 Segala Persoalan V15
Go to page : Previous  1, 2, 3 ... 9 ... 16  Next
tupaiku
PostSubject: Re: Segala Persoalan V15   Sun May 01, 2011 3:25 pm
korang sume top overhaul setiap bape km ea... biasanya???
Conan Edogawa
PostSubject: Re: Segala Persoalan V15   Sun May 01, 2011 7:33 pm
Man4822 wrote:
Blok y-1 biasa susah nak dapat dengan harga murah..
Untung la ko conan dapat harga murah.
rezeki...time tu blok byk pilihan kat halfcut...harga sama semua...pilih yang Y-1 la....
Man4822
PostSubject: Re: Segala Persoalan V15   Mon May 02, 2011 4:58 pm
dpt skali dengan head kan?? ke blok je??
PostSubject: Re: Segala Persoalan V15   Mon May 02, 2011 6:09 pm
setiap 10k...klaw rajin n byk duit leh buat stiap 7-8k
PostSubject: Re: Segala Persoalan V15   Mon May 02, 2011 6:31 pm
muto aku dah jln lbih 2Ok km....
bese ny brg aper yg perlu ditukar ganti...? Question Question
Conan Edogawa
PostSubject: Re: Segala Persoalan V15   Tue May 03, 2011 1:28 am
aku beli block ngn isi dalam....tapi masa pakai tukar ring ngn bearing kacang tu jer...
head beli asing...baru perasan tadi head pun Y-1...
PostSubject: Re: Segala Persoalan V15   Tue May 03, 2011 2:13 pm
biasa gasket je org tukar...kalaw ada part2 lain yg rosak...ataw nyawa2 ikan pun kena tukar ;a....
contoh mcm rod dh goyang kaw2...ring dh out....piston bearing dh rosak...
AdHwA
PostSubject: Re: Segala Persoalan V15   Tue May 03, 2011 3:21 pm
nk tau sume2 2, cmne ek? pe tnde2 awl die? ke antr pomen cek je?
PostSubject: Re: Segala Persoalan V15   Tue May 03, 2011 3:39 pm
tande2 awal dye mula la perfomance drop, bunyi kt blok ngan enjin dah makin kasar, gedegang2 bunyi sound effect tu hihi
PostSubject: Re: Segala Persoalan V15   Wed May 04, 2011 12:55 am
bunyi cam traktor... Laughing
MaGNum_1721
PostSubject: Re: Segala Persoalan V15   Wed May 04, 2011 1:22 am
nk tnye skit la....
apsal moto aq
bru lpas wat top obehol....
da gnti pston ring....tp bearing kat piston tu x gnti.....
bnyi moto aq kuat gak....ke sbb mearign tu aq x gnti.....
n bearing tu...ad goyang...ke mmg dye ade goyang2 atau ketat xde goyang....
musuhkil aq ni.....
tolong....!!!
mangketey
PostSubject: Re: Segala Persoalan V15   Wed May 04, 2011 3:52 am
aku nk tnyer cmner nk sttg biar mto rpm dier leh naik tggi smpai 10k@ 11k.mmbr aku pkai blok saiz 0.25 enduro dpt rpm tuh,tpi aku x dpt..aku nyer rpm smpai 8.5k jer..
http://man_rempitkerteh@yahoo.com
PostSubject: Re: Segala Persoalan V15   Wed May 04, 2011 8:57 am
MaGNum_1721 wrote:
nk tnye skit la....
apsal moto aq
musuhkil aq ni.....
tolong....!!!
ganti piston ring sj ka?mungkin piston dah longgar,xpun mmg roller ngan pin piston dah kene tukar skali..bearing tu mmg longgar
PostSubject: Re: Segala Persoalan V15   Wed May 04, 2011 9:01 am
blok korek x lg boh?ke stended blake?stau aku piston besor xmenambahkn rpm@TOP PON...hik3
PostSubject: Re: Segala Persoalan V15   Wed May 04, 2011 11:20 am
pickup je lbey..
kompresen lg tinggi.
hmm, dr segi kalkulasinye, kompresen same je kot; piston kecik head potong = piston besar head standard..
efisensi kt high rpm lak brgantung pd porting, intake n output sistem.
kwn2 kejuteraan mekanikal/automotif leh terangkan tk?
peringkat spm cikgu tk ajar ler~
Mad
mangketey
PostSubject: Re: Segala Persoalan V15   Wed May 04, 2011 12:02 pm
blok korek dh..tpi nk taw jgk bhgian mner yg mningktkn rpm tuh smpai leh trik 10k hngga 11k rpm..sme ader kt intake ker kt output dier yg mnyebabkn keadaan tuh brlaku
Conan Edogawa
PostSubject: Re: Segala Persoalan V15   Wed May 04, 2011 12:59 pm
pada pandangan aku,rpm leh capai tinggi ni sebab air/fuel ratio dia ngam....kalau minyak lebih2 sgt pun takleh nk high RPM sebab rich....
kalau minyak tak cukup lak tak support untuk high rpm sebab lean.....
sebab bila afr tu cun2....rotation untuk stroke tu lancar jer....
porting pulak untuk pastikan flow untuk combustion tu cantik...takde tersekat2...
kalau lawas sgt pun nnt tak sempat nk terbakar (time power stroke) then minyak jadi larung jer.. kalau kata 100% minyak yg masuk...cuma 70% aje yang sempat terbakar...selebihnya dah kuar kat ekzos...(itu anggran jer..)
lagi satu,kene ambil kire bila piston dah besar...combustion isipadu dah bertambah...then perlu ada ruang untuk keluar...lebih besar skit outlet,memudahkan sisa pembakaran keluar...tapi kalau besar sgt....jadi macam tadi...loose jer...
kesimpulan yg aku bleh buat...setting la carburator tu cun2....boleh dapat rpm sampai yang dikata...cuma enjin tahan tak tahan la....
aku penah setting sampai RPM leh cecah 10...11..tapi masa idling la...kalau on wheel...tak berani...dengan saiz piston yg standard,karburator standard... Malaysia Boleh
PostSubject: Re: Segala Persoalan V15   Wed May 04, 2011 1:24 pm
paling penting output port..ada tu smp rpm outmeter pd gear 6 walaopon piston 0-0..setting n jetting memg penting..tp jgn overport udah ler..xpasal2 low rpm lemau...
MaGNum_1721
PostSubject: Re: Segala Persoalan V15   Wed May 04, 2011 1:34 pm
MaGNum_1721 wrote:
nk tnye skit la....
apsal moto aq
musuhkil aq ni.....
tolong....!!!
yes aq tuka pston ring sje....kalo roller ngan pin piston x tuka ade bnyi gak ke...????
sbb aq x pnah tuka pon.....hehhehe
nk kate piston longgar ok je....
Conan Edogawa
PostSubject: Re: Segala Persoalan V15   Wed May 04, 2011 2:09 pm
MaGNum_1721 wrote:
MaGNum_1721 wrote:
nk tnye skit la....
apsal moto aq
musuhkil aq ni.....
tolong....!!!
aku pnh gak tukar ring jer...tapi ada bunyi...
bila check2 blik...bearing piston tu dah longgar skit...tukar yang NTN punya still bunyi...cari yang ori 125z baru dapat fit2 takde goyang kiri kanan...baru senyap takde kuar bunyi pelik2...cuma tnggal nk rebet mangkuk clutch je...
mangketey
PostSubject: Re: Segala Persoalan V15   Wed May 04, 2011 4:09 pm
klu blok 125 stndrt nk dpt rpm tggi tuh boleh ker?
biaser klu blok stndrt carb z org pkai mainjet n pilot bper?
aku pkai jarum gamma (racing design) brand safety..
PostSubject: Re: Segala Persoalan V15   Wed May 04, 2011 4:53 pm
blok stended bese rpm gear 6 8.5 je...dpt lebih pon xbyk la...
menurut superjoe----<< mj 170 keatas,pj27.5
bila pakai jarum tu,ada bobok x?
MaGNum_1721
PostSubject: Re: Segala Persoalan V15   Wed May 04, 2011 7:33 pm
MaGNum_1721 wrote:
MaGNum_1721 wrote:
nk tnye skit la....
apsal moto aq
musuhkil aq ni.....
tolong....!!!
owh yeke....aq rase aq pnye pon mcam ko gak la....
hehehehe.....xpe2 lpas ni aq wat top obehol....
gnti bearing pston dan sewaktu dngan nyer.....
hehehe..thanx 4 da info.....
NCH_KU
PostSubject: Re: Segala Persoalan V15   Wed May 04, 2011 7:40 pm
tanya sket..area shah alam ni mana nk dapat brake lever ori hly ye?
mangketey
PostSubject: Re: Segala Persoalan V15   Thu May 05, 2011 3:06 am
ader lar jgk..tpi x lme pn..skjp2 jer..dh nk wt cmner blok stndrt dpt rpm 9 pn dh ckup?
Page 2 of 16Go to page : Previous  1, 2, 3 ... 9 ... 16  Next
