bearing crankshaft kne wat balancing balik keh?
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptySun Mar 27, 2011 10:15 am
seeloknye buat la,sbb dah ketuk2x time barai enjin tue..
xopai
xopai
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptyWed Mar 30, 2011 5:58 am
ok bro.
last question,hehe.nk psg balik balncer ader marking pape keh?
Conan Edogawa
Conan Edogawa
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptyWed Mar 30, 2011 10:04 am
setahu aku kat gigi balancer tu ada marking...folo je marking tu.....tapi aku dah lama tak buat tak ingat dah...
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptyWed Mar 30, 2011 11:57 am
lame giler oberhol moto,a.ah ade marking ngan gear atas,ikut je titik die tue..
xopai
xopai
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptyWed Mar 30, 2011 1:58 pm
hah.mmg lme.x abih2 lg nih.nk dkt ilang saba da nih.skrg ni thread kt crankshaft da loose,dok ketuk2 nk mskkn dlm bearing.mampus la aku.
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptyWed Mar 30, 2011 4:22 pm
mmg masak..pesal ko ketuk crankshaft lak?,ko masukkan awal2x kt kulit enjin yg ber-no chasis tu dulu,yg tue buat kt kedai je,nnt die jek masuk ke dlm,tggl nk cmtumkan enjin blk je,klu masukkan sendiri mmg defect la..
Conan Edogawa
Conan Edogawa
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptyWed Mar 30, 2011 4:55 pm
patut press masukkan...takleh ketuk2...nnt crankshaft kau balancing lari....biasanya hantar casing kat kedai untuk press bearing masuk dalam housing dia....then masa nak masukan gear ngn crankshaft tu tinggal ikat pelan2 kasik center je...
xopai
xopai
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptyWed Mar 30, 2011 9:50 pm
aaaa.tu lah.lntak lah.bodoh gile aku.aku da mlas nk layan moto nih.mule2 aku pegi kdi da,suh dye press msk.tapi aku tgk dye psg bearing terbalik.so aku dgn selambe bangang nyer bukak.proses ketuk ngn menyirap pn belansung time uh.so inilah kesduhan nya.so skrg aku mmerlukn crank baru.
kdi tu amek upah smpi 30.mmg cam sial ah rse.bearing aku pn da out agak eh.pelah dosa aku nih..hmm. tapi xkesahlah, pnglamn lah kot.nnti jgn buat lg.....hmmmm.
letihnyer rse.
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptyWed Mar 30, 2011 9:57 pm
bearing terbalik..facing bearing x kisah mane2x,trip blh mane yg loose tue?..klu blh reper baik reper je,nnt die buat trip baru..
xopai
xopai
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptyWed Mar 30, 2011 10:13 pm
yke?tpi bearing uh facing nyer cm len.ader yg lebih trbuka.so aku egat nk facekn yg lebih trbuka tu ke arah 2t masuk.thread dua2 belah.aku pgi tnye kt bengkel engineering td.dye kte xpat diselamatkn.sbb hujung shaft tu da bengkak.whatever.xpe ah.aku dah ketuk2 natang uh byk kali cm nk mampus.egat nk cari crank lain jelah.balancing balik.abeh laa duit aku. Sad
xopai
xopai
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptyThu Mar 31, 2011 5:24 pm
haha.skrg da boleh da.aku anta repair thread uh kt kedai len.boleh plak dye buat.skli balancing balek ngan press msuk ke casing.cantek.hehe.syukur2.
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptyThu Mar 31, 2011 6:27 pm
mmg blh repair selagi ade trip tue,die just lay blk je,ataupun buat trip bru,klu trs tarak mmg hbs la,ok la tue..pengajaran,he3x..
xopai
xopai
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptyThu Mar 31, 2011 7:29 pm
ha tulah pengajaran.tapi pehal aku rse crank tu cm x center jeh.gap blh clutch cm bese skit(dlm 0.5-0.25)dari blah magnet.ak da ikat sme skru dah.da 2 kali aku bukak nih.
Conan Edogawa
Conan Edogawa
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptyMon Apr 04, 2011 10:06 am
takper,nak menimba pengalaman memang macam2 dugaan....biasa kalau nk bikin press ke,tread baru ke....hantar terus ke engineering...pasti boleh...kedai di kekadang kelengkapan tak cukup....
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptyMon Apr 04, 2011 11:31 am
kalau crankshaft da x balance apa effect dia?..enjin gegar ke?
aku pernah buka enjin aku..skrg shift gear x smooth macam asal..korang rasa sbab apa ya?..nak free gear pun keras..
Conan Edogawa
Conan Edogawa
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptyMon Apr 04, 2011 1:32 pm
kalau tak balance nnt gegar la.....bearing pun cepat kong...
shift gear ni aku rasa sebab kluc la...sama ada fit sangat atau dah kureng...aku pun alami benda sama....yang peliknye sejak aku beli...keluar kilang...sampai la sekarang...dah dua biji 125z aku pakai beli baru...pun sama...aku ignore je....
tp ada sape2 leh tolong jawap tak?
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptyTue Apr 05, 2011 11:23 am
fit sangat yang bro maksudkan tu bolt yang ikat spring clutch tu ker?
Conan Edogawa
Conan Edogawa
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptyTue Apr 05, 2011 6:13 pm
banyak punca...antaranya
1. rantai tegang sangat so takde clearance untuk shifting
2. kluc plat ngn besi plat fit2 takde clearence so takleh nak free turn untuk shifting walaupun dah tarik abis kabel kluc
3. minyak pelincir dah takde daya pelinciran so gigi gear tak leh nak shifting smooth.....
itu pada pendapat aku la.....cuba check satu2.....
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptyWed Apr 06, 2011 3:21 pm
orait..thanks bro.. Overhaul Motor - Page 10 713611
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptySat Apr 09, 2011 10:34 pm
sblm nie cmner?,ko ade lay crank ke?,klu time pusingkan crank x sgkt ke dinding ok je kot..
xopai
xopai
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptySun Apr 10, 2011 4:09 am
xde lay pn.ntah lah moto terpakai.hhee.da psg da.x snkt kt dinding pn.sodap jo poie skang moto.hhee.
time kasih byk² yo bro!
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptySun Apr 10, 2011 6:42 pm
aku nak tanya, mcmana nak buat clearence antara clutch plate ngan plat besi tu?
Conan Edogawa
Conan Edogawa
PostSubject: Re: Overhaul Motor   Overhaul Motor - Page 10 EmptyMon Apr 11, 2011 11:50 am
biasanya kalau tgk kat kluc set.....spring tu akan tekan semua plate jadi fit2....then bila kau tarik cable kluc,spring tu tertarik jadikan plate2 kluc tu longgar....
kalau tarik tak cukup untuk buat dia longgar,maknanyer kluc2 tu masih tertekan antara satu sama lain....
cuba adjustkan lagi cable kluc sampai dapat clearance...
tapi kalau plate2 baru biasanya tebal lagi...so maksimum tarik pun still nampak fit...
tunggu pendapat orang len pulak macamana....aku pun dah bertahun tak bukak bahagian kluc...
Overhaul Motor
Page 10 of 17Go to page : Previous  1 ... 6 ... 9, 10, 11 ... 13 ... 17  Next
» Overhaul Motor v2
» Laporan Kehilangan Motosikal..
» Segala Persoalan V15
