 Segala Persoalan V18
PostSubject: Re: Segala Persoalan V18   Thu Oct 27, 2011 4:03 pm
nk start x padu cm dlu.
compression kurang.
bunyi serabut.
PostSubject: Re: Segala Persoalan V18   Thu Oct 27, 2011 4:11 pm
blook calar manja sikit2 still bleh start...tp mcm ahben bgtau tu la...comperssion dh tak padu....
kalu block calar teruk ada parit dalam sgt moto terus tak le start..kena rebore & tukar piston la jwb nya
PostSubject: Re: Segala Persoalan V18   Thu Oct 27, 2011 5:48 pm
kalau masa tengah bawak moto, terasa loss compression dlm rpm 4.5-6 k, sebab ape yer? terpaksa pulak bawak rpm tggi sikit ataupun bwk selow terus...blok ada calar sedikit lah..
PostSubject: Re: Segala Persoalan V18   Thu Oct 27, 2011 5:50 pm
hu3.
tak dapat nak nolong.
x paham soalan cik tikuspink.
bukan loss compression kot. bobok nieh.
PostSubject: Re: Segala Persoalan V18   Thu Oct 27, 2011 5:54 pm
absolute_ahben wrote:
hu3.
aku pun xtau nk explain cmne..kalau loss compression dia punyer feeling bila tgh pulas trottle minyak tetibe rasa tersentak kuat kehadapan..lg 1 kt karburetor ada minyak menitik keluar
PostSubject: Re: Segala Persoalan V18   Fri Oct 28, 2011 12:04 am
kne bukak tgk la cik tikuspink.
x brani nk ckp.
PostSubject: Re: Segala Persoalan V18   Fri Oct 28, 2011 3:42 am
incik tikus rasanya cam kes bobok di rpm tgh jer...muto laju mmg camtu Very Happy
try set angin semula...
PostSubject: Re: Segala Persoalan V18   Fri Oct 28, 2011 3:45 am
gasket karb bocor kot...
PostSubject: Re: Segala Persoalan V18   Fri Oct 28, 2011 7:01 pm
Shark pfa wrote:
tlong2....mase dk sdap merembat tadi....tiba rasa mcm tyar blakang lock pas tu motor mati...stat xnk idup kena...kene bg sejuk sikit bru leh idup....knp ehh???...ni ke org ckp jem tuu???...kene setting carbretor ke ni??
jem panas blok calar silent padan muka tongue
ni ke perasaan orang yg berkali2 motonya jem. Kui2
PostSubject: Re: Segala Persoalan V18   Fri Oct 28, 2011 9:30 pm
xpe kawan2..td da bukak..tukar ring, polish sikit dgn servis karburetor..skrg da ok.. terima kasih sume yg beri pendapat Smile
Paktam
PostSubject: Re: Segala Persoalan V18   Sat Oct 29, 2011 4:47 pm
aku nk tanya ni... kalo port exzos aku tu cm bocor(ada minyak kuar2 skit), ada effect apa2 kt enjin x? aku tanya pomen tu dia kata kene tuka gasket... tpi aku malas lu nk bukak block enjin tuh... nk tanya ada effect jangka masa panjang x
PostSubject: Re: Segala Persoalan V18   Sat Oct 29, 2011 5:34 pm
kalo stkt skit2 tkpe je aku rase, tpi kalo nk tukar gasket pun tk bukak blok pon pak tam, just cabut ezos tu, pasang gasket, ikat balik tengkuk ejos tu
PostSubject: Re: Segala Persoalan V18   Sun Oct 30, 2011 3:33 pm
saje je nk tnyer ni..korg msti taw kan..ak je yg xreti2..hahaha
k camni, clutch muto asal pjg kn..skunk makin pendek..kdg2 masuk gear pon cam nk mati muto...
so persoalan nye..clutch tu abis ker? haus ker? rosak ker? sory la kalu soalan nubis...pe yg prlu buat..kalu tukar, kos braper ek? jename pe yg trbaik?
xmo racing2, standart pon dah ok..nti lenguh jari nk tarik clutch..hehehe, mekasih sumer~~
PostSubject: Re: Segala Persoalan V18   Sun Oct 30, 2011 4:02 pm
ori moto sampai 3-4 tahun @ 30K sumthing aku pki..mungkin sbb aku xganas sgt kot...
beli yg ori ler..resing2 ni mmg sedap tp tahan sekejap je
PostSubject: Re: Segala Persoalan V18   Mon Oct 31, 2011 7:17 am
mungkin mcm choco bgtau tu clutch dah abis...
tapi mungkin gak sbb nut kt cable clutch tu tergerak sendiri...
nut tu dkt PERTEMUAN antara 2 cable...CABLE THROTLE MINYAK+CABLE CLUTCH....tmptnya kt atas mangkuk gear,dkt2 dgn karburator....nk tunjuk gambar tak de plak...
pernah jd kt aku sbb clutch TIBA2 JE jd pendek & moto senang mati...aku set balik kt situ dh ok....
tak tau la plak kalu clutch ko mmg dah abis mcm choco bgtau tu...
aku rasa kalu kes TIBA2 JE ni mungkin mcm prob aku tu..
aku rasa clutch ni tak kn TIBA2 JE jd pendek & moto cepat mati..amik masa gak nk haus...
PostSubject: Re: Segala Persoalan V18   Mon Oct 31, 2011 1:01 pm
eh jawapan terkeluar landasan rupanya...
pernah tekene..baru kuar rumah,tgh jln kacip clutch tetiba jadi makin pendek,change gear dah mcm x pki clutch..berenti tgh jln check nut ikat kabel kat cover clutch longgar..yg harunya aku lupa nak bwk bekas tools bwh seat..
PostSubject: Re: Segala Persoalan V18   Mon Oct 31, 2011 1:02 pm
ok thanx choco n manJGN,
nut tu nk buat camner? pusing blah maner kang makin pendek..hahaha....kalu dah abis tu, pe yg abis? clutch plate ker...hm, bese yg ori rm brape ek? alahai kne tgu gaji la plak~
PostSubject: Re: Segala Persoalan V18   Mon Oct 31, 2011 1:03 pm
pastu ator kedai? hehehe...
PostSubject: Re: Segala Persoalan V18   Mon Oct 31, 2011 2:56 pm
sama dgn aku...tgh syok berembat atas hiway smpi kt exit nk masuk jln biasa tbe2 kacip clutch jd kosong..menggelabah aku nk change gear masa tu...time tu nk pulas nut tu mmg seksa la sbb just pakai jari je...sbb nut tu tersorok sikit..
PostSubject: Re: Segala Persoalan V18   Mon Oct 31, 2011 9:44 pm
aku pun sama. Penah jadi, tp bukan sema berembat la tp semasa jalan kura2. Pulas dgn tgn jgk. Pengajarannya pastikan tools ada bwh seat tu
PostSubject: Re: Segala Persoalan V18   Mon Oct 31, 2011 10:38 pm
aku sebenarnya dah cuak nak bwk tools sejak disampuk peronda keh3..
worm,aku buat sama mcm man,bersusah payah selit jari celah kaberset
aleen90
PostSubject: Re: Segala Persoalan V18   Wed Nov 02, 2011 11:45 am
http://www.facebook.com/AlifAzranShahIsmail
NCH_KU
PostSubject: Re: Segala Persoalan V18   Wed Nov 02, 2011 8:13 pm
as salam suma..moto aku makin lama makin parak minyak dia telan..moto standard kilang..
tak usik pe pon..last servis masa tu meter 19000++..sekarang 29000++..full tank dapat 125km++ camtu lah..agak2 sebab dh lama tak servis ke jd camni?.. bounce
PostSubject: Re: Segala Persoalan V18   Wed Nov 02, 2011 8:31 pm
okeyh la tu dlm 125km je bro, sbb slalu kalo standard kilang bleh dapat dlm 140 gitu her, cume tgk kt style bawak motor tu, kalo duk merembat je memang cepat skit, kalo maintain standard2 ni tahan la lame skit, mcm motor aku bleh dpt dlm 120km je
NCH_KU
PostSubject: Re: Segala Persoalan V18   Wed Nov 02, 2011 8:52 pm
ye ke standard bro?..aku bawak santai2 je..kalau nk servis nk kena tukar pe ye?..
