| 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 | |
+79NiTRO697 kamal96 ajmal92 budak kt same iqbal92 Snake125z Sya125z mzul787 areyz95 nurkaye_akmal BCDSyaz Azeri_conquistador serez sakaihutan muhd_amir kasimselamat matjang99 d1grandprix Liquey wan_210407 su thibhan stormtrooper WVG 9651 tongdrum92 am_pitam adeqyana comebackid MadAxel payjalrazali Ijat Stylo mangketey Paktam redline cabai low profile Conan Edogawa thee_abu sherlock mat lam L5M4 125z ganu bergerKedah qayyum_qz NIKZELMY paan1171 G.i.joule jmg235 pasquale Mal-PuChOng3300 aleen90 Shark pfa absolute_ahben samporna ccn mudienLC152 -sLip- HaIkAl 125z Kaer Apislegend wanhaniff devilmeasha k.a monster block Azrul amer_horatio throne_undead bender babet kenzou fizerpool der z0uwl fiq nazjb naem 2345 chocolate meerul KapcaiKuDie superjoemanito 83 posters |
NiTRO697 Laskar Muda
Posts : 35 Join date : 23/11/2012 Location : Taiping,Perak
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Fri Dec 06, 2013 4:13 pm | |
| - Azeri_conquistador wrote:
- NiTRO697 wrote:
- blok 0.0 dh korek,head ptong,kotak angin dh buang span n tebuk,ekzos tebok stopper
nk msuk carb z mili pilot n menjet ap yg sesuai? kalau nk yg cun betul2 kena try semua saiz kalau boleh.. sbb lain motor lain setting dia.. tapi kalau mau yg tahap setting yg okay2 je ko tnggu abam2 yg gna carb z memberi jawapan.. orite bro , kalu ak test moto pulas throttle rpm naik mencanak tp meter kmh pegi lembab knpa ye? mj ke pj yg x ok? | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Fri Dec 06, 2013 9:29 pm | |
nk msuk carb z mili pilot n menjet ap yg sesuai? kalau nk yg cun betul2 kena try semua saiz kalau boleh.. sbb lain motor lain setting dia.. tapi kalau mau yg tahap setting yg okay2 je ko tnggu abam2 yg gna carb z memberi jawapan.. orite bro , kalu ak test moto pulas throttle rpm naik mencanak tp meter kmh pegi lembab knpa ye? mj ke pj yg x ok? sprocket saiz berapa? masa rpm laju je dia naik ,speed berapa masa tu? | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Sat Dec 07, 2013 1:27 am | |
nk msuk carb z mili pilot n menjet ap yg sesuai? kalau nk yg cun betul2 kena try semua saiz kalau boleh.. sbb lain motor lain setting dia.. tapi kalau mau yg tahap setting yg okay2 je ko tnggu abam2 yg gna carb z memberi jawapan.. orite bro , kalu ak test moto pulas throttle rpm naik mencanak tp meter kmh pegi lembab knpa ye? mj ke pj yg x ok? sprocket saiz berapa? masa rpm laju je dia naik ,speed berapa masa tu? sprocket 15/36 428 , contoh rpm dh 4 tp kmh baru 30 nk ke 40 , rsanya ak slah settng carb leh ades letih dh duk bukak psg tp xkena jugak set:( | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Sat Dec 07, 2013 10:05 pm | |
| - NiTRO697 wrote:
sprocket 15/36 428 , contoh rpm dh 4 tp kmh baru 30 nk ke 40 , rsanya ak slah settng carb leh ades letih dh duk bukak psg tp xkena jugak set:( adoiyaii klau susah2 sgt antr pomen je senang..dh try tgk colour plug? confirm ke salah setting carb.. clutch cable semua ok.. klau boleh ambil gmbr plug then post kt sini..baru abam2 yg terer boleh bgi jawapan. | |
arai Laskar Muda
Posts : 2 Join date : 05/05/2014
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Mon May 05, 2014 4:01 pm | |
| salam sume bro2 otai2 . saya na tumpang tanya . carburator rxz mili dgn katok apa perbezaan die dr segi kelajuan ... tgh pening na beli yg mane . sbb stgh ckp mili stgah ckp katok . mintak pendapat dan tunjuk ajar yehh .. trima kasih | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Wed May 07, 2014 9:04 pm | |
| kalau ak carb mili dah ok.. carb apapn mcm mili ka bosch ka kalau setting cun baru leh rasa power + penjimatan mnyk dia .. kalau setting tk cun, siap la duit bnyk2 nk isi petrol | |
madan77 Laskar Muda
Posts : 2 Join date : 30/05/2014 Age : 32 Location : Penang
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Fri May 30, 2014 4:13 am | |
| salam buat semua, saya nak tanya sikit tentang set carb rxz catalyzer ni, ekzos potong, sarang buang silencer tukar pakai rxz. blok stendet. spoket 15-37. nak set jimat minyak ja. brapa size minjet dah pilot yg diperlukan? mohon penjelasan. saya baru ja belajar set2 carb ni, jadi tolong kasi info yg mudah utk faham ya kawan2 semua. | |
kadi7161 Laskar Muda
Posts : 2 Join date : 25/08/2014
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Mon Aug 25, 2014 3:53 am | |
| Salam bro2 tupai .nak tnye cket nie .gua bru sarung carb mili .mj 190 pj 225 .sume standart .kotak angin da tacap boh washer .ok x mj n pj tu ?so far so good tpi ad pomen ckp jgn rembat .npe ae ?ape kesan nye ? | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Mon Aug 25, 2014 3:59 am | |
| Lgi satu nk tnye ,ad x cdangan laen nk set pj n mj slaen dari mj '190 pj 225 tuk spec tupai gua nie ?harap blas cpat . | |
khairool Laskar Muda
Posts : 2 Join date : 21/07/2015
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Tue Jul 21, 2015 11:07 am | |
| To kadi7161: jetting carb z kw tu dh ok if kotak angin just buboh washer tnpa tebok2... pomen tu xnk tggugjwb la kiranya if kw jamkan piston kw... setting ni selamat utk dilenjan dn safe minyak... | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Tue Jul 21, 2015 11:12 am | |
| Carb uma racing plug n play je ke kt 125z...maksud ak tapak die ngam dn manifold xyh tukar laen... tulun2 den berhajat nk sarong kt tupai den just tinggal nk jetting je...if xngam den sarong carb z.. | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 | |
