 Yamaha Energy Induction System (YEIS)
Go to page : Previous  1, 2, 3, 4, 5, 6, 7  Next
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Fri Feb 19, 2010 10:57 am
yamaha energy induction system
kat tajuk thread dah bagitau...
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Fri Feb 19, 2010 11:55 am
pakai mende neh mmg besh..
kdg2 rase cam bwk rxz pn ade..
hehehe..
nk tau camne rase die bace la komen2 orang yg dh pkai kt page sblum2 neh.
nnt kalo senang aku snap pics yg aku DIY kt moto aku.
total cost tk smpai rm20 pn psl 100% DIY oleh aku.
hahaha...
apepn mmg besh la ini barang..
tp jgn lupe ade gak kelemahan iaitu enjin macam cpt pns.
leh terasa bahang die.
isk2..
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Sat Feb 20, 2010 1:45 pm
mane leh dpt bende nih...huhuhu
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Sat Feb 20, 2010 1:47 pm
hehehe..
hahaha...
isk2..
murah tu ultra... buatkan untuk aku leh tak???
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Sun Feb 21, 2010 5:07 pm
huhu..
tgk la kalo aku ade kesempatan..
modal aku murah sebab:
botol bodyspray - free@pau membr aku punye yg da abes
hos getah - rm3
ring ikat hos x 2 - rm 2
kepala tubeless - rm5
tengkuk carb - free@modi terus yg asal tkde backup yg standard
cable tie - ade simpan lbey2..
hehehe...
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Sun Feb 21, 2010 5:15 pm
xkena setting carb pulak ultra???
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Sun Feb 21, 2010 5:29 pm
ala.. ko kat ner ultra.. ehehehhee... boleh buatkan untuk aku.. hoho
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Sun Feb 21, 2010 5:35 pm
emm..ultra klu moto berbobok-bobok pakai mende nie semestinye bobok krg kan?,so kalau moto yg biase2x cam aku nie lak,xke mcm bwk ex5 nnt klu pakai mende nie?..
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Sun Feb 21, 2010 5:45 pm
haha a..ah la,leh main pickup kat traficlite ngan abg2 delivery mcd ke pizza ke..hahaha
*tapi setau aku pakai mende ni kene set balik carb kan?
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Sun Feb 21, 2010 10:15 pm
nk main pickup ngan bdk2x mcd pun xlps,ha3x..so nk bikin tarak bobok,he3x..
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Sun Feb 21, 2010 11:58 pm
msuk2 je itu brg timing jd tinggi sket..
aku set timing ngan angin je..
tp plug tk check lg kaler dier..
tk sempat check da cuti CNY aritu..
hehehe...
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Fri Feb 26, 2010 3:40 pm
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Wed Mar 17, 2010 1:40 am
translate dri laman web indon tu..
Theres much talk about building a boost bottle. Id like to get some input. When building a boost bottle it seams in general most people have stated that the bottle should be built to the size of your engine. So if you have a 26cc engine the bottle should be 26cc in volumn. Some believe it should be slightly larger maybe 2cc others dont. But my real question is when your building the bottle do you take into account the length of the hose. For instance 12 inches of 1/4 ID hose is approx 9.5cc.
So do I take that into account when building the bottle and reduce the size of the bottle by 9.5cc to acomidate the hose. I purchased a juice box in the past for another scooter I had and did measure the volumn. That particular juice box was for a 49cc engine. The volumn was 49cc when I did check it. But the Juice box is part of the manifold and doesnt require a hose to connect the two. Thanks in advance for any and all input
What is a boost bottle?
The boost bottle is a small sealed chamber connected to the manifold of a 2 stroke engine by a small tube. It works with a 2 stroke by when it sucks in gas, then the piston goes up the gas wants to keep going forward but hits the piston. It would then usually go back into your carb making your fuel mixture double rich in the time fractions of a second. With a boost bottle this flow back of gas goes up into the bottle and compresses itself to do inertia, it will then shoot back down into your cylinder. This makes gas go into your cylinder quicker, allowing for a better explostion and quicker stroke.
How to make one
You want the boost bottle to be greater then the cylinder volume. IF its a bigbore rc 25.4ccs you should make the bottle to be around 27-30ccs, not to much bigger then the cylinder. The bottle should be positioned above the intake manifold so that it drains down; an incorrect position of the bottle below will cause air/fuel sepersation and form a puddle of fuel over time.
If your going to make one, drill the intake manifold and put a 1/4in barb in it pointing upwards (you got have a drill and tap if you want to do it right, not having it ghetto with jb weld or something. You can really make it out of anything. I wouldn't recommend using pvc pipe because of gas. But you can make it out of pipe fittings, or even possibly butane bottles just something that is sealed all around. You don't want to have any air leaks. And use a 1/4 in fuel line, I would use pipe clamps around the two barbs(like what airfilter use to hold it to the velocity stack.
How a boost bottle improves performance
Written originally by: SRE
Air rushes thru the carb on the intake cycle. Ignition accelerates the piston down closing the intake port. The momentum (Intertia) of the air has to go someplace, it goes back thrue the carb causing a double rich mixture. The result can cause hesitation.
Due to the velocity of the air/fuel mixture through the carb, we need to take advantage of this momentum/inertia energy. The boost bottle provides a storage tank for pre-atomized air/fuel mixture. Now when the piston moves up towards TDC (top dead center) the boost bottle assisits in filling the cylinder with preatomized air/fuel mixture for a fraction of a second until the carburetor venturi gets enough velocity to fully atomize the fuel.
The boost bottle provies a "BOOST" supercharged effect to each cycle. The advantage is that it brings up the torque and horsepower in the lower RPM range.
Supplies:
Bottle of some sort
6in of 1/4 fuel line
2 1/4 in barbs
Drill and Tap
Some brains
What I experieced
I noticed when I was warming up my ped after installing it was quicker throttle response. When I got it running how I like it I had it tuned a bit richer on bot L and H. I noticed a lot accel power. When I would rev it a little in the air and drop the back tire to take off it didn't hesitate like it did prevously. A buddy of mine dj jon, that had been racing for meyer a while back and owned his own shop for a little while years back said that that thing had crazier torque that he ever seen. He said it was like the old reed motors that he use to mess with. IDK what there called but a couple sponsers^ use to sell them.
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Fri Mar 19, 2010 12:02 pm
sape2 nampak boost bottle ni kat kdi tlg bgtau ye...hehehee
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Fri Mar 19, 2010 2:31 pm
kt kedai ssh bro.
kne g syscast tu.
bli after market nye.
tp klu bli tu ak x nk botol.nk tengkuk tu je.
keh3.
ade spe2 nk g survey syscast tu?
kilang die kt setapk x silap.
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Fri Jun 04, 2010 10:08 am
lau botol tu kte wat sendri..
saiz botol de effect x ...?
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Fri Jun 04, 2010 6:24 pm
bace dari page 1 bos.
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Fri Jun 04, 2010 6:44 pm
owh...
sorry tuan ahben..
kwn cume konpius je pas bce info kt cni ngan info mbc..
cam de info yG sush tuk d phmi lau x nmpk bnde ni live dpn mate..
jgn mare ye tuan ahben..
kwn naif lg psl mto ni...
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Sat Jun 05, 2010 7:03 pm
kaer.. senang citer.. cari je vendetta/ultra.. dia olang suda DIY kat moto.. tengok kat link ni => http://125z.darkbb.com/diskusi-bengkel-diy-f5/do-it-yourself-diy-t618.htm#51453
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Sat Jun 05, 2010 8:41 pm
owh..
baek inchik mantadkb..
patik akn usha2 tgk cane menatang ni melekat kt body tupai ni..
cam bnyk je benefit ble pkai menatang ni..
huhu..
banchiksk8
Location : desa pinggiran putra, kajang, bangi, dengkil, putrajaya,serdang
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Sat Jun 05, 2010 11:41 pm
kalo aftermarket nye bape ek???
rufaz
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Sat Jun 05, 2010 11:42 pm
Kaer wrote:
owh..
huhu..
benefit ade, cons pun ade Razz
fizi88
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Fri Jul 09, 2010 5:05 am
uish...macam bez jew pasang bnde nhe....law pasang bnde YEIS nhe...nk bukak kotak angin pn msty tadehal kn....tol x..??
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Fri Jul 09, 2010 10:16 am
fizi88: mmg besh pn.. tkde mslh kalo kotak angin bukak sekali.. mende neh support cmpuran petrol+udara utk pembakaran kt blok.. rpm nek cepat tp turun lmbt.. hehehe..
fizi88
PostSubject: Re: Yamaha Energy Induction System (YEIS)   Fri Jul 09, 2010 10:31 am
yew kew...??ok2 aq nk try DIY nnty larh...skg nhe mase x mengizin kn....ko dok mane yer ultra...??
Page 3 of 7Go to page : Previous  1, 2, 3, 4, 5, 6, 7  Next
