| 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 | |
+79NiTRO697 kamal96 ajmal92 budak kt same iqbal92 Snake125z Sya125z mzul787 areyz95 nurkaye_akmal BCDSyaz Azeri_conquistador serez sakaihutan muhd_amir kasimselamat matjang99 d1grandprix Liquey wan_210407 su thibhan stormtrooper WVG 9651 tongdrum92 am_pitam adeqyana comebackid MadAxel payjalrazali Ijat Stylo mangketey Paktam redline cabai low profile Conan Edogawa thee_abu sherlock mat lam L5M4 125z ganu bergerKedah qayyum_qz NIKZELMY paan1171 G.i.joule jmg235 pasquale Mal-PuChOng3300 aleen90 Shark pfa absolute_ahben samporna ccn mudienLC152 -sLip- HaIkAl 125z Kaer Apislegend wanhaniff devilmeasha k.a monster block Azrul amer_horatio throne_undead bender babet kenzou fizerpool der z0uwl fiq nazjb naem 2345 chocolate meerul KapcaiKuDie superjoemanito 83 posters |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Sun Mar 18, 2012 4:06 pm | |
| oh kalo yg mcm ko ckp itu.. aku x tau.. x pe ko tunggu kot2 nnti ada yg mmberi sepatah 2 kata tetng pertnyaan ko itu hehee | |
125z ganu Laskar Kelas I
Posts : 164 Join date : 31/10/2011 Location : Kelate-Terengganu
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Sun Mar 18, 2012 9:32 pm | |
| halooo..
adess,sory la tnye bnda same.. nk tnye ni,camne nk setting angin carb z? ak carik2 post xjumpe gak..tlg ajar..
tq,,, | |
jmg235 Laskar Muda
Posts : 11 Join date : 27/09/2010 Age : 33 Location : batu pa[h]at
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Fri Mar 23, 2012 2:02 am | |
| brape saiz mj ngan pil0t yg ssuai kl0 tupai pki jarum panther + carb z b0sch + bl0k 0.0 + p0rting stended + k0tak angin buang span ngan muncung getah ue... | |
mangketey Laskar Kelas I
Posts : 119 Join date : 09/09/2010 Age : 33 Location : Kerteh,terengganu
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Thu Apr 05, 2012 3:12 pm | |
| [quote="jmg235"]brape saiz mj ngan pil0t yg ssuai kl0 tupai pki jarum panther + carb z b0sch + bl0k 0.0 + p0rting stended + k0tak angin buang span ngan muncung getah ue...[/quote]
jarum panther ssh nk sttg..lbh baik pkai jarum gamma..pkai mainjet 170 pilot 35
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Thu Apr 05, 2012 9:13 pm | |
| - mangketey wrote:
- jmg235 wrote:
- brape saiz mj ngan pil0t yg ssuai kl0 tupai pki jarum panther + carb z b0sch + bl0k 0.0 + p0rting stended + k0tak angin buang span ngan muncung getah ue...
besarnya pilot..x bobok ke moto karb tzm plak camne? | |
nazjb Bintara Muda
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Thu Apr 05, 2012 9:37 pm | |
| aku penah set pilot besar2 mcm ni..mid bobok sgt2..bile hi rpm berdesup..penat layan bobok,aku tukar pilot kecik,besarkn mj..errr..stended carb panther mj pj brape ek? | |
jmg235 Laskar Muda
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Fri Apr 06, 2012 8:19 pm | |
| [quote="mangketey"]jarum panther ssh nk sttg..lbh baik pkai jarum gamma..pkai mainjet 170 pilot 35 [/ quote] da try da...tp b0b0k la...plug wrne itam... | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Sat Apr 07, 2012 2:39 am | |
| [quote="jmg235"] - mangketey wrote:
- jarum panther ssh nk sttg..lbh baik
pkai jarum gamma..pkai mainjet 170 pilot 35 [/ quote] da try da...tp b0b0k la...plug wrne itam... pilot 25,menjet 220/210? | |
Ijat Stylo Laskar Kelas I
Posts : 113 Join date : 23/12/2011 Age : 35 Location : (KLang) Selangor
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Sat Apr 07, 2012 1:13 pm | |
takut dengar pilot smpai 35.. setting maut tu.. jarum standard Z x boleh keR?awk asah la depan tu guna sharpener bagi ada halus skit | |
jmg235 Laskar Muda
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Sat Apr 07, 2012 11:29 pm | |
| malas la nak asah2 ni...takot seting x ngam... pilot 25,menjet 220/210 pon bobok lg...plug pon wrne itam legam lg...huhu... | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Sun Apr 08, 2012 12:20 am | |
| kata port stended?ke blok dah modi?
camtu kalu try rendah kan pilot semata,menjet stay 220..angin stay dl satu pusingan..dah jumpa saiz jet yg cun br set angin balik | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Sun Apr 08, 2012 1:30 pm | |
| [quote="jmg235"][quote="mangketey"]jarum panther ssh nk sttg..lbh baik pkai jarum gamma..pkai mainjet 170 pilot 35 [/ quote] da try da...tp b0b0k la...plug wrne itam...[/quote]
kecikkn mainjet..pkai 150 | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Sun Apr 08, 2012 1:31 pm | |
| klu pkai jarum 7 try pilot 30, mainjet 190 | |
payjalrazali Laskar Muda
Posts : 55 Join date : 15/01/2011
| Subject: modify carb yang xde lubang 2t Sat Apr 28, 2012 3:04 pm | |
| salam, nk tnye sikit.. mcm mana nak modify carb yg xde lubang 2t mcm carb double r??aku nk pakai 2t direct kat carb..xpyh bancuh. | |
MadAxel Laskar Muda
Posts : 13 Join date : 19/07/2010
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Thu May 03, 2012 8:25 pm | |
| sye mcm nk cuba pkai carb z nii.. tapi x tau nk pkai yg mili atau yg katak? rse2 mne satu bgs segi performance dan minyak? Spec moto sye blok 0.0.. bukak kotak angin saje.. | |
Paktam Laskar Kelas I
Posts : 131 Join date : 04/10/2011 Age : 33 Location : Miri,Sarawak/Kuala Lumpur
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Thu May 03, 2012 9:35 pm | |
| org kata mili senang skit nk setting... tpi xtau laa... aku sarung je katak... blok 0.0 jugak... takat ni setting cm ok... sarung mana2 carb pun kene pandai setting... tu jee | |
MadAxel Laskar Muda
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Fri May 04, 2012 5:53 pm | |
| - Paktam wrote:
- org kata mili senang skit nk setting... tpi xtau laa... aku sarung je katak... blok 0.0 jugak... takat ni setting cm ok... sarung mana2 carb pun kene pandai setting... tu jee
minyak ok? meter bpe ble dpt? | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Fri May 04, 2012 8:50 pm | |
| - MadAxel wrote:
minyak ok? meter bpe ble dpt? takat ni minyak parak skit la dri carb stendet... aku lom abes setting agi... pomen aku kata angin x lawas kene buang span... tgk la nnti camna... otai2 sini kata minyak patutnya saving skit kalo dpt setting betul... meter ape maksud bro ni? kalo top sama je... tggl pickup lagi beshh!!... hahaha... | |
comebackid Laskar Muda
Posts : 96 Join date : 31/03/2012 Age : 28 Location : Perak
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Sat May 19, 2012 9:55 pm | |
| salam.
haritu carburetor z sya overflow pomen ckp tuka gasket
dah tuka tapi carburetor sya berpeluh tapi bau minyak
petang tadi nk p jalan2 boleh start tapi bila pulas trottle mati kenape ye ?
Harap Otai2 sini bleh membantu.. | |
nazjb Bintara Muda
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Sun May 20, 2012 2:38 am | |
| mcm minyak x support je..atau angin kecik sgt..ape2 pun elok buka,cek dan servis semula.. | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Sun May 20, 2012 7:49 pm | |
| pomen sya cakap mungkin minyak x sampai atau kena tuka reed valve..?
bergerKedah Laskar Muda
Posts : 11 Join date : 18/04/2011 Age : 32 Location : Kulim,Kedah
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Tue May 22, 2012 1:51 pm | |
| salam otai2..da nk tolak carb rxz boss murah2 x??huhuhu(sgt memerlukan ni) | |
adeqyana Laskar Kelas I
Posts : 133 Join date : 05/12/2011
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Mon May 28, 2012 2:37 am | |
| nak tanya skit ni..klu Mj 230 kira besar tak utk carb z,jarum panther?? bila pakai Mj kurang dari 200,motor akn semput Mid RPM..bila pakai Mj 165 time idle,leh sampai 11 rpm,tp sangkut2..motor aku semua std,blok std 0.00,ekzos je pakai ahm..
1 lg klu pakai Mj 200 ke atas kuat tak mkn minyak??
am_pitam Laskar Muda
Posts : 1 Join date : 31/05/2012
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Thu May 31, 2012 12:33 pm | |
| Salam sahabat2.. nak bertanya..saya baru beli 125z..2nd hand..keadaan stendet pekak tp owner sebelum ni bg 1 blok dah tengkorak..sumer lubang calung dah buat PnP head dah potong gak tp tak tau brp mm...piston size 1.00 125z... kata owner dulu..blok ni kena set ngan carb Rxz..so saya nak tanya sahabat2 apa pilot n minjet yg sesuai utk blok mcm nie..bkn nak laju sgt.. tp kurang2 leh duk dpn LC135 dah cukup harap tolong yer | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 Thu May 31, 2012 8:57 pm | |
| Subject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4 | |
