| Jenis Blok N Head Yg Digunakan | |
+27samporna ccn devilmeasha Man4822 -sLip- Kasut Terbang najmimecha ayl alemm gilgamesh88 ajizaimi vista1010 rizal haizamlee softoperator kUnAk superjoemanito paan1171 chocolate kelvin45 mantadkb fareez91 kyrasbc geeks vendetta hanturaya111 yi_tupaijek01 mazakim absolute_ahben 31 posters |
| Subject: Jenis Blok N Head Yg Digunakan Mon Aug 30, 2010 4:40 am | |
| Subject: Re: Jenis Blok N Head Yg Digunakan Mon Aug 30, 2010 5:02 am | |
| ki3.yg membezakn blok y-1 y-2 i-1 ngn i-2 huruf ngn no jela.ki3.klu ko prnh tgk blok y.msty ko prasan ape beza ngn blok i.ketebalan slip die je.material?ak rase sme je.wan wkq pown prnh ckp.same je. ki3.npe la sume org nk carik blok y-1 ngn y-2.ade ape kt blok tuh sampai menjd kegilaan ramai.ki3.ade lebey toyol ke blok tu?jwpan die same je bro blok i ngn y. | |
| Subject: Re: Jenis Blok N Head Yg Digunakan Mon Aug 30, 2010 8:36 am | |
| jenis y made in japan, jenis I made in bangla shah alam kot... 1st model japan mari...tue yg ngada2x market | |
| Subject: Re: Jenis Blok N Head Yg Digunakan Mon Aug 30, 2010 8:53 am | |
| Subject: Re: Jenis Blok N Head Yg Digunakan Mon Aug 30, 2010 10:29 am | |
| yeke material Y n I same?tp aku ra mcm len je hardness dia...lg2 slip tu...xpon yg Y ni material dia ada advance ckt dr segi process,atau heat treatment? | |
hanturaya111 Kadet
Posts : 1572 Join date : 23/10/2009 Age : 37 Location : Bandar Kinrara - Puchong - Johor Bahru
| Subject: Re: Jenis Blok N Head Yg Digunakan Mon Aug 30, 2010 12:48 pm | |
| Selama aku guna ni pun x de beza ape2 pun... Nak kate I-1 ni cepat lemau x jugak... stendard katak pun dapat gak sesekali 180....
Skrang pakai Y-1.... size 1.50... x de masalah gak... | |
| Subject: Re: Jenis Blok N Head Yg Digunakan Mon Aug 30, 2010 1:09 pm | |
| memg la pkai xda beza pape..tp kalo uh penah jem,akn npk efek dia...kalo yg i,mudah calar compare ngn Y..bkn xda calar lgsg,tp mudah ckt r....tu je pendapat aku...pendapat org len xtau r...hehehhe...nk tau beza,jom bt hardness test... | |
| Subject: Re: Jenis Blok N Head Yg Digunakan Mon Aug 30, 2010 3:32 pm | |
| rasanya material slip/sleeve blok tu mgkn sama jer...kalau beza pn skit jerla... tp material bhgn2 block yg lain tu ada beza.... kalau y-1, y-2 ada keras skit...i-1, i-2 tu biasa2 jer lg... ni cerita dr pomen yg biasa korek blok la...kalau blok stok Y ni lmbt skit nk korek2, kalau blok stok i tu kejap je dh setel....
bab mudah calar ker tak rasanya sama jer... pakai blok aprilia yg rendam sebulan dlm air pn tak karat lgsg tu tp kalau merembat dgn setting carb tak cun, 2t tak baik, mst calar punyerr....
head pn ada yg HY-1, HY-2..ni yg aku tau lar... dua2 ni pd aku sama jer...kalau standard takde usik2, ok jer... kalau dh potong, merembat jauh2, mst akan ada crack skit kt thread plug tu.... tp crack yg tak memudaratkn pun...
**jgn ingt brg lama tu mmg kualiti tiptop... blok y-1,y-2 tu dh stok 10tahun lps...ntah brape ribu kali kene panas-sejuk.. mst dh ada berubah skit material die... lain la kalau dpt blok y-1/y-2 yg baru...tu mmg betul2 terbaik lar... | |
| Subject: Re: Jenis Blok N Head Yg Digunakan Mon Aug 30, 2010 4:27 pm | |
| - vendetta wrote:
- rasanya material slip/sleeve blok tu mgkn sama jer...kalau beza pn skit jerla...
**jgn ingt brg lama tu mmg kualiti tiptop... blok y-1,y-2 tu dh stok 10tahun lps...ntah brape ribu kali kene panas-sejuk.. mst dh ada berubah skit material die... lain la kalau dpt blok y-1/y-2 yg baru...tu mmg betul2 terbaik lar... ven.. ade effect ke blok yng lambat nak korek nih?.. bek punyer la?.. material macam keras je. | |
| Subject: Re: Jenis Blok N Head Yg Digunakan Mon Aug 30, 2010 6:08 pm | |
| Subject: Re: Jenis Blok N Head Yg Digunakan Mon Aug 30, 2010 6:56 pm | |
| minum mlm2 xpe,siang ari jgn darksics,kn btl pose..ngeh3 | |
| Subject: Re: Jenis Blok N Head Yg Digunakan Mon Aug 30, 2010 9:37 pm | |
| hahaaha..ok2...back to de topic,anyway nt ct nt,ada kwn aku nk tukar blok Y 1 ngn aku...saiz 0-0..tp kne polish or rebore,sb blok dh karat,lame sekung | |
| Subject: Re: Jenis Blok N Head Yg Digunakan Mon Aug 30, 2010 11:43 pm | |
| hua3.x tawu lak den.material die punce faktor org cari blok tu.ki3. | |
| Subject: Re: Jenis Blok N Head Yg Digunakan Tue Aug 31, 2010 1:42 am | |
kyrasbc Laskar Muda
Posts : 44 Join date : 08/08/2010 Age : 37
| Subject: Re: Jenis Blok N Head Yg Digunakan Tue Aug 31, 2010 1:18 pm | |
| darksics ko angkt blok y2 tue baru or lama eh?kalo blok2 bru ori yamaha ade jual lg ke yg Y1, Y2 nie?
Antara i-1 ngn i-2 mane lg ok?aku tgk rmai yg modi blok pki i-1 berbanding i-2.. | |
| Subject: Re: Jenis Blok N Head Yg Digunakan Tue Aug 31, 2010 2:02 pm | |
| tlg jwb neh,aku rs blok i-1 i-2 same je kot...kalo Y-1 ngn i-2 xtau la aku..kih3 | |
kyrasbc Laskar Muda
| Subject: Re: Jenis Blok N Head Yg Digunakan Tue Aug 31, 2010 3:19 pm | |
| - kyrasbc wrote:
- darksics ko angkt blok y2 tue baru or lama eh?kalo blok2 bru ori yamaha ade jual lg ke yg Y1, Y2 nie?
Antara i-1 ngn i-2 mane lg ok?aku tgk rmai yg modi blok pki i-1 berbanding i-2.. yi ade tak jwpn tok soklan aku tue..hehehe | |
| Subject: Re: Jenis Blok N Head Yg Digunakan Tue Aug 31, 2010 3:33 pm | |
| aku xpenah dgr lg la ada org jual blok Y 1 baru...bkn xnk jwb,tp xtau jwapan...hehe... | |
fareez91 Pegawai Waran II
Posts : 1192 Join date : 22/06/2009 Location : Jinjang ↔ penang
| Subject: Re: Jenis Blok N Head Yg Digunakan Tue Aug 31, 2010 3:41 pm | |
| y1 kne cr kt mto first model je,xtw lak klo2 hly ade kua lg blok y1.hehe.. | |
| Subject: Re: Jenis Blok N Head Yg Digunakan Tue Aug 31, 2010 4:32 pm | |
| hah,tu cik fareez dh jwb....kne cr yg kt motor 1st model la...lame pon ok..tahan je.... | |
kyrasbc Laskar Muda
| Subject: Re: Jenis Blok N Head Yg Digunakan Tue Aug 31, 2010 9:36 pm | |
| - fareez91 wrote:
- y1 kne cr kt mto first model je,xtw lak klo2 hly ade kua lg blok y1.hehe..
ok2...tue la aku pun dok mencari gak blok2 tok modi..cm skunk nie blok aku I-2 ingt nk crk blok model laen..hehehe aku slalu dgr org ckp blok Y nie power..tang mane pun tak tau... ..sape2 penah pki dapat rase tak power die? | |
| Subject: Re: Jenis Blok N Head Yg Digunakan Tue Aug 31, 2010 10:37 pm | |
| Subject: Re: Jenis Blok N Head Yg Digunakan Tue Aug 31, 2010 10:51 pm | |
| ape yang sedap tu darksics? semua blok buat dari besi je.. bukan boleh makan pun.. ape yang sedap? | |
| Subject: Re: Jenis Blok N Head Yg Digunakan | |
