 Spec. 125Z Standard
Go to page : Previous  1, 2, 3 ... 7, 8, 9, 10, 11  Next
PostSubject: Re: Spec. 125Z Standard   Wed Sep 01, 2010 10:22 am
yi_tupaijek01 wrote:
nk tumpang tye kwn2 semua,mane leh dptkn stripe original motor selain drpd HLY n brape hargeyer?
cari kt kedai dealer yamaha lar...
kedai2 yamaha yg wujud sblm HLY lg..setiap tmpt mst ada...tmpt aku yg kt muar tu pn ada 2 kedai yamaha...
tp jarang kedai ambik stiker ori sbb die tahu takde org nk beli nnt..
kalau design lama, pakai stiker lokel pn dh cun...
design2 baru ni je kalau stiker lokel, mmg nmpk sgt berbeza dgn stiker ori...
PostSubject: Re: Spec. 125Z Standard   Wed Sep 01, 2010 2:03 pm
aritu aku pi kat qs kajang, dealer yamaha..antara harga spare part yg diorang quote
mangkuk clutch satu set(clutch basket + secondry gear siap rivet) = rm261.73
master pump brek depan(bodi pump + level + silinder pump kat dlm) = rm141.10
segala ball bearing,kon (kat handle ngan t-fork) = rm28.40 +rm 37.80 + rm24.15 + rm24.15 + rm35.50
kalo dia tipo aku maknanya aku pun tertipu korang jgk le..
PostSubject: Re: Spec. 125Z Standard   Wed Sep 01, 2010 3:45 pm
o yeke,hargenye mcne?yg ori
PostSubject: Re: Spec. 125Z Standard   Thu Sep 02, 2010 10:51 am
mangkuk clutch mmg dtg 1 set siap gear...mane ada jual asing...
sama la dgn coil enjin...mmg dtg 1 set dgn tapak coil tu..
masterpump+ leveL atau leveR? kalau lever brake tu jer dh rm70, masterpump shj takkan rm70 jer? ...caliper dpn = rm340
**pasal ko tak reply jer kt thread HLY genuine part tu?
yg aku jmpe dulu, stiker lama hrga rm50++ 1set...tu pn aku rasa nasib jer kalau ada lg skrg ni...
kalau stiker baru, hrga mcm HLY jer...yg jual lg mhl dr HLY pn ada...
PostSubject: Re: Spec. 125Z Standard   Thu Sep 02, 2010 11:29 am
erm kne berusha keras la mcm ni gk...
tupaiku
PostSubject: Re: Spec. 125Z Standard   Mon Sep 27, 2010 7:38 am
cbe try bli kat mudah ngan tokei http://www.mudah.my/li?ca=11_s&id=1375
PostSubject: Re: Spec. 125Z Standard   Mon Sep 27, 2010 9:14 am
WKQ4913 wrote:
23sh0pah0lic wrote:
aku pki 15/39..
berat seyh..
aku igt nk try pki 415 15/37..
amacam ok x?
brand yss agak2 bper ek hrga kdi sknk?
YSS brrand monoshock bro..SSS baru betul..<RM100 untuk satu set yg aluminium standard cubprix tu..
kalo 15/39 pun dah berat jangan la turunkan,kang lagi berat jadinye..
RM85 kalau tak silap, tapi kalau pandai carik, boleh dapat lagi murah dari tuh.
PostSubject: Re: Spec. 125Z Standard   Mon Sep 27, 2010 9:18 am
mzul787 wrote:
wan : owh so even klu tuka gear 6rxz pown RPM stuck kat stu gak. juz shiftng dr gear 5 k6 tu RPM x drop byk la ae. camtu?
skrnk aku gne spoket 15-37. nk idop kan gear aku yg mati tu kne tuka spoket bape agak2? hehe
n satu ag. pe function polish blok? leh naek kan top or power kn moto ke?
bese aku dga dlm forum nie org portng blok je leh naek kan top.
polish pown dkre moto tu tlh dmodified ke?
macam wan cakap, cube ko turun kan dulu saiz spoket ko..
azizi5587
azizi5587
PostSubject: Re: Spec. 125Z Standard   Wed Oct 06, 2010 10:26 pm
la ni kat pasaran meter model baru brp rm ha????
meter aku ori first model....
budackgempak
PostSubject: Re: Spec. 125Z Standard   Sun Oct 24, 2010 10:39 pm
ape jenama clucth yg bagos bagi 125zr...
PostSubject: Re: Spec. 125Z Standard   Mon Oct 25, 2010 4:10 pm
pkai clucth stended je bro.. ori nye... ssdap rase...
G.i.joule
G.i.joule
PostSubject: Re: Spec. 125Z Standard   Wed Oct 27, 2010 4:37 pm
tp law pkai clucth stnded lembek ajew knapew yer..??
nk gnti baru kew clucth platenye atau n tko spring clucth racing...? scratch scratch
PostSubject: Re: Spec. 125Z Standard   Sat Nov 06, 2010 11:12 pm
salam
sye nk tnye sumthing
panjang conrod
ngn tinggi deck
brpe ek?
hazwan achie
hazwan achie
PostSubject: Ape bezA 125z ngan 125zr???   Sun Nov 07, 2010 11:51 am
share2 lah. .budak baru nie..
PostSubject: Re: Spec. 125Z Standard   Tue Nov 30, 2010 5:46 pm
nak tnya, pasal pam 2t..time idle(tak pulas throttle) marking 2t 125z standed kilang kat angka kosong ker?..sape motor standed kat cni yg tak pnah kacau pam 2t die?
PostSubject: Re: Spec. 125Z Standard   Thu Mar 10, 2011 9:37 am
geeks wrote:
WKQ4913 wrote:
23sh0pah0lic wrote:
aku pki 15/39..
berat seyh..
amacam ok x?
kat sentul boleh aritu aku dpt rm70...
fx110
fx110
PostSubject: Re: Spec. 125Z Standard   Wed Mar 23, 2011 2:06 pm
salam dan selamat sejahtera..ambe duk cari2 xde nmpk spec 125z kat forum 125z nih..soo kut2 lah mate ambe rabun,mod jgn segan2 nak delete yer
spec 125z stended gaban
jenis : 2 lejang sejukan udara
bil silinder : single maa
lubang x lejang : 53.8mm x 54.7mm
nisbah mampatan : 6.5:1
max hp : 17.5ps/8000rpm
max torque : 1.65 kgf-m/7500rpm
karburetor : vm 22 ss
pilot jet : 15
main jet : 100
plug : bp8es,b8es,b8ecs (NGK)
sistem penyalaan : digital advanced
magneto tube C.D.I
primary reduction ratio : 3.227 (71/22)
secondery reduction ratio : 3.071
nisbah gear 1 : 2.833
nisbah gear 2 : 1.813
nisbah gear 3 : 1.368
nisbah gear 4 : 1.143
nisbah gear 5 : 1.000
nisbah gear 6 : 0.875 <-- gigi 21/24
final reduction ratio(ratio spoket) : 43/15 -->2.8667
berat kering : 101kg
bateri : YB3L-B
kapasiti petrol : 5.5 liter
lampu dpn : 12V,25W/25W
tayor blkg stended kilang : 80/90 17inch
tayor depan stended kilang : 70/90 17inch
kod bearing;
crankshaft : 6205(kiri,knn)
primary gear :6303(knn),6205(kiri)
secondry gear:6304(kiri),6205(knn)
balancer :6004,6202(lupa mana satu kiri ngan kanan)
hub depan : 6300
hub blkg : 6301
hub spoket: 6004
kod oilseal;(quote dr mbc oleh bro vandetta )
oil seal plak...
shaft spoket pakai 20-38-5
shaft lever gear 12-21-4
balancer 25-42-6
Tambah info sikit:-
secondery reduction ratio : 3.071(43/14)final reduction ratio juga dikenali sebagai secondery reduction ratio
nisbah gear 1 : 2.833(34/12)
nisbah gear 2 : 1.813(29/16)
nisbah gear 3 : 1.368(26/19)
nisbah gear 4 : 1.143(24/21)
nisbah gear 5 : 1.000(23/23)
final reduction ratio(ratio spoket) : 43/15 -->2.8667---->rasa dah wrong info
sekian Smile
PostSubject: Re: Spec. 125Z Standard   Wed Mar 23, 2011 10:27 pm
kt singapore pakai spoket kecik 14 untuk standard,kat malaysia yg sejahtera nie spoket kecik die 15 untuk standard,mungkin faktor jalan-raya menyebabkan yamaha buat mcm nie Laughing
fx110
fx110
PostSubject: Re: Spec. 125Z Standard   Thu Mar 24, 2011 10:38 am
check owner manual anda, mahupun parts catalog,
tambah lagi brochure tupai dr SINI pun menunjukkan secondery reduction ratio-nya : 3.071 Laughing
bukan setakat singapore je pakai 14T. Smile
dengan secondary reduction ratio-nya : 3.071
bro boleh cuba pakai 15T dan dptkan size sprocket belakangnya Smile
PostSubject: Re: Spec. 125Z Standard   Thu Mar 24, 2011 10:59 pm
aku paham mende yg bro trgkan tue,tapi malaysia mmg pakai spoket dpn 15 sbgi standard kilang..
manual malaysia..
fx110
fx110
PostSubject: Re: Spec. 125Z Standard   Fri Mar 25, 2011 10:04 am
TQ bro Very Happy
dah ada update Very Happy
maklumat di bawah ini dipetik dari Parts Catalog Y125'98(5BU1)Malaysia
(saya punya dah OUTDATED )
Applicable Serial No:-
Frame Serial:KE1-000001 ke atas
Engine Serial:E101E-000001 ke atas
nova
PostSubject: Re: Spec. 125Z Standard   Tue Apr 26, 2011 8:53 pm
moto aku taun 2003 ori 14 dpn..
Mafiaflix
Mafiaflix
PostSubject: Re: Spec. 125Z Standard   Tue May 10, 2011 5:48 pm
absolute_ahben wrote:
salam
panjang conrod
ngn tinggi deck
brpe ek?
panjang conrod 110 mm bro.
tinggi deck standard 1.5 mm.
https://www.facebook.com/dzakiwardana
firdausazman
firdausazman
PostSubject: Re: Spec. 125Z Standard   Wed May 18, 2011 8:32 pm
aq ader meter firsty model. .hha
http://fiyana9294.blogspot.com
PostSubject: Re: Spec. 125Z Standard   Wed May 18, 2011 8:48 pm
muto saya akhir tahun 2002,spoket stended gaban 15-43....
Spec. 125Z Standard
Page 8 of 11Go to page : Previous  1, 2, 3 ... 7, 8, 9, 10, 11  Next
