 Segala Persoalan V13
Go to page : Previous  1 ... 9 ... 14, 15, 16
PostSubject: Re: Segala Persoalan V13   Mon Apr 04, 2011 9:30 pm
ape beza spring clucth yg aku beli kat ats ngan yg kat bwh nie..?
yg ni ade 6 spring..cam ne beza dari segi performance? ade lg mantap ka?\
PostSubject: Re: Segala Persoalan V13   Mon Apr 04, 2011 10:30 pm
spring nie 2 jer beza dia tak kira la brand apa ko pki...
spring ori = lembut (tarik lever clucth pun smooth)
spring racing = keras (tarik lever clucth rasa ketat)
respon cepat/pantas bila pki spring racing ??? dengan kadar perkiraan microsecond
antara spring ori vs spring racing ak kata sama jer x sempat pun nak rasa bezanya...
beza paling ketara time tarik lever clucth tuh jer mmg jauh beza.... What a Face
askrun
PostSubject: Re: Segala Persoalan V13   Tue Apr 05, 2011 12:56 am
salam
nak tanya sikit
kenapa motor aku
gear 6 mati pada 120kmh je
gear 1 sampai 5 memang smooth macam nak terbang pun ada
bila time top macam angin tak cukup pun ada gak
spec moto
karburetor rxz
block racing dah porting lubang angin,minyak dengan ekzos
head adjust untuk piston
ekzos standard
reedvalve boyesen
primary gear 21T
spocket 35/15 420
bearing engin c3
kotak angin tebuk
tolong kawan2 tengah pening ni
PostSubject: Re: Segala Persoalan V13   Tue Apr 05, 2011 1:04 am
askrun wrote:
salam
nak tanya sikit
kenapa motor aku
spec moto
karburetor rxz
ekzos standard
reedvalve boyesen
primary gear 21T
spocket 35/15 420
bearing engin c3
kotak angin tebuk
waaa mantap btol mto ko, maybe setting carb x ngam kot..
PostSubject: Re: Segala Persoalan V13   Tue Apr 05, 2011 9:01 am
incik tanyalari patik pun penah merasa situasi tuan ambe dulo2x tp tue
sbb patik pki ejos pipe open..gear 1-5 mmg sedap tp masuk jer gear6
trus drop rpm...kelajuan max pun 120km/j saje....
kes patik tue berkaitan masalah ratio gear(gear6 standed xleh blah) so
patik tukar pki rxz punye...setting carb patik da cun cuma tue jerlah masalah
patik masuk gear6 mmg hampeh.....
tp incik tanyalari pki ejos stended kan so patut da tiptop tuh....
maybe angin & minyak dah lari.....
120km/h je?...biar btul..120m/h kot..bro salah tgk meter tu.. What a Face
askrun
PostSubject: Re: Segala Persoalan V13   Tue Apr 05, 2011 9:03 am
ye ke...
so apa yang patut saya buat
Smile
askrun
PostSubject: Re: Segala Persoalan V13   Tue Apr 05, 2011 9:04 am
betul x tipu pun
mmg 120 je
PostSubject: Re: Segala Persoalan V13   Tue Apr 05, 2011 9:05 am
tak penah kne mmg ler ckp itu ini kan....tp mmg betul gear 5 leh menten
170km/j....shift jer gear 6 dr 170km/j tuh trus drop ke 120km/j....
pulas ler camne xmo blah da...da cam bwk ex5 jer rasa What a Face
askrun
PostSubject: Re: Segala Persoalan V13   Tue Apr 05, 2011 9:07 am
tahu x pe betul kata ko mazakim, so apa yang patut aku lakukan...?
che cite skit
Smile
PostSubject: Re: Segala Persoalan V13   Tue Apr 05, 2011 9:10 am
yang ni spring untuk modenas kriss lar...
PostSubject: Re: Segala Persoalan V13   Tue Apr 05, 2011 9:14 am
mmg lar.. tp kedai ni time aku mintak yg 125z punye, dia bwk kuar yg ni gak.. dia ckp yg baikkk punya mcm nie..dia ade yg ni je..aku pi kedai len,dia bwk kuar mcm yg aku tunjuk yg sebelum ni RM15 je.. yg ni utk satu set kot..beli mangkuk clucth faito nye gak yg leh pkai 6spring..
PostSubject: Re: Segala Persoalan V13   Tue Apr 05, 2011 9:17 am
askrun...gear 6 ko tuh rs camne ??? cer citer skit..contoh bila ko menten
gear 5 leh dpt 160km/j bila shift jer gear 6 trus drop spi 120km/j...contoh
jer ler so cer citer skit.....
*p/s: ak x sure lar solution terbaik apapun try set carb dulu,klu masih jadi
gak tue dia mintak gear 6 alejek la tuh clown
askrun
PostSubject: Re: Segala Persoalan V13   Tue Apr 05, 2011 9:21 am
macam ko cakap gear 5 sampai 150-160km/j cm 2 pastu aku shift gear 6 terus drop
aku rasa ni mesti berkenaan dengan setting carburetor sebab dlu x pernah jadi macam ni, lepas aku porting block pulak jadi cm ni...
so apa jetting yang sesuai untuk carburetor aku
skrng pakai jarum standard rxz tapi dah asah skit, mainjet 210 tapi dah korek, pilot 22.5 ???
PostSubject: Re: Segala Persoalan V13   Tue Apr 05, 2011 9:22 am
cuba pkai jarum standard je..
askrun
PostSubject: Re: Segala Persoalan V13   Tue Apr 05, 2011 9:24 am
dah pakai der, memang x dpt setting susah gila nak ngam
PostSubject: Re: Segala Persoalan V13   Tue Apr 05, 2011 10:14 am
klau setting dh cun.. plug cun.. set balik ratio spoket... skrg pkai saiz ape..?
PostSubject: Re: Segala Persoalan V13   Tue Apr 05, 2011 11:09 am
prob askrun nie xda sangkut ngan ratio sprocket tp lebih pada setting
carb dia sbb gear 6 jer rpm drop....
ak cadang ko set carb dulu n klu boleh pki jarum panther...jarum alejet
mmg susah dpt setting yg cantik...ada jer prob dia...
*p/s : pki carb 125z pun ok der leh jer cecah top....
PostSubject: Re: Segala Persoalan V13   Tue Apr 05, 2011 12:48 pm
salam...ambe rs la...lubang ejos blok anda tu overport...solution dia,kne upkn spoket la...xpon cr blok len
askrun
PostSubject: Re: Segala Persoalan V13   Tue Apr 05, 2011 1:13 pm
mazakim-jarum panther eh...?aku takut pulak kalau nak pakai jarum panther nnti minyak cm parah je
Yi:-tak gak yi, lubang ekzos x ada overport sgt, sbb klu porting dia besar, bunyi dia yang kuar dkt ekzos mesti kasar dgn garang bak kata ultra
Smile
Page 16 of 16Go to page : Previous  1 ... 9 ... 14, 15, 16
