 Segala Persoalan V10
Go to page : Previous  1 ... 8 ... 13, 14, 15, 16  Next
PostSubject: Re: Segala Persoalan V10   Wed Dec 22, 2010 12:16 pm
babet wrote:
try bkk tgk..piston dah calar kot..kl lekuk rasanya trus jer mati membawa kpd tembus,xde tarik2 tyr blkg..ko ada porting ke apa?
xde porting pape lg...
1st kena lepas pkai blok 0.5 ni...
ok thnx...nt ak bukak cek...
kena up mainjet ke kalaw xnk kena bnda ni?
bukak dlu tgk kondisi piston, silinder blok n sbgainye.
mcm2 bleh brlaku..
- piston + blok calar, mungkin kurang minyak/kurang 2t/enjin tk ckup pns/piston clip tcabut/pin tcabut/bearing pecah<---rebore, set carb
- piston lekuk, minyak kurang/kompression head tinggi sgt<---tuka piston set, adjust head, set carb
cek kaler plug, dr ctu leh tau mainjet kne adjust ke camne2..
ntah2 blok n piston bcalar ko main PnP je blok 0.5 tk setting blk carb kot..?? tongue
hehehehe...
wokehh...thnx ultra...
ak ingt kalaw rebore je xperlu set carb...
angin dh set dh...cume xpnah tkr mainjet n pjet...
papepown thnx...nt ak cek sume2 tu
PostSubject: Re: Segala Persoalan V10   Wed Dec 22, 2010 4:27 pm
geeks wrote:
wormzx & babet.. cube tengok celah antare blok dengan head.. ade leaking tak?..
xder per pon...ak ingt mmg dh block, g 2tmpat sume ckp blok...ptg marin g tnye pomen suh potong head@blok?? rebore? ak pn fening ngn istilah ni...
PostSubject: Re: Segala Persoalan V10   Thu Dec 23, 2010 12:57 pm
rasenyer tak perlu nak potong head.. rebore tuh kalau calar kat blok tuh betul2 dalam.. ke sebab rantai jugak macam kes babet kat atas nih..
PostSubject: Re: Segala Persoalan V10   Thu Dec 23, 2010 1:25 pm
rantai xder per2 pon, just ader bunyi sket time ride..or time muto panas..tu jer laa...bunyi kt blok@head...ingt nk atar p kdai jer, wat siap2 tgu n tgk jer...1st time jd camni, muto bli awal thun ni...
PostSubject: Re: Segala Persoalan V10   Thu Dec 23, 2010 2:35 pm
kalau time perah minyak ade bunyi tak?..cube tengok kepale plug.. kemas tak pasang kat plug tuh..
PostSubject: Re: Segala Persoalan V10   Thu Dec 23, 2010 4:45 pm
pulas myak pon bunyi gak..xpnah sentuh pon plug tu, dari mule2 bli dulu...hehehe...xper nti ak check blik..thanx geeks
PostSubject: Re: Segala Persoalan V10   Thu Dec 23, 2010 10:47 pm
buat top overhaul je n tgk kondisi blok,klu calar ke ape,baru la rebore,klu ok tp ade skit2x bunyi ring n blok + piston,biase la tue,buat x reti je,pakai selagi x memudaratkan performance moto..
PostSubject: Re: Segala Persoalan V10   Fri Dec 24, 2010 1:59 am
salam nk spam jugak, nk tanye ni, ribet clutch ni bleh buat banyak kali ker, aku risau macm kot2 terpecah mangkuk clutch tu
PostSubject: Re: Segala Persoalan V10   Fri Dec 24, 2010 10:25 am
joe.. tulah.. pakai selagi boleh.. dah dalam sangat calar blok tuh baru la gi rebore balik.. ekeke.. projek baru bile joe?..
nurkaye_akmal.. rivet clutch kalau clutch tuh dah bunyik kuat sangat.. itu jer.. mangkuk clutch aku dulu retak jer.. so just tukar mangkuk clutch jer lah..
PostSubject: Re: Segala Persoalan V10   Fri Dec 24, 2010 12:19 pm
bro geeks-munyik tu tak kuat, cme rase mcm tk syiok je hehe, tpi ble dah jalan tak dgr dah pon
PostSubject: Re: Segala Persoalan V10   Fri Dec 24, 2010 2:37 pm
urmmm...kalu g2 ak try wat top jer dulu...bese rm brape ek? last2 ader yg suh ak rujuk thread overhaul..hahaha, sini2 jer..nk taw rege jep Razz
PostSubject: Re: Segala Persoalan V10   Fri Dec 24, 2010 2:48 pm
ak bwt hr tu rm45 tukr set gasket n plug je.servis head blok carb n piston...yg lain xde tukar2....
PostSubject: Re: Segala Persoalan V10   Fri Dec 24, 2010 3:33 pm
nk mencelah sekejap sume2, ade dua soalan utama ni
taktawla jadi kat aku je ke ni
1. ble nk masuk top speed je mesti dgr bunyi dengung, knape ek, takot gak dengar nyer
2. hari tu baru servis carb, tapi lpas tu motor jadi mcm lambat skit la, tp perfomance mcm sedap lagi
pliss help me sahabat2 sekalian
PostSubject: Re: Segala Persoalan V10   Fri Dec 24, 2010 6:44 pm
nurkaye - aku punyer motor pun ade bunyik clutch.. bile tarik clutch.. senyap.. pade aku kalau masuk gear tak meleret.. ok lagi.. tapi pade pendapat aku.. kalau dah alang-alang rivet, bek tukar sekali clutch plate tuh..
dengung macam mane ek?.. kalau ade motor 125z sebelah mungkin berdengung kut.. ekekeke..
wormzx - kalau top overhaul.. gasket top satu set baru rm3.. plug baru brape ringgit.. kalau buat sendiri get ready dengan batang stud spare..
babet - 45?.. pakai plug ape?
PostSubject: Re: Segala Persoalan V10   Fri Dec 24, 2010 7:11 pm
geeks:plug biasa b8es je....
kt area ak mmg upah stended lingkungan cmtu...
kalaw pndai wat sndiri mmg byk leh save...
PostSubject: Re: Segala Persoalan V10   Fri Dec 24, 2010 7:25 pm
bunyi dengung dye dkt enjin la, mcm bunyi besi berdengung gitu
PostSubject: Re: Segala Persoalan V10   Sat Dec 25, 2010 12:18 am
harge kedai wat top overhaul memang macam tuh ke?.. leh tahan gak mahal.. 45 bukan sekali dengan servis carb?..
nurkaye - mase tengah jalan jer bunyi enjin berdengung?.. kalau idling?..
PostSubject: Re: Segala Persoalan V10   Sat Dec 25, 2010 1:46 am
mase tgh nak top speed jer, dlm around 150-160 ker, ble idle tkde bunyi ape2, bunyi senyap jer..
PostSubject: Re: Segala Persoalan V10   Sat Dec 25, 2010 5:09 am
yup geeks....skali servis carb....lupe nk mention sblm ni....
archonixm
PostSubject: Re: Segala Persoalan V10   Sat Dec 25, 2010 3:32 pm
brake sangkot , camne nk btulkan ha? mcm pad tu kene kat disc, lagi2 lepas hard braking, dia mcm x nk lepas gigit, ada sket lg kene, mcmana?
ada sapa bole bg suggestion?
PostSubject: Re: Segala Persoalan V10   Sun Dec 26, 2010 7:16 pm
aku prnh kne cm ko dlu..
brake pump da xmen tu.
try lggarkn skit nat kt blkg,
gne spanar 10, pstu ko men brake.
ulang blk smpai elok.
law mlekat lg, antr kdai je.
srh pomen servis pump brake.
law dia srh tkr pump, ko libas pale dia.
hehe.pemalas pnye pomen.
otai2 tlg tmbh..
aku pon nk tnye ni..
sp taw kdai ketuk sportrim area s.alam/pj murah2?
ngokngek tul, lggar lobang pnye psl la.
cm nek kuda pulak rsenye.. geek
PostSubject: Re: Segala Persoalan V10   Sun Dec 26, 2010 10:13 pm
lggr lbg time blk td,mmg terbaik la,hbs enkei y-teq aku tue,spoil..
PostSubject: Re: Segala Persoalan V10   Sun Dec 26, 2010 10:19 pm
PostSubject: Re: Segala Persoalan V10   Mon Dec 27, 2010 2:55 am
hahaha... tu la aq nk bli x ksik... ahaks...
PostSubject: Re: Segala Persoalan V10   Mon Dec 27, 2010 6:47 am
dgr2 kota damansara ade kedai leh wat ketuk/align rim keta.
rim moto tatau la..
area umah aku tu.. tp aku haram tatau ktne.
hahahaha..
nnt try tnye blk incik yap s.alam atau carlz renyuk dan goncang.
Page 14 of 16Go to page : Previous  1 ... 8 ... 13, 14, 15, 16  Next
