| Apa Itu Reed Valve? | |
+53-sLip- comebackid Shark pfa nurkaye_akmal samporna ccn Kazamasaga-san KapcaiKuDie baim7935 yi_tupaijek01 chaosworld nizam1407 xopai wgs4@9 rusydan devilmeasha pasquale paan1171 unknownh Ezad wormzx ipin_8403 ss110 unggu mangketey absolute_ahben alpazz faiznbf6719 redline koie06 knightmotorxz vendetta h@ziQ xapex banchiksk8 supcendawan geeks man JGN8917 mazakim rufaz monyet Ultra-Z tupai comel fizerpool soNa assasin_lunxe neomerc chocolate napsterslay encik hariz Thund3r WKQ4913 hafidz superjoemanito arjuna86 57 posters |
h@ziQ Laskar Kelas I
Posts : 113 Join date : 14/04/2010 Location : KLANG
| Subject: Re: Apa Itu Reed Valve? Thu Jul 08, 2010 5:12 pm | |
| setting sng dapat x pas tukar benda alah ni?? ak tkt mcm Z valve potong setting bkn main payah nak dpt | |
| Subject: Re: Apa Itu Reed Valve? Thu Jul 08, 2010 5:14 pm | |
| perhh..askar,ank ke tue?,mmg lyn la nie bkn modifikasi yg x bertauliah bro,psg je dulu n tgk ape hsl,he3x.. | |
| Subject: Re: Apa Itu Reed Valve? Thu Jul 08, 2010 5:18 pm | |
| anak ak la,sorang hero tu ingat kotak dindang dia pi buka,menjerit aku tgk dah di buat mainan, kang ak pasang tgk pe hasilnya sbb blok head suci lg..jgn setting x dapat2 ak kasi belah itu boy eksen | |
knightmotorxz Laskar Muda
Posts : 7 Join date : 28/06/2010 Age : 34 Location : Semenyih
| Subject: Re: Apa Itu Reed Valve? Sat Jul 10, 2010 10:49 pm | |
| guys.... aku x paham lah cane reed valve ni berfungsi??? ade sesape boleh terangan???... | |
xapex Pegawai Waran II
Posts : 1040 Join date : 02/12/2009 Age : 28
| Subject: Re: Apa Itu Reed Valve? Mon Jul 12, 2010 10:44 am | |
| bro2 sume...ape beza reedvalve 125 ngan rxz..??? | |
| Subject: Re: Apa Itu Reed Valve? Mon Jul 12, 2010 11:13 am | |
boyesen ni dual stage.. means 2 kali bukak.. kalau reedvalve yg biase2 mura2,die satu kali bukak je..either low /mid rpm (untuk pickup so top lemau) or hujung bukak(pickup xde)..
reed valve boyesen ni dua kali bukak..klau motor aku,leh rase time rpm 5.5k ke 6.5 k tu cepat n time 8.5 k rpm keatas.. klau dapat pakai chamber lagi leh merase kalo leh run sampai 10k rpm (pinjam penerangan wan wkq) | |
| Subject: Re: Apa Itu Reed Valve? Mon Jul 12, 2010 11:20 am | |
| pinjam dr bro WKQ4913 reedvalve berfungsi utk regulate/mengawal air flow masuk ke cylinder dan lokasinya terletak selepas carburetor,sume otor 2stroke pakai reed valve.. tapi moto oldskul ade yg xpakai reedvalve,die pakai rotary valve.. quote from MBC : Reedvalve ori ialah reedvalve yg lebih tahan dari yg carbon atau fiberglass.tapi utk performance,org akan cari yg carbon sebab respon lebih cepat respon/buka.pasal brand cari lah yg jenama yg terbukti spt boyesen,carbon tech atau uma racing.racing bee ak x pernah dgr org pki so far. Boyesen ade 2 jenis,satu fiberglass,satu carbon fiber,dua2 double reed di dlm satu reedblock maksudnya satu nipis,satu tebal..carbon tech pulak ade jual carbon fiber.uma pun ader carbon nyerr. paling mahal vforce 3.mencecah 400-500 satu set reedcage/tapak ngan reedvalve set.tapi power memang puas ati lah. simptom reedvalve rosak : moto semput,kuat mkn minyak,lost kompresen,last skali tanak idop le... reedvalve ni kalo ade pasir sketol dah tak function dah... kne tilik halus2 area bibir die tuh... kikis kotoran kat reedvalve pkai pisau/ketas pasir halus tapi kne extra cautious la... calar sket susah.. keanjalan dan tebal nipis sesuatu reedvalve ada fungsi yg tersendiri.lebih anjal respon pada high rev dan sebaliknye.setting motor nak bawak mcm mane dan cari reedvalve yg sesuai.jgn takat nak bawak layan tapi pakai reedvalve yg keras.hasilnye akan sgt tak memuaskan... | |
koie06 Laskar Kelas I
| Subject: Re: Apa Itu Reed Valve? Tue Aug 03, 2010 10:01 am | |
| aku da masuk reed valve boyesen dual stage nie...tp npe xde beza pun...pickup n top sme je...tgk plug perang da...pilot ade itam ckit...
mainjet n pilot aku x usik lg lepas masuk petal boyesen nie...m=130 , p=17.5...
carb std lg...xde pun rse 2kali bukak tu...pakai exzos std... | |
| Subject: Re: Apa Itu Reed Valve? Tue Aug 03, 2010 10:32 am | |
| - koie06 wrote:
- aku da masuk reed valve boyesen dual stage nie...tp npe xde beza pun...pickup n top sme je...tgk plug perang da...pilot ade itam ckit...
carb std lg...xde pun rse 2kali bukak tu...pakai exzos std... top mmg sama,bende ni bukan tmbh topspeed, tmbh respons je.. 1st bukak rase time middle rpm,yg kedua time hi rpm.. klau blok standed,ekzos standed yg kedua tu mmg susah nk dpt sebb utk 2nd stage rpm 8k keatas baru rase.. klau blok dh porting utk kasi rpm naik lg tinggi barurase sekitar 8k ke 9.5k keatas. nak btol2 rase portong blok pastu pakai ekzos yg lawas smpi bleh tarik 11-13krpm.. jgn exect perubahanyg drastik takat tukar pakai boyesen ni.. | |
| Subject: Re: Apa Itu Reed Valve? Tue Aug 03, 2010 11:42 am | |
| ooo...tp block da touchup...xtau la kot2 meter lame nie rosak...rpm bley tarik max 9k je...da try ngan RXZ std piston 0.75 mmg xbley makan... adekah sbb pakai carb std yg wat rpm tu mati kat RPM 9k?...kalo masuk carb Z bley increase RPM x bro?... reed cage kne touchup gak ke kalo nak lg best?...sbb dgr org ckp lg besa reed cage lg best...btol ke?... sory byk tanye...sbb br 1st time pakai boyesen... kat kotak boyesen nie siap ade tulis "The best power increse you can get on a dollar-for-dollar basis...period."...tu yg termakan racun tu... | |
| Subject: Re: Apa Itu Reed Valve? Tue Aug 03, 2010 12:20 pm | |
| - koie06 wrote:
- ooo...tp block da touchup...xtau la kot2 meter lame nie rosak...rpm bley tarik max 9k je...da try ngan RXZ std piston 0.75 mmg xbley makan...
kat kotak boyesen nie siap ade tulis "The best power increse you can get on a dollar-for-dollar basis...period."...tu yg termakan racun tu... aik takkan tukar reedvalve jer dah boleh naik 20-30km kan... ok ler tue rpm 9, nak rev high rpm spi patah jarum pki ejos chamber ler... rev la spi jarum rpm patah lapan no hal.... nak lagi respon pki carb besar punya ats 30mm baru la ko rasa laju ke tak...
| Subject: Re: Apa Itu Reed Valve? Tue Aug 03, 2010 12:53 pm | |
kat kotak boyesen nie siap ade tulis "The best power increse you can get on a dollar-for-dollar basis...period."...tu yg termakan racun tu... aik takkan tukar reddvalve jer dah boleh naik 20-30km kan... ok ler tue rpm 9, nak rev high rpm spi patah jarum pki ejos chamber ler... rev la spi jarum rpm patah lapan no hal.... nak lagi respon pki carb besar punya ats 30mm baru la ko rasa laju ke tak... haha...xde la naik smp 20-30kmj...naik 5-10 pun ok la...chamber mmg dlm list...carb Powerjet TM 30mm da ade(dapat time beli TZR dulu2)...tp bg adik aku pakai kat LC die sementara die carik carb TZM... so,tuka reedvalve nie xde pape kelebihan la ek selain cepatkan respond engine(pickup ciput je)?... sape ade reed cage 125z@RXZ yg xpakai bley jual kat aku sbb nak mod ckit...murah2 da la ek... | |
| Subject: Re: Apa Itu Reed Valve? Tue Aug 03, 2010 1:41 pm | |
| a'ah gitu lew citer nyer, pade ak psg reedvalve dual stage nih respon jer ader rs skit bese, takde meningkatkan hp @ kelajuan motot pun.... | |
| Subject: Re: Apa Itu Reed Valve? Tue Aug 03, 2010 1:55 pm | |
| skali nie je la aku beli boyesen nie...cm ne lak ngan VForce3?...ade yg da try?... | |
redline Laskar Kanan
| Subject: Re: Apa Itu Reed Valve? Mon Aug 30, 2010 1:59 pm | |
| boyesen ni dulu mmg susah nak cari kat tempat aku, tp skang x tau la... da lama x survey... harga mahal ke? | |
faiznbf6719 Laskar Kelas I
Posts : 188 Join date : 15/06/2010 Location : ipoh--->>>seremban-->>>ipoh-->>PD
| Subject: Re: Apa Itu Reed Valve? Mon Aug 30, 2010 2:08 pm | |
| bpe reger boyesen ni... aku nk gak try camne agak nye die g ek... | |
alpazz Laskar Kelas I
Posts : 143 Join date : 06/04/2010 Location : ipoh
| Subject: Re: Apa Itu Reed Valve? Mon Aug 30, 2010 3:41 pm | |
| - faiznbf6719 wrote:
- bpe reger boyesen ni...
aku nk gak try camne agak nye die g ek... oit.. roger ahben la.. bengkel die stok baru smpai.. rm150 rsenye die bgtau dlu.. | |
| Subject: Re: Apa Itu Reed Valve? Mon Aug 30, 2010 11:50 pm | |
| tula.org dekt2 x nk dtg bengkel rakie2 brg.ki3 | |
| Subject: Re: Apa Itu Reed Valve? Wed Sep 01, 2010 12:48 pm | |
| gilos ahben... ptg ni aku smpai... hahaha | |
mangketey Laskar Kelas I
Posts : 119 Join date : 09/09/2010 Age : 33 Location : Kerteh,terengganu
| Subject: Re: Apa Itu Reed Valve? Thu Sep 16, 2010 3:15 am | |
| mcm best jer topik nih..klu pkai reed valve boyesen nih cme reed petal jer lar yg dtkr kn?reed stop ttp pkai kn? | |
| Subject: Re: Apa Itu Reed Valve? Thu Sep 16, 2010 5:58 pm | |
| - mangketey wrote:
- mcm best jer topik nih..klu pkai reed valve boyesen nih cme reed petal jer lar yg dtkr kn?reed stop ttp pkai kn?
petal ditukar ngan 2 stage punye,stopper tue x pyh pakai.. | |
| Subject: Re: Apa Itu Reed Valve? Thu Sep 16, 2010 6:04 pm | |
| stopper reedvalve tu kalau pakai lg selamat... tp kene adjust skit lar...bg bengkok lbh lg...salah adjust, tak jd gak.. tak pakai pn aku tgk mtr masing2 ok jer... | |
| Subject: Re: Apa Itu Reed Valve? Thu Sep 16, 2010 7:55 pm | |
| owh..bru aku phm..aku nih bru jer berjinak nk main mtor 2t..sblm nih aku main 4t jer.. | |
ss110 unggu Laskar Muda
Posts : 33 Join date : 23/11/2010 Age : 33 Location : PJ
| Subject: Re: Apa Itu Reed Valve? Thu Dec 16, 2010 2:22 am | |
| Blok porting ckit+ejos buang 2 sarang +Reed Boyesen+carb std kt leher lay ckit.... ad la gax penigktan.. pikup cam puaka top sme jew rsepi sye yg seposen... | |
ipin_8403 Laskar Kelas I
Posts : 148 Join date : 24/05/2009 Age : 41 Location : jb,kota tinggi
| Subject: Re: Apa Itu Reed Valve? Wed Dec 22, 2010 12:11 am | |
| aku jual reedvalve boysen.cuma rm100 barang baru.setakat ni aku pakai ok aja.rpm sedap.top pun sedap.cuma berani atau x berani aja aku bawa motor sekrang ni.dpd korang beli sampai rm150 tu baik beli kat aku.lagi rm40 korang jimat. rm10 tuk kos pengantaran aja. | |
| Subject: Re: Apa Itu Reed Valve? | |
