 Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4
Go to page : Previous  1 ... 5, 6, 7 ... 11 ... 17  Next
Azrul
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Thu Apr 28, 2011 12:17 am
aku nk tanye skit..dgn spec moto aku ni..blok da port lubang angin,minyak n lubang ekzos..piston 0.25..carb panther..tp problem nye past aku try top time 150kmh dye mcm semput2 la..mcm ada yg x lps jew..apa sbb ek?kna set main jet n pilot blek ke ?
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Thu Apr 28, 2011 8:15 am
semput sedut2x ke blkg?,klu camtue mnyk krg,kene setting mainjet n pilotjet..
Azrul
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Thu Apr 28, 2011 3:56 pm
main jet 220,pilot 30..main jet n pilot elok set bpe ek ?..takot la jem jew nnti..
Man4822
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Thu Apr 28, 2011 6:56 pm
nak tanye sikit, area kl ni, kat mana lagi ada kedai foundry selain area sentul??
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Fri Apr 29, 2011 12:33 am
tue aku tanye simpton semput tue cmner?,bobok ke?,rase moto sedut ke?,try tarik gear ke gear ngan max rpm,tgk ape jd..
Azrul
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Fri Apr 29, 2011 4:55 pm
aku tarik gear ke gear ok jew..bobok mmg x de..aku rse mcm moto sedut2 la time top 2..npe ek ?
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Sat Apr 30, 2011 1:38 pm
tarik max rpm dari gear ke gear?,klu sedut2x atau tarik2x ke blkg tue mnyk kurang,tgk plug warne ape..
Azrul
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Sat Apr 30, 2011 2:18 pm
npe bila aku buka head,kt permukaan head 2 da kesan terkopak-kopak la ?pe ssb ek..
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Sat Apr 30, 2011 6:48 pm
upload pic tgk..
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Mon May 02, 2011 11:33 pm
wahaahha da lame x bersuara share skit...aku 180MJ,PJ 27.5.....
boleh la ckup2 makan.,...nak jalan jauh pun ok...2 jam maintain..tapi kene bancuh la..Razz
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Mon May 02, 2011 11:39 pm
karb ape tu adzli?pah mane mg hlg?
faristrx
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Sat May 07, 2011 5:40 pm
nape ek moto aku bunyi terhantuk cmtue masa dari laju nk ke perlahankn moto???
Mafiaflix
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Sun May 08, 2011 8:16 pm
bro bro semua, aku nak tanya...
kalau kat sana motor 125Z standard gaban dapat max RPM berape?
aku pakai 125Z first model, sudah porting blok piston size standard dg carb RXK 26 mm gunakan ekzos AHM SPR RPM boleh outmeter.
http://www.facebook.com/dzakiwardana
Azrul
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Tue May 10, 2011 1:38 am
aku nk kongsi skit spec moto aku ni..
-blok da port
-piston 0.75
-head da potong
-carb 125z jew
untuk sementara ni aku pkai MAIN JET 140,tapi bobok gk la bwh rpm 5K..agk2 mainjet 140 ok x ngan spec moto akuw ?..
Mafiaflix
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Tue May 10, 2011 1:44 am
-blok da port
-piston 0.75
-head da potong
-carb 125z jew
ko cek busi dulu bro...
tengok kat tengah electroda busi tu.
kalau hitam berarti kebesaran MJ kau, tp kalau putih terlalu kecik... yg pas warna coklat / merah bata.
Mafiaflix
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Tue May 10, 2011 1:57 am
Ini foto blok aku...
exhaust port height 28 mm, width 35 mm, inlet height standard.
clearance piston at top dead center 0 mm.
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Tue May 10, 2011 8:24 am
waduh blok nya.Twisted Evil ..mcmana mau bikin 0mm clearance at top dead center tu Mafiaflix.?
kenapa tidak di skimmed saja headnya?..ini kalau d pake head yg suda d skim mmg kuat compression nya.. x gitu mafiaflix?
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Tue May 10, 2011 9:37 am
lubg ejos amat menakutkan...mgkin sesuai ngn saiz pistonnyer kot?hehehe..xterantuk ke piston ngn head kalo dh rapat cgt?mesti bunyi xmnyenagkn akn kluar nt...ngeh3
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Tue May 10, 2011 9:39 am
wasalam..ape yg outmeter?rpm ke?ada motor forumer boleh dpt rpm outmeter blok saiz stendard,karb stendard dh lay,ekzos stendard Very Happy
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Tue May 10, 2011 10:10 am
outmeter time idle ka..atau time top? Cool
Mafiaflix
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Tue May 10, 2011 2:32 pm
ye bro, bawah blok kena skim lagi kemaren pomen kurangi blok bawah tu 0.8 mm, tepi piston pun di sesuaikan 0.8 mm juga.
head pun sudah kena skim 2 mm.
compression jadi kuat bro, karena aku buat kejar exhaust port yg sudah naik banyak.
Mafiaflix
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Tue May 10, 2011 2:36 pm
tidak bro, masih aman la...
itu kan masih ada gasket cylinder head tebal 0.5 mm jadi masih aman.
ini hasil dynotest motor aku.
top speed gear 6th sproket size 14-42
Mafiaflix
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Tue May 10, 2011 2:38 pm
idle RPM bisa outmeter, time top speed gear 6th bisa outmeter juga RPM ku bro.
tapi aku gunakan sproket ringan 14-42.
piston size standard 125Z.
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Tue May 10, 2011 4:00 pm
laju banget 125z kamu..
bila di skim bawah blok..lubang intake dan exhaust pun harus d porting ke atas kan?
kalau skim bawah 0.8mm..tambah skim head 2mm total 2.8mm..sma ngak kalau headnya saja d skim 2.8mm terus?.
Mafiaflix
PostSubject: Re: Korek, Potong, Rebore, Port, Polish Blok & Potong Head V4   Tue May 10, 2011 4:51 pm
belum laju itu bro, motor drag 125 cc kat sini rata rata dapat 35 HP,
ye betol bro... karena semua port akan turun, ini pun blok aku salah pengerjaan bro, seharusnya tidak perlu potong blok bawah dan piston, cukup skim head je... misalkan mau buat deck clearence 0 maka cukup potong/skim blok atas je.
sama bro karena totalnya kan 2.8 mm, namun kalau potong headnya saja porting porting tidak akan turun.
CMIIW.
Page 6 of 17Go to page : Previous  1 ... 5, 6, 7 ... 11 ... 17  Next
