| Chain Lube, Grease & Minyak Hitam Pada Rantai??? | |
+41ariffm0hd kenzou fishbike azdli90 xapex zr90 Ajib wormzx eddy8075 man JGN8917 rufaz hakemrahim tupai comel kudaunismall amex sy.izzuan hanturaya111 rizzal78 ihsanxx geeks vendetta sk8jaybees matwe87 ekzosboorukipoh tupai_tempur red_alert kick_ingoal superjoemanito mazakim assasin_lunxe aus_ipoh lanunlaut chocolate neomerc jerunghitam udin_014 venom WKQ4913 Admin mantadkb HailToKing 45 posters |
HailToKing Laskar Kanan
Posts : 321 Join date : 24/03/2009 Age : 43 Location : KK-Likas-Penampang-Keningau-Labuan
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Wed Apr 08, 2009 1:58 pm | |
| Brand revoil ni biasa2 je, nak yg bgus motul la x pn shell ke motorex pn ade | |
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Wed Apr 08, 2009 4:35 pm | |
| susah la nak cari spray chain nih... kedai motor kat sini x banyak jual...
motul dgn shell tu... mmg takkan jumpa la kat Kuantan ngan Pekan ni...
kalau ada ternampak tu... kira rezeki la tu... |
Admin Laksamana Armada
Posts : 518 Join date : 22/03/2009
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Wed Apr 08, 2009 7:16 pm | |
| 1 cara aku x nak bagi orang tumpang motor aku... letak minyak hitam... confirm terpercik kat baju... terus x sanggup naik | |
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Thu Apr 09, 2009 10:35 pm | |
| - Admin wrote:
- 1 cara aku x nak bagi orang tumpang motor aku... letak minyak hitam...
terus x sanggup naik pergh... kedekut sangat la tu... hahahahaha.. awek pun tak nak tumpang la kalau macam tu... | |
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Fri Apr 10, 2009 8:32 pm | |
| susah la ngepong² awek...
kalau gi date naik keta lerr... kalau ngan member² mmg best naik motor... lebih² lagi kalau beramai |
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Sat Apr 11, 2009 6:53 pm | |
| aku ada beli Revoil Super Lube sebab aku x jumpa Revoil Heavy Duty Chain kegunaan nampak cam sama dgn WD40 jer... cuma kat tin ni ada gambar rantai basikal rasanya bukan khusus untuk rantai... bleh pakai kat rantai motor ke nih?? |
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Mon Apr 20, 2009 10:03 pm | |
| - deskcom wrote:
- aku ada beli Revoil Super Lube sebab aku x jumpa Revoil Heavy Duty Chain
kegunaan nampak cam sama dgn WD40 jer... cuma kat tin ni ada gambar rantai basikal rasanya bukan khusus untuk rantai... bleh pakai kat rantai motor ke nih?? boleh je.. janji die leh lube rantai.. WD40 bukan lubricant,tapi degreaser.. | |
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Tue Apr 21, 2009 6:17 pm | |
| lepas pakai best juga... smooth jer
cuma... bila pegang² rantai tu... nampak cam kurang minyak jer kalau yang pure cam motorex mmg kurang minyak gak ker? | |
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Tue Apr 21, 2009 7:42 pm | |
| - Admin wrote:
- lepas pakai best juga... smooth jer
cuma... bila pegang² rantai tu... nampak cam kurang minyak jer kalau yang pure cam motorex mmg kurang minyak gak ker? x dela bmyk sgt kalo motorex ni, myk dier kaler kuning, dier akn meresap dlm celah2 rntai tu, tp stakat aku pkai rantai cpat je kering | |
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Tue Apr 21, 2009 8:06 pm | |
| kalau nak yang x terbang nye myk,cari spray lube yg ade tulih anti fling off..tp b4 tu kasi cuci bersih2 rantai anda dulu.. | |
jerunghitam Laskar Kanan
Posts : 227 Join date : 22/04/2009 Age : 36
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Wed Apr 22, 2009 3:37 am | |
| aku pakai revoil chain lube je hrga pn murah je rm6 | |
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Wed Apr 22, 2009 7:13 am | |
| ini yang wat aku musykil ni... aku x jumpa pun revoil chain lube tu aku just jumpa revoil super lube.. harga RM8.50 |
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Wed Apr 22, 2009 11:36 am | |
| - deskcom wrote:
- ini yang wat aku musykil ni... aku x jumpa pun revoil chain lube tu
aku just jumpa revoil super lube.. harga RM8.50 ok la tu murah gak revoil super lube ni lebih up sikit dr revoil chain lube psl tu hrga mhl lg | |
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Wed Apr 22, 2009 6:20 pm | |
| macam tu ker? tapi yang revoil chain lube tu dekat tin ni ada gambar apa? tin revoil superlube ni x de spesifik untuk chain lube pun.. nampak cam pelincir engsel pintu jer... seram juga ni!
bro nanti tolong post gambar revoil chain lube tu |
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Thu Apr 23, 2009 1:11 am | |
| ni gmbarnye | |
udin_014 Laskar Kelas I
Posts : 109 Join date : 23/03/2009 Age : 37 Location : taman melawati - kl
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Thu Apr 23, 2009 6:47 pm | |
| - jerunghitam wrote:
- ni gmbarnye
yg revoil ni pekat tak bro? kire kalo dah spray, die ada terbang2 kat rim tak? | |
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Thu Apr 23, 2009 7:13 pm | |
| masa aku servey tadi mula² aku gi kedai Pennzoil... tanya pasal Revoil... dia kata takde... Lube Pennzoil je ade.. tapi untuk multi purpose... x mau ahh... nak cari Revoil jugak! kah kah... yang buat tak tahan tu... stok 2T Pennzoil baru sampai... berkotak kotak... rasa nak rembat jer 2 3 kotak... pastu aku gi kedai Motul RM8... aku tanye ada brand lain x...? dia tunjuk Motul punye Chainlube... dalam lima puluh lebih... besar jugak botol dia... hah.. macam kat bawah ni Sejenis semburan perekat tanpa warna yang tahan air, tahan karat dan menyaluti rantai motosikal walaupun pada kelajuan tinggi. Disyorkan khusus untuk motosikal yang amat laju, CHAIN LUBE ROAD (CHAIN LUBE) mengurangkan geseran dan meningkatkan daya tahan rantai. tapi sebab aku takde duit... aku pun beli jelah revoil | |
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Thu Apr 23, 2009 7:32 pm | |
- ni gmbarnye
yg revoil ni pekat tak bro? kire kalo dah spray, die ada terbang2 kat rim tak? aku pn pkai yg ni gak bro, x la pekat sgt, mmg ade terbang2 kat rim, pas spray tu lap2 la yg meleleh tu, tp sng hilang la bla cuci | |
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Fri Apr 24, 2009 12:59 am | |
| - Admin wrote:
- masa aku servey tadi
tapi sebab aku takde duit... aku pun beli jelah revoil motul mmg mahal sikit bro revoil ni ok la gak.murah tp kualiti x la sgt tp kalu nk pakai revoil ni x payah la sembur byk sgt.nnti kotor rim.sembur sikit pn ok janji de minyak sikit rantai tu | |
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Fri Apr 24, 2009 7:53 pm | |
| Rupanya minyak Revoil ni warna kuning bila sembur... aku ingatkan dia transparent...
kira oklah drpd pakai minyak hitam (confirm rim berbelang) |
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Sat Apr 25, 2009 7:51 pm | |
motul mmg mahal sikit bro revoil ni ok la gak.murah tp kualiti x la sgt tp kalu nk pakai revoil ni x payah la sembur byk sgt.nnti kotor rim.sembur sikit pn ok janji de minyak sikit rantai tu motul mahal sebab pade jename..hehe.. lagipun die anti fling off.. kire cam silkolene gak ler.. aku pakai silkolene semi sintetik rm28 400ml kot klau x silap.. | |
venom Laskar Kanan
Posts : 343 Join date : 03/04/2009 Age : 49 Location : Semenyih - KL - Semenyih
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Wed May 06, 2009 6:56 pm | |
| - venom wrote:
- aku confius betul pasal benda ni....
skrg aku nak tahu satu je.... brand minyak mana yg berkesan (tahan segalanya) tanpa mengotorkan rim..... tu jer brand yg mahal2 kot..hehe motul ke silkolene ke ape2 je janji ade tulih anti fling off,tapi yg penting rantai kene cuci kasi bersih dulu,then baru sembur menatang ni,klau x same je rim ade kotor2.. | |
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? Thu May 07, 2009 9:11 am | |
| pakai revoil rim kotor gak... tapi better than minyak hitam coz senang nak cuci... |
| Subject: Re: Chain Lube, Grease & Minyak Hitam Pada Rantai??? | |
