 Cover Engine Pecah
Go to page : 1, 2  Next
payjalrazali
PostSubject: Cover Engine Pecah   Mon Jan 17, 2011 1:03 pm
hari tu aku dah post topic ni.. tapi xtau kemana topic tu hilang..
aku nk tnye kt spe2 yg tau.
cover engine aku belah nombor engine telah pecah.
cover tu da welding.tp tak rata.. kene letak gam tebal. kalau x minyak hitam licking turun dr antara block dan engine.
motor blh jalan jaoh x? blh buat ubah suai ke atas saiz block?? blh ubah suai coil api dan guna cdi racing??
atau pon ade cara lain?? **selain cari cover engine dan ketok nombor baru
PostSubject: Re: Cover Engine Pecah   Mon Jan 17, 2011 8:11 pm
bro.. yang pecah@crack tu belah mana? cover ke crankcase
PostSubject: Re: Cover Engine Pecah   Mon Jan 17, 2011 8:43 pm
aku rasa, yg pecah ni crankcase yg ada nombor siri enjin..
payjalrazali
PostSubject: Re: Cover Engine Pecah   Tue Jan 18, 2011 9:42 pm
aku xtau ape nme dye.
nnti aku amik gmbar.
tp, crack tu kat di antara block dgn engine.
PostSubject: Re: Cover Engine Pecah   Wed Jan 19, 2011 1:55 am
bro setelkan dl prob yg ada seblom nak tambah prob baru..camner bleh pecah tu?
PostSubject: Re: Cover Engine Pecah   Wed Jan 19, 2011 2:25 am
pegi HLY tempah casing baru.
maybe arge dekat riban, tp satu kali pening kepala je dh settle.
tampal-bocor 14kali leh wat nyampah rase nk jual 125z je kot..
apepn usha gambau dlu br leh kompom bleh bikin ke tk kerosakan casing tu.
k..
PostSubject: Re: Cover Engine Pecah   Wed Jan 19, 2011 5:49 pm
cuba tanya chocolate.. dier ade pengalaman tu.. better order direct dari HLY.. nombor kosong.. atau mintak terus 1set.. tapi nak gi register memang masak la.. setahu aku crankcase kosong tu dalam
PostSubject: Re: Cover Engine Pecah   Wed Jan 19, 2011 6:06 pm
member ambe penah welding...tp yg sebelah lua jela..yg sebelah dalam kalo pecah xtau la....member punyer pecah kt bahagian bwh enjin.dia welding ..alhmdllh xleaking...tp kne cr kedai yg btol2 speselist r...tu kalo nk jimat la...kalo agk2 ada duit lebih,baik beli yg baru je...pastu register..
payjalrazali
PostSubject: Re: Cover Engine Pecah   Wed Jan 19, 2011 8:15 pm
xde la.. kalu pg hong leong.byk citer la plak.. benda ni da 6bulan lepas jd.. mse tu aku xde pengalaman beli motor. so, aku beli motor 2nd.xperasan bnde tu.. bwak membe pon dye xperasan.
lepas 2bulan pakai. engine aku jem.aku anta pg overoil.. da 4bulan aku pakai ok.xde licking..cume xtau blh blik kg ke x. paling jaoh aku pg melaka dan port dickson.alhamdullillah xde pape.. cume kalu nk msok block racing blh ke x
PostSubject: Re: Cover Engine Pecah   Wed Jan 19, 2011 11:20 pm
lor,kl tgh problem tu jgn le disumbat lg brg2 resing,bwk bertendang..
jauh mana nak travel tu?kl bwk pelan2 ok jer kot..tp atas tuan tanah gak le,berani ke tidak..sbb kl jadi apa2 tuan tanah yg tanggung,tukang bg nasihat ni mampu dgr jer hu2
PostSubject: Re: Cover Engine Pecah   Wed Jan 19, 2011 11:33 pm
tah.. kalau tukang bagi nasihat tu tulung repair kan bagus.. eh.. bukan ke tukang bagi nasihat ni ade sebijik lagi crancase kat bawah katil.. ape lagi.. hehehe
PostSubject: Re: Cover Engine Pecah   Wed Jan 19, 2011 11:38 pm
agagagaga itu crank nak masuk projek baeekkkk punya..tp poket mmg baaaekkkkkk punya kering adui..
PostSubject: Re: Cover Engine Pecah   Thu Jan 20, 2011 1:34 am
pergh..
modi crankcase = tahap muto mlm minggu.
payjalrazali
PostSubject: Re: Cover Engine Pecah   Thu Jan 20, 2011 8:44 am
oh.. yeke? dgr citer tukang bg nasihat ni pernah mengalami bnde yg sama. cmne tukang bg nasihat atasi masalah ini??nk balik terengganu
PostSubject: Re: Cover Engine Pecah   Thu Jan 20, 2011 9:01 am
org ganu ke ni?bila nk balik tganu?erk...spam ckt
PostSubject: Re: Cover Engine Pecah   Thu Jan 20, 2011 12:22 pm
tukang bagi nasihat nih amik alternatif utk option "citer banyak ngan hong leong"..sbb xnak citer pendek ngan brg panas,dan xnak problem dtg berturut2 nnt
pi hong leong cakap nak beli crankcase baru kiri knn,pi balai polis buat report nak tukar crankcase belah ada no,nnt crank lama kene serahkan kat hly..dgr citer kene buat camni ler,aku buat cara lain,kunun nak jimat masa,last2 2-3 bulan gak kene,padan muka aku
hoh,balik skali ngan yi,yi ada bwk kot crank spare agagagaga
PostSubject: Re: Cover Engine Pecah   Thu Jan 20, 2011 12:47 pm
ni yg tuan tanah mtk pndgan..yg ambe lamputinggikn tu...mgkin tt dh tau care beli c.case baru,cuma mtk pndgn kot2 ada alternatif lain yg lebih compatible..
erk ambe xdop crank spare,stakat skru spare dua tiga butir tu ada la...tu pon cicir sokmo...ngeh3
PostSubject: Re: Cover Engine Pecah   Thu Jan 20, 2011 1:03 pm
sng snap pic tgk cmner,klu nk tampal kt bhgn enjin bwh ok la,cari kedai yg blh tampal blk bhgn pecah tue,bbdk pggl tampal daging baru,tpi kene cari kedai yg blh bt ngan btl2x cun la..
payjalrazali
PostSubject: Re: Cover Engine Pecah   Wed Jan 26, 2011 3:34 am
raya cina kot. tatau lg.ade buat kenduri.meh ar nk ikot. tp xkompem lg. tatau nk pg cameron atau blek tganu. yi tganu kt ne?
payjalrazali
PostSubject: Re: Cover Engine Pecah   Wed Jan 26, 2011 3:35 am
kat mana ade buat??
izuan
PostSubject: Re: Cover Engine Pecah   Fri Feb 25, 2011 10:00 pm
yg aku punye pecah jgk ni......binggung rasenye.....mule2 crankshaft patah,bile buke crankcase plk crack...mmg malang nasib,dh la tayar pancit mase nk g jupe ultra-z tu....pendek crite harge crankcase brape ek klu yg baru?
payjalrazali
PostSubject: Re: Cover Engine Pecah   Wed Mar 02, 2011 5:50 pm
tak tahu la aku.. ko punya pecah belah ade nombor ke?
Raptor 660
PostSubject: Re: Cover Engine Pecah   Thu Jun 23, 2011 10:28 pm
aloo geng;salam perkenalan
moto aku pun ada masalah yg sama, enjin crack belah nombor,aku bawa pergi IPoh (foundry),welding kena rm150.moto sekarang dh tk bes mcm dulu.nak citer camner yer tapi tak sedap la.cuba2 gak pergi tanya kat kdai baper kos nak tukar enjin..hampir 2ribu jugak la.jadi aku rasa mana yang jd cam aku ni, baik jual jela tak pun trade in je.tapi jgn la jual kat member2 sian plak nanti.jual kat kdai la.
PostSubject: Re: Cover Engine Pecah   Thu Jun 23, 2011 11:03 pm
crankcase baru(kosong xde no enjin) dekat 7 rat jgak...x campur lg dgn wat no enjin.aku beli taun lepas tu pon suh pomen belikan..korg bajet dlm 1 ribu pon dh ok,cr bengkel yg bole dipercayai..yg korg selesa....
rensu
PostSubject: engine saya retak sebelah sireal number.   Sat Jul 23, 2011 7:54 pm
hi engine saya dah retak sebelah seriel number.fomen suruh saya jual motor itu dan saya tak nak jual.itu motor pertama saya.baru beli second hand.apa yang perlu saya buat.tolong sifu?
Cover Engine Pecah
Page 1 of 2Go to page : 1, 2  Next
