 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4
Go to page : Previous  1 ... 5, 6, 7 ... 10 ... 15  Next
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Thu Dec 15, 2011 8:24 pm
aku berpendapat yg sama,yg ada made in japan Bosch... yg x de made in japan(kosong) millenium,tapi kalo tersalah info mintak maap yer..
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Sat Dec 17, 2011 1:28 pm
nie pula
[img] [/img]
[img] [/img]
vm26-9504
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Wed Dec 28, 2011 4:26 pm
ni carb ori kedai..
Shark pfa
Shark pfa
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Wed Dec 28, 2011 5:35 pm
pkataan Mikuni xde bang...Ori kedai Apek kot...pendapat nubie
bergerKedah
bergerKedah
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Wed Dec 28, 2011 9:46 pm
hehe,aku da pertanyaan ntok member2..
aku nk bg mto aku laju skit(sedap naik)
tp aku xmaula kcau blok ngn enjin,hehe bajet xdak sangatla..
pa aku kna bt slain dri tukaq carb ek??huuu Rolling Eyes
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Wed Dec 28, 2011 10:14 pm
lapik span tebal sikit dekat seat.
bru sedap naik.
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Fri Dec 30, 2011 6:25 pm
A'ah caburetor ori kedai Apek ada Amoi seksi.... dia kata ori punyerrr,kalo x ori mmg aku kena kencing berdiri la dgn apek dan amoi tu keh3.... u mau lokel pnyerr pn ada maaa tapi nnti u jgn complen susah mau setting sama u pnya tupai,kasi angkut itu ori punyerr mesti ok punyerr.
Yg pasti caburetor tu ok jeeee heehehee,Al hamdulilah,x ,mendtgkn masalah kt moto aku,bentuk mcm millenium cuma no.code tu je yg lain,yg lain sama,cap mikuni pn ada.
terima ksh la kt En.chocolate kerana mengatakn caburetor ori kedai spare part apek & amoi bole pakai.
abis aku baca pasal caburetor,fuh best betul membaca,info2 lain pn aku nk baca smpai abis,dah bosan dgn FB nk ushar awek x dpt sambutan,mmbaca info lagi best la keh3....
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Fri Jan 06, 2012 4:10 pm
aku pn da try 3 jenis carb rxz..
catalyte- susa nak dpt setting, mnyk mcm standard
carb boss 55k- sedap, senang setting, jimat minyak.
carb boss 26 9 504 (ori kedai) - sedap..99.99% mcm ori..jimat mnyak..hampir xde beza..
Aku ada persoalan..kalau nak lay carb..lay kat mana ye..kat intake (ada tulis 26 tu)..atau kat minyak keluar?..atau lay tembus..??
biasa lay berapa MM untuk carb rxz?
125z ganu
125z ganu
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Fri Jan 06, 2012 10:20 pm
lay kat minyak keluar tuh..sbb kat situ la kadar minyak n angin masuk lam blok ntuk proses pembakaran..bese 26mm -> 28mm je..same ngan saiz karb tzm(xsilap ak la)..xley lay parak sgt sbb bende nih kalo lay byk sgt,nnti jadik leaking..
L5M4
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Sat Jan 07, 2012 2:34 pm
guys, help me.... aku ader carburator panther, nk masuk kat 125z aku n nk pkai box angin. ble x tlong bagi aku saiz mainjet n pilotjet yg ngam. motor aku standard jer.
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Sun Jan 08, 2012 11:11 pm
tp bro, aku ukur carb standard z kat intake yg 26mm..bukan kat minyak kluar (out-put)..
tu yang konpius..nak lay kat intake ker..atau bahagian yg ke reed-valve?
kalau lay kat out-put carb..bermaksud kat intake 26mm..kat outter pun 26mm ker?
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Sun Jan 08, 2012 11:13 pm
kenal kan diri dulu bro..
http://125z.forumms.net/t2-attention-to-all-new-members
kenzou
kenzou
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Tue Jan 10, 2012 4:22 am
carb tzm size brapa ye bro bro sume.? sedapp taa masuk tupai.? ke kuat makan minyak.?
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Wed Jan 11, 2012 12:46 am
30mm kalau x silap.
mat lam
mat lam
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Fri Jan 27, 2012 10:11 pm
sape2 pnah pakai karb keihin pe 28 x?? nk try ni... bounce bounce
sherlock
sherlock
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Sat Jan 28, 2012 8:22 am
absolute_ahben wrote:
30mm kalau x silap.
kalo aku lak yg xclap,tzm 28mm kot...
sherlock
sherlock
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Sat Jan 28, 2012 8:24 am
pnh gak try keihin pwl28...
pndi set power mmg x'kate...
pikap m'canak2...
125z ganu
125z ganu
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Sat Jan 28, 2012 9:52 pm
mksud ak,lay yang ke reedvalve(out-put/outter),bkn yang di kotak angin tu..sbb katsitu la angin yg bercampur minyak keluar terus ke reedvalve..
btw,ak pon pakai carb camni jgk..senang setting,jimat minyak..
thee_abu
thee_abu
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Sun Jan 29, 2012 3:12 pm
sape2 kat sini pnh pakai carb panther.. ?? best ta pakai kat 125 korang..??
qayyum_qz
qayyum_qz
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Sun Jan 29, 2012 5:42 pm
aq dah pakai...minyak jimat gler...pikap pon ade...tp mili lg power piakp dy...
thee_abu
thee_abu
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Sun Jan 29, 2012 10:36 pm
laaa yeke.. mane 1 na beli nie.. ahhh belilah ke22ya sekali.. bila dh boring pakai mili pulak.. ermmmm
sherlock
sherlock
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Mon Jan 30, 2012 1:47 am
pakai stendet set jetting jer abu...
thee_abu
thee_abu
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Mon Jan 30, 2012 9:08 am
hehehehe.. taleh2 nanti jauh tertinggal..
mat lam
mat lam
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Mon Jan 30, 2012 3:10 pm
pikap m'canak2...
minyak un mcanak2 jgk ker?? affraid top ade x??
sherlock
sherlock
PostSubject: Re: 125Z + Carb Rxz @ Carb Panther @ Carb Tzm @ Aftermarket V4   Tue Jan 31, 2012 3:43 am
bek jaoh ley pegi dr jaoh kne tggl...
plg kuat pon skilo 2 jer kne tggl,tp kalo modi2 jem tgh jln ditinggalkan lg jaoh lak...
hahahaaaaa...
Page 6 of 15Go to page : Previous  1 ... 5, 6, 7 ... 10 ... 15  Next
