| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Thu Dec 09, 2010 3:35 pm | |
| klu time moto hdp pun x nyala,kene tgk kt wiring,takut wiring dari coil magnet ke wiring body longgar ke,reput ke..cek dulu connection antara coil magnet ke wiring body.. | |
redline Laskar Kanan
| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Fri Dec 10, 2010 2:44 pm | |
pasquale Kadet
| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Fri Dec 10, 2010 8:44 pm | |
| spoiler led tu skang bape dpt kat a bros? | |
MegatBLA3089 Laskar Kelas I
Posts : 106 Join date : 13/12/2010
| Subject: Ignition Coil Mon Dec 13, 2010 11:51 am | |
| ape bende Ignition Coil ni. tolong terang kan eh THnks | |
| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Mon Dec 13, 2010 4:45 pm | |
| klu google pun dpt tau bro,mende nie sistem api kt moto,step down voltage cdi untuk ke spark plug,sng kate fungsi die cam transformer la,ade step-up n step-down,sbb konsepnye same,ade lilitan coil n plat core.. | |
| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Mon Dec 13, 2010 4:59 pm | |
| - pasquale wrote:
- spoiler led tu skang bape dpt kat a bros?
ori dpt la rm40++,klu lokel pun agk2x rm30++ gk la.. | |
nurkaye_akmal Pegawai Waran I
| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Tue Dec 14, 2010 3:24 am | |
| mcm senang je nak pasang lampu spoiler ni, ade sape2 nk jual tak, dlm RM30 nk angkat ni | |
venom Laskar Kanan
Posts : 343 Join date : 03/04/2009 Age : 49 Location : Semenyih - KL - Semenyih
| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Thu Dec 16, 2010 3:02 pm | |
| okay Thnks | |
unknownh Bintara Kanan
| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Thu Mar 03, 2011 10:33 pm | |
| BUMP haha oi korang yang pro2 blake.. moto aku kan,signal x nyale..bulb ok.. hon ok,lampu atas bwh ok,just signal je x ok.. mula2 ingt wiring tercabut,check2 sume ok.. pastu try tukar switch handle,same gk.signal je problem... korang rase sal pe a?ke relay?..aku ingat kalau relay prob mesti nyale jgk tp x kelip je la..atau tekaan aku ni salah?tapi aku xknal mane satu relay tu. ke relay yg sangkut kt tengah2 handle bar tu? ataupun korang rase ade problem lain ni? | |
| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Fri Mar 04, 2011 7:07 pm | |
| signal tu signal dpn & blkg sekali ke xnyala...
hon mcm mana..bunyi lemah ke kuat...kalu hon bunyi lemah ade kemungkinan prob signal tu berkaitan dgn bateri..
bateri weak akan wat signal tu xberkelip..dia nyala tapi xberkelip..
tp kalu hon bunyi kuat maksudnya bateri ok & mmg kemungkinan relay tu yg problem..
relay tu duk kt handle(kt tengkuk lampu dpn tu)..org pgil namanya flash relay... | |
| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Fri Mar 04, 2011 7:55 pm | |
| signal depan blakang x nyale. hon bunyi bese je..kuat cmtu a..x lemah gemalai pun. relay tu duk kat tgkuk lampu depan eh?aku x knal relay ni.. kat mane eh?yg sangkut kt handle bar tu la kan?kan2? aku ingatkan klu relay prob ye nyale jgk tp x kelip je..hehe..slh la tekaan aku ni eh. relay ni mahal x? | |
| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Fri Mar 04, 2011 8:11 pm | |
| harganya xtau..sbb aku xpernah beli... yup..relay tu duk kt tengkuk lampu dpn.. | |
| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Fri Mar 04, 2011 8:26 pm | |
| tengkuk lampu depan??aku konfius la...kat tengkuk lampu depan?kat mane tu.. sal aku jumpe satu bende elektronik ni..duduk tersangkut kat handle bar..bwh sket dr meter | |
| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Sun Mar 06, 2011 8:00 pm | |
| btl la tue,name die flasher @ relay,mende tue yg buat signal kelip2x umpama kunang2x tue.. | |
najmimecha Laskar Kanan
Posts : 331 Join date : 24/01/2011 Location : BandarTasikSelatan
| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Mon Mar 07, 2011 7:11 pm | |
| yg mn pling baik...bateri sel basah or bateri sel kering? utk tupai ni.. | |
| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Mon Mar 07, 2011 11:53 pm | |
| sel kering baik,free maintenance..harge pun maintain skit la,pakai sel basah ok je,air kene selalu cek,cuci2x terminal die sekali-sekala,blh la nk pakai smpi sethn n lebih2x lagi.. | |
| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Tue Mar 08, 2011 12:08 am | |
| - najmimecha wrote:
- yg mn pling baik...bateri sel basah or bateri sel kering? utk tupai ni..
jwpn ni ade pada sikap owner... kalu owner jenis malas nak maintanance selalu baik beli BATERI SEL KERING(FREE MAINTANANCE xperlu topup air bateri)....harga lagi mahal dari bateri sel basah..mahal sikit je kot..tah aku xtau sbb xpernah beli.. tapi kalu owner jenis rajin sikit..sikit je tau...jenis suka diy baik beli bateri SEL BASAH..PERLU topup air bateri kalu air dh kurang... nak kata bateri sel basah ni kena selalu maintanence x jugak..kdg2 dlm 2 bulan tu baru air kurang..tu pun sikit je kurang nye.. nak kata tahan tu antara 2 jenis bateri ni depand pada owner gak... kalu owner jenis xjaga wayering motor.. kalu rosak part2 elektrik dia just biarkan melarat lama2 effect kt jangka hayat bateri gak...xkirala sel basah @ sel kering.. pendapat aku kalu tanya jangka hayat bateri ni aku pilih sel basah untuk jangka hayat yg lg lama... ape2pn bateri apepun anda paki..jangan guna smpi kong pun buat derkkkk je..cpt2 la tukar.. sbb dari rosak bateri leh sbbkan cdi lame2 kong..mentol xnyala..wayering jd short...moto xle start..ekeke | |
faaizil Laskar Kanan
Posts : 258 Join date : 10/10/2010 Age : 36 Location : kl
| Subject: Hal Berkaitan Wiring Untuk Lampu, Sistem Api & Lain2x.. Tue Mar 22, 2011 7:34 pm | |
| err mtor aku dua2 tu xberfungsi...apa yg rosak eh...blh D.I.Y tak...saper2 yg reti tlg ajor...da lama rosak tp br smp seru nk repair...wakakaka | |
| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Tue Mar 22, 2011 7:38 pm | |
| ada org ckp mentol kt meter tu terbakar,,,tah btl ker x...tp rasanyer kabel kot yg shock... | |
Kato_125 Bintara Kanan
Posts : 682 Join date : 28/09/2010 Age : 33 Location : kUaNtaN mEnJeRiT
| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Tue Mar 22, 2011 7:47 pm | |
| mentol yg t'bakar 2...kne tuka baru~ aku da penah kne... | |
| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Tue Mar 22, 2011 7:49 pm | |
| dlm tu ada mentol eh...hahaha xtau lak aku...erm cmane lak kalu suiz hi beam tp sbnrnyer lmpu rndh then sbaliknyer...er yg tu lak nk wt cmaner.. | |
| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Tue Mar 22, 2011 8:43 pm | |
| perlu ke bk topik ni?ermmm...lampu tinggi rendh terbalik besenyer mentol lokel mcm tu...mentol beam boleh tukar..semua mentol dlm meter tu boleh tukr | |
| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Tue Mar 22, 2011 8:50 pm | |
- perlu ke bk topik ni?ermmm...lampu tinggi rendh terbalik besenyer mentol lokel mcm tu...mentol beam boleh tukar..semua mentol dlm meter tu boleh tukr
ok mod...topic bulih lock~ LarikKkKk.... | |
| Subject: Re: Perbincangan Wiring Untuk Lampu, Sistem Api, Bateri & Lain2x Tue Mar 22, 2011 9:09 pm | |
