| Segala Persoalan V16 | |
+55mangketey samporna ccn Apislegend herel_rocks iqram mhafiz Capslock EjanNiz man JGN8917 askrun absolute_ahben kenzou tupai comel nazjb bender mousepink meetoto Ejan_Santo superjoemanito hasrul_90 are_d7 monster block farez mrbean NCH_KU ak su eddy8075 der z0uwl fiq devilmeasha Azrul wormzx mutoudoh roda karat abg_apis redline Ultra-Z nurkaye_akmal yan_zr silent_+125zs Kazamasaga-san jacob chocolate mazakim syamaleeto Kaer babet xopai Shark pfa ajizaimi amex chaosworld malaon7 paan1171 59 posters |
mutoudoh Laskar Muda
Posts : 34 Join date : 24/01/2011
| Subject: Re: Segala Persoalan V16 Fri Jul 01, 2011 9:46 pm | |
| - Shark pfa wrote:
- mutoudoh wrote:
- salam..tompang tanya nape ekk rpm moto ak naik tetibe j time idle..bese dlm 1.5k j..ni smpai 3.5k gitu..rpm jd cam tu lepas ak perah moto dlm 80-90 gitu..adakah ni disebabkan brekpad masih ketat?? sbb sbelom aku tukor brekpad tkder pulak jdi cenggitu..
try set blik carb tuu.... err tp aku xpenah pon usik carb ni..probs timbul slpas ak tukar brekpad.. | |
wormzx Support Crew
Posts : 1825 Join date : 05/04/2010 Location : kemaman<--->kerteh
| Subject: Re: Segala Persoalan V16 Fri Jul 01, 2011 11:31 pm | |
| - mutoudoh wrote:
- Shark pfa wrote:
try set blik carb tuu.... err tp aku xpenah pon usik carb ni..probs timbul slpas ak tukar brekpad.. ak aritu jd gak camni..tgk2 gasket bocor so try tgk head ade leaking x?.... | |
nurkaye_akmal Pegawai Waran I
| Subject: Re: Segala Persoalan V16 Sat Jul 02, 2011 12:09 am | |
| ha'ah yg pasal gasket head pun punca rasenye, aku dah kene dua kali yg tu, memang timing selalu naik tk pasal2, brake pad tk kene mengena bro, kalo rase ketat tu sbb pad tu baru ngan tebal lagi | |
Shark pfa Bintara Kanan
| Subject: Re: Segala Persoalan V16 Sat Jul 02, 2011 7:42 pm | |
| salam 1malaysia aq nk tnya ni apasal tyar blakang moto aq bergoyang??....kwan aq ckp bearing moto dh pecah betul kee... | |
| Subject: Re: Segala Persoalan V16 Sat Jul 02, 2011 8:00 pm | |
| ko try double stand motor ko, ko pgg tayar belakang ko tu lpas tu tolak ke kiri and kanan slow, kalo ade rase mcm longgar, lpas tu kalo rase mcm berpasir je bile time pusing tayar tu maybe bearing dye dah pecah la tu | |
| Subject: Re: Segala Persoalan V16 Sun Jul 03, 2011 12:20 pm | |
| - nurkaye_akmal wrote:
- ko try double stand motor ko, ko pgg tayar belakang ko tu lpas tu tolak ke kiri and kanan slow, kalo ade rase mcm longgar, lpas tu kalo rase mcm berpasir je bile time pusing tayar tu maybe bearing dye dah pecah la tu
masa pusing xade rasa mcm berpasir....tp klau tgk tayar tu mase kita pusing dia mcm goyang2.... | |
Azrul Laskar Kelas I
Posts : 146 Join date : 24/01/2011
| Subject: Re: Segala Persoalan V16 Mon Jul 04, 2011 6:09 am | |
| nk tanye skit..time aku full trottle kn,asal bila aku nk slow dye mcm ada bunyi mcm kuar kt head..bunyi dye lebey kurang mcm ni la tussss,tussss..nape bley jd mcm ni ek ?.. | |
| Subject: Re: Segala Persoalan V16 Mon Jul 04, 2011 9:13 am | |
| gasket bocor kot..xpun ikat plug tak kuat atau thread die da loose.. | |
| Subject: Re: Segala Persoalan V16 Mon Jul 04, 2011 9:56 am | |
| - devilmeasha wrote:
- gasket bocor kot..xpun ikat plug tak kuat atau thread die da loose..
tapi moto aku baru ja past rebore..da abiz pantang aku try full trootle..x kn gasket head bocor kot ?..klau thread da loose boley wt baru ke ?.. | |
| Subject: Re: Segala Persoalan V16 Mon Jul 04, 2011 2:46 pm | |
| ce tgk kat block dulu..biasanya kalau ada bocor..akan ade minyak leaking..dari situ boleh tau kat mana tempat yg bocor..kalau thread plug rosak tu aku xtau leh repair atau x..kena hantar engineering la kot.. | |
| Subject: Re: Segala Persoalan V16 Mon Jul 04, 2011 11:24 pm | |
- ce tgk kat block dulu..biasanya kalau ada bocor..akan ade minyak leaking..dari situ boleh tau kat mana tempat yg bocor..kalau thread plug rosak tu aku xtau leh repair atau x..kena hantar engineering la kot..
aku kt blok x de leaking pon..cuma leaking kt lubang exzos ja..lubang xzos leaking boley drop ke performance dye ?.. | |
| Subject: Re: Segala Persoalan V16 Tue Jul 05, 2011 6:22 am | |
- ha'ah yg pasal gasket head pun punca rasenye, aku dah kene dua kali yg tu, memang timing selalu naik tk pasal2, brake pad tk kene mengena bro, kalo rase ketat tu sbb pad tu baru ngan tebal lagi
tande2 leaking 2 cmne ekk..dia bminyak kehitam-hitaman sket gitu ke..psal kat tepi kick starter tu ade itam2 sket..ak try tuka minyak itam pakai motul 3100..rpm jd okey sikit..ak try merembat n benti tgk idle dlm 2k..okey ke tu? ke muto ak xleh pakai rimula? sori ak noob.. | |
| Subject: Re: Segala Persoalan V16 Tue Jul 05, 2011 8:17 am | |
aku kt blok x de leaking pon..cuma leaking kt lubang exzos ja..lubang xzos leaking boley drop ke performance dye ?.. kalau kat lubang ekzos..maknanya gasket ekzos je la yg kena tukar.. .. drop performance?..xde la drop kaw2..mgkin dlm 1% je(sbb moto kelihatan kotor).. | |
| Subject: Re: Segala Persoalan V16 Tue Jul 05, 2011 8:39 pm | |
| weeeeeeeeeee,,,,,ak kompius ni...
waktu set skru angin kat carb...
1 pusingan tu bmaksud 180 degree ke atau 360 degree????
ak skrg buat dua pusingan tp ak refer pd 360/pusingan so ak buat 720 degree pusingan...
mana yg betol sbnrnya ni??? | |
| Subject: Re: Segala Persoalan V16 Tue Jul 05, 2011 10:52 pm | |
Kazamasaga-san Laskar Kanan
Posts : 201 Join date : 15/12/2010
| Subject: Re: Segala Persoalan V16 Wed Jul 06, 2011 12:35 am | |
| kawan2
Ak nak tau, skang ni market tupai baru brape sbnarnye? Kalo kt area ak baru mmg 7k-8k la.. 2nd 3500-4500 utk range tahun 03-08... mcm mane plak kt tmpat korg?
fiq Laskar Kanan
| Subject: Re: Segala Persoalan V16 Wed Jul 06, 2011 12:47 am | |
| ak ad soklan pasal gasket ni..
1)ak pkai gasket head tembaga..perlu ke letak gam gasket @hardexx?
2) ak pakai piston lc..bape banyak gasket nak letak ngan perlu ke letak gam gasket?
| Subject: Re: Segala Persoalan V16 Wed Jul 06, 2011 4:16 am | |
| minyak break keta bley msuk ke kt moto ?.. | |
der z0uwl Laskar Kelas I
Posts : 121 Join date : 02/05/2010 Location : kl
| Subject: Re: Segala Persoalan V16 Wed Jul 06, 2011 4:45 am | |
| - Azrul wrote:
- minyak break keta bley msuk ke kt moto ?..
bleh je...pkai yg dot4 lg elok.. | |
| Subject: Re: Segala Persoalan V16 Wed Jul 06, 2011 4:48 am | |
| - der z0uwl wrote:
bleh je...pkai yg dot4 lg elok.. oke..minyak break semua warna merah ke air dye ?. | |
| Subject: Re: Segala Persoalan V16 Wed Jul 06, 2011 5:00 am | |
| Subject: Re: Segala Persoalan V16 Wed Jul 06, 2011 5:07 am | |
| - der z0uwl wrote:
- kebanyakannye lah...
oke .. thankzz | |
| Subject: Re: Segala Persoalan V16 Wed Jul 06, 2011 8:37 am | |
| - babet wrote:
- weeeeeeeeeee,,,,,ak kompius ni...
mana yg betol sbnrnya ni??? btul la tu 1 pusingan=360 deg..hehehe aku x biasa guna istilah degree2 ni hehehe..biasa set kampung2 main bantai jer ikut sedap telinga..haha | |
eddy8075 Support Crew
Posts : 971 Join date : 03/02/2010
| Subject: Re: Segala Persoalan V16 Wed Jul 06, 2011 8:38 am | |
| - Kazamasaga-san wrote:
- kawan2
ni aku cte bln 4, bln 5 ritu. mto baru kt klang aku survey rm 7.6k pling murah. pling mhl rm7.8k. kt kl pon lbh kurang je.bwh rm7.5k xdpt da kot skrg ni. so, jge tupai korg baik2. dgr cte tahun ni last production.ke da stop.ntahla. hrp2 sempatla ank cucu men tupai z aku ni..hehe | |
| Subject: Re: Segala Persoalan V16 Wed Jul 06, 2011 8:41 am | |
| aku nak tanya..sape ada pendapat pasal masalah moto aku..
gni.. moto aku bila bawak slow..rpm 2-5k moto vibrate kuat...tp bila up 5k baru moto kurang vibrate..kenape aa?..
geli la badan aku naik moto getar2 ni.. xkan nak laju memanjang kot..hahaha | |
| Subject: Re: Segala Persoalan V16 | |
